[U-Boot] [PATCH] at91: extract reset from timer
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm926ejs/at91/Makefile | 1 + cpu/arm926ejs/at91/reset.c | 42 ++++++++++++++++++++++++++++++++++++++++++ cpu/arm926ejs/at91/timer.c | 15 --------------- 3 files changed, 43 insertions(+), 15 deletions(-) create mode 100644 cpu/arm926ejs/at91/reset.c
diff --git a/cpu/arm926ejs/at91/Makefile b/cpu/arm926ejs/at91/Makefile index 71acb0b..66eec76 100644 --- a/cpu/arm926ejs/at91/Makefile +++ b/cpu/arm926ejs/at91/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o COBJS-$(CONFIG_AT91_LED) += led.o COBJS-y += clock.o COBJS-y += cpu.o +COBJS-y += reset.o COBJS-y += timer.o
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) diff --git a/cpu/arm926ejs/at91/reset.c b/cpu/arm926ejs/at91/reset.c new file mode 100644 index 0000000..f963e14 --- /dev/null +++ b/cpu/arm926ejs/at91/reset.c @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/io.h> + +/* + * Reset the cpu by setting up the watchdog timer and let him time out. + */ +void reset_cpu(ulong ignored) +{ + /* this is the way Linux does it */ + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | + AT91_RSTC_PROCRST | + AT91_RSTC_PERRST); + + while (1); + /* Never reached */ +} diff --git a/cpu/arm926ejs/at91/timer.c b/cpu/arm926ejs/at91/timer.c index c84cb5e..811bb3c 100644 --- a/cpu/arm926ejs/at91/timer.c +++ b/cpu/arm926ejs/at91/timer.c @@ -26,7 +26,6 @@ #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/io.h> #include <div64.h> @@ -139,17 +138,3 @@ ulong get_tbclk(void) tbclk = CONFIG_SYS_HZ; return tbclk; } - -/* - * Reset the cpu by setting up the watchdog timer and let him time out. - */ -void reset_cpu(ulong ignored) -{ - /* this is the way Linux does it */ - at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | - AT91_RSTC_PROCRST | - AT91_RSTC_PERRST); - - while (1); - /* Never reached */ -}
