[U-Boot] [PATCH v4 0/2] Rename ax25-ae350 defconfig
Remove cpu name from the defconfig naming. Because other cpus maybe run on AE350 platform. So only use platfrom name in defconfig naming will be better.
Changes since v3: - squashed [PATCH v3 2/3] MAINTAINERS: Sync for ax25-ae350 rename into [PATCH v3 1/3] riscv: configs: Rename ax25-ae350 defconfig
Changes since v2: - Fix travis failure case 6.51 Checkfor configs without MAINTAINERS entry. https://travis-ci.org/rickchen36/u-boot-riscv/builds/468881778 So add this two patchs: MAINTAINERS: Sync for ax25-ae350 rename doc: README.ae350: Sync for ax25-ae350 rename
Changes since v1: - Use git mv and git format-patch -M to show delta when rename.
Rick Chen (2): riscv: configs: Rename ax25-ae350 defconfig doc: README.ae350: Sync for ax25-ae350 rename
board/AndesTech/ax25-ae350/MAINTAINERS | 5 ++--- configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} | 0 configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} | 0 doc/README.ae350 | 2 +- 4 files changed, 3 insertions(+), 4 deletions(-) rename configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} (100%) rename configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} (100%)
Also sync MAINTAINERS: Rename a25-ae350_32_defconfig as ae350_rv32_defconfig ax25-ae350_64_defconfig as ae350_rv64_defconfig
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- board/AndesTech/ax25-ae350/MAINTAINERS | 5 ++--- configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} | 0 configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} | 0 3 files changed, 2 insertions(+), 3 deletions(-) rename configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} (100%) rename configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} (100%)
diff --git a/board/AndesTech/ax25-ae350/MAINTAINERS b/board/AndesTech/ax25-ae350/MAINTAINERS index d87446e..b0a99e4 100644 --- a/board/AndesTech/ax25-ae350/MAINTAINERS +++ b/board/AndesTech/ax25-ae350/MAINTAINERS @@ -3,6 +3,5 @@ M: Rick Chen rick@andestech.com S: Maintained F: board/AndesTech/ax25-ae350/ F: include/configs/ax25-ae350.h -F: configs/a25-ae350_32_defconfig -F: configs/ax25-ae350_64_defconfig -F: configs/ax25-ae350_defconfig +F: configs/ae350_rv32_defconfig +F: configs/ae350_rv64_defconfig diff --git a/configs/a25-ae350_32_defconfig b/configs/ae350_rv32_defconfig similarity index 100% rename from configs/a25-ae350_32_defconfig rename to configs/ae350_rv32_defconfig diff --git a/configs/ax25-ae350_64_defconfig b/configs/ae350_rv64_defconfig similarity index 100% rename from configs/ax25-ae350_64_defconfig rename to configs/ae350_rv64_defconfig
Rename ax25-ae350 as ae350_rv[32|64] for 32 or 64 bit.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- doc/README.ae350 | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/README.ae350 b/doc/README.ae350 index fe75b80..189a6b7 100644 --- a/doc/README.ae350 +++ b/doc/README.ae350 @@ -25,7 +25,7 @@ Build and boot steps
build: 1. Prepare the toolchains and make sure the $PATH to toolchains is correct. -2. Use `make ax25-ae350_defconfig` in u-boot root to build the image. +2. Use `make ae350_rv[32|64]_defconfig` in u-boot root to build the image for 32 or 64 bit.
Verification ====================
Andes
Bin Meng
