[U-Boot] Timer on OMAP3430SDP.
Hi All,
I am using get_timer() function to find nof system ticks the NAND Read API is using. When I convert these system ticks into second I am not getting the expected value.
I observed that 1 sec = 50781 ticks on OMAP3430SDP.
Is this timer fine tuned for performance.
Could someone suggest me on this.
Thanks, Krishna.
Hi Krishna,
Radha Krishna wrote:
Hi All,
I can't remember that we have any OMAP3430SDP support in U-Boot mainline. What U-Boot (patch) do you use?
There was some discussion that there might be an issue with timer:
http://lists.denx.de/pipermail/u-boot/2009-February/048146.html
Can you check if this is the issue you see?
If yes, a patch for this is would be greatly appreciated!
Best regards
Dirk
Dirk Behme
Radha Krishna
