[U-Boot] [PATCH 1/3] ARM: imx: cm_fx6: env: use standard variables
From: Christopher Spinrath christopher.spinrath@rwth-aachen.de
In preparation for supporting the distro boot command, introduce the standard variables for specifying load addresses, which are documented in README and doc/README.distro, and replace the custom variables used so far with them.
Since the current address layout disregards an address for an initramfs, also switch to the load addresses used and proven by other imx6 boards (e.g. the wandboard and nitrogen6x), instead of going on with our own way.
Signed-off-by: Christopher Spinrath christopher.spinrath@rwth-aachen.de --- include/configs/cm_fx6.h | 28 ++++++++++++++++------------ 1 file changed, 16 insertions(+), 12 deletions(-)
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index da3233e965..e446caee66 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -63,6 +63,13 @@ #define CONFIG_ENV_OFFSET (768 * 1024)
#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_addr_r=0x18000000\0" \ + "ramdisk_addr_r=0x13000000\0" \ + "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "pxefile_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "scriptaddr=" __stringify(CONFIG_LOADADDR) "\0" \ "stdin=serial,usbkbd\0" \ "stdout=serial,vga\0" \ "stderr=serial,vga\0" \ @@ -73,22 +80,19 @@ "kernel=uImage-cm-fx6\0" \ "script=boot.scr\0" \ "dtb=cm-fx6.dtb\0" \ - "bootm_low=18000000\0" \ - "loadaddr=0x10800000\0" \ - "fdtaddr=0x11000000\0" \ "console=ttymxc3,115200\0" \ "ethprime=FEC0\0" \ "video_hdmi=mxcfb0:dev=hdmi,1920x1080M-32@50,if=RGB32\0" \ "video_dvi=mxcfb0:dev=dvi,1280x800M-32@50,if=RGB32\0" \ - "doboot=bootm ${loadaddr}\0" \ + "doboot=bootm ${kernel_addr_r}\0" \ "doloadfdt=false\0" \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "setboottypez=setenv kernel ${zImage};" \ - "setenv doboot bootz ${loadaddr} - ${fdtaddr};" \ + "setenv doboot bootz ${kernel_addr_r} - ${fdt_addr_r};" \ "setenv doloadfdt true;\0" \ "setboottypem=setenv kernel ${uImage};" \ - "setenv doboot bootm ${loadaddr};" \ + "setenv doboot bootm ${kernel_addr_r};" \ "setenv doloadfdt false;\0"\ "mmcroot=/dev/mmcblk0p2 rw rootwait\0" \ "sataroot=/dev/sda2 rw rootwait\0" \ @@ -112,13 +116,13 @@ "run_eboot=echo Starting EBOOT ...; "\ "mmc dev 2 && " \ "mmc rescan && mmc read 10042000 a 400 && go 10042000\0" \ - "loadscript=load ${storagetype} ${storagedev} ${loadaddr} ${script};\0"\ - "loadkernel=load ${storagetype} ${storagedev} ${loadaddr} ${kernel};\0"\ - "loadfdt=load ${storagetype} ${storagedev} ${fdtaddr} ${dtb};\0" \ + "loadscript=load ${storagetype} ${storagedev} ${scriptaddr} ${script};\0"\ + "loadkernel=load ${storagetype} ${storagedev} ${kernel_addr_r} ${kernel};\0"\ + "loadfdt=load ${storagetype} ${storagedev} ${fdt_addr_r} ${dtb};\0" \ "bootscript=echo Running bootscript from ${storagetype} ...;" \ - "source ${loadaddr};\0" \ - "nandloadkernel=nand read ${loadaddr} 0 780000;\0" \ - "nandloadfdt=nand read ${fdtaddr} 780000 80000;\0" \ + "source ${scriptaddr};\0" \ + "nandloadkernel=nand read ${kernel_addr_r} 0 780000;\0" \ + "nandloadfdt=nand read ${fdt_addr_r} 780000 80000;\0" \ "setupmmcboot=setenv storagetype mmc; setenv storagedev 2;\0" \ "setupsataboot=setenv storagetype sata; setenv storagedev 0;\0" \ "setupnandboot=setenv storagetype nand;\0" \
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Fabio Estevam
