[U-Boot] [PATCH] arm: socfpga: Add example config entry for EPCS/EPCQ SPI
Add example config file entry for the Altera SPI controller. This SPI controller can also, under special conditions, be used to operate the EPCS/EPCQ SPI NOR.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Pavel Machek pavel@denx.de Cc: Stefan Roese sr@denx.de --- include/configs/socfpga_common.h | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 83a1bcd..1df886b 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -79,6 +79,25 @@ #define CONFIG_SYS_PL310_BASE SOCFPGA_MPUL2_ADDRESS
/* + * EPCS/EPCQx1 Serial Flash Controller + */ +#ifdef CONFIG_ALTERA_SPI +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 30000000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_BAR +/* + * The base address is configurable in QSys, each board must specify the + * base address based on it's particular FPGA configuration. Please note + * that the address here is incremented by 0x400 from the Base address + * selected in QSys, since the SPI registers are at offset +0x400. + * #define CONFIG_SYS_SPI_BASE 0xff240400 + */ +#endif + +/* * Ethernet on SoC (EMAC) */ #if defined(CONFIG_CMD_NET) && !defined(CONFIG_SOCFPGA_VIRTUAL_TARGET)
Acked-by: Pavel Machek pavel@denx.de
- EPCS/EPCQx1 Serial Flash Controller
- The base address is configurable in QSys, each board must specify the
- base address based on it's particular FPGA configuration. Please note
- that the address here is incremented by 0x400 from the Base address
Are the double spaces around 0x400 intentional?
Pavel
Yes, to stress it out and align the text to a nice block ;-)
Best regards, Marek Vasut
Thanks, Stefan
- selected in QSys, since the SPI registers are at offset +0x400.
- #define CONFIG_SYS_SPI_BASE 0xff240400
So each board-specific config header will define CONFIG_SYS_SPI_BASE is it? for using ALTERA_SPI
- Ethernet on SoC (EMAC)
2.0.0
thanks!
Yes, the address is not fixed, since this is FPGA IP.
May be use conditional ifdef with CONFIG_SYS_SPI_BASE instead of CONFIG_ALTERA_SPI so who ever use SPI on their board will define CONFIG_SYS_SPI_BASE config.
thanks!
You can have different SPI controllers enabled on the SoCFPGA, so enabling CONFIG_ALTERA_SPI explicitly in case CONFIG_SYS_SPI_BASE is defined is a very bad idea.
In that case - It's true.
Reviewed-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
thanks!
Applied to u-boot-socfpga, thanks.
Jagan Teki
Pavel Machek
Stefan Roese
