[U-Boot] [PATCH] Powerpc/DIU: Fixed the 800x600 and 1024x768 resolution bug
When the resolution is set to 800x600 and 1024x768, but, the driver will use 1280x1024 resolution to set the DIU register
Signed-off-by: Jerry Huang Chang-Ming.Huang@freescale.com --- drivers/video/fsl_diu_fb.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/drivers/video/fsl_diu_fb.c b/drivers/video/fsl_diu_fb.c index e1d6c26..7cb8cb6 100644 --- a/drivers/video/fsl_diu_fb.c +++ b/drivers/video/fsl_diu_fb.c @@ -296,8 +296,10 @@ int fsl_diu_init(u16 xres, u16 yres, u32 pixel_format, int gamma_fix) break; case RESOLUTION(800, 600): fsl_diu_mode_db = &fsl_diu_mode_800_600; + break; case RESOLUTION(1024, 768): fsl_diu_mode_db = &fsl_diu_mode_1024_768; + break; case RESOLUTION(1280, 1024): fsl_diu_mode_db = &fsl_diu_mode_1280_1024; break;
Acked-by: Timur Tabi timur@freescale.com
Thanks, Jerry. I'm amazed that I didn't notice this mistake earlier.
Applied to u-boot-video/master, thanks!
Anatolij
Anatolij Gustschin
Tabi Timur-B04825
