[U-Boot] Problems booting Linux 3.18 on SH7785LCR
Hello!
I recently got Renesas SH7785LCR board which I am currently setting up as a Debian porterbox for sh4. Currently, all sh4 build machines at Debian for sh4 are running kernel 3.2.0 which is showing its age now, especially since newer versions of udev are complaining about the deprecated kernel.
Since I am setting up my SH7785LCR board as a new machine, I wanted to start with a new kernel right away. But since I also don't have any older base system which I could use, I need to use an updated kernel anyway.
While I had no problems booting an old uImage with the aforementioned 3.2.0 kernel, I haven't had any success with kernel 3.18 so far. u-boot loads the kernel, decompresses it but seems to perform a reset right away:
U-Boot 2014.01 (Jan 30 2015 - 11:01:14)
CPU: SH4 BOARD: Renesas Technology Corp. R0P7785LC0011RL DRAM: 384MB Flash: 64MB PCI: SH7780 PCI host bridge found. PCI: Bus Dev VenId DevId Class Int 00:00.0 - 10ec:8169 - Network controller 00:01.0 - 1095:3512 - Mass storage controller In: serial Out: serial Err: serial Net: RTL8169#0 =>
=> usb reset (Re)start USB... USB0: scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => fatload usb 0:1 0x89000000 uImage-3.18 reading uImage-3.18 2977932 bytes read in 1690 ms (1.7 MiB/s) => pmb => bootm ## Booting kernel from Legacy Image at 89000000 ... Image Name: Image Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 2977868 Bytes = 2.8 MiB Load Address: 80001000 Entry Point: 80002000 Verifying Checksum ... OK � Uncompressing Kernel Image ... OK
The 3.18 uImage was created by downloading the Debian kernel image package for the SH7785LCR [1] and unpacking the package. Then I created the uImage using the following command using the same loader and entry address that are being set for the 3.2.0 uImage:
mkimage -A sh -O linux -a 0x80001000 -e 0x80002000 -d vmlinuz-3.18.0-trunk-sh7785lcr.gz uImage-3.18
Does anyone know what could be wrong such that the kernel wouldn't boot as shown above?
Cheers, Adrian
[1]
ftp://ftp.debian-ports.org/debian/pool-sh4/main/l/linux/linux-image-3.18.0-trunk-sh7785lcr_3.18.3-1~exp1_sh4.deb
John Paul Adrian Glaubitz
