[U-Boot] [PATCH v2] ARM: AM437x: Sync defconfig between GP and HS EVM
Adds missing NAND option to CONFIG_SYS_EXTRA_OPTIONS for AM437x HS EVMs. This syncs up the config options between GP and HS EVMs.
Signed-off-by: Madan Srinivas madans@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com --- Changes in v2: Rebased patch to apply without errors on u-boot master branch.
configs/am437x_hs_evm_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/am437x_hs_evm_defconfig b/configs/am437x_hs_evm_defconfig index b4f7c77..73e894a 100644 --- a/configs/am437x_hs_evm_defconfig +++ b/configs/am437x_hs_evm_defconfig @@ -10,7 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1, NAND" CONFIG_SPL_LOAD_FIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y
Adds FIT support to the SPL and u-boot for AM437x HS devices.
Signed-off-by: Madan Srinivas madans@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com --- Changes in v3: Rebased patch to apply without errors on u-boot master branch.
Changes in v2: Removes NAND that was incorrectly added in v1 to CONFIG_SYS_EXTRA_OPTIONS
configs/am437x_hs_evm_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/am437x_hs_evm_defconfig b/configs/am437x_hs_evm_defconfig index 95b28fb..b4f7c77 100644 --- a/configs/am437x_hs_evm_defconfig +++ b/configs/am437x_hs_evm_defconfig @@ -9,7 +9,9 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +CONFIG_SPL_LOAD_FIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -32,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am437x-gp-evm" CONFIG_DM=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y @@ -52,3 +55,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_SPL_OF_LIBFDT=y
Tested-by: Andreas Dannenberg dannenberg@ti.com
1.9.1
diff --git a/configs/am437x_hs_evm_defconfig b/configs/am437x_hs_evm_defconfig index b4f7c77..73e894a 100644 --- a/configs/am437x_hs_evm_defconfig +++ b/configs/am437x_hs_evm_defconfig @@ -10,7 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1, NAND" CONFIG_SPL_LOAD_FIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y -- 1.9.1
Andreas Dannenberg
Madan Srinivas
