[U-Boot] [PATCH] beagle: make get_expansion_id(), get_board_revision(), beagle_display_init() static
Signed-off-by: Peter Meerwald p.meerwald@bct-electronic.com --- board/ti/beagle/beagle.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 9edd3c5..4611b8a 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -111,7 +111,7 @@ int board_init(void) * GPIO173, GPIO172, GPIO171: 1 0 1 => C4 * GPIO173, GPIO172, GPIO171: 0 0 0 => xM */ -int get_board_revision(void) +static int get_board_revision(void) { int revision;
@@ -210,7 +210,7 @@ void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, * bus 1 for the availability of an AT24C01B serial EEPROM. * returns the device_vendor field from the EEPROM */ -unsigned int get_expansion_id(void) +static unsigned int get_expansion_id(void) { i2c_set_bus_num(EXPANSION_EEPROM_I2C_BUS);
@@ -233,7 +233,7 @@ unsigned int get_expansion_id(void) * Configure DSS to display background color on DVID * Configure VENC to display color bar on S-Video */ -void beagle_display_init(void) +static void beagle_display_init(void) { omap3_dss_venc_config(&venc_config_std_tv, VENC_HEIGHT, VENC_WIDTH); switch (get_board_revision()) {
Peter Meerwald
