[U-Boot] [PATCH v2 0/7] Various USB improvements
This series adds a few USB improvements for Marek:
- Support for interupt transfers - Faster start-up and proper shutdown of ASIX USB adapter - Basic 64-bit controller support (used by x86)
Changes in v2: - Use errno where possible - Use PCI_CLASS_SERIAL_USB_EHCI instead of the number - Update to use errno - Remove TODOs - Tidy code style a little - Squash timeouts patch into interrupt patch - Add blank line before function return
Michael Spang (1): usb: usbeth: smsc95xx: remove EEPROM loaded check
Patrick Georgi (1): usb: ehci: Support interrupt transfers via periodic list
Simon Glass (2): usb: net: asix: Do a fast init if link already established x86: Enable USB features for coreboot
Vincent Palatin (3): usb: ehci: generic PCI support usb: ehci: Fix aliasing issue in EHCI interrupt code usb: Add multiple controllers support for EHCI PCI
drivers/usb/eth/asix.c | 40 +++++- drivers/usb/eth/smsc95xx.c | 4 - drivers/usb/host/ehci-hcd.c | 315 ++++++++++++++++++++++++++++++++++++++++++- drivers/usb/host/ehci-pci.c | 61 ++++++++- drivers/usb/host/ehci.h | 6 +- include/configs/coreboot.h | 17 +++ include/usb_ether.h | 1 + 7 files changed, 420 insertions(+), 24 deletions(-)
The Asix driver takes the link down during init() and then brings it back up. This commit changes this so that if a link has already been established successfully we simply check that the link is still good.
Also fix up asix_halt() to actually halt RX on the interface. Previously this was not done, so the device would continue to operate evern when halted, violating a U-Boot requirement.
This reduces the delay between successive network commands. Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: None
drivers/usb/eth/asix.c | 40 ++++++++++++++++++++++++++++++++-------- include/usb_ether.h | 1 + 2 files changed, 33 insertions(+), 8 deletions(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index 75ec8f7..a991fea 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -84,6 +84,7 @@
#define AX_DEFAULT_RX_CTL \ (AX_RX_CTL_SO | AX_RX_CTL_AB) +#define AX_DISABLE_RX_CTL AX_RX_CTL_AB
/* GPIO 2 toggles */ #define AX_GPIO_GPO2EN 0x10 /* GPIO2 Output enable */ @@ -410,17 +411,16 @@ static int asix_basic_reset(struct ueth_data *dev) return 0; }
-/* - * Asix callbacks - */ -static int asix_init(struct eth_device *eth, bd_t *bd) +static int full_init(struct eth_device *eth) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; - int timeout = 0; -#define TIMEOUT_RESOLUTION 50 /* ms */ - int link_detected; + struct ueth_data *dev = (struct ueth_data *)eth->priv;
debug("** %s()\n", __func__); + if (asix_basic_reset(dev)) + goto out_err; + + if (asix_write_rx_ctl(dev, AX_DEFAULT_RX_CTL) < 0) + goto out_err;
dev->phy_id = asix_get_phy_addr(dev); if (dev->phy_id < 0) @@ -446,6 +446,25 @@ static int asix_init(struct eth_device *eth, bd_t *bd) debug("Write IPG,IPG1,IPG2 failed\n"); goto out_err; } + return 0; +out_err: + return -1; +} + +/* + * Asix callbacks + */ +static int asix_init(struct eth_device *eth, bd_t *bd) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + int timeout = 0; +#define TIMEOUT_RESOLUTION 50 /* ms */ + int link_detected; + + debug("** %s()\n", __func__); + + if (!dev->has_been_running && full_init(eth)) + return -1;
if (asix_write_rx_ctl(dev, AX_DEFAULT_RX_CTL) < 0) goto out_err; @@ -467,6 +486,7 @@ static int asix_init(struct eth_device *eth, bd_t *bd) printf("unable to connect.\n"); goto out_err; } + dev->has_been_running = 1;
return 0; out_err: @@ -571,7 +591,11 @@ static int asix_recv(struct eth_device *eth)
static void asix_halt(struct eth_device *eth) { + struct ueth_data *dev = (struct ueth_data *)eth->priv; + + /* Disable packet reception */ debug("** %s()\n", __func__); + (void)asix_write_rx_ctl(dev, AX_DISABLE_RX_CTL); }
/* diff --git a/include/usb_ether.h b/include/usb_ether.h index 7c7aecb..6145210 100644 --- a/include/usb_ether.h +++ b/include/usb_ether.h @@ -49,6 +49,7 @@ struct ueth_data { unsigned char subclass; /* as in overview */ unsigned char protocol; /* .............. */ unsigned char irqinterval; /* Intervall for IRQ Pipe */ + char has_been_running; /* PHY already inited */
/* driver private */ void *dev_priv;
Hi Simon,
Changes in v2: None
Hi Joe,
On Thu, Dec 20, 2012 at 6:29 PM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
Changes in v2: None
Are you going to pull this one in through net?
Hi Simon,
On Sun, Feb 17, 2013 at 12:47 AM, Simon Glass sjg@chromium.org wrote:
Hi Joe,
Hi Simon,
Changes in v2: None
Yes, I will pull it through net. Please make sure it's assigned to me in patchwork.
Thanks, -Joe
Hi Joe,
On Sun, Feb 17, 2013 at 1:39 PM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
Hi Joe,
Hi Simon,
Changes in v2: None
OK, done, thanks.
Thanks, -Joe
Instead of hardcoding the PCI IDs on the USB controller, use the PCI class to detect them.
Ensure the busmaster bit is properly set in the PCI configuration.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Use errno where possible - Use PCI_CLASS_SERIAL_USB_EHCI instead of the number
drivers/usb/host/ehci-pci.c | 41 ++++++++++++++++++++++++++++++++++++++++- 1 files changed, 40 insertions(+), 1 deletions(-)
diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index 29af02d..8064a32 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -19,6 +19,7 @@ */
#include <common.h> +#include <errno.h> #include <pci.h> #include <usb.h>
@@ -32,6 +33,35 @@ static struct pci_device_id ehci_pci_ids[] = { {0x12D8, 0x400F}, /* Pericom */ {0, 0} }; +#else +static pci_dev_t ehci_find_class(void) +{ + int bus; + int devnum; + pci_dev_t bdf; + uint32_t class; + + for (bus = 0; bus < pci_last_busno(); bus++) { + for (devnum = 0; devnum < PCI_MAX_PCI_DEVICES-1; devnum++) { + pci_read_config_dword(PCI_BDF(bus, devnum, 0), + PCI_CLASS_REVISION, &class); + if (class >> 16 == 0xffff) + continue; + + for (bdf = PCI_BDF(bus, devnum, 0); + bdf <= PCI_BDF(bus, devnum, + PCI_MAX_PCI_FUNCTIONS - 1); + bdf += PCI_BDF(0, 0, 1)) { + pci_read_config_dword(bdf, PCI_CLASS_REVISION, + &class); + if (class >> 8 == PCI_CLASS_SERIAL_USB_EHCI) + return bdf; + } + } + } + + return -ENODEV; +} #endif
/* @@ -41,9 +71,14 @@ static struct pci_device_id ehci_pci_ids[] = { int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) { pci_dev_t pdev; + uint32_t cmd;
+#ifdef CONFIG_PCI_EHCI_DEVICE pdev = pci_find_devices(ehci_pci_ids, CONFIG_PCI_EHCI_DEVICE); - if (pdev == -1) { +#else + pdev = ehci_find_class(); +#endif + if (pdev < 0) { printf("EHCI host controller not found\n"); return -1; } @@ -57,6 +92,10 @@ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) (uint32_t)*hccr, (uint32_t)*hcor, (uint32_t)HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase)));
+ /* enable busmaster */ + pci_read_config_dword(pdev, PCI_COMMAND, &cmd); + cmd |= PCI_COMMAND_MASTER; + pci_write_config_dword(pdev, PCI_COMMAND, cmd); return 0; }
Interrupt transfers aren't meant to be used from the async list (the EHCI spec indicates trouble with low/full-speed intr on async).
Build a periodic list instead, and provide an API to make use of it. Then, use that API from the existing interrupt transfer API.
This provides support for USB keyboards using EHCI.
Use timeouts to ensure we cannot get stuck in the keyboard scanning if something wrong happens (USB device unplugged or fatal I/O error)
Signed-off-by: Vincent Palatin vpalatin@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Update to use errno - Remove TODOs - Tidy code style a little - Squash timeouts patch into interrupt patch
drivers/usb/host/ehci-hcd.c | 315 ++++++++++++++++++++++++++++++++++++++++++- drivers/usb/host/ehci.h | 6 +- 2 files changed, 316 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 20309ad..8b10b19 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -21,12 +21,14 @@ * MA 02111-1307 USA */ #include <common.h> +#include <errno.h> #include <asm/byteorder.h> #include <asm/unaligned.h> #include <usb.h> #include <asm/io.h> #include <malloc.h> #include <watchdog.h> +#include <linux/compiler.h>
#include "ehci.h"
@@ -39,7 +41,10 @@ static struct ehci_ctrl { struct ehci_hcor *hcor; int rootdev; uint16_t portreset; - struct QH qh_list __attribute__((aligned(USB_DMA_MINALIGN))); + struct QH qh_list __aligned(USB_DMA_MINALIGN); + struct QH periodic_queue __aligned(USB_DMA_MINALIGN); + uint32_t *periodic_list; + int ntds; } ehcic[CONFIG_USB_MAX_CONTROLLER_COUNT];
#define ALIGN_END_ADDR(type, ptr, size) \ @@ -858,6 +863,8 @@ int usb_lowlevel_init(int index, void **controller) uint32_t reg; uint32_t cmd; struct QH *qh_list; + struct QH *periodic; + int i;
if (ehci_hcd_init(index, &ehcic[index].hccr, &ehcic[index].hcor)) return -1; @@ -887,6 +894,40 @@ int usb_lowlevel_init(int index, void **controller) qh_list->qh_overlay.qt_token = cpu_to_hc32(QT_TOKEN_STATUS(QT_TOKEN_STATUS_HALTED));
+ /* Set async. queue head pointer. */ + ehci_writel(&ehcic[index].hcor->or_asynclistaddr, (uint32_t)qh_list); + + /* + * Set up periodic list + * Step 1: Parent QH for all periodic transfers. + */ + periodic = &ehcic[index].periodic_queue; + memset(periodic, 0, sizeof(*periodic)); + periodic->qh_link = cpu_to_hc32(QH_LINK_TERMINATE); + periodic->qh_overlay.qt_next = cpu_to_hc32(QT_NEXT_TERMINATE); + periodic->qh_overlay.qt_altnext = cpu_to_hc32(QT_NEXT_TERMINATE); + + /* + * Step 2: Setup frame-list: Every microframe, USB tries the same list. + * In particular, device specifications on polling frequency + * are disregarded. Keyboards seem to send NAK/NYet reliably + * when polled with an empty buffer. + * + * Split Transactions will be spread across microframes using + * S-mask and C-mask. + */ + ehcic[index].periodic_list = memalign(4096, 1024*4); + if (!ehcic[index].periodic_list) + return -ENOMEM; + for (i = 0; i < 1024; i++) { + ehcic[index].periodic_list[i] = (uint32_t)periodic + | QH_LINK_TYPE_QH; + } + + /* Set periodic list base address */ + ehci_writel(&ehcic[index].hcor->or_periodiclistbase, + (uint32_t)ehcic[index].periodic_list); + reg = ehci_readl(&ehcic[index].hccr->cr_hcsparams); descriptor.hub.bNbrPorts = HCS_N_PORTS(reg); debug("Register %x NbrPorts %d\n", reg, descriptor.hub.bNbrPorts); @@ -956,10 +997,254 @@ submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, return ehci_submit_async(dev, pipe, buffer, length, setup); }
+struct int_queue { + struct QH *first; + struct QH *current; + struct QH *last; + struct qTD *tds; +}; + +#define NEXT_QH(qh) (struct QH *)((qh)->qh_link & ~0x1f) + +static int +enable_periodic(struct ehci_ctrl *ctrl) +{ + uint32_t cmd; + struct ehci_hcor *hcor = ctrl->hcor; + int ret; + + cmd = ehci_readl(&hcor->or_usbcmd); + cmd |= CMD_PSE; + ehci_writel(&hcor->or_usbcmd, cmd); + + ret = handshake((uint32_t *)&hcor->or_usbsts, + STD_PSS, STD_PSS, 100 * 1000); + if (ret < 0) { + printf("EHCI failed: timeout when enabling periodic list\n"); + return -ETIMEDOUT; + } + udelay(1000); + return 0; +} + +static int +disable_periodic(struct ehci_ctrl *ctrl) +{ + uint32_t cmd; + struct ehci_hcor *hcor = ctrl->hcor; + int ret; + + cmd = ehci_readl(&hcor->or_usbcmd); + cmd &= ~CMD_PSE; + ehci_writel(&hcor->or_usbcmd, cmd); + + ret = handshake((uint32_t *)&hcor->or_usbsts, + STD_PSS, 0, 100 * 1000); + if (ret < 0) { + printf("EHCI failed: timeout when enabling periodic list\n"); + return -ETIMEDOUT; + } + return 0; +} + +static int periodic_schedules; + +struct int_queue * +create_int_queue(struct usb_device *dev, unsigned long pipe, int queuesize, + int elementsize, void *buffer) +{ + struct ehci_ctrl *ctrl = dev->controller; + struct int_queue *result = NULL; + int i; + + debug("Enter create_int_queue\n"); + if (usb_pipetype(pipe) != PIPE_INTERRUPT) { + debug("non-interrupt pipe (type=%lu)", usb_pipetype(pipe)); + return NULL; + } + + /* limit to 4 full pages worth of data - + * we can safely fit them in a single TD, + * no matter the alignment + */ + if (elementsize >= 16384) { + debug("too large elements for interrupt transfers\n"); + return NULL; + } + + result = malloc(sizeof(*result)); + if (!result) { + debug("ehci intr queue: out of memory\n"); + goto fail1; + } + result->first = memalign(32, sizeof(struct QH) * queuesize); + if (!result->first) { + debug("ehci intr queue: out of memory\n"); + goto fail2; + } + result->current = result->first; + result->last = result->first + elementsize - 1; + result->tds = memalign(32, sizeof(struct qTD) * queuesize); + if (!result->tds) { + debug("ehci intr queue: out of memory\n"); + goto fail3; + } + memset(result->first, 0, sizeof(struct QH) * queuesize); + memset(result->tds, 0, sizeof(struct qTD) * queuesize); + + for (i = 0; i < queuesize; i++) { + struct QH *qh = result->first + i; + struct qTD *td = result->tds + i; + void **buf = &qh->buffer; + + qh->qh_link = (uint32_t)(qh+1) | QH_LINK_TYPE_QH; + if (i == queuesize - 1) + qh->qh_link = QH_LINK_TERMINATE; + + qh->qh_overlay.qt_next = (uint32_t)td; + qh->qh_endpt1 = (0 << 28) | /* No NAK reload (ehci 4.9) */ + (usb_maxpacket(dev, pipe) << 16) | /* MPS */ + (1 << 14) | + QH_ENDPT1_EPS(ehci_encode_speed(dev->speed)) | + (usb_pipeendpoint(pipe) << 8) | /* Endpoint Number */ + (usb_pipedevice(pipe) << 0); + qh->qh_endpt2 = (1 << 30); /* 1 Tx per mframe */ + if (dev->speed == USB_SPEED_LOW || + dev->speed == USB_SPEED_FULL) { + debug("TT: port: %d, hub address: %d\n", + dev->portnr, dev->parent->devnum); + qh->qh_endpt2 |= (dev->portnr << 23) | + (dev->parent->devnum << 16) | + (0x1c << 8) | /* C-mask: microframes 2-4 */ + (1 << 0); /* S-mask: microframe 0 */ + } + + td->qt_next = QT_NEXT_TERMINATE; + td->qt_altnext = QT_NEXT_TERMINATE; + debug("communication direction is '%s'\n", + usb_pipein(pipe) ? "in" : "out"); + td->qt_token = (elementsize << 16) | + ((usb_pipein(pipe) ? 1 : 0) << 8) | /* IN/OUT token */ + 0x80; /* active */ + td->qt_buffer[0] = (uint32_t)buffer + i * elementsize; + td->qt_buffer[1] = (td->qt_buffer[0] + 0x1000) & ~0xfff; + td->qt_buffer[2] = (td->qt_buffer[0] + 0x2000) & ~0xfff; + td->qt_buffer[3] = (td->qt_buffer[0] + 0x3000) & ~0xfff; + td->qt_buffer[4] = (td->qt_buffer[0] + 0x4000) & ~0xfff; + + *buf = buffer + i * elementsize; + } + + if (disable_periodic(ctrl) < 0) { + debug("FATAL: periodic should never fail, but did"); + goto fail3; + } + + /* hook up to periodic list */ + struct QH *list = &ctrl->periodic_queue; + result->last->qh_link = list->qh_link; + list->qh_link = (uint32_t)result->first | QH_LINK_TYPE_QH; + + if (enable_periodic(ctrl) < 0) { + debug("FATAL: periodic should never fail, but did"); + goto fail3; + } + periodic_schedules++; + + debug("Exit create_int_queue\n"); + return result; +fail3: + if (result->tds) + free(result->tds); +fail2: + if (result->first) + free(result->first); + if (result) + free(result); +fail1: + return NULL; +} + +void *poll_int_queue(struct usb_device *dev, struct int_queue *queue) +{ + struct QH *cur = queue->current; + + /* depleted queue */ + if (cur == NULL) { + debug("Exit poll_int_queue with completed queue\n"); + return NULL; + } + /* still active */ + if (cur->qh_overlay.qt_token & 0x80) { + debug("Exit poll_int_queue with no completed intr transfer. " + "token is %x\n", cur->qh_overlay.qt_token); + return NULL; + } + if (!(cur->qh_link & QH_LINK_TERMINATE)) + queue->current++; + else + queue->current = NULL; + debug("Exit poll_int_queue with completed intr transfer. " + "token is %x at %p (first at %p)\n", cur->qh_overlay.qt_token, + &cur->qh_overlay.qt_token, queue->first); + return cur->buffer; +} + +/* Do not free buffers associated with QHs, they're owned by someone else */ +int +destroy_int_queue(struct usb_device *dev, struct int_queue *queue) +{ + struct ehci_ctrl *ctrl = dev->controller; + int result = -1; + unsigned long timeout; + + if (disable_periodic(ctrl) < 0) { + debug("FATAL: periodic should never fail, but did"); + goto out; + } + periodic_schedules--; + + struct QH *cur = &ctrl->periodic_queue; + timeout = get_timer(0) + 500; /* abort after 500ms */ + while (!(cur->qh_link & QH_LINK_TERMINATE)) { + debug("considering %p, with qh_link %x\n", cur, cur->qh_link); + if (NEXT_QH(cur) == queue->first) { + debug("found candidate. removing from chain\n"); + cur->qh_link = queue->last->qh_link; + result = 0; + goto out; + } + cur = NEXT_QH(cur); + if (get_timer(0) > timeout) { + printf("Timeout destroying interrupt endpoint queue\n"); + result = -1; + break; + } + } + + if (periodic_schedules > 0) { + result = enable_periodic(ctrl); + if (result < 0) + debug("FATAL: periodic should never fail, but did"); + } + +out: + free(queue->tds); + free(queue->first); + free(queue); + + return result; +} + int submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, int length, int interval) { + void *backbuffer; + struct int_queue *queue; + unsigned long timeout; + int result = 0, ret; + debug("dev=%p, pipe=%lu, buffer=%p, length=%d, interval=%d", dev, pipe, buffer, length, interval);
@@ -975,9 +1260,31 @@ submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, * not require more than a single qTD. */ if (length > usb_maxpacket(dev, pipe)) { - printf("%s: Interrupt transfers requiring several transactions " - "are not supported.\n", __func__); + printf("%s: Interrupt transfers requiring several " + "transactions are not supported.\n", __func__); return -1; } - return ehci_submit_async(dev, pipe, buffer, length, NULL); + + queue = create_int_queue(dev, pipe, 1, length, buffer); + + timeout = get_timer(0) + USB_TIMEOUT_MS(pipe); + while ((backbuffer = poll_int_queue(dev, queue)) == NULL) + if (get_timer(0) > timeout) { + printf("Timeout poll on interrupt endpoint\n"); + result = -ETIMEDOUT; + break; + } + + if (backbuffer != buffer) { + debug("got wrong buffer back (%x instead of %x)\n", + (uint32_t)backbuffer, (uint32_t)buffer); + return -EINVAL; + } + + ret = destroy_int_queue(dev, queue); + if (ret < 0) + return ret; + + /* everything worked out fine */ + return result; } diff --git a/drivers/usb/host/ehci.h b/drivers/usb/host/ehci.h index 1e3cd79..8bc2ba1 100644 --- a/drivers/usb/host/ehci.h +++ b/drivers/usb/host/ehci.h @@ -69,6 +69,7 @@ struct ehci_hcor { #define CMD_RUN (1 << 0) /* start/stop HC */ uint32_t or_usbsts; #define STS_ASS (1 << 15) +#define STD_PSS (1 << 14) #define STS_HALT (1 << 12) uint32_t or_usbintr; #define INTR_UE (1 << 0) /* USB interrupt enable */ @@ -245,7 +246,10 @@ struct QH { * Add dummy fill value to make the size of this struct * aligned to 32 bytes */ - uint8_t fill[16]; + union { + uint8_t fill[16]; + void *buffer; + }; };
/* Low level init functions */
There is a potential bug. See below.
+struct int_queue {
struct QH *first;
struct QH *current;
struct QH *last;
struct qTD *tds;
uint32_t cmd;
int ret;
cmd |= CMD_PSE;
Using STS_PSS may be better. STS means status, for USBSTS register.
if (ret < 0) {
return -ETIMEDOUT;
udelay(1000);
uint32_t cmd;
int ret;
cmd &= ~CMD_PSE;
if (ret < 0) {
return -ETIMEDOUT;
int i;
return NULL;
return NULL;
if (!result) {
goto fail1;
goto fail2;
If input queuesize is 1 and elementsize is 8 (for a low-speed keyboard), result->first points to one allocated QH. result->last points to 8th QH (starting from result->first). But we only allocate one QH space for result->first. The location pointed by result->last is beyond the space we allocate. It seems not right.
if (!result->tds) {
goto fail3;
(1 << 14) |
0x80; /* active */
goto fail3;
goto fail3;
return result;
+fail3:
if (result->tds)
free(result->tds);
+fail2:
if (result->first)
if (result)
free(result);
+fail1:
return NULL;
void *backbuffer;
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
The interrupt endpoint handling code stores the buffer pointer in the QH padding field. We need to make it the size of a pointer to avoid strict aliasing issue with the compiler.
drivers/usb/host/ehci.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/usb/host/ehci.h b/drivers/usb/host/ehci.h index 8bc2ba1..5370eb0 100644 --- a/drivers/usb/host/ehci.h +++ b/drivers/usb/host/ehci.h @@ -247,7 +247,7 @@ struct QH { * aligned to 32 bytes */ union { - uint8_t fill[16]; + uint32_t fill[4]; void *buffer; }; };
+Julius
Hi Marek,
I think this patch and a few others are still in the queue. Does that sound right to you?
9c9f379 x86: Enable USB features for coreboot ecefc3fc usb: Add multiple controllers support for EHCI PCI 4950984 usb: usbeth: smsc95xx: remove EEPROM loaded check 606a9e0 usb: ehci: Fix aliasing issue in EHCI interrupt code d2f9f89 usb: ehci: Support interrupt transfers via periodic list
We will be sending a v3 with a few fixes.
Changes in v2: None
uint8_t fill[16];
1.7.7.3
[port of Linux kernel commit bcd218be5aeb by Steve Glendinning]
The eeprom read & write commands currently check the E2P_CMD_LOADED_ bit is set before allowing any operations. This prevents any reading or writing unless a correctly programmed EEPROM is installed.
Signed-off-by: Michael Spang spang@chromium.org Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Marek Vasut marex@denx.de --- Changes in v2: None
drivers/usb/eth/smsc95xx.c | 4 ---- 1 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/eth/smsc95xx.c b/drivers/usb/eth/smsc95xx.c index dc5ca65..fd8f8a7 100644 --- a/drivers/usb/eth/smsc95xx.c +++ b/drivers/usb/eth/smsc95xx.c @@ -265,10 +265,6 @@ static int smsc95xx_eeprom_confirm_not_busy(struct ueth_data *dev)
do { smsc95xx_read_reg(dev, E2P_CMD, &val); - if (!(val & E2P_CMD_LOADED_)) { - debug("No EEPROM present\n"); - return -1; - } if (!(val & E2P_CMD_BUSY_)) return 0; udelay(40);
Hi Simon,
Use the ability to have several active EHCI controller on a system in the PCI EHCI controller implementation.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add blank line before function return
drivers/usb/host/ehci-pci.c | 26 +++++++++++++++++--------- 1 files changed, 17 insertions(+), 9 deletions(-)
diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index 8064a32..b258772 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -34,7 +34,7 @@ static struct pci_device_id ehci_pci_ids[] = { {0, 0} }; #else -static pci_dev_t ehci_find_class(void) +static pci_dev_t ehci_find_class(int index) { int bus; int devnum; @@ -54,7 +54,8 @@ static pci_dev_t ehci_find_class(void) bdf += PCI_BDF(0, 0, 1)) { pci_read_config_dword(bdf, PCI_CLASS_REVISION, &class); - if (class >> 8 == PCI_CLASS_SERIAL_USB_EHCI) + if ((class >> 8 == PCI_CLASS_SERIAL_USB_EHCI) + && !index--) return bdf; } } @@ -68,34 +69,41 @@ static pci_dev_t ehci_find_class(void) * Create the appropriate control structures to manage * a new EHCI host controller. */ -int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) +int ehci_hcd_init(int index, struct ehci_hccr **ret_hccr, + struct ehci_hcor **ret_hcor) { pci_dev_t pdev; uint32_t cmd; + struct ehci_hccr *hccr; + struct ehci_hcor *hcor;
#ifdef CONFIG_PCI_EHCI_DEVICE pdev = pci_find_devices(ehci_pci_ids, CONFIG_PCI_EHCI_DEVICE); #else - pdev = ehci_find_class(); + pdev = ehci_find_class(index); #endif if (pdev < 0) { printf("EHCI host controller not found\n"); return -1; }
- *hccr = (struct ehci_hccr *)pci_map_bar(pdev, + hccr = (struct ehci_hccr *)pci_map_bar(pdev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); - *hcor = (struct ehci_hcor *)((uint32_t) *hccr + - HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + hcor = (struct ehci_hcor *)((uint32_t) hccr + + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
debug("EHCI-PCI init hccr 0x%x and hcor 0x%x hc_length %d\n", - (uint32_t)*hccr, (uint32_t)*hcor, - (uint32_t)HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + (uint32_t)hccr, (uint32_t)hcor, + (uint32_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
/* enable busmaster */ pci_read_config_dword(pdev, PCI_COMMAND, &cmd); cmd |= PCI_COMMAND_MASTER; pci_write_config_dword(pdev, PCI_COMMAND, cmd); + + *ret_hccr = hccr; + *ret_hcor = hcor; + return 0; }
Enable PCI EHCI, storage, keyboard and Ethernet for USB.
include/configs/coreboot.h | 17 +++++++++++++++++ 1 files changed, 17 insertions(+), 0 deletions(-)
diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index adeace0..79adbc0 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -267,6 +267,23 @@ */ #define CONFIG_PCI
+/*----------------------------------------------------------------------- + * USB configuration + */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_PCI +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 12 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_KEYBOARD +#define CONFIG_SYS_USB_EVENT_POLL + +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX + +#define CONFIG_CMD_USB + #define CONFIG_EXTRA_ENV_SETTINGS \ CONFIG_STD_DEVICES_SETTINGS
Jim Lin
Joe Hershberger
