[PATCH] riscv: Fix detecting FPU support in standard extension
We should check the string until it hits underscore, in case it searches for the letters in the custom extension. For example, "rv64imac_xandes" will be treated as D extension support since there is a "d" in "andes", resulting illegal instruction caused by initializing FCSR.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com --- arch/riscv/cpu/cpu.c | 14 +++++++++++--- 1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c index 52ab02519f..dc949c1306 100644 --- a/arch/riscv/cpu/cpu.c +++ b/arch/riscv/cpu/cpu.c @@ -36,6 +36,7 @@ static inline bool supports_extension(char ext) #ifdef CONFIG_CPU struct udevice *dev; char desc[32]; + int i;
uclass_find_first_device(UCLASS_CPU, &dev); if (!dev) { @@ -43,9 +44,16 @@ static inline bool supports_extension(char ext) return false; } if (!cpu_get_desc(dev, desc, sizeof(desc))) { - /* skip the first 4 characters (rv32|rv64) */ - if (strchr(desc + 4, ext)) - return true; + /* + * skip the first 4 characters (rv32|rv64) and + * check until underscore + */ + for (i = 4; i < sizeof(desc); i++) { + if (!(desc[i] - '_')) + break; + if (desc[i] == ext) + return true; + } }
return false;
int i;
return true;
Why not use "if (desc[i] == '_')"? Also, you need to stop at the null terminator.
Regards, Samuel
break;
if (desc[i] == ext)
return true;
return false;
int i;
return true;
Regards, Samuel
Hi Samuel,
Oops, I'll fix this. Thanks for your review!
Best regards, Peter Lin
break;
if (desc[i] == ext)
return true;
return false;
Samuel Holland
Yu Chien Peter Lin
Yu-Chien Peter Lin
