[U-Boot] [v3 patch] net: fman: Support both new and legacy FMan Compatibles
Recently the FMan Port and MAC compatibles were changed. This patch aligns the FMan Port and MAC compatibles to the new FMan device tree binding document. The FMan device tree binding document can be found in the Linux kernel: version 3.18.0 commit 297d35fd2a7d3fbd4e5c0f0c1c18213117ba11ba ./Documentation/devicetree/bindings/powerpc/fsl/fman.txt
This patch doesn't affect legacy compatibles support.
Signed-off-by: Zhao Qiang qiang.zhao@nxp.com --- Changes for v2 - add kernel version and commit id modifing the binding Changes for v3 - put "fsl,fman-xgec" before "fsl,fman-tgec" - because it use the former in latest kernel version
drivers/net/fm/init.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index 147d043..f896e80 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -328,7 +328,8 @@ void fdt_fixup_fman_ethernet(void *blob) ft_fixup_port(blob, &fm_info[i], "fsl,fman-1g-mac"); } else { - if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec")) + if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-xgec") && + ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec")) ft_fixup_port(blob, &fm_info[i], "fsl,fman-10g-mac"); }
Hi York,
It seems nobody have comments on this patch, Could you help to take action on it?
Best Regards Qiang Zhao
-----Original Message----- From: Zhao Qiang qiang.zhao@nxp.com Sent: 2018年8月29日 11:47 To: York Sun york.sun@nxp.com; joe.hershberger@ni.com Cc: u-boot@lists.denx.de; Qiang Zhao qiang.zhao@nxp.com Subject: [v3 patch] net: fman: Support both new and legacy FMan Compatibles
Changes for v2
}ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec")) ft_fixup_port(blob, &fm_info[i], "fsl,fman-10g-mac");
-- 1.7.1
Changes for v2
Changes for v3
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Qiang Zhao
York Sun
Zhao Qiang
