[PATCH v3 0/2] sunxi: add support for Tanix TX6
This series introduces Tanix TX6 TV box support based on Allwinner H6 SoC. First patch syncs H6 DT files from Linux 5.11-rc1 release and second one adds support for Tanix TX6 board.
Please take a look.
Best regards, Jernej
Changes from v2: - added OrangePi One Plus DT update in patch 1 - removed "# CONFIG_PSCI_RESET is not set" from config Changes from v1: - add missing tanix_tx6_defconfig
Jernej Skrabec (2): ARM: dts: sunxi: h6: Update DT files sunxi: Add support for Tanix TX6
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 70 +++- arch/arm/dts/sun50i-h6-cpu-opp.dtsi | 117 ++++++ arch/arm/dts/sun50i-h6-orangepi-lite2.dts | 71 +++- arch/arm/dts/sun50i-h6-orangepi-one-plus.dts | 41 +- arch/arm/dts/sun50i-h6-orangepi.dtsi | 72 +++- arch/arm/dts/sun50i-h6-pine-h64.dts | 102 +++-- arch/arm/dts/sun50i-h6-tanix-tx6.dts | 124 ++++++ arch/arm/dts/sun50i-h6.dtsi | 394 +++++++++++++++++-- board/sunxi/MAINTAINERS | 6 + configs/tanix_tx6_defconfig | 10 + 11 files changed, 936 insertions(+), 74 deletions(-) create mode 100644 arch/arm/dts/sun50i-h6-cpu-opp.dtsi create mode 100644 arch/arm/dts/sun50i-h6-tanix-tx6.dts create mode 100644 configs/tanix_tx6_defconfig
Updated H6 DT files are based on Linux 5.11-rc1 release.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 70 +++- arch/arm/dts/sun50i-h6-cpu-opp.dtsi | 117 ++++++ arch/arm/dts/sun50i-h6-orangepi-lite2.dts | 71 +++- arch/arm/dts/sun50i-h6-orangepi-one-plus.dts | 41 +- arch/arm/dts/sun50i-h6-orangepi.dtsi | 72 +++- arch/arm/dts/sun50i-h6-pine-h64.dts | 102 +++-- arch/arm/dts/sun50i-h6.dtsi | 394 +++++++++++++++++-- 7 files changed, 794 insertions(+), 73 deletions(-) create mode 100644 arch/arm/dts/sun50i-h6-cpu-opp.dtsi
diff --git a/arch/arm/dts/sun50i-h6-beelink-gs1.dts b/arch/arm/dts/sun50i-h6-beelink-gs1.dts index 0dc33c90dd60..7c9dbde645b5 100644 --- a/arch/arm/dts/sun50i-h6-beelink-gs1.dts +++ b/arch/arm/dts/sun50i-h6-beelink-gs1.dts @@ -1,11 +1,10 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) -/* - * Copyright (C) 2019 Clément Péron peron.clem@gmail.com - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2019 Clément Péron peron.clem@gmail.com
/dts-v1/;
#include "sun50i-h6.dtsi" +#include "sun50i-h6-cpu-opp.dtsi"
#include <dt-bindings/gpio/gpio.h>
@@ -25,6 +24,7 @@ connector { compatible = "hdmi-connector"; type = "a"; + ddc-en-gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */
port { hdmi_con_in: endpoint { @@ -33,6 +33,13 @@ }; };
+ ext_osc32k: ext_osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "ext_osc32k"; + }; + leds { compatible = "gpio-leds";
@@ -51,12 +58,38 @@ regulator-max-microvolt = <5000000>; regulator-always-on; }; + + sound-spdif { + compatible = "simple-audio-card"; + simple-audio-card,name = "sun50i-h6-spdif"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_out>; + }; + }; + + spdif_out: spdif-out { + #sound-dai-cells = <0>; + compatible = "linux,spdif-dit"; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdca>; };
&de { status = "okay"; };
+&dwc3 { + status = "okay"; +}; + &ehci0 { status = "okay"; }; @@ -64,12 +97,17 @@ &emac { pinctrl-names = "default"; pinctrl-0 = <&ext_rgmii_pins>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_aldo2>; status = "okay"; };
+&gpu { + mali-supply = <®_dcdcc>; + status = "okay"; +}; + &hdmi { status = "okay"; }; @@ -201,13 +239,16 @@ reg_dcdca: dcdca { regulator-always-on; regulator-min-microvolt = <810000>; - regulator-max-microvolt = <1080000>; + regulator-max-microvolt = <1160000>; + regulator-ramp-delay = <2500>; regulator-name = "vdd-cpu"; };
reg_dcdcc: dcdcc { + regulator-enable-ramp-delay = <32000>; regulator-min-microvolt = <810000>; regulator-max-microvolt = <1080000>; + regulator-ramp-delay = <2500>; regulator-name = "vdd-gpu"; };
@@ -232,6 +273,11 @@ }; };
+&r_ir { + linux,rc-map-name = "rc-beelink-gs1"; + status = "okay"; +}; + &r_pio { /* * PL0 and PL1 are used for PMIC I2C @@ -243,6 +289,14 @@ vcc-pm-supply = <®_aldo1>; };
+&rtc { + clocks = <&ext_osc32k>; +}; + +&spdif { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; @@ -258,3 +312,7 @@ usb0_vbus-supply = <®_vcc5v>; status = "okay"; }; + +&usb3phy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h6-cpu-opp.dtsi b/arch/arm/dts/sun50i-h6-cpu-opp.dtsi new file mode 100644 index 000000000000..1a5eddc5a40f --- /dev/null +++ b/arch/arm/dts/sun50i-h6-cpu-opp.dtsi @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2020 Ondrej Jirman megous@megous.com +// Copyright (C) 2020 Clément Péron peron.clem@gmail.com + +/ { + cpu_opp_table: cpu-opp-table { + compatible = "allwinner,sun50i-h6-operating-points"; + nvmem-cells = <&cpu_speed_grade>; + opp-shared; + + opp@480000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <480000000>; + + opp-microvolt-speed0 = <880000 880000 1200000>; + opp-microvolt-speed1 = <820000 820000 1200000>; + opp-microvolt-speed2 = <820000 820000 1200000>; + }; + + opp@720000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <720000000>; + + opp-microvolt-speed0 = <880000 880000 1200000>; + opp-microvolt-speed1 = <820000 820000 1200000>; + opp-microvolt-speed2 = <820000 820000 1200000>; + }; + + opp@816000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <816000000>; + + opp-microvolt-speed0 = <880000 880000 1200000>; + opp-microvolt-speed1 = <820000 820000 1200000>; + opp-microvolt-speed2 = <820000 820000 1200000>; + }; + + opp@888000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <888000000>; + + opp-microvolt-speed0 = <880000 880000 1200000>; + opp-microvolt-speed1 = <820000 820000 1200000>; + opp-microvolt-speed2 = <820000 820000 1200000>; + }; + + opp@1080000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1080000000>; + + opp-microvolt-speed0 = <940000 940000 1200000>; + opp-microvolt-speed1 = <880000 880000 1200000>; + opp-microvolt-speed2 = <880000 880000 1200000>; + }; + + opp@1320000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1320000000>; + + opp-microvolt-speed0 = <1000000 1000000 1200000>; + opp-microvolt-speed1 = <940000 940000 1200000>; + opp-microvolt-speed2 = <940000 940000 1200000>; + }; + + opp@1488000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1488000000>; + + opp-microvolt-speed0 = <1060000 1060000 1200000>; + opp-microvolt-speed1 = <1000000 1000000 1200000>; + opp-microvolt-speed2 = <1000000 1000000 1200000>; + }; + + opp@1608000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1608000000>; + + opp-microvolt-speed0 = <1090000 1090000 1200000>; + opp-microvolt-speed1 = <1030000 1030000 1200000>; + opp-microvolt-speed2 = <1030000 1030000 1200000>; + }; + + opp@1704000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1704000000>; + + opp-microvolt-speed0 = <1120000 1120000 1200000>; + opp-microvolt-speed1 = <1060000 1060000 1200000>; + opp-microvolt-speed2 = <1060000 1060000 1200000>; + }; + + opp@1800000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1800000000>; + + opp-microvolt-speed0 = <1160000 1160000 1200000>; + opp-microvolt-speed1 = <1100000 1100000 1200000>; + opp-microvolt-speed2 = <1100000 1100000 1200000>; + }; + }; +}; + +&cpu0 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu1 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu2 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu3 { + operating-points-v2 = <&cpu_opp_table>; +}; diff --git a/arch/arm/dts/sun50i-h6-orangepi-lite2.dts b/arch/arm/dts/sun50i-h6-orangepi-lite2.dts index e098a2475f2d..e8770858b5d0 100644 --- a/arch/arm/dts/sun50i-h6-orangepi-lite2.dts +++ b/arch/arm/dts/sun50i-h6-orangepi-lite2.dts @@ -1,11 +1,74 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) -/* - * Copyright (C) 2018 Jagan Teki jagan@openedev.com - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2018 Jagan Teki jagan@openedev.com
#include "sun50i-h6-orangepi.dtsi"
/ { model = "OrangePi Lite2"; compatible = "xunlong,orangepi-lite2", "allwinner,sun50i-h6"; + + aliases { + serial1 = &uart1; /* BT-UART */ + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc 1>; + clock-names = "ext_clock"; + reset-gpios = <&r_pio 1 3 GPIO_ACTIVE_LOW>; /* PM3 */ + post-power-on-delay-ms = <200>; + }; +}; + +&mmc1 { + vmmc-supply = <®_cldo2>; + vqmmc-supply = <®_bldo3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcm: sdio-wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <1 0 IRQ_TYPE_LEVEL_LOW>; /* PM0 */ + interrupt-names = "host-wake"; + }; +}; + +®_cldo2 { + /* + * This regulator is connected with CLDO3. + * Before the kernel can support synchronized + * enable of coupled regulators, keep them + * both always on as a ugly hack. + */ + regulator-always-on; +}; + +®_cldo3 { + /* + * This regulator is connected with CLDO2. + * See the comments for CLDO2. + */ + regulator-always-on; +}; + +/* There's the BT part of the AP6255 connected to that UART */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm4345c5"; + clocks = <&rtc 1>; + clock-names = "lpo"; + device-wakeup-gpios = <&r_pio 1 2 GPIO_ACTIVE_HIGH>; /* PM2 */ + host-wakeup-gpios = <&r_pio 1 1 GPIO_ACTIVE_HIGH>; /* PM1 */ + shutdown-gpios = <&r_pio 1 4 GPIO_ACTIVE_HIGH>; /* PM4 */ + max-speed = <1500000>; + }; }; diff --git a/arch/arm/dts/sun50i-h6-orangepi-one-plus.dts b/arch/arm/dts/sun50i-h6-orangepi-one-plus.dts index 12e17567ab56..29a081e72a9b 100644 --- a/arch/arm/dts/sun50i-h6-orangepi-one-plus.dts +++ b/arch/arm/dts/sun50i-h6-orangepi-one-plus.dts @@ -1,12 +1,43 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) -/* - * Copyright (C) 2018 Amarula Solutions - * Author: Jagan Teki jagan@amarulasolutions.com - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2018 Amarula Solutions +// Author: Jagan Teki jagan@amarulasolutions.com
/ { model = "OrangePi One Plus"; compatible = "xunlong,orangepi-one-plus", "allwinner,sun50i-h6"; + + aliases { + ethernet0 = &emac; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc-gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; /* PD6 */ + vin-supply = <®_aldo2>; + }; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&ext_rgmii_pins>; + phy-mode = "rgmii-id"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_gmac_3v3>; + allwinner,rx-delay-ps = <200>; + allwinner,tx-delay-ps = <200>; + status = "okay"; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; }; diff --git a/arch/arm/dts/sun50i-h6-orangepi.dtsi b/arch/arm/dts/sun50i-h6-orangepi.dtsi index 62e27948a3fa..ebc120a9232f 100644 --- a/arch/arm/dts/sun50i-h6-orangepi.dtsi +++ b/arch/arm/dts/sun50i-h6-orangepi.dtsi @@ -1,8 +1,6 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) -/* - * Copyright (C) 2018 Amarula Solutions - * Author: Jagan Teki jagan@amarulasolutions.com - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2018 Amarula Solutions +// Author: Jagan Teki jagan@amarulasolutions.com
/dts-v1/;
@@ -22,6 +20,25 @@ stdout-path = "serial0:115200n8"; };
+ connector { + compatible = "hdmi-connector"; + type = "a"; + ddc-en-gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */ + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + ext_osc32k: ext_osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "ext_osc32k"; + }; + leds { compatible = "gpio-leds";
@@ -47,6 +64,10 @@ }; };
+&de { + status = "okay"; +}; + &ehci0 { status = "okay"; }; @@ -55,6 +76,21 @@ status = "okay"; };
+&gpu { + mali-supply = <®_dcdcc>; + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &mmc0 { vmmc-supply = <®_cldo1>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; @@ -70,6 +106,12 @@ status = "okay"; };
+&pio { + vcc-pc-supply = <®_bldo2>; + vcc-pd-supply = <®_cldo1>; + vcc-pg-supply = <®_aldo1>; +}; + &r_i2c { status = "okay";
@@ -163,6 +205,7 @@ };
reg_dcdcc: dcdcc { + regulator-enable-ramp-delay = <32000>; regulator-min-microvolt = <810000>; regulator-max-microvolt = <1080000>; regulator-name = "vdd-gpu"; @@ -189,6 +232,18 @@ }; };
+&r_ir { + status = "okay"; +}; + +&r_pio { + vcc-pm-supply = <®_bldo3>; +}; + +&rtc { + clocks = <&ext_osc32k>; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; @@ -196,7 +251,12 @@ };
&usb2otg { - dr_mode = "otg"; + /* + * OrangePi Lite 2 and One Plus, where this DT is used, don't + * have a controllable VBUS even though they do have an ID pin. + * Using it as anything but a USB host is unsafe. + */ + dr_mode = "host"; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-h6-pine-h64.dts b/arch/arm/dts/sun50i-h6-pine-h64.dts index 189834518391..961732c52aa0 100644 --- a/arch/arm/dts/sun50i-h6-pine-h64.dts +++ b/arch/arm/dts/sun50i-h6-pine-h64.dts @@ -1,30 +1,38 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) -/* - * Copyright (c) 2017 Icenowy Zheng icenowy@aosc.io - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (c) 2017 Icenowy Zheng icenowy@aosc.io
/dts-v1/;
/ { - model = "Pine H64"; + model = "Pine H64 model A"; compatible = "pine64,pine-h64", "allwinner,sun50i-h6";
aliases { ethernet0 = &emac; serial0 = &uart0; + spi0 = &spi0; };
chosen { stdout-path = "serial0:115200n8"; };
- connector { + ext_osc32k: ext_osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "ext_osc32k"; + }; + + hdmi_connector: connector { compatible = "hdmi-connector"; type = "a"; + ddc-en-gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */
port { hdmi_con_in: endpoint { @@ -52,6 +60,16 @@ }; };
+ reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc-gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + gpio = <&pio 2 16 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + reg_usb_vbus: vbus { compatible = "regulator-fixed"; regulator-name = "usb-vbus"; @@ -63,25 +81,35 @@ }; };
+&cpu0 { + cpu-supply = <®_dcdca>; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci3 { + status = "okay"; +}; + &emac { pinctrl-names = "default"; pinctrl-0 = <&ext_rgmii_pins>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; - phy-supply = <®_aldo2>; + phy-supply = <®_gmac_3v3>; allwinner,rx-delay-ps = <200>; allwinner,tx-delay-ps = <200>; status = "okay"; };
-&mdio { - ext_rgmii_phy: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; -}; - -&de { +&gpu { + mali-supply = <®_dcdcc>; status = "okay"; };
@@ -95,12 +123,11 @@ }; };
-&ehci0 { - status = "okay"; -}; - -&ehci3 { - status = "okay"; +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; };
&mmc0 { @@ -216,13 +243,16 @@ reg_dcdca: dcdca { regulator-always-on; regulator-min-microvolt = <810000>; - regulator-max-microvolt = <1080000>; + regulator-max-microvolt = <1160000>; + regulator-ramp-delay = <2500>; regulator-name = "vdd-cpu"; };
@@ -255,10 +285,36 @@ }; };
+&r_ir { + status = "okay"; +}; + &r_pio { vcc-pm-supply = <®_aldo1>; };
+&rtc { + clocks = <&ext_osc32k>; +}; + +/* + * The CS pin is shared with the MMC2 CMD pin, so we cannot have the SPI + * flash and eMMC at the same time, as one of them would fail probing. + * Disable SPI0 in here, to prefer the more useful eMMC. U-Boot can + * fix this up in no eMMC is connected. + */ +&spi0 { + pinctrl-0 = <&spi0_pins>, <&spi0_cs_pin>; + pinctrl-names = "default"; + status = "disabled"; + + flash@0 { + compatible = "winbond,w25q128", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <4000000>; + }; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; diff --git a/arch/arm/dts/sun50i-h6.dtsi b/arch/arm/dts/sun50i-h6.dtsi index a117f479ae55..8a62a9fbe347 100644 --- a/arch/arm/dts/sun50i-h6.dtsi +++ b/arch/arm/dts/sun50i-h6.dtsi @@ -1,7 +1,5 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) -/* - * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io
#include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/clock/sun50i-h6-ccu.h> @@ -11,6 +9,7 @@ #include <dt-bindings/reset/sun50i-h6-ccu.h> #include <dt-bindings/reset/sun50i-h6-r-ccu.h> #include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/thermal/thermal.h>
/ { interrupt-parent = <&gic>; @@ -26,6 +25,9 @@ device_type = "cpu"; reg = <0>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; };
cpu1: cpu@1 { @@ -33,6 +35,9 @@ device_type = "cpu"; reg = <1>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; };
cpu2: cpu@2 { @@ -40,6 +45,9 @@ device_type = "cpu"; reg = <2>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; };
cpu3: cpu@3 { @@ -47,6 +55,9 @@ device_type = "cpu"; reg = <3>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; }; };
@@ -56,14 +67,6 @@ status = "disabled"; };
- iosc: internal-osc-clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <16000000>; - clock-accuracy = <300000000>; - clock-output-names = "iosc"; - }; - osc24M: osc24M_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -71,11 +74,13 @@ clock-output-names = "osc24M"; };
- osc32k: osc32k_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <32768>; - clock-output-names = "osc32k"; + pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; };
psci { @@ -85,6 +90,7 @@
timer { compatible = "arm,armv8-timer"; + arm,no-tick-in-suspend; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 @@ -130,6 +136,7 @@ clock-names = "bus", "mod"; resets = <&display_clocks RST_MIXER0>; + iommus = <&iommu 0>;
ports { #address-cells = <1>; @@ -155,6 +162,30 @@ resets = <&ccu RST_BUS_VE>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; allwinner,sram = <&ve_sram 1>; + iommus = <&iommu 3>; + }; + + gpu: gpu@1800000 { + compatible = "allwinner,sun50i-h6-mali", + "arm,mali-t720"; + reg = <0x01800000 0x4000>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "job", "mmu", "gpu"; + clocks = <&ccu CLK_GPU>, <&ccu CLK_BUS_GPU>; + clock-names = "core", "bus"; + resets = <&ccu RST_BUS_GPU>; + status = "disabled"; + }; + + crypto: crypto@1904000 { + compatible = "allwinner,sun50i-h6-crypto"; + reg = <0x01904000 0x1000>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>; + clock-names = "bus", "mod", "ram"; + resets = <&ccu RST_BUS_CE>; };
syscon: syscon@3000000 { @@ -197,7 +228,7 @@ ccu: clock@3001000 { compatible = "allwinner,sun50i-h6-ccu"; reg = <0x03001000 0x1000>; - clocks = <&osc24M>, <&osc32k>, <&iosc>; + clocks = <&osc24M>, <&rtc 0>, <&rtc 2>; clock-names = "hosc", "losc", "iosc"; #clock-cells = <1>; #reset-cells = <1>; @@ -215,9 +246,29 @@ #dma-cells = <1>; };
- sid: sid@3006000 { + msgbox: mailbox@3003000 { + compatible = "allwinner,sun50i-h6-msgbox", + "allwinner,sun6i-a31-msgbox"; + reg = <0x03003000 0x1000>; + clocks = <&ccu CLK_BUS_MSGBOX>; + resets = <&ccu RST_BUS_MSGBOX>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + #mbox-cells = <1>; + }; + + sid: efuse@3006000 { compatible = "allwinner,sun50i-h6-sid"; reg = <0x03006000 0x400>; + #address-cells = <1>; + #size-cells = <1>; + + ths_calibration: thermal-sensor-calibration@14 { + reg = <0x14 0x8>; + }; + + cpu_speed_grade: cpu-speed-grade@1c { + reg = <0x1c 0x4>; + }; };
watchdog: watchdog@30090a0 { @@ -225,10 +276,21 @@ "allwinner,sun6i-a31-wdt"; reg = <0x030090a0 0x20>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; /* Broken on some H6 boards */ status = "disabled"; };
+ pwm: pwm@300a000 { + compatible = "allwinner,sun50i-h6-pwm"; + reg = <0x0300a000 0x400>; + clocks = <&osc24M>, <&ccu CLK_BUS_PWM>; + clock-names = "mod", "bus"; + resets = <&ccu RST_BUS_PWM>; + #pwm-cells = <3>; + status = "disabled"; + }; + pio: pinctrl@300b000 { compatible = "allwinner,sun50i-h6-pinctrl"; reg = <0x0300b000 0x400>; @@ -236,7 +298,7 @@ <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_APB1>, <&osc24M>, <&osc32k>; + clocks = <&ccu CLK_APB1>, <&osc24M>, <&rtc 0>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <3>; @@ -256,6 +318,21 @@ function = "hdmi"; };
+ i2c0_pins: i2c0-pins { + pins = "PD25", "PD26"; + function = "i2c0"; + }; + + i2c1_pins: i2c1-pins { + pins = "PH5", "PH6"; + function = "i2c1"; + }; + + i2c2_pins: i2c2-pins { + pins = "PD23", "PD24"; + function = "i2c2"; + }; + mmc0_pins: mmc0-pins { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; @@ -264,10 +341,7 @@ bias-pull-up; };
- /* - * /omit-if-no-ref/ isn't supported by U-boot - * keep this comment to avoid bad sync with Linux - */ + /omit-if-no-ref/ mmc1_pins: mmc1-pins { pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; @@ -285,10 +359,50 @@ bias-pull-up; };
+ /omit-if-no-ref/ + spi0_pins: spi0-pins { + pins = "PC0", "PC2", "PC3"; + function = "spi0"; + }; + + /* pin shared with MMC2-CMD (eMMC) */ + /omit-if-no-ref/ + spi0_cs_pin: spi0-cs-pin { + pins = "PC5"; + function = "spi0"; + }; + + /omit-if-no-ref/ + spi1_pins: spi1-pins { + pins = "PH4", "PH5", "PH6"; + function = "spi1"; + }; + + /omit-if-no-ref/ + spi1_cs_pin: spi1-cs-pin { + pins = "PH3"; + function = "spi1"; + }; + + spdif_tx_pin: spdif-tx-pin { + pins = "PH7"; + function = "spdif"; + }; + uart0_ph_pins: uart0-ph-pins { pins = "PH0", "PH1"; function = "uart0"; }; + + uart1_pins: uart1-pins { + pins = "PG6", "PG7"; + function = "uart1"; + }; + + uart1_rts_cts_pins: uart1-rts-cts-pins { + pins = "PG8", "PG9"; + function = "uart1"; + }; };
gic: interrupt-controller@3021000 { @@ -302,6 +416,15 @@ #interrupt-cells = <3>; };
+ iommu: iommu@30f0000 { + compatible = "allwinner,sun50i-h6-iommu"; + reg = <0x030f0000 0x10000>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_IOMMU>; + resets = <&ccu RST_BUS_IOMMU>; + #iommu-cells = <1>; + }; + mmc0: mmc@4020000 { compatible = "allwinner,sun50i-h6-mmc", "allwinner,sun50i-a64-mmc"; @@ -394,6 +517,78 @@ status = "disabled"; };
+ i2c0: i2c@5002000 { + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x05002000 0x400>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@5002400 { + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x05002400 0x400>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c2: i2c@5002800 { + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x05002800 0x400>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi0: spi@5010000 { + compatible = "allwinner,sun50i-h6-spi", + "allwinner,sun8i-h3-spi"; + reg = <0x05010000 0x1000>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; + clock-names = "ahb", "mod"; + dmas = <&dma 22>, <&dma 22>; + dma-names = "rx", "tx"; + resets = <&ccu RST_BUS_SPI0>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi1: spi@5011000 { + compatible = "allwinner,sun50i-h6-spi", + "allwinner,sun8i-h3-spi"; + reg = <0x05011000 0x1000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; + clock-names = "ahb", "mod"; + dmas = <&dma 23>, <&dma 23>; + dma-names = "rx", "tx"; + resets = <&ccu RST_BUS_SPI1>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + emac: ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac", "allwinner,sun50i-a64-emac"; @@ -414,6 +609,34 @@ }; };
+ i2s1: i2s@5091000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun50i-h6-i2s"; + reg = <0x05091000 0x1000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S1>, <&ccu CLK_I2S1>; + clock-names = "apb", "mod"; + dmas = <&dma 4>, <&dma 4>; + resets = <&ccu RST_BUS_I2S1>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + spdif: spdif@5093000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun50i-h6-spdif"; + reg = <0x05093000 0x400>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPDIF>, <&ccu CLK_SPDIF>; + clock-names = "apb", "spdif"; + resets = <&ccu RST_BUS_SPDIF>; + dmas = <&dma 2>; + dma-names = "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pin>; + status = "disabled"; + }; + usb2otg: usb@5100000 { compatible = "allwinner,sun50i-h6-musb", "allwinner,sun8i-a33-musb"; @@ -470,6 +693,38 @@ status = "disabled"; };
+ dwc3: usb@5200000 { + compatible = "snps,dwc3"; + reg = <0x05200000 0x10000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_XHCI>, + <&ccu CLK_BUS_XHCI>, + <&rtc 0>; + clock-names = "ref", "bus_early", "suspend"; + resets = <&ccu RST_BUS_XHCI>; + /* + * The datasheet of the chip doesn't declare the + * peripheral function, and there's no boards known + * to have a USB Type-B port routed to the port. + * In addition, no one has tested the peripheral + * function yet. + * So set the dr_mode to "host" in the DTSI file. + */ + dr_mode = "host"; + phys = <&usb3phy>; + phy-names = "usb3-phy"; + status = "disabled"; + }; + + usb3phy: phy@5210000 { + compatible = "allwinner,sun50i-h6-usb3-phy"; + reg = <0x5210000 0x10000>; + clocks = <&ccu CLK_USB_PHY1>; + resets = <&ccu RST_USB_PHY1>; + #phy-cells = <0>; + status = "disabled"; + }; + ehci3: usb@5311000 { compatible = "allwinner,sun50i-h6-ehci", "generic-ehci"; reg = <0x05311000 0x100>; @@ -480,6 +735,7 @@ resets = <&ccu RST_BUS_OHCI3>, <&ccu RST_BUS_EHCI3>; phys = <&usb2phy 3>; + phy-names = "usb"; status = "disabled"; };
@@ -491,6 +747,7 @@ <&ccu CLK_USB_OHCI3>; resets = <&ccu RST_BUS_OHCI3>; phys = <&usb2phy 3>; + phy-names = "usb"; status = "disabled"; };
@@ -507,7 +764,7 @@ resets = <&ccu RST_BUS_HDMI_SUB>, <&ccu RST_BUS_HDCP>; reset-names = "ctrl", "hdcp"; phys = <&hdmi_phy>; - phy-names = "hdmi-phy"; + phy-names = "phy"; pinctrl-names = "default"; pinctrl-0 = <&hdmi_pins>; status = "disabled"; @@ -549,7 +806,6 @@ "tcon-tv0"; clock-output-names = "tcon-top-tv0"; resets = <&ccu RST_BUS_TCON_TOP>; - reset-names = "rst"; #clock-cells = <1>;
ports { @@ -636,10 +892,19 @@ }; };
+ rtc: rtc@7000000 { + compatible = "allwinner,sun50i-h6-rtc"; + reg = <0x07000000 0x400>; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "osc32k", "osc32k-out", "iosc"; + #clock-cells = <1>; + }; + r_ccu: clock@7010000 { compatible = "allwinner,sun50i-h6-r-ccu"; reg = <0x07010000 0x400>; - clocks = <&osc24M>, <&osc32k>, <&iosc>, + clocks = <&osc24M>, <&rtc 0>, <&rtc 2>, <&ccu CLK_PLL_PERIPH0>; clock-names = "hosc", "losc", "iosc", "pll-periph"; #clock-cells = <1>; @@ -651,6 +916,7 @@ "allwinner,sun6i-a31-wdt"; reg = <0x07020400 0x20>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; };
r_intc: interrupt-controller@7021000 { @@ -667,7 +933,7 @@ reg = <0x07022000 0x400>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&r_ccu CLK_R_APB1>, <&osc24M>, <&osc32k>; + clocks = <&r_ccu CLK_R_APB1>, <&osc24M>, <&rtc 0>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <3>; @@ -678,10 +944,30 @@ pins = "PL0", "PL1"; function = "s_i2c"; }; + + r_ir_rx_pin: r-ir-rx-pin { + pins = "PL9"; + function = "s_cir_rx"; + }; + }; + + r_ir: ir@7040000 { + compatible = "allwinner,sun50i-h6-ir", + "allwinner,sun6i-a31-ir"; + reg = <0x07040000 0x400>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_R_APB1_IR>, + <&r_ccu CLK_IR>; + clock-names = "apb", "ir"; + resets = <&r_ccu RST_R_APB1_IR>; + pinctrl-names = "default"; + pinctrl-0 = <&r_ir_rx_pin>; + status = "disabled"; };
r_i2c: i2c@7081400 { - compatible = "allwinner,sun6i-a31-i2c"; + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; reg = <0x07081400 0x400>; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; clocks = <&r_ccu CLK_R_APB2_I2C>; @@ -692,5 +978,55 @@ #address-cells = <1>; #size-cells = <0>; }; + + ths: thermal-sensor@5070400 { + compatible = "allwinner,sun50i-h6-ths"; + reg = <0x05070400 0x100>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_THS>; + clock-names = "bus"; + resets = <&ccu RST_BUS_THS>; + nvmem-cells = <&ths_calibration>; + nvmem-cell-names = "calibration"; + #thermal-sensor-cells = <1>; + }; + }; + + thermal-zones { + cpu-thermal { + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&ths 0>; + + trips { + cpu_alert: cpu-alert { + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu-crit { + temperature = <100000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu-thermal { + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&ths 1>; + }; }; };
Reviewed-by: Andre Przywara andre.przywara@arm.com
Two things to note: - This relies on the U-Boot patch to sun8i-emac to recognise rgmii-id and friends, otherwise Ethernet won't work. The patch should ideally be merged before those ones.
- This decreases DT compatibilty with older kernels, which don't know about the H6 RTC (introduced in Linux v5.4). The IOSC fixed clock got replaced by <&rtc 2>, so this won't be available everywhere.
Cheers, Andre
- Copyright (C) 2019 Clément Péron peron.clem@gmail.com
/dts-v1/;
- ext_osc32k: ext_osc32k_clk {
#clock-cells = <0>;
- leds { compatible = "gpio-leds";
- sound-spdif {
- spdif_out: spdif-out {
+&cpu0 {
- cpu-supply = <®_dcdca>;
+&dwc3 {
- status = "okay";
- phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_aldo2>; status = "okay";
+&gpu {
- mali-supply = <®_dcdcc>;
- status = "okay";
regulator-ramp-delay = <2500>; regulator-name = "vdd-cpu"; }; reg_dcdcc: dcdcc {
+&r_ir {
- linux,rc-map-name = "rc-beelink-gs1";
- status = "okay";
+&rtc {
- clocks = <&ext_osc32k>;
+&spdif {
- status = "okay";
+&usb3phy {
- status = "okay";
- cpu_opp_table: cpu-opp-table {
opp-shared;
opp@480000000 {
opp@720000000 {
opp@816000000 {
opp@888000000 {
opp@1080000000 {
opp@1320000000 {
opp@1488000000 {
opp@1608000000 {
opp@1704000000 {
opp@1800000000 {
+&cpu0 {
- operating-points-v2 = <&cpu_opp_table>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
- Copyright (C) 2018 Jagan Teki jagan@openedev.com
- aliases {
- wifi_pwrseq: wifi_pwrseq {
clocks = <&rtc 1>;
+&mmc1 {
- vmmc-supply = <®_cldo2>;
- vqmmc-supply = <®_bldo3>;
- mmc-pwrseq = <&wifi_pwrseq>;
- bus-width = <4>;
- non-removable;
- status = "okay";
- brcm: sdio-wifi@1 {
reg = <1>;
+®_cldo2 {
- regulator-always-on;
+®_cldo3 {
- pinctrl-names = "default";
- pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>;
- uart-has-rtscts;
- status = "okay";
- bluetooth {
clocks = <&rtc 1>;
- Copyright (C) 2018 Amarula Solutions
- Author: Jagan Teki jagan@amarulasolutions.com
- aliases {
ethernet0 = &emac;
- reg_gmac_3v3: gmac-3v3 {
enable-active-high;
+&emac {
- pinctrl-0 = <&ext_rgmii_pins>;
- phy-handle = <&ext_rgmii_phy>;
- phy-supply = <®_gmac_3v3>;
- allwinner,rx-delay-ps = <200>;
- allwinner,tx-delay-ps = <200>;
- status = "okay";
+&mdio {
reg = <1>;
/dts-v1/;
- connector {
type = "a";
port {
#clock-cells = <0>;
+&de {
- status = "okay";
+&gpu {
- status = "okay";
+&hdmi {
- status = "okay";
+&hdmi_out {
- hdmi_out_con: endpoint {
+&pio {
- vcc-pc-supply = <®_bldo2>;
- vcc-pd-supply = <®_cldo1>;
- vcc-pg-supply = <®_aldo1>;
reg_dcdcc: dcdcc {
+&r_ir {
- status = "okay";
+&r_pio {
- vcc-pm-supply = <®_bldo3>;
+&rtc {
&usb2otg {
- dr_mode = "otg";
- dr_mode = "host"; status = "okay";
- Copyright (c) 2017 Icenowy Zheng icenowy@aosc.io
/dts-v1/;
spi0 = &spi0;
- connector {
#clock-cells = <0>;
enable-active-high;
- reg_usb_vbus: vbus { compatible = "regulator-fixed"; regulator-name = "usb-vbus";
+&cpu0 {
+&de {
- status = "okay";
+&ehci0 {
- status = "okay";
+&ehci3 {
- status = "okay";
- phy-supply = <®_gmac_3v3>; allwinner,rx-delay-ps = <200>; allwinner,tx-delay-ps = <200>; status = "okay";
-&mdio {
reg = <1>;
-&de { +&gpu {
- mali-supply = <®_dcdcc>; status = "okay";
-&ehci0 {
- status = "okay";
-&ehci3 {
- status = "okay";
+&mdio {
reg = <1>;
+&r_ir {
- status = "okay";
+&rtc {
- The CS pin is shared with the MMC2 CMD pin, so we cannot have the SPI
- flash and eMMC at the same time, as one of them would fail probing.
- Disable SPI0 in here, to prefer the more useful eMMC. U-Boot can
- fix this up in no eMMC is connected.
+&spi0 {
- pinctrl-0 = <&spi0_pins>, <&spi0_cs_pin>;
- status = "disabled";
- flash@0 {
reg = <0>;
- Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io
cpu1: cpu@1 {
cpu2: cpu@2 {
cpu3: cpu@3 {
}; };#cooling-cells = <2>;
#clock-cells = <0>;
#clock-cells = <0>;
pmu {
psci {
@@ -85,6 +90,7 @@
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14arm,no-tick-in-suspend;
iommus = <&iommu 0>; ports { #address-cells = <1>;
gpu: gpu@1800000 {
"arm,mali-t720";
sid: sid@3006000 {
#mbox-cells = <1>;
#size-cells = <1>;
reg = <0x14 0x8>;
reg = <0x1c 0x4>;
pwm: pwm@300a000 {
#pwm-cells = <3>;
function = "i2c0";
function = "i2c1";
function = "i2c2";
/omit-if-no-ref/
function = "spi0";
/omit-if-no-ref/
pins = "PC5";
function = "spi0";
/omit-if-no-ref/
function = "spi1";
/omit-if-no-ref/
pins = "PH3";
function = "spi1";
pins = "PH7";
function = "spdif";
function = "uart1";
function = "uart1";
#iommu-cells = <1>;
- mmc0: mmc@4020000 { compatible = "allwinner,sun50i-h6-mmc", "allwinner,sun50i-a64-mmc";
i2c0: i2c@5002000 {
#size-cells = <0>;
i2c1: i2c@5002400 {
#size-cells = <0>;
i2c2: i2c@5002800 {
#size-cells = <0>;
spi0: spi@5010000 {
#size-cells = <0>;
spi1: spi@5011000 {
#size-cells = <0>;
- emac: ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac", "allwinner,sun50i-a64-emac";
i2s1: i2s@5091000 {
dmas = <&dma 2>;
dma-names = "tx";
- usb2otg: usb@5100000 { compatible = "allwinner,sun50i-h6-musb", "allwinner,sun8i-a33-musb";
dwc3: usb@5200000 {
<&rtc 0>;
* function yet.
dr_mode = "host";
phys = <&usb3phy>;
#phy-cells = <0>;
- ehci3: usb@5311000 { compatible = "allwinner,sun50i-h6-ehci", "generic-ehci"; reg = <0x05311000 0x100>;
};phy-names = "usb"; status = "disabled";
reset-names = "rst"; #clock-cells = <1>; ports {
rtc: rtc@7000000 {
#clock-cells = <1>;
- r_ccu: clock@7010000 { compatible = "allwinner,sun50i-h6-r-ccu"; reg = <0x07010000 0x400>;
clocks = <&osc24M>;
pins = "PL9";
r_ir: ir@7040000 {
<&r_ccu CLK_IR>;
- thermal-zones {
cpu-thermal {
trips {
type = "passive";
cpu-crit {
hysteresis = <0>;
type = "critical";
cooling-maps {
map0 {
gpu-thermal {
This commit adds support for Tanix TX6 TV box, based on H6. It's low end H6 board, with 3 GiB of RAM, eMMC, fast ethernet, USB, IR and other peripherals.
DT file is taken from Linux 5.11-rc1 release.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-h6-tanix-tx6.dts | 124 +++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 ++ configs/tanix_tx6_defconfig | 10 +++ 4 files changed, 142 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-h6-tanix-tx6.dts create mode 100644 configs/tanix_tx6_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fd47e408f826..e00aed1ec207 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -607,7 +607,8 @@ dtb-$(CONFIG_MACH_SUN50I_H6) += \ sun50i-h6-beelink-gs1.dtb \ sun50i-h6-orangepi-lite2.dtb \ sun50i-h6-orangepi-one-plus.dtb \ - sun50i-h6-pine-h64.dtb + sun50i-h6-pine-h64.dtb \ + sun50i-h6-tanix-tx6.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-amarula-relic.dtb \ sun50i-a64-bananapi-m64.dtb \ diff --git a/arch/arm/dts/sun50i-h6-tanix-tx6.dts b/arch/arm/dts/sun50i-h6-tanix-tx6.dts new file mode 100644 index 000000000000..be81330db14f --- /dev/null +++ b/arch/arm/dts/sun50i-h6-tanix-tx6.dts @@ -0,0 +1,124 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (c) 2019 Jernej Skrabec jernej.skrabec@siol.net + +/dts-v1/; + +#include "sun50i-h6.dtsi" +#include "sun50i-h6-cpu-opp.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Tanix TX6"; + compatible = "oranth,tanix-tx6", "allwinner,sun50i-h6"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + connector { + compatible = "hdmi-connector"; + ddc-en-gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */ + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_vdd_cpu_gpu: vdd-cpu-gpu { + compatible = "regulator-fixed"; + regulator-name = "vdd-cpu-gpu"; + regulator-min-microvolt = <1135000>; + regulator-max-microvolt = <1135000>; + }; +}; + +&cpu0 { + cpu-supply = <®_vdd_cpu_gpu>; +}; + +&de { + status = "okay"; +}; + +&dwc3 { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci3 { + status = "okay"; +}; + +&gpu { + mali-supply = <®_vdd_cpu_gpu>; + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + bus-width = <4>; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + +&r_ir { + linux,rc-map-name = "rc-tanix-tx5max"; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_ph_pins>; + status = "okay"; +}; + +&usb2otg { + dr_mode = "host"; + status = "okay"; +}; + +&usb2phy { + status = "okay"; +}; + +&usb3phy { + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index d3755ae41a9d..1b37a9899edd 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -489,6 +489,12 @@ S: Maintained F: configs/Sunchip_CX-A99_defconfig W: https://linux-sunxi.org/Sunchip_CX-A99
+TANIX TX6 BOARD +M: Jernej Skrabec jernej.skrabec@siol.net +S: Maintained +F: configs/tanix_tx6_defconfig +W: https://linux-sunxi.org/Tanix_TX6 + TBS A711 BOARD M: Maxime Ripard mripard@kernel.org S: Maintained diff --git a/configs/tanix_tx6_defconfig b/configs/tanix_tx6_defconfig new file mode 100644 index 000000000000..9ce812ecc35d --- /dev/null +++ b/configs/tanix_tx6_defconfig @@ -0,0 +1,10 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I_H6=y +CONFIG_SUNXI_DRAM_H6_DDR3_1333=y +CONFIG_DRAM_CLK=648 +CONFIG_MMC0_CD_PIN="PF6" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-tanix-tx6" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
Thanks! Andre
- sun50i-h6-pine-h64.dtb \
- sun50i-h6-tanix-tx6.dtb
+/dts-v1/;
- model = "Tanix TX6";
- compatible = "oranth,tanix-tx6", "allwinner,sun50i-h6";
- aliases {
serial0 = &uart0;
- chosen {
- connector {
type = "a";
port {
- reg_vcc3v3: vcc3v3 {
- reg_vdd_cpu_gpu: vdd-cpu-gpu {
+&cpu0 {
- cpu-supply = <®_vdd_cpu_gpu>;
+&de {
- status = "okay";
+&dwc3 {
- status = "okay";
+&ehci0 {
- status = "okay";
+&ehci3 {
- status = "okay";
+&gpu {
- mali-supply = <®_vdd_cpu_gpu>;
- status = "okay";
+&hdmi {
- status = "okay";
+&hdmi_out {
+&mmc0 {
- pinctrl-0 = <&mmc0_pins>;
- vmmc-supply = <®_vcc3v3>;
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>;
- bus-width = <4>;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci3 {
- status = "okay";
+&r_ir {
- linux,rc-map-name = "rc-tanix-tx5max";
- status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_ph_pins>;
- status = "okay";
+&usb2otg {
- dr_mode = "host";
- status = "okay";
+&usb2phy {
- status = "okay";
+&usb3phy {
- status = "okay";
André Przywara
Jernej Skrabec
