[PATCH 0/6] imx93-11x11-evk: convert to OF_UPSTREAM
To support OF_UPSTREAM, a few driver changes are included. For TMU, still use U-Boot node, I will prepare a kernel update, then back to U-Boot support. Add the pmic nodes to x-u-boot.dtsi, since upstream still not has it. imx93.dtsi still kept because other boards still use it as of now.
Signed-off-by: Peng Fan peng.fan@nxp.com --- Peng Fan (6): gpio: imx_rgpio2p: support one address serial: lpuart: use ipg clk for i.MX7ULP cpu: drop imx9_cpu clk: imx93: fix anatop base Makefile: tune the include order imx: imx93-11x11-evk: convert to OF_UPSTREAM
Makefile | 6 +- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 +++++++++++ arch/arm/dts/imx93-11x11-evk.dts | 322 ------------------------------- arch/arm/dts/imx93-u-boot.dtsi | 15 ++ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- drivers/clk/imx/clk-imx93.c | 2 +- drivers/cpu/imx9_cpu.c | 224 --------------------- drivers/gpio/imx_rgpio2p.c | 42 +++- drivers/serial/serial_lpuart.c | 9 +- 12 files changed, 186 insertions(+), 558 deletions(-) --- base-commit: ab8d9ca3044acf51d8ff3bf3c4718c48f30ad606 change-id: 20240327-imx93-of-56ef2b96f2e2
The i.MX8ULP/93 gpio dt-schema have been updated to only have one address entry, update the driver to support it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/gpio/imx_rgpio2p.c | 42 ++++++++++++++++++++++++++++++++++++++---- 1 file changed, 38 insertions(+), 4 deletions(-)
diff --git a/drivers/gpio/imx_rgpio2p.c b/drivers/gpio/imx_rgpio2p.c index 175e460aff5..3227a8d5b57 100644 --- a/drivers/gpio/imx_rgpio2p.c +++ b/drivers/gpio/imx_rgpio2p.c @@ -21,6 +21,12 @@ enum imx_rgpio2p_direction {
#define GPIO_PER_BANK 32
+struct imx_rgpio2p_soc_data { + bool have_dual_base; +}; + +#define IMX8ULP_GPIO_BASE_OFF 0x40 + struct imx_rgpio2p_data { struct gpio_regs *regs; }; @@ -165,6 +171,9 @@ static int imx_rgpio2p_probe(struct udevice *dev) static int imx_rgpio2p_bind(struct udevice *dev) { struct imx_rgpio2p_plat *plat = dev_get_plat(dev); + struct imx_rgpio2p_soc_data *data = + (struct imx_rgpio2p_soc_data *)dev_get_driver_data(dev); + bool dual_base = data->have_dual_base; fdt_addr_t addr;
/* @@ -176,9 +185,26 @@ static int imx_rgpio2p_bind(struct udevice *dev) if (plat) return 0;
- addr = devfdt_get_addr_index(dev, 1); - if (addr == FDT_ADDR_T_NONE) - return -EINVAL; + /* + * Handle legacy compatible combinations which used two reg values + * for the i.MX8ULP and i.MX93. + */ + if (device_is_compatible(dev, "fsl,imx7ulp-gpio") && + (device_is_compatible(dev, "fsl,imx93-gpio") || + (device_is_compatible(dev, "fsl,imx8ulp-gpio")))) + dual_base = true; + + if (dual_base) { + addr = devfdt_get_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + } else { + addr = devfdt_get_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + addr += IMX8ULP_GPIO_BASE_OFF; + }
/* * TODO: @@ -202,9 +228,17 @@ static int imx_rgpio2p_bind(struct udevice *dev) return 0; }
+static struct imx_rgpio2p_soc_data imx7ulp_data = { + .have_dual_base = true, +}; + +static struct imx_rgpio2p_soc_data imx8ulp_data = { + .have_dual_base = false, +};
static const struct udevice_id imx_rgpio2p_ids[] = { - { .compatible = "fsl,imx7ulp-gpio" }, + { .compatible = "fsl,imx7ulp-gpio", .data = (ulong)&imx7ulp_data }, + { .compatible = "fsl,imx8ulp-gpio", .data = (ulong)&imx8ulp_data }, { } };
To i.MX7ULP compatible lpuart, there is only ipg clk, no per clk. So add a devtype check for i.MX7ULP.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/serial/serial_lpuart.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index ce08a6b4486..653ff99e67b 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -111,11 +111,18 @@ u32 __weak get_lpuart_clk(void) #if CONFIG_IS_ENABLED(CLK) static int get_lpuart_clk_rate(struct udevice *dev, u32 *clk) { + struct lpuart_serial_plat *plat = dev_get_plat(dev); struct clk per_clk; ulong rate; int ret; + char *name;
- ret = clk_get_by_name(dev, "per", &per_clk); + if (plat->devtype == DEV_MX7ULP) + name = "ipg"; + else + name = "per"; + + ret = clk_get_by_name(dev, name, &per_clk); if (ret) { dev_err(dev, "Failed to get per clk: %d\n", ret); return ret;
This was wrongly committed, no user, remove it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/cpu/imx9_cpu.c | 224 ------------------------------------------------- 1 file changed, 224 deletions(-)
diff --git a/drivers/cpu/imx9_cpu.c b/drivers/cpu/imx9_cpu.c deleted file mode 100644 index 66534fe6d17..00000000000 --- a/drivers/cpu/imx9_cpu.c +++ /dev/null @@ -1,224 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2019 NXP - */ - -#include <common.h> -#include <cpu.h> -#include <dm.h> -#include <thermal.h> -#include <asm/global_data.h> -#include <asm/system.h> -#include <firmware/linux/imx/sci/sci.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch-imx/cpu.h> -#include <asm/armv8/cpu.h> -#include <linux/bitops.h> - -DECLARE_GLOBAL_DATA_PTR; - -struct cpu_imx_plat { - const char *name; - const char *rev; - const char *type; - u32 cpu_rsrc; - u32 cpurev; - u32 freq_mhz; - u32 mpidr; -}; - -const char *get_imx9_type(u32 imxtype) -{ - switch (imxtype) { - case MXC_CPU_IMX93: - return "93"; - default: - return "??"; - } -} - -const char *get_imx9_rev(u32 rev) -{ - switch (rev) { - case CHIP_REV_1_0: - return "1."; - case CHIP_REV_B: - return "B"; - case CHIP_REV_C: - return "C"; - default: - return "?"; - } -} - -static void set_core_data(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - if (device_is_compatible(dev, "arm,cortex-a35")) - plat->name = "A35"; - else - plat->name = "?"; -} - -#if IS_ENABLED(CONFIG_IMX_SCU_THERMAL) -static int cpu_imx_get_temp(struct cpu_imx_plat *plat) -{ - struct udevice *thermal_dev; - int cpu_tmp, ret; - int idx = 1; /* use "cpu-thermal0" device */ - - if (plat->cpu_rsrc == SC_R_A72) - idx = 2; /* use "cpu-thermal1" device */ - - ret = uclass_get_device(UCLASS_THERMAL, idx, &thermal_dev); - if (!ret) { - ret = thermal_get_temp(thermal_dev, &cpu_tmp); - if (ret) - return 0xdeadbeef; - } else { - return 0xdeadbeef; - } - - return cpu_tmp; -} -#else -static int cpu_imx_get_temp(struct cpu_imx_plat *plat) -{ - return 0; -} -#endif - -int cpu_imx_get_desc(const struct udevice *dev, char *buf, int size) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - int ret, temp; - - if (size < 100) - return -ENOSPC; - - ret = snprintf(buf, size, "NXP i.MX8%s Rev%s %s at %u MHz", - plat->type, plat->rev, plat->name, plat->freq_mhz); - - if (IS_ENABLED(CONFIG_IMX_SCU_THERMAL)) { - temp = cpu_imx_get_temp(plat); - buf = buf + ret; - size = size - ret; - if (temp != 0xdeadbeef) - ret = snprintf(buf, size, " at %dC", temp); - else - ret = snprintf(buf, size, " - invalid sensor data"); - } - - snprintf(buf + ret, size - ret, "\n"); - - return 0; -} - -static int cpu_imx_get_info(const struct udevice *dev, struct cpu_info *info) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - info->cpu_freq = plat->freq_mhz * 1000; - info->features = BIT(CPU_FEAT_L1_CACHE) | BIT(CPU_FEAT_MMU); - return 0; -} - -static int cpu_imx_get_count(const struct udevice *dev) -{ - ofnode node; - int num = 0; - - ofnode_for_each_subnode(node, dev_ofnode(dev->parent)) { - const char *device_type; - - if (!ofnode_is_enabled(node)) - continue; - - device_type = ofnode_read_string(node, "device_type"); - if (!device_type) - continue; - - if (!strcmp(device_type, "cpu")) - num++; - } - - return num; -} - -static int cpu_imx_get_vendor(const struct udevice *dev, char *buf, int size) -{ - snprintf(buf, size, "NXP"); - return 0; -} - -static int cpu_imx_is_current(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - if (plat->mpidr == (read_mpidr() & 0xffff)) - return 1; - - return 0; -} - -static const struct cpu_ops cpu_imx9_ops = { - .get_desc = cpu_imx_get_desc, - .get_info = cpu_imx_get_info, - .get_count = cpu_imx_get_count, - .get_vendor = cpu_imx_get_vendor, - .is_current = cpu_imx_is_current, -}; - -static const struct udevice_id cpu_imx9_ids[] = { - { .compatible = "arm,cortex-a35" }, - { .compatible = "arm,cortex-a53" }, - { .compatible = "arm,cortex-a72" }, - { } -}; - -static ulong imx9_get_cpu_rate(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - ulong rate; - int ret; - - ret = sc_pm_get_clock_rate(-1, plat->cpu_rsrc, SC_PM_CLK_CPU, - (sc_pm_clock_rate_t *)&rate); - if (ret) { - printf("Could not read CPU frequency: %d\n", ret); - return 0; - } - - return rate; -} - -static int imx9_cpu_probe(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - u32 cpurev; - - set_core_data(dev); - cpurev = get_cpu_rev(); - plat->cpurev = cpurev; - plat->rev = get_imx9_rev(cpurev & 0xFFF); - plat->type = get_imx9_type((cpurev & 0xFF000) >> 12); - plat->freq_mhz = imx9_get_cpu_rate(dev) / 1000000; - plat->mpidr = dev_read_addr(dev); - if (plat->mpidr == FDT_ADDR_T_NONE) { - printf("%s: Failed to get CPU reg property\n", __func__); - return -EINVAL; - } - - return 0; -} - -U_BOOT_DRIVER(cpu_imx9_drv) = { - .name = "imx9x_cpu", - .id = UCLASS_CPU, - .of_match = cpu_imx9_ids, - .ops = &cpu_imx9_ops, - .probe = imx9_cpu_probe, - .plat_auto = sizeof(struct cpu_imx_plat), - .flags = DM_FLAG_PRE_RELOC, -};
The PLL clk needs use anatop base, otherwise wrong PLL address will be used.
Fixes: 9c153e46661b ("clk: imx: add i.MX93 CCF driver") Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/clk/imx/clk-imx93.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx93.c b/drivers/clk/imx/clk-imx93.c index ce10d795316..f0cb797d975 100644 --- a/drivers/clk/imx/clk-imx93.c +++ b/drivers/clk/imx/clk-imx93.c @@ -289,7 +289,7 @@ static int imx93_clk_probe(struct udevice *dev) clk_dm(IMX93_CLK_SYS_PLL_PFD2_DIV2, imx_clk_fixed_factor("sys_pll_pfd2_div2", "sys_pll_pfd2", 1, 2));
- base = (void *)ANATOP_BASE_ADDR; + anatop_base = (void *)ANATOP_BASE_ADDR;
clk_dm(IMX93_CLK_ARM_PLL, imx_clk_fracn_gppll_integer("arm_pll", "clock-osc-24m",
For OF_UPSTREAM support, the U-Boot headers under dt-bindings/ maybe different with OF_UPSTREAM headers. So let OF_UPSTREAM headers be included first when migrating to OF_UPSTREAM.
Signed-off-by: Peng Fan peng.fan@nxp.com --- Makefile | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index b80924241ec..b9c2d896c2e 100644 --- a/Makefile +++ b/Makefile @@ -827,6 +827,7 @@ KBUILD_HOSTCFLAGS += $(if $(CONFIG_TOOLS_DEBUG),-g) # Use UBOOTINCLUDE when you must reference the include/ directory. # Needed to be compatible with the O= option UBOOTINCLUDE := \ + -I$(srctree)/dts/upstream/include \ -Iinclude \ $(if $(KBUILD_SRC), -I$(srctree)/include) \ $(if $(CONFIG_$(SPL_)SYS_THUMB_BUILD), \ @@ -835,8 +836,7 @@ UBOOTINCLUDE := \ -I$(srctree)/arch/arm/thumb1/include), \ -I$(srctree)/arch/arm/thumb1/include)) \ -I$(srctree)/arch/$(ARCH)/include \ - -include $(srctree)/include/linux/kconfig.h \ - -I$(srctree)/dts/upstream/include + -include $(srctree)/include/linux/kconfig.h
NOSTDINC_FLAGS += -nostdinc -isystem $(shell $(CC) -print-file-name=include)
@@ -907,7 +907,7 @@ ifeq ($(CONFIG_USE_PRIVATE_LIBGCC),y) PLATFORM_LIBGCC = arch/$(ARCH)/lib/lib.a else ifndef CONFIG_CC_IS_CLANG -PLATFORM_LIBGCC := -L $(shell dirname `$(CC) $(c_flags) -print-libgcc-file-name`) -lgcc +PLATFORM_LIBGCC := -L $(shell dirname `$(CC) $(c_flags) -print-libgcc-file-name`) endif endif PLATFORM_LIBS += $(PLATFORM_LIBGCC)
Hi Peng,
No, please don't do that. The current include order gives preference to the U-Boot headers under dt-bindings/ such that we don't break platforms which haven't converted to OF_UPSTREAM.
So while migrating to OF_UPSTREAM, you should just drop redundant headers under dt-bindings/ instead.
-Sumit
-- 2.35.3
Subject: Re: [PATCH 5/6] Makefile: tune the include order
Hi Peng,
No, please don't do that. The current include order gives preference to the U- Boot headers under dt-bindings/ such that we don't break platforms which haven't converted to OF_UPSTREAM.
But while in the middle that some boards using OF_UPSTREAM, some not, we could not drop that.
I could sync the dt-bindings header first to avoid break anyway.
Regards, Peng.
-Sumit
@@ -907,7 +907,7 @@ ifeq ($(CONFIG_USE_PRIVATE_LIBGCC),y) PLATFORM_LIBGCC = arch/$(ARCH)/lib/lib.a else ifndef CONFIG_CC_IS_CLANG -PLATFORM_LIBGCC := -L $(shell dirname `$(CC) $(c_flags) -print-libgcc-file-name`) -lgcc +PLATFORM_LIBGCC := -L $(shell dirname `$(CC) $(c_flags) +-print-libgcc-file-name`) endif endif PLATFORM_LIBS += $(PLATFORM_LIBGCC)
-- 2.35.3
Hi Peng,
That's the real reason why we should try to migrate to OF_UPSTREAM at SoC level rather than at board level. If a particular board isn't supported upstream then they can opt out for the time being.
Once you do that sync then there won't be any reason to keep headers under dt-bindings/.
-Sumit
Regards, Peng.
-Sumit
-- 2.35.3
Peng,
All the imx93 boards in U-Boot are supported by the upstream kernel, so, yes, please migrate all of them to OF_UPSTREAM.
Convert to OF_UPSTREAM for i.MX93 11x11 EVK.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 +++++++++++ arch/arm/dts/imx93-11x11-evk.dts | 322 ------------------------------- arch/arm/dts/imx93-u-boot.dtsi | 15 ++ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- 7 files changed, 136 insertions(+), 325 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d85a33055c9..71c2facfb5e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1115,7 +1115,6 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-librem5-r4.dtb
dtb-$(CONFIG_ARCH_IMX9) += \ - imx93-11x11-evk.dtb \ imx93-var-som-symphony.dtb \ imx93-phyboard-segin.dtb
diff --git a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi index a99ba99bfb4..408e601bc90 100644 --- a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi +++ b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi @@ -26,6 +26,111 @@ bootph-pre-ram; };
+&lpi2c2 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_lpi2c2>; + pinctrl-1 = <&pinctrl_lpi2c2>; + status = "okay"; + + pmic@25 { + compatible = "nxp,pca9451a"; + reg = <0x25>; + interrupt-parent = <&pcal6524>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + + regulators { + buck1: BUCK1 { + regulator-name = "BUCK1"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <2237500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck4: BUCK4{ + regulator-name = "BUCK4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5{ + regulator-name = "BUCK5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + pcal6524: gpio@22 { + compatible = "nxp,pcal6524"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcal6524>; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupt-parent = <&gpio3>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + }; + + adp5585gpio: gpio@34 { + compatible = "adp5585"; + reg = <0x34>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + &aips1 { bootph-pre-ram; bootph-all; @@ -44,6 +149,19 @@ &iomuxc { bootph-pre-ram; bootph-some-ram; + + pinctrl_lpi2c2: lpi2c2grp { + fsl,pins = < + MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e + MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e + >; + }; + + pinctrl_pcal6524: pcal6524grp { + fsl,pins = < + MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e + >; + }; };
®_usdhc2_vmmc { diff --git a/arch/arm/dts/imx93-11x11-evk.dts b/arch/arm/dts/imx93-11x11-evk.dts deleted file mode 100644 index 4322cc3e11b..00000000000 --- a/arch/arm/dts/imx93-11x11-evk.dts +++ /dev/null @@ -1,322 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 NXP - */ - -/dts-v1/; - -#include "imx93.dtsi" - -/ { - model = "NXP i.MX93 11X11 EVK board"; - compatible = "fsl,imx93-11x11-evk", "fsl,imx93"; - - chosen { - stdout-path = &lpuart1; - }; - - reg_vref_1v8: regulator-adc-vref { - compatible = "regulator-fixed"; - regulator-name = "vref_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&adc1 { - vref-supply = <®_vref_1v8>; - status = "okay"; -}; - -&mu1 { - status = "okay"; -}; - -&mu2 { - status = "okay"; -}; - -&eqos { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy1>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy1: ethernet-phy@1 { - reg = <1>; - eee-broken-1000t; - }; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy2>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy2: ethernet-phy@2 { - reg = <2>; - eee-broken-1000t; - }; - }; -}; - -&lpi2c2 { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <400000>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pinctrl_lpi2c2>; - pinctrl-1 = <&pinctrl_lpi2c2>; - status = "okay"; - - pmic@25 { - compatible = "nxp,pca9451a"; - reg = <0x25>; - interrupt-parent = <&pcal6524>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - - regulators { - buck1: BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <2237500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck2: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <2187500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck4: BUCK4{ - regulator-name = "BUCK4"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: BUCK5{ - regulator-name = "BUCK5"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6: BUCK6 { - regulator-name = "BUCK6"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: LDO4 { - regulator-name = "LDO4"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo5: LDO5 { - regulator-name = "LDO5"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; - - pcal6524: gpio@22 { - compatible = "nxp,pcal6524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcal6524>; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - interrupt-parent = <&gpio3>; - interrupts = <27 IRQ_TYPE_LEVEL_LOW>; - }; - - adp5585gpio: gpio@34 { - compatible = "adp5585"; - reg = <0x34>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&lpuart1 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1>; - pinctrl-2 = <&pinctrl_usdhc1>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio3 00 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - bus-width = <4>; - status = "okay"; - no-sdio; - no-mmc; -}; - -&iomuxc { - pinctrl_lpi2c2: lpi2c2grp { - fsl,pins = < - MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e - MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e - >; - }; - - pinctrl_pcal6524: pcal6524grp { - fsl,pins = < - MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e - >; - }; - - pinctrl_eqos: eqosgrp { - fsl,pins = < - MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x57e - MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x57e - MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x57e - MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x57e - MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x57e - MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x57e - MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x5fe - MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x57e - MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x57e - MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x57e - MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x57e - MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x57e - MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x5fe - MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_fec: fecgrp { - fsl,pins = < - MX93_PAD_ENET2_MDC__ENET1_MDC 0x57e - MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x57e - MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e - MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e - MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x57e - MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x57e - MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x5fe - MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e - MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x57e - MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x57e - MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x57e - MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x57e - MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x5fe - MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX93_PAD_UART1_RXD__LPUART1_RX 0x31e - MX93_PAD_UART1_TXD__LPUART1_TX 0x31e - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX93_PAD_SD1_CLK__USDHC1_CLK 0x15fe - MX93_PAD_SD1_CMD__USDHC1_CMD 0x13fe - MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x13fe - MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x13fe - MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x13fe - MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x13fe - MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x13fe - MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x13fe - MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x13fe - MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x13fe - MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x15fe - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x31e - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x15fe - MX93_PAD_SD2_CMD__USDHC2_CMD 0x13fe - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x13fe - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x13fe - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x13fe - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x13fe - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; -}; diff --git a/arch/arm/dts/imx93-u-boot.dtsi b/arch/arm/dts/imx93-u-boot.dtsi index 40e17bbc5ae..289aba17584 100644 --- a/arch/arm/dts/imx93-u-boot.dtsi +++ b/arch/arm/dts/imx93-u-boot.dtsi @@ -86,3 +86,18 @@ }; }; }; + +&tmu { + compatible = "fsl,imx93-tmu"; + reg = <0x44482000 0x1000>; + clocks = <&clk IMX93_CLK_TMC_GATE>; + little-endian; + fsl,tmu-calibration = <0x0000000e 0x800000da + 0x00000029 0x800000e9 + 0x00000056 0x80000102 + 0x000000a2 0x8000012a + 0x00000116 0x80000166 + 0x00000195 0x800001a7 + 0x000001b2 0x800001b6>; + #thermal-sensor-cells = <1>; +}; diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index b79485f1f75..e892da80fe8 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -31,6 +31,7 @@ choice config TARGET_IMX93_11X11_EVK bool "imx93_11x11_evk" select IMX93 + imply OF_UPSTREAM
config TARGET_IMX93_VAR_SOM bool "imx93_var_som" diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 63613477c7f..a671de7ca40 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_TARGET_IMX93_11X11_EVK=y CONFIG_SYS_MONITOR_LEN=524288 diff --git a/configs/imx93_11x11_evk_ld_defconfig b/configs/imx93_11x11_evk_ld_defconfig index 4e3bbdd0cf5..4e1f162e35a 100644 --- a/configs/imx93_11x11_evk_ld_defconfig +++ b/configs/imx93_11x11_evk_ld_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x400000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_IMX9_LOW_DRIVE_MODE=y CONFIG_TARGET_IMX93_11X11_EVK=y
Fabio Estevam
Peng Fan
Peng Fan (OSS)
Sumit Garg
