[U-Boot] [PATCH 2/3 v2] MIPS: Add VCT board series support (Part 2/3)
This patch adds support for the Micronas VCT board series. Currently the following platforms are supported:
vct_premium vct_premium_small vct_premium_onenand vct_premium_onenand_small vct_platinum vct_platinum_small vct_platinum_onenand vct_platinum_onenand_small vct_platinumavc vct_platinumavc_small vct_platinumavc_onenand vct_platinumavc_onenand_small
One speciality of the VCT board is that it can't access NOR FLASH memory-mapped. It has to use special access functions for this.
Signed-off-by: Stefan Roese sr@denx.de --- v2: - No changes
board/micronas/vct/ebi.h | 95 +++++++++++ board/micronas/vct/vct.h | 97 +++++++++++ board/micronas/vct/vcth/reg_dcgu.h | 25 +++ board/micronas/vct/vcth/reg_ebi.h | 242 ++++++++++++++++++++++++++ board/micronas/vct/vcth/reg_fwsram.h | 73 ++++++++ board/micronas/vct/vcth/reg_gpio.h | 32 ++++ board/micronas/vct/vcth/reg_wdt.h | 24 +++ board/micronas/vct/vcth2/reg_ebi.h | 290 +++++++++++++++++++++++++++++++ board/micronas/vct/vctv/reg_dcgu.h | 25 +++ board/micronas/vct/vctv/reg_ebi.h | 290 +++++++++++++++++++++++++++++++ board/micronas/vct/vctv/reg_gpio.h | 32 ++++ board/micronas/vct/vctv/reg_wdt.h | 24 +++ include/configs/vct.h | 310 ++++++++++++++++++++++++++++++++++ 13 files changed, 1559 insertions(+), 0 deletions(-) create mode 100644 board/micronas/vct/ebi.h create mode 100644 board/micronas/vct/vct.h create mode 100644 board/micronas/vct/vcth/reg_dcgu.h create mode 100644 board/micronas/vct/vcth/reg_ebi.h create mode 100644 board/micronas/vct/vcth/reg_fwsram.h create mode 100644 board/micronas/vct/vcth/reg_gpio.h create mode 100644 board/micronas/vct/vcth/reg_wdt.h create mode 100644 board/micronas/vct/vcth2/reg_ebi.h create mode 100644 board/micronas/vct/vctv/reg_dcgu.h create mode 100644 board/micronas/vct/vctv/reg_ebi.h create mode 100644 board/micronas/vct/vctv/reg_gpio.h create mode 100644 board/micronas/vct/vctv/reg_wdt.h create mode 100644 include/configs/vct.h
diff --git a/board/micronas/vct/ebi.h b/board/micronas/vct/ebi.h new file mode 100644 index 0000000..69456bd --- /dev/null +++ b/board/micronas/vct/ebi.h @@ -0,0 +1,95 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __EBI__ +#define __EBI__ + +#include <common.h> +#include <asm/io.h> +#include "vct.h" + +#define EXT_DEVICE_CHANNEL_3 (0x30000000) +#define EXT_DEVICE_CHANNEL_2 (0x20000000) +#define EXT_DEVICE_CHANNEL_1 (0x10000000) +#define EXT_CPU_ACCESS_ACTIVE (0x00000001) +#define EXT_DMA_ACCESS_ACTIVE (1 << 14) +#define EXT_CPU_IORDY_SL (0x00000001) + +#define EBI_CPU_WRITE (1 << 31) +#define EBI_CPU_ID_SHIFT (28) +#define EBI_CPU_ADDR_MASK ~(~0UL << EBI_CPU_ID_SHIFT) + +/* position of various bit slices in timing register EBI_DEV[01]_TIM1_RD1 */ +#define ADDR_LATCH_ENABLE 0 +#define ADDR_ACTIVATION 4 +#define CHIP_SELECT_START 8 +#define OUTPUT_ENABLE_START 12 +#define WAIT_TIME 28 +#define READ_DURATION 20 + +/* position of various bit slices in timing register EBI_DEV[01]_TIM1_RD2 */ +#define OUTPUT_ENABLE_END 0 +#define CHIP_SELECT_END 4 +#define ADDR_DEACTIVATION 8 +#define RECOVER_TIME 12 +#define ACK_TIME 20 + +/* various bits in configuration register EBI_DEV[01]_CONFIG1 */ +#define EBI_EXTERNAL_DATA_8 (1 << 8) +#define EBI_EXT_ADDR_SHIFT (1 << 22) +#define EBI_EXTERNAL_DATA_16 EBI_EXT_ADDR_SHIFT +#define EBI_CHIP_SELECT_1 0x2 +#define EBI_CHIP_SELECT_2 0x4 +#define EBI_BUSY_EN_RD (1 << 12) +#define DIR_ACCESS_WRITE (1 << 20) +#define DIR_ACCESS_MASK (1 << 20) + +/* various bits in configuration register EBI_DEV[01]_CONFIG2 */ +#define ADDRESS_INCREMENT_ON 0x0 +#define ADDRESS_INCREMENT_OFF 0x100 +#define QUEUE_LENGTH_1 0x40 +#define QUEUE_LENGTH_2 0x80 +#define QUEUE_LENGTH_3 0xC0 +#define QUEUE_LENGTH_4 0 +#define CPU_TRANSFER_SIZE_32 0 +#define CPU_TRANSFER_SIZE_16 0x10 +#define CPU_TRANSFER_SIZE_8 0x20 +#define READ_ENDIANNESS_ABCD 0 +#define READ_ENDIANNESS_DCBA 0x4 +#define READ_ENDIANNESS_BADC 0x8 +#define READ_ENDIANNESS_CDAB 0xC +#define WRITE_ENDIANNESS_ABCD 0 +#define WRITE_ENDIANNESS_DCBA 0x1 +#define WRITE_ENDIANNESS_BADC 0x2 +#define WRITE_ENDIANNESS_CDAB 0x3 + +/* various bits in configuration register EBI_CTRL_SIG_ACTLV */ +#define IORDY_ACTIVELEVEL_HIGH (1 << 14) +#define ALE_ACTIVELEVEL_HIGH (1 << 8) + +/* bits in register EBI_SIG_LEVEL */ +#define IORDY_LEVEL_MASK 1 + +static inline void ebi_wait(void) +{ + while (reg_read(EBI_STATUS(EBI_BASE)) & EXT_CPU_ACCESS_ACTIVE) + ; /* wait */ +} + +#endif diff --git a/board/micronas/vct/vct.h b/board/micronas/vct/vct.h new file mode 100644 index 0000000..c14f46d --- /dev/null +++ b/board/micronas/vct/vct.h @@ -0,0 +1,97 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * Copyright (C) 2006 Micronas GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/io.h> + +#include "ebi.h" + +#ifdef CONFIG_VCT_PREMIUM +/* Global start address of all memory mapped registers */ +#define REG_GLOBAL_START_ADDR 0xbf800000 +#define TOP_BASE 0x000c8000 + +#include "vcth/reg_ebi.h" +#include "vcth/reg_dcgu.h" +#include "vcth/reg_wdt.h" +#include "vcth/reg_gpio.h" +#include "vcth/reg_fwsram.h" +#endif + +#ifdef CONFIG_VCT_PLATINUM +/* Global start address of all memory mapped registers */ +#define REG_GLOBAL_START_ADDR 0xbf800000 +#define TOP_BASE 0x000c8000 + +#include "vcth2/reg_ebi.h" +#include "vcth/reg_dcgu.h" +#include "vcth/reg_wdt.h" +#include "vcth/reg_gpio.h" +#include "vcth/reg_fwsram.h" +#endif + +#ifdef CONFIG_VCT_PLATINUMAVC +/* Global start address of all memory mapped registers */ +#define REG_GLOBAL_START_ADDR 0xbdc00000 +#define TOP_BASE 0x00050000 + +#include "vctv/reg_ebi.h" +#include "vctv/reg_dcgu.h" +#include "vctv/reg_wdt.h" +#include "vctv/reg_gpio.h" +#endif + +#ifndef _VCT_H +#define _VCT_H + +/* + * Defines + */ +#define PRID_COMP_LEGACY 0x000000 +#define PRID_COMP_MIPS 0x010000 +#define PRID_IMP_LX4280 0xc200 +#define PRID_IMP_VGC 0x9000 + +/* + * Prototypes + */ +int ebi_initialize(void); +int ebi_init_nor_flash(void); +int ebi_init_onenand(void); +int ebi_init_smc911x(void); +u32 smc911x_reg_read(u32 addr); +void smc911x_reg_write(u32 addr, u32 data); +int top_set_pin(int pin, int func); +void vct_pin_mux_initialize(void); + +/* + * static inlines + */ +static inline void reg_write(u32 addr, u32 data) +{ + __raw_writel(data, addr + REG_GLOBAL_START_ADDR); +} + +static inline u32 reg_read(u32 addr) +{ + return __raw_readl(addr + REG_GLOBAL_START_ADDR); +} + +#endif /* _VCT_H */ diff --git a/board/micronas/vct/vcth/reg_dcgu.h b/board/micronas/vct/vcth/reg_dcgu.h new file mode 100644 index 0000000..c83ef27 --- /dev/null +++ b/board/micronas/vct/vcth/reg_dcgu.h @@ -0,0 +1,25 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define DCGU_BASE 0x00084000 +#define DCGU_EN_WDT_RESET_OFFS 0x00000064 +#define DCGU_EN_WDT_RESET(base) ((base) + DCGU_EN_WDT_RESET_OFFS) + +/* The magic value to write in order to activate the WDT */ +#define DCGU_MAGIC_WDT 0x1909 diff --git a/board/micronas/vct/vcth/reg_ebi.h b/board/micronas/vct/vcth/reg_ebi.h new file mode 100644 index 0000000..7a1e115 --- /dev/null +++ b/board/micronas/vct/vcth/reg_ebi.h @@ -0,0 +1,242 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * Copyright (C) 2006 Micronas GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _REG_EBI_PREMIUM_H_ +#define _REG_EBI_PREMIUM_H_ + +#define EBI_BASE 0x00000000 + +/* Relative offsets of the register adresses */ + +#define EBI_CPU_IO_ACCS_OFFS 0x00000000 +#define EBI_CPU_IO_ACCS(base) ((base) + EBI_CPU_IO_ACCS_OFFS) +#define EBI_IO_ACCS_DATA_OFFS 0x00000004 +#define EBI_IO_ACCS_DATA(base) ((base) + EBI_IO_ACCS_DATA_OFFS) +#define EBI_CTRL_OFFS 0x00000008 +#define EBI_CTRL(base) ((base) + EBI_CTRL_OFFS) +#define EBI_IRQ_MASK_OFFS 0x00000010 +#define EBI_IRQ_MASK(base) ((base) + EBI_IRQ_MASK_OFFS) +#define EBI_TAG1_SYS_ID_OFFS 0x00000030 +#define EBI_TAG1_SYS_ID(base) ((base) + EBI_TAG1_SYS_ID_OFFS) +#define EBI_TAG2_SYS_ID_OFFS 0x00000040 +#define EBI_TAG2_SYS_ID(base) ((base) + EBI_TAG2_SYS_ID_OFFS) +#define EBI_TAG3_SYS_ID_OFFS 0x00000050 +#define EBI_TAG3_SYS_ID(base) ((base) + EBI_TAG3_SYS_ID_OFFS) +#define EBI_TAG4_SYS_ID_OFFS 0x00000060 +#define EBI_TAG4_SYS_ID(base) ((base) + EBI_TAG4_SYS_ID_OFFS) +#define EBI_GEN_DMA_CTRL_OFFS 0x00000070 +#define EBI_GEN_DMA_CTRL(base) ((base) + EBI_GEN_DMA_CTRL_OFFS) +#define EBI_STATUS_OFFS 0x00000080 +#define EBI_STATUS(base) ((base) + EBI_STATUS_OFFS) +#define EBI_STATUS_DMA_CNT_OFFS 0x00000084 +#define EBI_STATUS_DMA_CNT(base) ((base) + EBI_STATUS_DMA_CNT_OFFS) +#define EBI_SIG_LEVEL_OFFS 0x00000088 +#define EBI_SIG_LEVEL(base) ((base) + EBI_SIG_LEVEL_OFFS) +#define EBI_CTRL_SIG_ACTLV_OFFS 0x0000008C +#define EBI_CTRL_SIG_ACTLV(base) ((base) + EBI_CTRL_SIG_ACTLV_OFFS) +#define EBI_EXT_ADDR_OFFS 0x000000A0 +#define EBI_EXT_ADDR(base) ((base) + EBI_EXT_ADDR_OFFS) +#define EBI_IRQ_STATUS_OFFS 0x000000B0 +#define EBI_IRQ_STATUS(base) ((base) + EBI_IRQ_STATUS_OFFS) +#define EBI_DEV1_DMA_EXT_ADDR_OFFS 0x00000100 +#define EBI_DEV1_DMA_EXT_ADDR(base) ((base) + EBI_DEV1_DMA_EXT_ADDR_OFFS) +#define EBI_DEV1_EXT_ACC_OFFS 0x00000104 +#define EBI_DEV1_EXT_ACC(base) ((base) + EBI_DEV1_EXT_ACC_OFFS) +#define EBI_DEV1_CONFIG1_OFFS 0x00000108 +#define EBI_DEV1_CONFIG1(base) ((base) + EBI_DEV1_CONFIG1_OFFS) +#define EBI_DEV1_CONFIG2_OFFS 0x0000010C +#define EBI_DEV1_CONFIG2(base) ((base) + EBI_DEV1_CONFIG2_OFFS) +#define EBI_DEV1_FIFO_CONFIG_OFFS 0x00000110 +#define EBI_DEV1_FIFO_CONFIG(base) ((base) + EBI_DEV1_FIFO_CONFIG_OFFS) +#define EBI_DEV1_FLASH_CONF_ST_OFFS 0x00000114 +#define EBI_DEV1_FLASH_CONF_ST(base) ((base) + EBI_DEV1_FLASH_CONF_ST_OFFS) +#define EBI_DEV1_DMA_CONFIG1_OFFS 0x00000118 +#define EBI_DEV1_DMA_CONFIG1(base) ((base) + EBI_DEV1_DMA_CONFIG1_OFFS) +#define EBI_DEV1_DMA_CONFIG2_OFFS 0x0000011C +#define EBI_DEV1_DMA_CONFIG2(base) ((base) + EBI_DEV1_DMA_CONFIG2_OFFS) +#define EBI_DEV1_TIM1_RD1_OFFS 0x00000124 +#define EBI_DEV1_TIM1_RD1(base) ((base) + EBI_DEV1_TIM1_RD1_OFFS) +#define EBI_DEV1_TIM1_RD2_OFFS 0x00000128 +#define EBI_DEV1_TIM1_RD2(base) ((base) + EBI_DEV1_TIM1_RD2_OFFS) +#define EBI_DEV1_TIM1_WR1_OFFS 0x0000012C +#define EBI_DEV1_TIM1_WR1(base) ((base) + EBI_DEV1_TIM1_WR1_OFFS) +#define EBI_DEV1_TIM1_WR2_OFFS 0x00000130 +#define EBI_DEV1_TIM1_WR2(base) ((base) + EBI_DEV1_TIM1_WR2_OFFS) +#define EBI_DEV1_TIM_EXT_OFFS 0x00000134 +#define EBI_DEV1_TIM_EXT(base) ((base) + EBI_DEV1_TIM_EXT_OFFS) +#define EBI_DEV1_TIM2_CFI_RD1_OFFS 0x00000138 +#define EBI_DEV1_TIM2_CFI_RD1(base) ((base) + EBI_DEV1_TIM2_CFI_RD1_OFFS) +#define EBI_DEV1_TIM2_CFI_RD2_OFFS 0x0000013C +#define EBI_DEV1_TIM2_CFI_RD2(base) ((base) + EBI_DEV1_TIM2_CFI_RD2_OFFS) +#define EBI_DEV1_TIM3_DMA1_OFFS 0x00000140 +#define EBI_DEV1_TIM3_DMA1(base) ((base) + EBI_DEV1_TIM3_DMA1_OFFS) +#define EBI_DEV1_TIM3_DMA2_OFFS 0x00000144 +#define EBI_DEV1_TIM3_DMA2(base) ((base) + EBI_DEV1_TIM3_DMA2_OFFS) +#define EBI_DEV1_ACK_RM_CNT_OFFS 0x00000150 +#define EBI_DEV1_ACK_RM_CNT(base) ((base) + EBI_DEV1_ACK_RM_CNT_OFFS) +#define EBI_DEV2_DMA_EXT_ADDR_OFFS 0x00000200 +#define EBI_DEV2_DMA_EXT_ADDR(base) ((base) + EBI_DEV2_DMA_EXT_ADDR_OFFS) +#define EBI_DEV2_EXT_ACC_OFFS 0x00000204 +#define EBI_DEV2_EXT_ACC(base) ((base) + EBI_DEV2_EXT_ACC_OFFS) +#define EBI_DEV2_CONFIG1_OFFS 0x00000208 +#define EBI_DEV2_CONFIG1(base) ((base) + EBI_DEV2_CONFIG1_OFFS) +#define EBI_DEV2_CONFIG2_OFFS 0x0000020C +#define EBI_DEV2_CONFIG2(base) ((base) + EBI_DEV2_CONFIG2_OFFS) +#define EBI_DEV2_FIFO_CONFIG_OFFS 0x00000210 +#define EBI_DEV2_FIFO_CONFIG(base) ((base) + EBI_DEV2_FIFO_CONFIG_OFFS) +#define EBI_DEV2_FLASH_CONF_ST_OFFS 0x00000214 +#define EBI_DEV2_FLASH_CONF_ST(base) ((base) + EBI_DEV2_FLASH_CONF_ST_OFFS) +#define EBI_DEV2_DMA_CONFIG1_OFFS 0x00000218 +#define EBI_DEV2_DMA_CONFIG1(base) ((base) + EBI_DEV2_DMA_CONFIG1_OFFS) +#define EBI_DEV2_DMA_CONFIG2_OFFS 0x0000021C +#define EBI_DEV2_DMA_CONFIG2(base) ((base) + EBI_DEV2_DMA_CONFIG2_OFFS) +#define EBI_DEV2_TIM1_RD1_OFFS 0x00000224 +#define EBI_DEV2_TIM1_RD1(base) ((base) + EBI_DEV2_TIM1_RD1_OFFS) +#define EBI_DEV2_TIM1_RD2_OFFS 0x00000228 +#define EBI_DEV2_TIM1_RD2(base) ((base) + EBI_DEV2_TIM1_RD2_OFFS) +#define EBI_DEV2_TIM1_WR1_OFFS 0x0000022C +#define EBI_DEV2_TIM1_WR1(base) ((base) + EBI_DEV2_TIM1_WR1_OFFS) +#define EBI_DEV2_TIM1_WR2_OFFS 0x00000230 +#define EBI_DEV2_TIM1_WR2(base) ((base) + EBI_DEV2_TIM1_WR2_OFFS) +#define EBI_DEV2_TIM_EXT_OFFS 0x00000234 +#define EBI_DEV2_TIM_EXT(base) ((base) + EBI_DEV2_TIM_EXT_OFFS) +#define EBI_DEV2_TIM2_CFI_RD1_OFFS 0x00000238 +#define EBI_DEV2_TIM2_CFI_RD1(base) ((base) + EBI_DEV2_TIM2_CFI_RD1_OFFS) +#define EBI_DEV2_TIM2_CFI_RD2_OFFS 0x0000023C +#define EBI_DEV2_TIM2_CFI_RD2(base) ((base) + EBI_DEV2_TIM2_CFI_RD2_OFFS) +#define EBI_DEV2_TIM3_DMA1_OFFS 0x00000240 +#define EBI_DEV2_TIM3_DMA1(base) ((base) + EBI_DEV2_TIM3_DMA1_OFFS) +#define EBI_DEV2_TIM3_DMA2_OFFS 0x00000244 +#define EBI_DEV2_TIM3_DMA2(base) ((base) + EBI_DEV2_TIM3_DMA2_OFFS) +#define EBI_DEV2_ACK_RM_CNT_OFFS 0x00000250 +#define EBI_DEV2_ACK_RM_CNT(base) ((base) + EBI_DEV2_ACK_RM_CNT_OFFS) +#define EBI_DEV3_DMA_EXT_ADDR_OFFS 0x00000300 +#define EBI_DEV3_DMA_EXT_ADDR(base) ((base) + EBI_DEV3_DMA_EXT_ADDR_OFFS) +#define EBI_DEV3_EXT_ACC_OFFS 0x00000304 +#define EBI_DEV3_EXT_ACC(base) ((base) + EBI_DEV3_EXT_ACC_OFFS) +#define EBI_DEV3_CONFIG1_OFFS 0x00000308 +#define EBI_DEV3_CONFIG1(base) ((base) + EBI_DEV3_CONFIG1_OFFS) +#define EBI_DEV3_CONFIG2_OFFS 0x0000030C +#define EBI_DEV3_CONFIG2(base) ((base) + EBI_DEV3_CONFIG2_OFFS) +#define EBI_DEV3_FIFO_CONFIG_OFFS 0x00000310 +#define EBI_DEV3_FIFO_CONFIG(base) ((base) + EBI_DEV3_FIFO_CONFIG_OFFS) +#define EBI_DEV3_FLASH_CONF_ST_OFFS 0x00000314 +#define EBI_DEV3_FLASH_CONF_ST(base) ((base) + EBI_DEV3_FLASH_CONF_ST_OFFS) +#define EBI_DEV3_DMA_CONFIG1_OFFS 0x00000318 +#define EBI_DEV3_DMA_CONFIG1(base) ((base) + EBI_DEV3_DMA_CONFIG1_OFFS) +#define EBI_DEV3_DMA_CONFIG2_OFFS 0x0000031C +#define EBI_DEV3_DMA_CONFIG2(base) ((base) + EBI_DEV3_DMA_CONFIG2_OFFS) +#define EBI_DEV3_TIM1_RD1_OFFS 0x00000324 +#define EBI_DEV3_TIM1_RD1(base) ((base) + EBI_DEV3_TIM1_RD1_OFFS) +#define EBI_DEV3_TIM1_RD2_OFFS 0x00000328 +#define EBI_DEV3_TIM1_RD2(base) ((base) + EBI_DEV3_TIM1_RD2_OFFS) +#define EBI_DEV3_TIM1_WR1_OFFS 0x0000032C +#define EBI_DEV3_TIM1_WR1(base) ((base) + EBI_DEV3_TIM1_WR1_OFFS) +#define EBI_DEV3_TIM1_WR2_OFFS 0x00000330 +#define EBI_DEV3_TIM1_WR2(base) ((base) + EBI_DEV3_TIM1_WR2_OFFS) +#define EBI_DEV3_TIM_EXT_OFFS 0x00000334 +#define EBI_DEV3_TIM_EXT(base) ((base) + EBI_DEV3_TIM_EXT_OFFS) +#define EBI_DEV3_TIM2_CFI_RD1_OFFS 0x00000338 +#define EBI_DEV3_TIM2_CFI_RD1(base) ((base) + EBI_DEV3_TIM2_CFI_RD1_OFFS) +#define EBI_DEV3_TIM2_CFI_RD2_OFFS 0x0000033C +#define EBI_DEV3_TIM2_CFI_RD2(base) ((base) + EBI_DEV3_TIM2_CFI_RD2_OFFS) +#define EBI_DEV3_TIM3_DMA1_OFFS 0x00000340 +#define EBI_DEV3_TIM3_DMA1(base) ((base) + EBI_DEV3_TIM3_DMA1_OFFS) +#define EBI_DEV3_TIM3_DMA2_OFFS 0x00000344 +#define EBI_DEV3_TIM3_DMA2(base) ((base) + EBI_DEV3_TIM3_DMA2_OFFS) +#define EBI_DEV3_ACK_RM_CNT_OFFS 0x00000350 +#define EBI_DEV3_ACK_RM_CNT(base) ((base) + EBI_DEV3_ACK_RM_CNT_OFFS) +#define EBI_DEV4_DMA_EXT_ADDR_OFFS 0x00000400 +#define EBI_DEV4_DMA_EXT_ADDR(base) ((base) + EBI_DEV4_DMA_EXT_ADDR_OFFS) +#define EBI_DEV4_EXT_ACC_OFFS 0x00000404 +#define EBI_DEV4_EXT_ACC(base) ((base) + EBI_DEV4_EXT_ACC_OFFS) +#define EBI_DEV4_CONFIG1_OFFS 0x00000408 +#define EBI_DEV4_CONFIG1(base) ((base) + EBI_DEV4_CONFIG1_OFFS) +#define EBI_DEV4_CONFIG2_OFFS 0x0000040C +#define EBI_DEV4_CONFIG2(base) ((base) + EBI_DEV4_CONFIG2_OFFS) +#define EBI_DEV4_FIFO_CONFIG_OFFS 0x00000410 +#define EBI_DEV4_FIFO_CONFIG(base) ((base) + EBI_DEV4_FIFO_CONFIG_OFFS) +#define EBI_DEV4_FLASH_CONF_ST_OFFS 0x00000414 +#define EBI_DEV4_FLASH_CONF_ST(base) ((base) + EBI_DEV4_FLASH_CONF_ST_OFFS) +#define EBI_DEV4_DMA_CONFIG1_OFFS 0x00000418 +#define EBI_DEV4_DMA_CONFIG1(base) ((base) + EBI_DEV4_DMA_CONFIG1_OFFS) +#define EBI_DEV4_DMA_CONFIG2_OFFS 0x0000041C +#define EBI_DEV4_DMA_CONFIG2(base) ((base) + EBI_DEV4_DMA_CONFIG2_OFFS) +#define EBI_DEV4_TIM1_RD1_OFFS 0x00000424 +#define EBI_DEV4_TIM1_RD1(base) ((base) + EBI_DEV4_TIM1_RD1_OFFS) +#define EBI_DEV4_TIM1_RD2_OFFS 0x00000428 +#define EBI_DEV4_TIM1_RD2(base) ((base) + EBI_DEV4_TIM1_RD2_OFFS) +#define EBI_DEV4_TIM1_WR1_OFFS 0x0000042C +#define EBI_DEV4_TIM1_WR1(base) ((base) + EBI_DEV4_TIM1_WR1_OFFS) +#define EBI_DEV4_TIM1_WR2_OFFS 0x00000430 +#define EBI_DEV4_TIM1_WR2(base) ((base) + EBI_DEV4_TIM1_WR2_OFFS) +#define EBI_DEV4_TIM_EXT_OFFS 0x00000434 +#define EBI_DEV4_TIM_EXT(base) ((base) + EBI_DEV4_TIM_EXT_OFFS) +#define EBI_DEV4_TIM2_CFI_RD1_OFFS 0x00000438 +#define EBI_DEV4_TIM2_CFI_RD1(base) ((base) + EBI_DEV4_TIM2_CFI_RD1_OFFS) +#define EBI_DEV4_TIM2_CFI_RD2_OFFS 0x0000043C +#define EBI_DEV4_TIM2_CFI_RD2(base) ((base) + EBI_DEV4_TIM2_CFI_RD2_OFFS) +#define EBI_DEV4_TIM3_DMA1_OFFS 0x00000440 +#define EBI_DEV4_TIM3_DMA1(base) ((base) + EBI_DEV4_TIM3_DMA1_OFFS) +#define EBI_DEV4_TIM3_DMA2_OFFS 0x00000444 +#define EBI_DEV4_TIM3_DMA2(base) ((base) + EBI_DEV4_TIM3_DMA2_OFFS) +#define EBI_DEV4_ACK_RM_CNT_OFFS 0x00000450 +#define EBI_DEV4_ACK_RM_CNT(base) ((base) + EBI_DEV4_ACK_RM_CNT_OFFS) +#define EBI_CNT_FL_PROGR_OFFS 0x00000904 +#define EBI_CNT_FL_PROGR(base) ((base) + EBI_CNT_FL_PROGR_OFFS) +#define EBI_CNT_EXT_PAGE_SZ_OFFS 0x0000090C +#define EBI_CNT_EXT_PAGE_SZ(base) ((base) + EBI_CNT_EXT_PAGE_SZ_OFFS) +#define EBI_CNT_WAIT_RDY_OFFS 0x00000914 +#define EBI_CNT_WAIT_RDY(base) ((base) + EBI_CNT_WAIT_RDY_OFFS) +#define EBI_CNT_ACK_OFFS 0x00000918 +#define EBI_CNT_ACK(base) ((base) + EBI_CNT_ACK_OFFS) +#define EBI_GENIO1_CONFIG1_OFFS 0x00000A00 +#define EBI_GENIO1_CONFIG1(base) ((base) + EBI_GENIO1_CONFIG1_OFFS) +#define EBI_GENIO1_CONFIG2_OFFS 0x00000A04 +#define EBI_GENIO1_CONFIG2(base) ((base) + EBI_GENIO1_CONFIG2_OFFS) +#define EBI_GENIO1_CONFIG3_OFFS 0x00000A08 +#define EBI_GENIO1_CONFIG3(base) ((base) + EBI_GENIO1_CONFIG3_OFFS) +#define EBI_GENIO2_CONFIG1_OFFS 0x00000A10 +#define EBI_GENIO2_CONFIG1(base) ((base) + EBI_GENIO2_CONFIG1_OFFS) +#define EBI_GENIO2_CONFIG2_OFFS 0x00000A14 +#define EBI_GENIO2_CONFIG2(base) ((base) + EBI_GENIO2_CONFIG2_OFFS) +#define EBI_GENIO2_CONFIG3_OFFS 0x00000A18 +#define EBI_GENIO2_CONFIG3(base) ((base) + EBI_GENIO2_CONFIG3_OFFS) +#define EBI_GENIO3_CONFIG1_OFFS 0x00000A20 +#define EBI_GENIO3_CONFIG1(base) ((base) + EBI_GENIO3_CONFIG1_OFFS) +#define EBI_GENIO3_CONFIG2_OFFS 0x00000A24 +#define EBI_GENIO3_CONFIG2(base) ((base) + EBI_GENIO3_CONFIG2_OFFS) +#define EBI_GENIO3_CONFIG3_OFFS 0x00000A28 +#define EBI_GENIO3_CONFIG3(base) ((base) + EBI_GENIO3_CONFIG3_OFFS) +#define EBI_GENIO4_CONFIG1_OFFS 0x00000A30 +#define EBI_GENIO4_CONFIG1(base) ((base) + EBI_GENIO4_CONFIG1_OFFS) +#define EBI_GENIO4_CONFIG2_OFFS 0x00000A34 +#define EBI_GENIO4_CONFIG2(base) ((base) + EBI_GENIO4_CONFIG2_OFFS) +#define EBI_GENIO4_CONFIG3_OFFS 0x00000A38 +#define EBI_GENIO4_CONFIG3(base) ((base) + EBI_GENIO4_CONFIG3_OFFS) +#define EBI_GENIO5_CONFIG1_OFFS 0x00000A40 +#define EBI_GENIO5_CONFIG1(base) ((base) + EBI_GENIO5_CONFIG1_OFFS) +#define EBI_GENIO5_CONFIG2_OFFS 0x00000A44 +#define EBI_GENIO5_CONFIG2(base) ((base) + EBI_GENIO5_CONFIG2_OFFS) +#define EBI_GENIO5_CONFIG3_OFFS 0x00000A48 +#define EBI_GENIO5_CONFIG3(base) ((base) + EBI_GENIO5_CONFIG3_OFFS) + +#endif diff --git a/board/micronas/vct/vcth/reg_fwsram.h b/board/micronas/vct/vcth/reg_fwsram.h new file mode 100644 index 0000000..19afb6b --- /dev/null +++ b/board/micronas/vct/vcth/reg_fwsram.h @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * Copyright (C) 2006 Micronas GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Premium & Platinum register addresses/definitions seem to be + * identical, so we only need to use one file for both platforms. + */ + +#ifndef _REG_FWSRAM_H_ +#define _REG_FWSRAM_H_ + +#define FWSRAM_BASE 0x00030000 + +/* Relative offsets of the register adresses */ + +#define FWSRAM_SR_ADDR_OFFSET_OFFS 0x00002000 +#define FWSRAM_SR_ADDR_OFFSET(base) ((base) + FWSRAM_SR_ADDR_OFFSET_OFFS) +#define FWSRAM_TOP_BOOT_LOG_OFFS 0x00002004 +#define FWSRAM_TOP_BOOT_LOG(base) ((base) + FWSRAM_TOP_BOOT_LOG_OFFS) +#define FWSRAM_TOP_ROM_KBIST_OFFS 0x00002008 +#define FWSRAM_TOP_ROM_KBIST(base) ((base) + FWSRAM_TOP_ROM_KBIST_OFFS) +#define FWSRAM_TOP_CID1_H_OFFS 0x0000200C +#define FWSRAM_TOP_CID1_H(base) ((base) + FWSRAM_TOP_CID1_H_OFFS) +#define FWSRAM_TOP_CID1_L_OFFS 0x00002010 +#define FWSRAM_TOP_CID1_L(base) ((base) + FWSRAM_TOP_CID1_L_OFFS) +#define FWSRAM_TOP_CID2_H_OFFS 0x00002014 +#define FWSRAM_TOP_CID2_H(base) ((base) + FWSRAM_TOP_CID2_H_OFFS) +#define FWSRAM_TOP_CID2_L_OFFS 0x00002018 +#define FWSRAM_TOP_CID2_L(base) ((base) + FWSRAM_TOP_CID2_L_OFFS) +#define FWSRAM_TOP_TDO_CFG_OFFS 0x0000203C +#define FWSRAM_TOP_TDO_CFG(base) ((base) + FWSRAM_TOP_TDO_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_0_CFG_OFFS 0x00002040 +#define FWSRAM_TOP_GPIO2_0_CFG(base) ((base) + FWSRAM_TOP_GPIO2_0_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_1_CFG_OFFS 0x00002044 +#define FWSRAM_TOP_GPIO2_1_CFG(base) ((base) + FWSRAM_TOP_GPIO2_1_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_2_CFG_OFFS 0x00002048 +#define FWSRAM_TOP_GPIO2_2_CFG(base) ((base) + FWSRAM_TOP_GPIO2_2_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_3_CFG_OFFS 0x0000204C +#define FWSRAM_TOP_GPIO2_3_CFG(base) ((base) + FWSRAM_TOP_GPIO2_3_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_4_CFG_OFFS 0x00002050 +#define FWSRAM_TOP_GPIO2_4_CFG(base) ((base) + FWSRAM_TOP_GPIO2_4_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_5_CFG_OFFS 0x00002054 +#define FWSRAM_TOP_GPIO2_5_CFG(base) ((base) + FWSRAM_TOP_GPIO2_5_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_6_CFG_OFFS 0x00002058 +#define FWSRAM_TOP_GPIO2_6_CFG(base) ((base) + FWSRAM_TOP_GPIO2_6_CFG_OFFS) +#define FWSRAM_TOP_GPIO2_7_CFG_OFFS 0x0000205C +#define FWSRAM_TOP_GPIO2_7_CFG(base) ((base) + FWSRAM_TOP_GPIO2_7_CFG_OFFS) +#define FWSRAM_TOP_SCL_CFG_OFFS 0x00002060 +#define FWSRAM_TOP_SCL_CFG(base) ((base) + FWSRAM_TOP_SCL_CFG_OFFS) +#define FWSRAM_TOP_SDA_CFG_OFFS 0x00002064 +#define FWSRAM_TOP_SDA_CFG(base) ((base) + FWSRAM_TOP_SDA_CFG_OFFS) +#define FWSRAM_NO_MCM_FLASH_OFFS 0x00002068 +#define FWSRAM_NO_MCM_FLASH(base) ((base) + FWSRAM_NO_MCM_FLASH_OFFS) + +#endif diff --git a/board/micronas/vct/vcth/reg_gpio.h b/board/micronas/vct/vcth/reg_gpio.h new file mode 100644 index 0000000..7ada9c9 --- /dev/null +++ b/board/micronas/vct/vcth/reg_gpio.h @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define GPIO1_BASE 0x00088000 +#define GPIO2_BASE 0x0008c000 + +/* Instances */ +#define GPIO_INSTANCES 2 + +/* Relative offsets of the register adresses */ +#define GPIO_SWPORTA_DR_OFFS 0x00000000 +#define GPIO_SWPORTA_DR(base) ((base) + GPIO_SWPORTA_DR_OFFS) +#define GPIO_SWPORTA_DDR_OFFS 0x00000004 +#define GPIO_SWPORTA_DDR(base) ((base) + GPIO_SWPORTA_DDR_OFFS) +#define GPIO_EXT_PORTA_OFFS 0x00000050 +#define GPIO_EXT_PORTA(base) ((base) + GPIO_EXT_PORTA_OFFS) diff --git a/board/micronas/vct/vcth/reg_wdt.h b/board/micronas/vct/vcth/reg_wdt.h new file mode 100644 index 0000000..a9b4bf0 --- /dev/null +++ b/board/micronas/vct/vcth/reg_wdt.h @@ -0,0 +1,24 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define WDT_BASE 0x000b0000 +#define WDT_CR_OFFS 0x00000000 +#define WDT_CR(base) ((base) + WDT_CR_OFFS) +#define WDT_TORR_OFFS 0x00000004 +#define WDT_TORR(base) ((base) + WDT_TORR_OFFS) diff --git a/board/micronas/vct/vcth2/reg_ebi.h b/board/micronas/vct/vcth2/reg_ebi.h new file mode 100644 index 0000000..37f0711 --- /dev/null +++ b/board/micronas/vct/vcth2/reg_ebi.h @@ -0,0 +1,290 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * Copyright (C) 2006 Micronas GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _REG_EBI_PREMIUM_H_ +#define _REG_EBI_PREMIUM_H_ + +#define EBI_BASE 0x00000000 + +/* Relative offsets of the register adresses */ + +#define EBI_CPU_IO_ACCS_OFFS 0x00000000 +#define EBI_CPU_IO_ACCS(base) ((base) + EBI_CPU_IO_ACCS_OFFS) +#define EBI_IO_ACCS_DATA_OFFS 0x00000004 +#define EBI_IO_ACCS_DATA(base) ((base) + EBI_IO_ACCS_DATA_OFFS) +#define EBI_CPU_IO_ACCS2_OFFS 0x00000008 +#define EBI_CPU_IO_ACCS2(base) ((base) + EBI_CPU_IO_ACCS2_OFFS) +#define EBI_IO_ACCS2_DATA_OFFS 0x0000000C +#define EBI_IO_ACCS2_DATA(base) ((base) + EBI_IO_ACCS2_DATA_OFFS) +#define EBI_CTRL_OFFS 0x00000010 +#define EBI_CTRL(base) ((base) + EBI_CTRL_OFFS) +#define EBI_IRQ_MASK_OFFS 0x00000018 +#define EBI_IRQ_MASK(base) ((base) + EBI_IRQ_MASK_OFFS) +#define EBI_IRQ_MASK2_OFFS 0x0000001C +#define EBI_IRQ_MASK2(base) ((base) + EBI_IRQ_MASK2_OFFS) +#define EBI_TAG1_SYS_ID_OFFS 0x00000030 +#define EBI_TAG1_SYS_ID(base) ((base) + EBI_TAG1_SYS_ID_OFFS) +#define EBI_TAG2_SYS_ID_OFFS 0x00000040 +#define EBI_TAG2_SYS_ID(base) ((base) + EBI_TAG2_SYS_ID_OFFS) +#define EBI_TAG3_SYS_ID_OFFS 0x00000050 +#define EBI_TAG3_SYS_ID(base) ((base) + EBI_TAG3_SYS_ID_OFFS) +#define EBI_TAG4_SYS_ID_OFFS 0x00000060 +#define EBI_TAG4_SYS_ID(base) ((base) + EBI_TAG4_SYS_ID_OFFS) +#define EBI_GEN_DMA_CTRL_OFFS 0x00000070 +#define EBI_GEN_DMA_CTRL(base) ((base) + EBI_GEN_DMA_CTRL_OFFS) +#define EBI_STATUS_OFFS 0x00000080 +#define EBI_STATUS(base) ((base) + EBI_STATUS_OFFS) +#define EBI_STATUS_DMA_CNT_OFFS 0x00000084 +#define EBI_STATUS_DMA_CNT(base) ((base) + EBI_STATUS_DMA_CNT_OFFS) +#define EBI_SIG_LEVEL_OFFS 0x00000088 +#define EBI_SIG_LEVEL(base) ((base) + EBI_SIG_LEVEL_OFFS) +#define EBI_CTRL_SIG_ACTLV_OFFS 0x0000008C +#define EBI_CTRL_SIG_ACTLV(base) ((base) + EBI_CTRL_SIG_ACTLV_OFFS) +#define EBI_CRC_GEN_OFFS 0x00000090 +#define EBI_CRC_GEN(base) ((base) + EBI_CRC_GEN_OFFS) +#define EBI_EXT_ADDR_OFFS 0x000000A0 +#define EBI_EXT_ADDR(base) ((base) + EBI_EXT_ADDR_OFFS) +#define EBI_IRQ_STATUS_OFFS 0x000000B0 +#define EBI_IRQ_STATUS(base) ((base) + EBI_IRQ_STATUS_OFFS) +#define EBI_IRQ_STATUS2_OFFS 0x000000B4 +#define EBI_IRQ_STATUS2(base) ((base) + EBI_IRQ_STATUS2_OFFS) +#define EBI_EXT_MASTER_SRAM_HIGH_OFFS 0x000000C0 +#define EBI_EXT_MASTER_SRAM_HIGH(base) ((base) + EBI_EXT_MASTER_SRAM_HIGH_OFFS) +#define EBI_EXT_MASTER_SRAM_LOW_OFFS 0x000000C4 +#define EBI_EXT_MASTER_SRAM_LOW(base) ((base) + EBI_EXT_MASTER_SRAM_LOW_OFFS) +#define EBI_ECC0_OFFS 0x000000D0 +#define EBI_ECC0(base) ((base) + EBI_ECC0_OFFS) +#define EBI_ECC1_OFFS 0x000000D4 +#define EBI_ECC1(base) ((base) + EBI_ECC1_OFFS) +#define EBI_ECC2_OFFS 0x000000D8 +#define EBI_ECC2(base) ((base) + EBI_ECC2_OFFS) +#define EBI_ECC3_OFFS 0x000000DC +#define EBI_ECC3(base) ((base) + EBI_ECC3_OFFS) +#define EBI_DEV1_DMA_EXT_ADDR_OFFS 0x00000100 +#define EBI_DEV1_DMA_EXT_ADDR(base) ((base) + EBI_DEV1_DMA_EXT_ADDR_OFFS) +#define EBI_DEV1_EXT_ACC_OFFS 0x00000104 +#define EBI_DEV1_EXT_ACC(base) ((base) + EBI_DEV1_EXT_ACC_OFFS) +#define EBI_DEV1_CONFIG1_OFFS 0x00000108 +#define EBI_DEV1_CONFIG1(base) ((base) + EBI_DEV1_CONFIG1_OFFS) +#define EBI_DEV1_CONFIG2_OFFS 0x0000010C +#define EBI_DEV1_CONFIG2(base) ((base) + EBI_DEV1_CONFIG2_OFFS) +#define EBI_DEV1_FIFO_CONFIG_OFFS 0x00000110 +#define EBI_DEV1_FIFO_CONFIG(base) ((base) + EBI_DEV1_FIFO_CONFIG_OFFS) +#define EBI_DEV1_FLASH_CONF_ST_OFFS 0x00000114 +#define EBI_DEV1_FLASH_CONF_ST(base) ((base) + EBI_DEV1_FLASH_CONF_ST_OFFS) +#define EBI_DEV1_DMA_CONFIG1_OFFS 0x00000118 +#define EBI_DEV1_DMA_CONFIG1(base) ((base) + EBI_DEV1_DMA_CONFIG1_OFFS) +#define EBI_DEV1_DMA_CONFIG2_OFFS 0x0000011C +#define EBI_DEV1_DMA_CONFIG2(base) ((base) + EBI_DEV1_DMA_CONFIG2_OFFS) +#define EBI_DEV1_DMA_ECC_CTRL_OFFS 0x00000120 +#define EBI_DEV1_DMA_ECC_CTRL(base) ((base) + EBI_DEV1_DMA_ECC_CTRL_OFFS) +#define EBI_DEV1_TIM1_RD1_OFFS 0x00000124 +#define EBI_DEV1_TIM1_RD1(base) ((base) + EBI_DEV1_TIM1_RD1_OFFS) +#define EBI_DEV1_TIM1_RD2_OFFS 0x00000128 +#define EBI_DEV1_TIM1_RD2(base) ((base) + EBI_DEV1_TIM1_RD2_OFFS) +#define EBI_DEV1_TIM1_WR1_OFFS 0x0000012C +#define EBI_DEV1_TIM1_WR1(base) ((base) + EBI_DEV1_TIM1_WR1_OFFS) +#define EBI_DEV1_TIM1_WR2_OFFS 0x00000130 +#define EBI_DEV1_TIM1_WR2(base) ((base) + EBI_DEV1_TIM1_WR2_OFFS) +#define EBI_DEV1_TIM_EXT_OFFS 0x00000134 +#define EBI_DEV1_TIM_EXT(base) ((base) + EBI_DEV1_TIM_EXT_OFFS) +#define EBI_DEV1_TIM2_CFI_RD1_OFFS 0x00000138 +#define EBI_DEV1_TIM2_CFI_RD1(base) ((base) + EBI_DEV1_TIM2_CFI_RD1_OFFS) +#define EBI_DEV1_TIM2_CFI_RD2_OFFS 0x0000013C +#define EBI_DEV1_TIM2_CFI_RD2(base) ((base) + EBI_DEV1_TIM2_CFI_RD2_OFFS) +#define EBI_DEV1_TIM3_DMA1_OFFS 0x00000140 +#define EBI_DEV1_TIM3_DMA1(base) ((base) + EBI_DEV1_TIM3_DMA1_OFFS) +#define EBI_DEV1_TIM3_DMA2_OFFS 0x00000144 +#define EBI_DEV1_TIM3_DMA2(base) ((base) + EBI_DEV1_TIM3_DMA2_OFFS) +#define EBI_DEV1_TIM4_UDMA1_OFFS 0x00000148 +#define EBI_DEV1_TIM4_UDMA1(base) ((base) + EBI_DEV1_TIM4_UDMA1_OFFS) +#define EBI_DEV1_TIM4_UDMA2_OFFS 0x0000014C +#define EBI_DEV1_TIM4_UDMA2(base) ((base) + EBI_DEV1_TIM4_UDMA2_OFFS) +#define EBI_DEV1_ACK_RM_CNT_OFFS 0x00000150 +#define EBI_DEV1_ACK_RM_CNT(base) ((base) + EBI_DEV1_ACK_RM_CNT_OFFS) +#define EBI_DEV2_DMA_EXT_ADDR_OFFS 0x00000200 +#define EBI_DEV2_DMA_EXT_ADDR(base) ((base) + EBI_DEV2_DMA_EXT_ADDR_OFFS) +#define EBI_DEV2_EXT_ACC_OFFS 0x00000204 +#define EBI_DEV2_EXT_ACC(base) ((base) + EBI_DEV2_EXT_ACC_OFFS) +#define EBI_DEV2_CONFIG1_OFFS 0x00000208 +#define EBI_DEV2_CONFIG1(base) ((base) + EBI_DEV2_CONFIG1_OFFS) +#define EBI_DEV2_CONFIG2_OFFS 0x0000020C +#define EBI_DEV2_CONFIG2(base) ((base) + EBI_DEV2_CONFIG2_OFFS) +#define EBI_DEV2_FIFO_CONFIG_OFFS 0x00000210 +#define EBI_DEV2_FIFO_CONFIG(base) ((base) + EBI_DEV2_FIFO_CONFIG_OFFS) +#define EBI_DEV2_FLASH_CONF_ST_OFFS 0x00000214 +#define EBI_DEV2_FLASH_CONF_ST(base) ((base) + EBI_DEV2_FLASH_CONF_ST_OFFS) +#define EBI_DEV2_DMA_CONFIG1_OFFS 0x00000218 +#define EBI_DEV2_DMA_CONFIG1(base) ((base) + EBI_DEV2_DMA_CONFIG1_OFFS) +#define EBI_DEV2_DMA_CONFIG2_OFFS 0x0000021C +#define EBI_DEV2_DMA_CONFIG2(base) ((base) + EBI_DEV2_DMA_CONFIG2_OFFS) +#define EBI_DEV2_DMA_ECC_CTRL_OFFS 0x00000220 +#define EBI_DEV2_DMA_ECC_CTRL(base) ((base) + EBI_DEV2_DMA_ECC_CTRL_OFFS) +#define EBI_DEV2_TIM1_RD1_OFFS 0x00000224 +#define EBI_DEV2_TIM1_RD1(base) ((base) + EBI_DEV2_TIM1_RD1_OFFS) +#define EBI_DEV2_TIM1_RD2_OFFS 0x00000228 +#define EBI_DEV2_TIM1_RD2(base) ((base) + EBI_DEV2_TIM1_RD2_OFFS) +#define EBI_DEV2_TIM1_WR1_OFFS 0x0000022C +#define EBI_DEV2_TIM1_WR1(base) ((base) + EBI_DEV2_TIM1_WR1_OFFS) +#define EBI_DEV2_TIM1_WR2_OFFS 0x00000230 +#define EBI_DEV2_TIM1_WR2(base) ((base) + EBI_DEV2_TIM1_WR2_OFFS) +#define EBI_DEV2_TIM_EXT_OFFS 0x00000234 +#define EBI_DEV2_TIM_EXT(base) ((base) + EBI_DEV2_TIM_EXT_OFFS) +#define EBI_DEV2_TIM2_CFI_RD1_OFFS 0x00000238 +#define EBI_DEV2_TIM2_CFI_RD1(base) ((base) + EBI_DEV2_TIM2_CFI_RD1_OFFS) +#define EBI_DEV2_TIM2_CFI_RD2_OFFS 0x0000023C +#define EBI_DEV2_TIM2_CFI_RD2(base) ((base) + EBI_DEV2_TIM2_CFI_RD2_OFFS) +#define EBI_DEV2_TIM3_DMA1_OFFS 0x00000240 +#define EBI_DEV2_TIM3_DMA1(base) ((base) + EBI_DEV2_TIM3_DMA1_OFFS) +#define EBI_DEV2_TIM3_DMA2_OFFS 0x00000244 +#define EBI_DEV2_TIM3_DMA2(base) ((base) + EBI_DEV2_TIM3_DMA2_OFFS) +#define EBI_DEV2_TIM4_UDMA1_OFFS 0x00000248 +#define EBI_DEV2_TIM4_UDMA1(base) ((base) + EBI_DEV2_TIM4_UDMA1_OFFS) +#define EBI_DEV2_TIM4_UDMA2_OFFS 0x0000024C +#define EBI_DEV2_TIM4_UDMA2(base) ((base) + EBI_DEV2_TIM4_UDMA2_OFFS) +#define EBI_DEV2_ACK_RM_CNT_OFFS 0x00000250 +#define EBI_DEV2_ACK_RM_CNT(base) ((base) + EBI_DEV2_ACK_RM_CNT_OFFS) +#define EBI_DEV3_DMA_EXT_ADDR_OFFS 0x00000300 +#define EBI_DEV3_DMA_EXT_ADDR(base) ((base) + EBI_DEV3_DMA_EXT_ADDR_OFFS) +#define EBI_DEV3_EXT_ACC_OFFS 0x00000304 +#define EBI_DEV3_EXT_ACC(base) ((base) + EBI_DEV3_EXT_ACC_OFFS) +#define EBI_DEV3_CONFIG1_OFFS 0x00000308 +#define EBI_DEV3_CONFIG1(base) ((base) + EBI_DEV3_CONFIG1_OFFS) +#define EBI_DEV3_CONFIG2_OFFS 0x0000030C +#define EBI_DEV3_CONFIG2(base) ((base) + EBI_DEV3_CONFIG2_OFFS) +#define EBI_DEV3_FIFO_CONFIG_OFFS 0x00000310 +#define EBI_DEV3_FIFO_CONFIG(base) ((base) + EBI_DEV3_FIFO_CONFIG_OFFS) +#define EBI_DEV3_FLASH_CONF_ST_OFFS 0x00000314 +#define EBI_DEV3_FLASH_CONF_ST(base) ((base) + EBI_DEV3_FLASH_CONF_ST_OFFS) +#define EBI_DEV3_DMA_CONFIG1_OFFS 0x00000318 +#define EBI_DEV3_DMA_CONFIG1(base) ((base) + EBI_DEV3_DMA_CONFIG1_OFFS) +#define EBI_DEV3_DMA_CONFIG2_OFFS 0x0000031C +#define EBI_DEV3_DMA_CONFIG2(base) ((base) + EBI_DEV3_DMA_CONFIG2_OFFS) +#define EBI_DEV3_DMA_ECC_CTRL_OFFS 0x00000320 +#define EBI_DEV3_DMA_ECC_CTRL(base) ((base) + EBI_DEV3_DMA_ECC_CTRL_OFFS) +#define EBI_DEV3_TIM1_RD1_OFFS 0x00000324 +#define EBI_DEV3_TIM1_RD1(base) ((base) + EBI_DEV3_TIM1_RD1_OFFS) +#define EBI_DEV3_TIM1_RD2_OFFS 0x00000328 +#define EBI_DEV3_TIM1_RD2(base) ((base) + EBI_DEV3_TIM1_RD2_OFFS) +#define EBI_DEV3_TIM1_WR1_OFFS 0x0000032C +#define EBI_DEV3_TIM1_WR1(base) ((base) + EBI_DEV3_TIM1_WR1_OFFS) +#define EBI_DEV3_TIM1_WR2_OFFS 0x00000330 +#define EBI_DEV3_TIM1_WR2(base) ((base) + EBI_DEV3_TIM1_WR2_OFFS) +#define EBI_DEV3_TIM_EXT_OFFS 0x00000334 +#define EBI_DEV3_TIM_EXT(base) ((base) + EBI_DEV3_TIM_EXT_OFFS) +#define EBI_DEV3_TIM2_CFI_RD1_OFFS 0x00000338 +#define EBI_DEV3_TIM2_CFI_RD1(base) ((base) + EBI_DEV3_TIM2_CFI_RD1_OFFS) +#define EBI_DEV3_TIM2_CFI_RD2_OFFS 0x0000033C +#define EBI_DEV3_TIM2_CFI_RD2(base) ((base) + EBI_DEV3_TIM2_CFI_RD2_OFFS) +#define EBI_DEV3_TIM3_DMA1_OFFS 0x00000340 +#define EBI_DEV3_TIM3_DMA1(base) ((base) + EBI_DEV3_TIM3_DMA1_OFFS) +#define EBI_DEV3_TIM3_DMA2_OFFS 0x00000344 +#define EBI_DEV3_TIM3_DMA2(base) ((base) + EBI_DEV3_TIM3_DMA2_OFFS) +#define EBI_DEV3_TIM4_UDMA1_OFFS 0x00000348 +#define EBI_DEV3_TIM4_UDMA1(base) ((base) + EBI_DEV3_TIM4_UDMA1_OFFS) +#define EBI_DEV3_TIM4_UDMA2_OFFS 0x0000034C +#define EBI_DEV3_TIM4_UDMA2(base) ((base) + EBI_DEV3_TIM4_UDMA2_OFFS) +#define EBI_DEV3_ACK_RM_CNT_OFFS 0x00000350 +#define EBI_DEV3_ACK_RM_CNT(base) ((base) + EBI_DEV3_ACK_RM_CNT_OFFS) +#define EBI_DEV4_DMA_EXT_ADDR_OFFS 0x00000400 +#define EBI_DEV4_DMA_EXT_ADDR(base) ((base) + EBI_DEV4_DMA_EXT_ADDR_OFFS) +#define EBI_DEV4_EXT_ACC_OFFS 0x00000404 +#define EBI_DEV4_EXT_ACC(base) ((base) + EBI_DEV4_EXT_ACC_OFFS) +#define EBI_DEV4_CONFIG1_OFFS 0x00000408 +#define EBI_DEV4_CONFIG1(base) ((base) + EBI_DEV4_CONFIG1_OFFS) +#define EBI_DEV4_CONFIG2_OFFS 0x0000040C +#define EBI_DEV4_CONFIG2(base) ((base) + EBI_DEV4_CONFIG2_OFFS) +#define EBI_DEV4_FIFO_CONFIG_OFFS 0x00000410 +#define EBI_DEV4_FIFO_CONFIG(base) ((base) + EBI_DEV4_FIFO_CONFIG_OFFS) +#define EBI_DEV4_FLASH_CONF_ST_OFFS 0x00000414 +#define EBI_DEV4_FLASH_CONF_ST(base) ((base) + EBI_DEV4_FLASH_CONF_ST_OFFS) +#define EBI_DEV4_DMA_CONFIG1_OFFS 0x00000418 +#define EBI_DEV4_DMA_CONFIG1(base) ((base) + EBI_DEV4_DMA_CONFIG1_OFFS) +#define EBI_DEV4_DMA_CONFIG2_OFFS 0x0000041C +#define EBI_DEV4_DMA_CONFIG2(base) ((base) + EBI_DEV4_DMA_CONFIG2_OFFS) +#define EBI_DEV4_DMA_ECC_CTRL_OFFS 0x00000420 +#define EBI_DEV4_DMA_ECC_CTRL(base) ((base) + EBI_DEV4_DMA_ECC_CTRL_OFFS) +#define EBI_DEV4_TIM1_RD1_OFFS 0x00000424 +#define EBI_DEV4_TIM1_RD1(base) ((base) + EBI_DEV4_TIM1_RD1_OFFS) +#define EBI_DEV4_TIM1_RD2_OFFS 0x00000428 +#define EBI_DEV4_TIM1_RD2(base) ((base) + EBI_DEV4_TIM1_RD2_OFFS) +#define EBI_DEV4_TIM1_WR1_OFFS 0x0000042C +#define EBI_DEV4_TIM1_WR1(base) ((base) + EBI_DEV4_TIM1_WR1_OFFS) +#define EBI_DEV4_TIM1_WR2_OFFS 0x00000430 +#define EBI_DEV4_TIM1_WR2(base) ((base) + EBI_DEV4_TIM1_WR2_OFFS) +#define EBI_DEV4_TIM_EXT_OFFS 0x00000434 +#define EBI_DEV4_TIM_EXT(base) ((base) + EBI_DEV4_TIM_EXT_OFFS) +#define EBI_DEV4_TIM2_CFI_RD1_OFFS 0x00000438 +#define EBI_DEV4_TIM2_CFI_RD1(base) ((base) + EBI_DEV4_TIM2_CFI_RD1_OFFS) +#define EBI_DEV4_TIM2_CFI_RD2_OFFS 0x0000043C +#define EBI_DEV4_TIM2_CFI_RD2(base) ((base) + EBI_DEV4_TIM2_CFI_RD2_OFFS) +#define EBI_DEV4_TIM3_DMA1_OFFS 0x00000440 +#define EBI_DEV4_TIM3_DMA1(base) ((base) + EBI_DEV4_TIM3_DMA1_OFFS) +#define EBI_DEV4_TIM3_DMA2_OFFS 0x00000444 +#define EBI_DEV4_TIM3_DMA2(base) ((base) + EBI_DEV4_TIM3_DMA2_OFFS) +#define EBI_DEV4_TIM4_UDMA1_OFFS 0x00000448 +#define EBI_DEV4_TIM4_UDMA1(base) ((base) + EBI_DEV4_TIM4_UDMA1_OFFS) +#define EBI_DEV4_TIM4_UDMA2_OFFS 0x0000044C +#define EBI_DEV4_TIM4_UDMA2(base) ((base) + EBI_DEV4_TIM4_UDMA2_OFFS) +#define EBI_DEV4_ACK_RM_CNT_OFFS 0x00000450 +#define EBI_DEV4_ACK_RM_CNT(base) ((base) + EBI_DEV4_ACK_RM_CNT_OFFS) +#define EBI_INTERLEAVE_CNT_OFFS 0x00000900 +#define EBI_INTERLEAVE_CNT(base) ((base) + EBI_INTERLEAVE_CNT_OFFS) +#define EBI_CNT_FL_PROGR_OFFS 0x00000904 +#define EBI_CNT_FL_PROGR(base) ((base) + EBI_CNT_FL_PROGR_OFFS) +#define EBI_CNT_EXT_PAGE_SZ_OFFS 0x0000090C +#define EBI_CNT_EXT_PAGE_SZ(base) ((base) + EBI_CNT_EXT_PAGE_SZ_OFFS) +#define EBI_CNT_WAIT_RDY_OFFS 0x00000914 +#define EBI_CNT_WAIT_RDY(base) ((base) + EBI_CNT_WAIT_RDY_OFFS) +#define EBI_CNT_ACK_OFFS 0x00000918 +#define EBI_CNT_ACK(base) ((base) + EBI_CNT_ACK_OFFS) +#define EBI_GENIO1_CONFIG1_OFFS 0x00000A00 +#define EBI_GENIO1_CONFIG1(base) ((base) + EBI_GENIO1_CONFIG1_OFFS) +#define EBI_GENIO1_CONFIG2_OFFS 0x00000A04 +#define EBI_GENIO1_CONFIG2(base) ((base) + EBI_GENIO1_CONFIG2_OFFS) +#define EBI_GENIO1_CONFIG3_OFFS 0x00000A08 +#define EBI_GENIO1_CONFIG3(base) ((base) + EBI_GENIO1_CONFIG3_OFFS) +#define EBI_GENIO2_CONFIG1_OFFS 0x00000A10 +#define EBI_GENIO2_CONFIG1(base) ((base) + EBI_GENIO2_CONFIG1_OFFS) +#define EBI_GENIO2_CONFIG2_OFFS 0x00000A14 +#define EBI_GENIO2_CONFIG2(base) ((base) + EBI_GENIO2_CONFIG2_OFFS) +#define EBI_GENIO2_CONFIG3_OFFS 0x00000A18 +#define EBI_GENIO2_CONFIG3(base) ((base) + EBI_GENIO2_CONFIG3_OFFS) +#define EBI_GENIO3_CONFIG1_OFFS 0x00000A20 +#define EBI_GENIO3_CONFIG1(base) ((base) + EBI_GENIO3_CONFIG1_OFFS) +#define EBI_GENIO3_CONFIG2_OFFS 0x00000A24 +#define EBI_GENIO3_CONFIG2(base) ((base) + EBI_GENIO3_CONFIG2_OFFS) +#define EBI_GENIO3_CONFIG3_OFFS 0x00000A28 +#define EBI_GENIO3_CONFIG3(base) ((base) + EBI_GENIO3_CONFIG3_OFFS) +#define EBI_GENIO4_CONFIG1_OFFS 0x00000A30 +#define EBI_GENIO4_CONFIG1(base) ((base) + EBI_GENIO4_CONFIG1_OFFS) +#define EBI_GENIO4_CONFIG2_OFFS 0x00000A34 +#define EBI_GENIO4_CONFIG2(base) ((base) + EBI_GENIO4_CONFIG2_OFFS) +#define EBI_GENIO4_CONFIG3_OFFS 0x00000A38 +#define EBI_GENIO4_CONFIG3(base) ((base) + EBI_GENIO4_CONFIG3_OFFS) +#define EBI_GENIO5_CONFIG1_OFFS 0x00000A40 +#define EBI_GENIO5_CONFIG1(base) ((base) + EBI_GENIO5_CONFIG1_OFFS) +#define EBI_GENIO5_CONFIG2_OFFS 0x00000A44 +#define EBI_GENIO5_CONFIG2(base) ((base) + EBI_GENIO5_CONFIG2_OFFS) +#define EBI_GENIO5_CONFIG3_OFFS 0x00000A48 +#define EBI_GENIO5_CONFIG3(base) ((base) + EBI_GENIO5_CONFIG3_OFFS) + +#endif diff --git a/board/micronas/vct/vctv/reg_dcgu.h b/board/micronas/vct/vctv/reg_dcgu.h new file mode 100644 index 0000000..6f5c968 --- /dev/null +++ b/board/micronas/vct/vctv/reg_dcgu.h @@ -0,0 +1,25 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define DCGU_BASE 0x0004c000 +#define DCGU_EN_WDT_RESET_OFFS 0x000000FC +#define DCGU_EN_WDT_RESET(base) ((base) + DCGU_EN_WDT_RESET_OFFS) + +/* The magic value to write in order to activate the WDT */ +#define DCGU_MAGIC_WDT 0x1909 diff --git a/board/micronas/vct/vctv/reg_ebi.h b/board/micronas/vct/vctv/reg_ebi.h new file mode 100644 index 0000000..82f345e --- /dev/null +++ b/board/micronas/vct/vctv/reg_ebi.h @@ -0,0 +1,290 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * Copyright (C) 2006 Micronas GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _REG_EBI_PLATINUMAVC_H_ +#define _REG_EBI_PLATINUMAVC_H_ + +#define EBI_BASE 0x00014000 + +/* Relative offsets of the register adresses */ + +#define EBI_CPU_IO_ACCS_OFFS 0x00000000 +#define EBI_CPU_IO_ACCS(base) ((base) + EBI_CPU_IO_ACCS_OFFS) +#define EBI_IO_ACCS_DATA_OFFS 0x00000004 +#define EBI_IO_ACCS_DATA(base) ((base) + EBI_IO_ACCS_DATA_OFFS) +#define EBI_CPU_IO_ACCS2_OFFS 0x00000008 +#define EBI_CPU_IO_ACCS2(base) ((base) + EBI_CPU_IO_ACCS2_OFFS) +#define EBI_IO_ACCS2_DATA_OFFS 0x0000000C +#define EBI_IO_ACCS2_DATA(base) ((base) + EBI_IO_ACCS2_DATA_OFFS) +#define EBI_CTRL_OFFS 0x00000010 +#define EBI_CTRL(base) ((base) + EBI_CTRL_OFFS) +#define EBI_IRQ_MASK_OFFS 0x00000018 +#define EBI_IRQ_MASK(base) ((base) + EBI_IRQ_MASK_OFFS) +#define EBI_IRQ_MASK2_OFFS 0x0000001C +#define EBI_IRQ_MASK2(base) ((base) + EBI_IRQ_MASK2_OFFS) +#define EBI_TAG1_SYS_ID_OFFS 0x00000030 +#define EBI_TAG1_SYS_ID(base) ((base) + EBI_TAG1_SYS_ID_OFFS) +#define EBI_TAG2_SYS_ID_OFFS 0x00000040 +#define EBI_TAG2_SYS_ID(base) ((base) + EBI_TAG2_SYS_ID_OFFS) +#define EBI_TAG3_SYS_ID_OFFS 0x00000050 +#define EBI_TAG3_SYS_ID(base) ((base) + EBI_TAG3_SYS_ID_OFFS) +#define EBI_TAG4_SYS_ID_OFFS 0x00000060 +#define EBI_TAG4_SYS_ID(base) ((base) + EBI_TAG4_SYS_ID_OFFS) +#define EBI_GEN_DMA_CTRL_OFFS 0x00000070 +#define EBI_GEN_DMA_CTRL(base) ((base) + EBI_GEN_DMA_CTRL_OFFS) +#define EBI_STATUS_OFFS 0x00000080 +#define EBI_STATUS(base) ((base) + EBI_STATUS_OFFS) +#define EBI_STATUS_DMA_CNT_OFFS 0x00000084 +#define EBI_STATUS_DMA_CNT(base) ((base) + EBI_STATUS_DMA_CNT_OFFS) +#define EBI_SIG_LEVEL_OFFS 0x00000088 +#define EBI_SIG_LEVEL(base) ((base) + EBI_SIG_LEVEL_OFFS) +#define EBI_CTRL_SIG_ACTLV_OFFS 0x0000008C +#define EBI_CTRL_SIG_ACTLV(base) ((base) + EBI_CTRL_SIG_ACTLV_OFFS) +#define EBI_CRC_GEN_OFFS 0x00000090 +#define EBI_CRC_GEN(base) ((base) + EBI_CRC_GEN_OFFS) +#define EBI_EXT_ADDR_OFFS 0x000000A0 +#define EBI_EXT_ADDR(base) ((base) + EBI_EXT_ADDR_OFFS) +#define EBI_IRQ_STATUS_OFFS 0x000000B0 +#define EBI_IRQ_STATUS(base) ((base) + EBI_IRQ_STATUS_OFFS) +#define EBI_IRQ_STATUS2_OFFS 0x000000B4 +#define EBI_IRQ_STATUS2(base) ((base) + EBI_IRQ_STATUS2_OFFS) +#define EBI_EXT_MASTER_SRAM_HIGH_OFFS 0x000000C0 +#define EBI_EXT_MASTER_SRAM_HIGH(base) ((base) + EBI_EXT_MASTER_SRAM_HIGH_OFFS) +#define EBI_EXT_MASTER_SRAM_LOW_OFFS 0x000000C4 +#define EBI_EXT_MASTER_SRAM_LOW(base) ((base) + EBI_EXT_MASTER_SRAM_LOW_OFFS) +#define EBI_ECC0_OFFS 0x000000D0 +#define EBI_ECC0(base) ((base) + EBI_ECC0_OFFS) +#define EBI_ECC1_OFFS 0x000000D4 +#define EBI_ECC1(base) ((base) + EBI_ECC1_OFFS) +#define EBI_ECC2_OFFS 0x000000D8 +#define EBI_ECC2(base) ((base) + EBI_ECC2_OFFS) +#define EBI_ECC3_OFFS 0x000000DC +#define EBI_ECC3(base) ((base) + EBI_ECC3_OFFS) +#define EBI_DEV1_DMA_EXT_ADDR_OFFS 0x00000100 +#define EBI_DEV1_DMA_EXT_ADDR(base) ((base) + EBI_DEV1_DMA_EXT_ADDR_OFFS) +#define EBI_DEV1_EXT_ACC_OFFS 0x00000104 +#define EBI_DEV1_EXT_ACC(base) ((base) + EBI_DEV1_EXT_ACC_OFFS) +#define EBI_DEV1_CONFIG1_OFFS 0x00000108 +#define EBI_DEV1_CONFIG1(base) ((base) + EBI_DEV1_CONFIG1_OFFS) +#define EBI_DEV1_CONFIG2_OFFS 0x0000010C +#define EBI_DEV1_CONFIG2(base) ((base) + EBI_DEV1_CONFIG2_OFFS) +#define EBI_DEV1_FIFO_CONFIG_OFFS 0x00000110 +#define EBI_DEV1_FIFO_CONFIG(base) ((base) + EBI_DEV1_FIFO_CONFIG_OFFS) +#define EBI_DEV1_FLASH_CONF_ST_OFFS 0x00000114 +#define EBI_DEV1_FLASH_CONF_ST(base) ((base) + EBI_DEV1_FLASH_CONF_ST_OFFS) +#define EBI_DEV1_DMA_CONFIG1_OFFS 0x00000118 +#define EBI_DEV1_DMA_CONFIG1(base) ((base) + EBI_DEV1_DMA_CONFIG1_OFFS) +#define EBI_DEV1_DMA_CONFIG2_OFFS 0x0000011C +#define EBI_DEV1_DMA_CONFIG2(base) ((base) + EBI_DEV1_DMA_CONFIG2_OFFS) +#define EBI_DEV1_DMA_ECC_CTRL_OFFS 0x00000120 +#define EBI_DEV1_DMA_ECC_CTRL(base) ((base) + EBI_DEV1_DMA_ECC_CTRL_OFFS) +#define EBI_DEV1_TIM1_RD1_OFFS 0x00000124 +#define EBI_DEV1_TIM1_RD1(base) ((base) + EBI_DEV1_TIM1_RD1_OFFS) +#define EBI_DEV1_TIM1_RD2_OFFS 0x00000128 +#define EBI_DEV1_TIM1_RD2(base) ((base) + EBI_DEV1_TIM1_RD2_OFFS) +#define EBI_DEV1_TIM1_WR1_OFFS 0x0000012C +#define EBI_DEV1_TIM1_WR1(base) ((base) + EBI_DEV1_TIM1_WR1_OFFS) +#define EBI_DEV1_TIM1_WR2_OFFS 0x00000130 +#define EBI_DEV1_TIM1_WR2(base) ((base) + EBI_DEV1_TIM1_WR2_OFFS) +#define EBI_DEV1_TIM_EXT_OFFS 0x00000134 +#define EBI_DEV1_TIM_EXT(base) ((base) + EBI_DEV1_TIM_EXT_OFFS) +#define EBI_DEV1_TIM2_CFI_RD1_OFFS 0x00000138 +#define EBI_DEV1_TIM2_CFI_RD1(base) ((base) + EBI_DEV1_TIM2_CFI_RD1_OFFS) +#define EBI_DEV1_TIM2_CFI_RD2_OFFS 0x0000013C +#define EBI_DEV1_TIM2_CFI_RD2(base) ((base) + EBI_DEV1_TIM2_CFI_RD2_OFFS) +#define EBI_DEV1_TIM3_DMA1_OFFS 0x00000140 +#define EBI_DEV1_TIM3_DMA1(base) ((base) + EBI_DEV1_TIM3_DMA1_OFFS) +#define EBI_DEV1_TIM3_DMA2_OFFS 0x00000144 +#define EBI_DEV1_TIM3_DMA2(base) ((base) + EBI_DEV1_TIM3_DMA2_OFFS) +#define EBI_DEV1_TIM4_UDMA1_OFFS 0x00000148 +#define EBI_DEV1_TIM4_UDMA1(base) ((base) + EBI_DEV1_TIM4_UDMA1_OFFS) +#define EBI_DEV1_TIM4_UDMA2_OFFS 0x0000014C +#define EBI_DEV1_TIM4_UDMA2(base) ((base) + EBI_DEV1_TIM4_UDMA2_OFFS) +#define EBI_DEV1_ACK_RM_CNT_OFFS 0x00000150 +#define EBI_DEV1_ACK_RM_CNT(base) ((base) + EBI_DEV1_ACK_RM_CNT_OFFS) +#define EBI_DEV2_DMA_EXT_ADDR_OFFS 0x00000200 +#define EBI_DEV2_DMA_EXT_ADDR(base) ((base) + EBI_DEV2_DMA_EXT_ADDR_OFFS) +#define EBI_DEV2_EXT_ACC_OFFS 0x00000204 +#define EBI_DEV2_EXT_ACC(base) ((base) + EBI_DEV2_EXT_ACC_OFFS) +#define EBI_DEV2_CONFIG1_OFFS 0x00000208 +#define EBI_DEV2_CONFIG1(base) ((base) + EBI_DEV2_CONFIG1_OFFS) +#define EBI_DEV2_CONFIG2_OFFS 0x0000020C +#define EBI_DEV2_CONFIG2(base) ((base) + EBI_DEV2_CONFIG2_OFFS) +#define EBI_DEV2_FIFO_CONFIG_OFFS 0x00000210 +#define EBI_DEV2_FIFO_CONFIG(base) ((base) + EBI_DEV2_FIFO_CONFIG_OFFS) +#define EBI_DEV2_FLASH_CONF_ST_OFFS 0x00000214 +#define EBI_DEV2_FLASH_CONF_ST(base) ((base) + EBI_DEV2_FLASH_CONF_ST_OFFS) +#define EBI_DEV2_DMA_CONFIG1_OFFS 0x00000218 +#define EBI_DEV2_DMA_CONFIG1(base) ((base) + EBI_DEV2_DMA_CONFIG1_OFFS) +#define EBI_DEV2_DMA_CONFIG2_OFFS 0x0000021C +#define EBI_DEV2_DMA_CONFIG2(base) ((base) + EBI_DEV2_DMA_CONFIG2_OFFS) +#define EBI_DEV2_DMA_ECC_CTRL_OFFS 0x00000220 +#define EBI_DEV2_DMA_ECC_CTRL(base) ((base) + EBI_DEV2_DMA_ECC_CTRL_OFFS) +#define EBI_DEV2_TIM1_RD1_OFFS 0x00000224 +#define EBI_DEV2_TIM1_RD1(base) ((base) + EBI_DEV2_TIM1_RD1_OFFS) +#define EBI_DEV2_TIM1_RD2_OFFS 0x00000228 +#define EBI_DEV2_TIM1_RD2(base) ((base) + EBI_DEV2_TIM1_RD2_OFFS) +#define EBI_DEV2_TIM1_WR1_OFFS 0x0000022C +#define EBI_DEV2_TIM1_WR1(base) ((base) + EBI_DEV2_TIM1_WR1_OFFS) +#define EBI_DEV2_TIM1_WR2_OFFS 0x00000230 +#define EBI_DEV2_TIM1_WR2(base) ((base) + EBI_DEV2_TIM1_WR2_OFFS) +#define EBI_DEV2_TIM_EXT_OFFS 0x00000234 +#define EBI_DEV2_TIM_EXT(base) ((base) + EBI_DEV2_TIM_EXT_OFFS) +#define EBI_DEV2_TIM2_CFI_RD1_OFFS 0x00000238 +#define EBI_DEV2_TIM2_CFI_RD1(base) ((base) + EBI_DEV2_TIM2_CFI_RD1_OFFS) +#define EBI_DEV2_TIM2_CFI_RD2_OFFS 0x0000023C +#define EBI_DEV2_TIM2_CFI_RD2(base) ((base) + EBI_DEV2_TIM2_CFI_RD2_OFFS) +#define EBI_DEV2_TIM3_DMA1_OFFS 0x00000240 +#define EBI_DEV2_TIM3_DMA1(base) ((base) + EBI_DEV2_TIM3_DMA1_OFFS) +#define EBI_DEV2_TIM3_DMA2_OFFS 0x00000244 +#define EBI_DEV2_TIM3_DMA2(base) ((base) + EBI_DEV2_TIM3_DMA2_OFFS) +#define EBI_DEV2_TIM4_UDMA1_OFFS 0x00000248 +#define EBI_DEV2_TIM4_UDMA1(base) ((base) + EBI_DEV2_TIM4_UDMA1_OFFS) +#define EBI_DEV2_TIM4_UDMA2_OFFS 0x0000024C +#define EBI_DEV2_TIM4_UDMA2(base) ((base) + EBI_DEV2_TIM4_UDMA2_OFFS) +#define EBI_DEV2_ACK_RM_CNT_OFFS 0x00000250 +#define EBI_DEV2_ACK_RM_CNT(base) ((base) + EBI_DEV2_ACK_RM_CNT_OFFS) +#define EBI_DEV3_DMA_EXT_ADDR_OFFS 0x00000300 +#define EBI_DEV3_DMA_EXT_ADDR(base) ((base) + EBI_DEV3_DMA_EXT_ADDR_OFFS) +#define EBI_DEV3_EXT_ACC_OFFS 0x00000304 +#define EBI_DEV3_EXT_ACC(base) ((base) + EBI_DEV3_EXT_ACC_OFFS) +#define EBI_DEV3_CONFIG1_OFFS 0x00000308 +#define EBI_DEV3_CONFIG1(base) ((base) + EBI_DEV3_CONFIG1_OFFS) +#define EBI_DEV3_CONFIG2_OFFS 0x0000030C +#define EBI_DEV3_CONFIG2(base) ((base) + EBI_DEV3_CONFIG2_OFFS) +#define EBI_DEV3_FIFO_CONFIG_OFFS 0x00000310 +#define EBI_DEV3_FIFO_CONFIG(base) ((base) + EBI_DEV3_FIFO_CONFIG_OFFS) +#define EBI_DEV3_FLASH_CONF_ST_OFFS 0x00000314 +#define EBI_DEV3_FLASH_CONF_ST(base) ((base) + EBI_DEV3_FLASH_CONF_ST_OFFS) +#define EBI_DEV3_DMA_CONFIG1_OFFS 0x00000318 +#define EBI_DEV3_DMA_CONFIG1(base) ((base) + EBI_DEV3_DMA_CONFIG1_OFFS) +#define EBI_DEV3_DMA_CONFIG2_OFFS 0x0000031C +#define EBI_DEV3_DMA_CONFIG2(base) ((base) + EBI_DEV3_DMA_CONFIG2_OFFS) +#define EBI_DEV3_DMA_ECC_CTRL_OFFS 0x00000320 +#define EBI_DEV3_DMA_ECC_CTRL(base) ((base) + EBI_DEV3_DMA_ECC_CTRL_OFFS) +#define EBI_DEV3_TIM1_RD1_OFFS 0x00000324 +#define EBI_DEV3_TIM1_RD1(base) ((base) + EBI_DEV3_TIM1_RD1_OFFS) +#define EBI_DEV3_TIM1_RD2_OFFS 0x00000328 +#define EBI_DEV3_TIM1_RD2(base) ((base) + EBI_DEV3_TIM1_RD2_OFFS) +#define EBI_DEV3_TIM1_WR1_OFFS 0x0000032C +#define EBI_DEV3_TIM1_WR1(base) ((base) + EBI_DEV3_TIM1_WR1_OFFS) +#define EBI_DEV3_TIM1_WR2_OFFS 0x00000330 +#define EBI_DEV3_TIM1_WR2(base) ((base) + EBI_DEV3_TIM1_WR2_OFFS) +#define EBI_DEV3_TIM_EXT_OFFS 0x00000334 +#define EBI_DEV3_TIM_EXT(base) ((base) + EBI_DEV3_TIM_EXT_OFFS) +#define EBI_DEV3_TIM2_CFI_RD1_OFFS 0x00000338 +#define EBI_DEV3_TIM2_CFI_RD1(base) ((base) + EBI_DEV3_TIM2_CFI_RD1_OFFS) +#define EBI_DEV3_TIM2_CFI_RD2_OFFS 0x0000033C +#define EBI_DEV3_TIM2_CFI_RD2(base) ((base) + EBI_DEV3_TIM2_CFI_RD2_OFFS) +#define EBI_DEV3_TIM3_DMA1_OFFS 0x00000340 +#define EBI_DEV3_TIM3_DMA1(base) ((base) + EBI_DEV3_TIM3_DMA1_OFFS) +#define EBI_DEV3_TIM3_DMA2_OFFS 0x00000344 +#define EBI_DEV3_TIM3_DMA2(base) ((base) + EBI_DEV3_TIM3_DMA2_OFFS) +#define EBI_DEV3_TIM4_UDMA1_OFFS 0x00000348 +#define EBI_DEV3_TIM4_UDMA1(base) ((base) + EBI_DEV3_TIM4_UDMA1_OFFS) +#define EBI_DEV3_TIM4_UDMA2_OFFS 0x0000034C +#define EBI_DEV3_TIM4_UDMA2(base) ((base) + EBI_DEV3_TIM4_UDMA2_OFFS) +#define EBI_DEV3_ACK_RM_CNT_OFFS 0x00000350 +#define EBI_DEV3_ACK_RM_CNT(base) ((base) + EBI_DEV3_ACK_RM_CNT_OFFS) +#define EBI_DEV4_DMA_EXT_ADDR_OFFS 0x00000400 +#define EBI_DEV4_DMA_EXT_ADDR(base) ((base) + EBI_DEV4_DMA_EXT_ADDR_OFFS) +#define EBI_DEV4_EXT_ACC_OFFS 0x00000404 +#define EBI_DEV4_EXT_ACC(base) ((base) + EBI_DEV4_EXT_ACC_OFFS) +#define EBI_DEV4_CONFIG1_OFFS 0x00000408 +#define EBI_DEV4_CONFIG1(base) ((base) + EBI_DEV4_CONFIG1_OFFS) +#define EBI_DEV4_CONFIG2_OFFS 0x0000040C +#define EBI_DEV4_CONFIG2(base) ((base) + EBI_DEV4_CONFIG2_OFFS) +#define EBI_DEV4_FIFO_CONFIG_OFFS 0x00000410 +#define EBI_DEV4_FIFO_CONFIG(base) ((base) + EBI_DEV4_FIFO_CONFIG_OFFS) +#define EBI_DEV4_FLASH_CONF_ST_OFFS 0x00000414 +#define EBI_DEV4_FLASH_CONF_ST(base) ((base) + EBI_DEV4_FLASH_CONF_ST_OFFS) +#define EBI_DEV4_DMA_CONFIG1_OFFS 0x00000418 +#define EBI_DEV4_DMA_CONFIG1(base) ((base) + EBI_DEV4_DMA_CONFIG1_OFFS) +#define EBI_DEV4_DMA_CONFIG2_OFFS 0x0000041C +#define EBI_DEV4_DMA_CONFIG2(base) ((base) + EBI_DEV4_DMA_CONFIG2_OFFS) +#define EBI_DEV4_DMA_ECC_CTRL_OFFS 0x00000420 +#define EBI_DEV4_DMA_ECC_CTRL(base) ((base) + EBI_DEV4_DMA_ECC_CTRL_OFFS) +#define EBI_DEV4_TIM1_RD1_OFFS 0x00000424 +#define EBI_DEV4_TIM1_RD1(base) ((base) + EBI_DEV4_TIM1_RD1_OFFS) +#define EBI_DEV4_TIM1_RD2_OFFS 0x00000428 +#define EBI_DEV4_TIM1_RD2(base) ((base) + EBI_DEV4_TIM1_RD2_OFFS) +#define EBI_DEV4_TIM1_WR1_OFFS 0x0000042C +#define EBI_DEV4_TIM1_WR1(base) ((base) + EBI_DEV4_TIM1_WR1_OFFS) +#define EBI_DEV4_TIM1_WR2_OFFS 0x00000430 +#define EBI_DEV4_TIM1_WR2(base) ((base) + EBI_DEV4_TIM1_WR2_OFFS) +#define EBI_DEV4_TIM_EXT_OFFS 0x00000434 +#define EBI_DEV4_TIM_EXT(base) ((base) + EBI_DEV4_TIM_EXT_OFFS) +#define EBI_DEV4_TIM2_CFI_RD1_OFFS 0x00000438 +#define EBI_DEV4_TIM2_CFI_RD1(base) ((base) + EBI_DEV4_TIM2_CFI_RD1_OFFS) +#define EBI_DEV4_TIM2_CFI_RD2_OFFS 0x0000043C +#define EBI_DEV4_TIM2_CFI_RD2(base) ((base) + EBI_DEV4_TIM2_CFI_RD2_OFFS) +#define EBI_DEV4_TIM3_DMA1_OFFS 0x00000440 +#define EBI_DEV4_TIM3_DMA1(base) ((base) + EBI_DEV4_TIM3_DMA1_OFFS) +#define EBI_DEV4_TIM3_DMA2_OFFS 0x00000444 +#define EBI_DEV4_TIM3_DMA2(base) ((base) + EBI_DEV4_TIM3_DMA2_OFFS) +#define EBI_DEV4_TIM4_UDMA1_OFFS 0x00000448 +#define EBI_DEV4_TIM4_UDMA1(base) ((base) + EBI_DEV4_TIM4_UDMA1_OFFS) +#define EBI_DEV4_TIM4_UDMA2_OFFS 0x0000044C +#define EBI_DEV4_TIM4_UDMA2(base) ((base) + EBI_DEV4_TIM4_UDMA2_OFFS) +#define EBI_DEV4_ACK_RM_CNT_OFFS 0x00000450 +#define EBI_DEV4_ACK_RM_CNT(base) ((base) + EBI_DEV4_ACK_RM_CNT_OFFS) +#define EBI_INTERLEAVE_CNT_OFFS 0x00000900 +#define EBI_INTERLEAVE_CNT(base) ((base) + EBI_INTERLEAVE_CNT_OFFS) +#define EBI_CNT_FL_PROGR_OFFS 0x00000904 +#define EBI_CNT_FL_PROGR(base) ((base) + EBI_CNT_FL_PROGR_OFFS) +#define EBI_CNT_EXT_PAGE_SZ_OFFS 0x0000090C +#define EBI_CNT_EXT_PAGE_SZ(base) ((base) + EBI_CNT_EXT_PAGE_SZ_OFFS) +#define EBI_CNT_WAIT_RDY_OFFS 0x00000914 +#define EBI_CNT_WAIT_RDY(base) ((base) + EBI_CNT_WAIT_RDY_OFFS) +#define EBI_CNT_ACK_OFFS 0x00000918 +#define EBI_CNT_ACK(base) ((base) + EBI_CNT_ACK_OFFS) +#define EBI_GENIO1_CONFIG1_OFFS 0x00000A00 +#define EBI_GENIO1_CONFIG1(base) ((base) + EBI_GENIO1_CONFIG1_OFFS) +#define EBI_GENIO1_CONFIG2_OFFS 0x00000A04 +#define EBI_GENIO1_CONFIG2(base) ((base) + EBI_GENIO1_CONFIG2_OFFS) +#define EBI_GENIO1_CONFIG3_OFFS 0x00000A08 +#define EBI_GENIO1_CONFIG3(base) ((base) + EBI_GENIO1_CONFIG3_OFFS) +#define EBI_GENIO2_CONFIG1_OFFS 0x00000A10 +#define EBI_GENIO2_CONFIG1(base) ((base) + EBI_GENIO2_CONFIG1_OFFS) +#define EBI_GENIO2_CONFIG2_OFFS 0x00000A14 +#define EBI_GENIO2_CONFIG2(base) ((base) + EBI_GENIO2_CONFIG2_OFFS) +#define EBI_GENIO2_CONFIG3_OFFS 0x00000A18 +#define EBI_GENIO2_CONFIG3(base) ((base) + EBI_GENIO2_CONFIG3_OFFS) +#define EBI_GENIO3_CONFIG1_OFFS 0x00000A20 +#define EBI_GENIO3_CONFIG1(base) ((base) + EBI_GENIO3_CONFIG1_OFFS) +#define EBI_GENIO3_CONFIG2_OFFS 0x00000A24 +#define EBI_GENIO3_CONFIG2(base) ((base) + EBI_GENIO3_CONFIG2_OFFS) +#define EBI_GENIO3_CONFIG3_OFFS 0x00000A28 +#define EBI_GENIO3_CONFIG3(base) ((base) + EBI_GENIO3_CONFIG3_OFFS) +#define EBI_GENIO4_CONFIG1_OFFS 0x00000A30 +#define EBI_GENIO4_CONFIG1(base) ((base) + EBI_GENIO4_CONFIG1_OFFS) +#define EBI_GENIO4_CONFIG2_OFFS 0x00000A34 +#define EBI_GENIO4_CONFIG2(base) ((base) + EBI_GENIO4_CONFIG2_OFFS) +#define EBI_GENIO4_CONFIG3_OFFS 0x00000A38 +#define EBI_GENIO4_CONFIG3(base) ((base) + EBI_GENIO4_CONFIG3_OFFS) +#define EBI_GENIO5_CONFIG1_OFFS 0x00000A40 +#define EBI_GENIO5_CONFIG1(base) ((base) + EBI_GENIO5_CONFIG1_OFFS) +#define EBI_GENIO5_CONFIG2_OFFS 0x00000A44 +#define EBI_GENIO5_CONFIG2(base) ((base) + EBI_GENIO5_CONFIG2_OFFS) +#define EBI_GENIO5_CONFIG3_OFFS 0x00000A48 +#define EBI_GENIO5_CONFIG3(base) ((base) + EBI_GENIO5_CONFIG3_OFFS) + +#endif diff --git a/board/micronas/vct/vctv/reg_gpio.h b/board/micronas/vct/vctv/reg_gpio.h new file mode 100644 index 0000000..24eb8e9 --- /dev/null +++ b/board/micronas/vct/vctv/reg_gpio.h @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define GPIO1_BASE 0x00044000 +#define GPIO2_BASE 0x00048000 + +/* Instances */ +#define GPIO_INSTANCES 2 + +/* Relative offsets of the register adresses */ +#define GPIO_SWPORTA_DR_OFFS 0x00000000 +#define GPIO_SWPORTA_DR(base) ((base) + GPIO_SWPORTA_DR_OFFS) +#define GPIO_SWPORTA_DDR_OFFS 0x00000004 +#define GPIO_SWPORTA_DDR(base) ((base) + GPIO_SWPORTA_DDR_OFFS) +#define GPIO_EXT_PORTA_OFFS 0x00000050 +#define GPIO_EXT_PORTA(base) ((base) + GPIO_EXT_PORTA_OFFS) diff --git a/board/micronas/vct/vctv/reg_wdt.h b/board/micronas/vct/vctv/reg_wdt.h new file mode 100644 index 0000000..04842e5 --- /dev/null +++ b/board/micronas/vct/vctv/reg_wdt.h @@ -0,0 +1,24 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define WDT_BASE 0x00040000 +#define WDT_CR_OFFS 0x00000000 +#define WDT_CR(base) ((base) + WDT_CR_OFFS) +#define WDT_TORR_OFFS 0x00000004 +#define WDT_TORR(base) ((base) + WDT_TORR_OFFS) diff --git a/include/configs/vct.h b/include/configs/vct.h new file mode 100644 index 0000000..5ef88ec --- /dev/null +++ b/include/configs/vct.h @@ -0,0 +1,310 @@ +/* + * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This file contains the configuration parameters for the VCT board + * family: + * + * vct_premium + * vct_premium_small + * vct_premium_onenand + * vct_premium_onenand_small + * vct_platinum + * vct_platinum_small + * vct_platinum_onenand + * vct_platinum_onenand_small + * vct_platinumavc + * vct_platinumavc_small + * vct_platinumavc_onenand + * vct_platinumavc_onenand_small + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MIPS32 /* MIPS 4Kc CPU core */ +#define CPU_CLOCK_RATE 324000000 /* Clock for the MIPS core */ +#define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE / 2) +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_SKIP_LOWLEVEL_INIT /* SDRAM is initialized by the bootstrap code */ + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#define CONFIG_SYS_MONITOR_LEN (256 << 10) +#define CONFIG_STACKSIZE (256 << 10) +#define CONFIG_SYS_MALLOC_LEN (1 << 20) +#define CONFIG_SYS_BOOTPARAMS_LEN (128 << 10) +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +#if !defined(CONFIG_VCT_NAND) && !defined(CONFIG_VCT_ONENAND) +#define CONFIG_VCT_NOR +#else +#define CONFIG_SYS_NO_FLASH +#endif + +/* + * UART + */ +#define CONFIG_VCT_SERIAL +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * SDRAM + */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_MBYTES_SDRAM 128 +#define CONFIG_SYS_MEMTEST_START 0x80200000 +#define CONFIG_SYS_MEMTEST_END 0x80400000 +#define CONFIG_SYS_LOAD_ADDR 0x80400000 /* default load address */ + +#if defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM) +/* + * SMSC91C11x Network Card + */ +#define CONFIG_DRIVER_SMC911X +#define CONFIG_DRIVER_SMC911X_BASE 0x00000000 +#define CONFIG_DRIVER_SMC911X_32_BIT +#define CONFIG_NET_RETRY_COUNT 20 +#endif + +/* + * Commands + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C + +/* + * Only Premium/Platinum have ethernet support right now + */ +#if defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM) +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#else +#undef CONFIG_CMD_NET +#endif + +#if !defined(CONFIG_VCT_NOR) +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#endif + +#if defined(CONFIG_VCT_NAND) +#define CONFIG_CMD_NAND +#endif + +#if defined(CONFIG_VCT_ONENAND) +#define CONFIG_CMD_ONENAND +#endif + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_SUBNETMASK + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "VCT# " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ +#define CONFIG_CMDLINE_EDITING /* add command line history */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/ + +/* + * FLASH and environment organization + */ +#if defined(CONFIG_VCT_NOR) +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_FLASH_NOT_MEM_MAPPED + +/* + * We need special accessor functions for the CFI FLASH driver. This + * can be enabled via the CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS option. + */ +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS + +/* + * For the non-memory-mapped NOR FLASH, we need to define the + * NOR FLASH area. This can't be detected via the addr2info() + * function, since we check for flash access in the very early + * U-Boot code, before the NOR FLASH is detected. + */ +#define CONFIG_FLASH_BASE 0xb0000000 +#define CONFIG_FLASH_END 0xbfffffff + +/* + * CFI driver settings + */ +#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ +#define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CONFIG_SYS_FLASH_CFI_AMD_RESET 1 /* Use AMD (Spansion) reset cmd */ +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT /* no byte writes on IXP4xx */ + +#define CONFIG_SYS_FLASH_BASE 0xb0000000 +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#ifdef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#endif /* CONFIG_ENV_IS_IN_FLASH */ +#endif /* CONFIG_VCT_NOR */ + +#if defined(CONFIG_VCT_ONENAND) +#define CONFIG_USE_ONENAND_BOARD_INIT +#define CONFIG_ENV_IS_IN_ONENAND +#define CONFIG_SYS_ONENAND_BASE 0x00000000 /* this is not real address */ +#define CONFIG_SYS_FLASH_BASE 0x00000000 +#define CONFIG_ENV_ADDR (128 << 10) /* after compr. U-Boot image */ +#define CONFIG_ENV_SIZE (128 << 10) /* erase size */ +#endif /* CONFIG_VCT_ONENAND */ + +/* + * Cache Configuration + */ +#define CONFIG_SYS_DCACHE_SIZE 16384 +#define CONFIG_SYS_ICACHE_SIZE 16384 +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* + * I2C/EEPROM + */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C /* I2C bit-banged */ + +#define CONFIG_SYS_I2C_SPEED 83000 /* 83 kHz is supposed to work */ +#define CONFIG_SYS_I2C_SLAVE 0x7f + +/* + * Software (bit-bang) I2C driver configuration + */ +#define CONFIG_SYS_GPIO_I2C_SCL 11 +#define CONFIG_SYS_GPIO_I2C_SDA 10 + +#ifndef __ASSEMBLY__ +int vct_gpio_dir(int pin, int dir); +void vct_gpio_set(int pin, int val); +int vct_gpio_get(int pin); +#endif + +#define I2C_INIT vct_gpio_dir(CONFIG_SYS_GPIO_I2C_SCL, 1) +#define I2C_ACTIVE vct_gpio_dir(CONFIG_SYS_GPIO_I2C_SDA, 1) +#define I2C_TRISTATE vct_gpio_dir(CONFIG_SYS_GPIO_I2C_SDA, 0) +#define I2C_READ vct_gpio_get(CONFIG_SYS_GPIO_I2C_SDA) +#define I2C_SDA(bit) vct_gpio_set(CONFIG_SYS_GPIO_I2C_SDA, bit) +#define I2C_SCL(bit) vct_gpio_set(CONFIG_SYS_GPIO_I2C_SCL, bit) +#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ + +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +/* CAT24WC32 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* Bytes of address */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* The Catalyst CAT24WC32 has */ + /* 32 byte page write mode using*/ + /* last 5 bits of the address */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ + +#define CONFIG_BOOTCOMMAND "run test3" +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ + +/* + * Needed for 64bit printf format + */ +#define CONFIG_SYS_64BIT_VSPRINTF 1 +#define CONFIG_SYS_64BIT_STRTOUL 1 + +/* + * UBI configuration + */ +#if defined(CONFIG_VCT_ONENAND) +#define CONFIG_SYS_USE_UBI +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_UBI +#define CONFIG_RBTREE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_JFFS2_CMDLINE + +#define MTDIDS_DEFAULT "onenand0=onenand" +#define MTDPARTS_DEFAULT "mtdparts=onenand:128k(u-boot)," \ + "128k(env)," \ + "20m(kernel)," \ + "-(rootfs)" +#endif + +/* + * We need a small, stripped down image to fit into the first 128k OneNAND + * erase block (gzipped). This image only needs basic commands for FLASH + * (NOR/OneNAND) usage and Linux kernel booting. + */ +#if defined(CONFIG_VCT_SMALL_IMAGE) +#undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_PING +#undef CONFIG_CMD_SNTP +#undef CONFIG_CMD_ELF +#undef CONFIG_CMD_CONSOLE +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_IRQ +#undef CONFIG_CMD_ITEST +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_REGINFO +#undef CONFIG_CMD_STRINGS +#undef CONFIG_CMD_TERMINAL +#undef CONFIG_CMD_ASKENV +#undef CONFIG_CMD_CRC32 +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADY +#undef CONFIG_CMD_BDI + +#undef CONFIG_DRIVER_SMC911X +#undef CONFIG_SOFT_I2C +#undef CONFIG_AUTOSCRIPT +#undef CONFIG_SYS_LONGHELP +#undef CONFIG_TIMESTAMP +#endif /* CONFIG_VCT_SMALL_IMAGE */ + +#endif /* __CONFIG_H */
Stefan Roese
