[U-Boot] [PATCH 1/1] arm: spl: Fix SPL falcon mode boot on MMC with ext partition
If the kernel is on an ext partition, we cannot load it because spl_boot_mode() return MMCSD_MODE_RAW instead of MMCSD_MODE_FS.
Signed-off-by: Fabien Lahoudere fabien.lahoudere@collabora.co.uk --- arch/arm/mach-imx/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index a20b30d154..4da028a6e7 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -162,7 +162,7 @@ u32 spl_boot_mode(const u32 boot_device) /* for MMC return either RAW or FAT mode */ case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2: -#if defined(CONFIG_SPL_FAT_SUPPORT) +#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT;
Fabien Lahoudere
