Please pull u-boot-marvell/master v2
please pull the next batch of Marvell Armada related patches. Here the summary log:
---------------------------------------------------------------- - Add base support for Marvell OcteonTX2 CN9130 DB (mostly done by Kostya) - Sync Armada 8k MMU setup with Marvell version (misc Marvell authors) - spi: kirkwood: Some fixes especially for baudrate generation (misc Marvell authors) - mvebu: x530: Reduce SPL image size (Stefan) - Rename "rx_training" to "mvebu_comphy_rx_training" (Stefan) ----------------------------------------------------------------
Here the Azure build without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=89&view=resul...
I've dropped the mvpp2 ethernet driver sync with the PHY header extension as it introduces some issues on xilinx_versal_virt which need to be investigated.
Thanks, Stefan
The following changes since commit e644dfbb1786a4a3308b068e1f61cd9e2dfac237:
configs: Resync with savedefconfig (2021-05-15 08:10:13 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to e1c55dfc7b59e8e49fc400290b3bea8066b74de1:
arm: octeontx2: Add Octeon TX2 CN913x DB support (2021-05-16 06:48:45 +0200)
---------------------------------------------------------------- Grzegorz Jaszczyk (4): spi: kirkwood: prevent limiting speed to 0 arm64: mvebu: do not map firmware RT service region arm64: mvebu: a8k: move firmware related definitions to fw info arm64: mvebu: extend the mmio region
Ken Ma (1): spi: kirkwood: support extended baud rates
Konstantin Porotchkin (2): arm: octeontx2: Add dtsi/dts files for Octeon TX2 CN913x DB arm: octeontx2: Add Octeon TX2 CN913x DB support
Marcin Wojtas (2): spi: kirkwood: prevent configuring speed exceeding max controller freq pcie: designware: mvebu: do not configure ATU for IO when not used
Stefan Roese (2): mvebu: x530: Reduce SPL image size cmd: mvebu: Rename rx_training to mvebu_comphy_rx_training
jinghua (1): arm64: mvebu: a8k: align memory regions
arch/arm/dts/Makefile | 6 + arch/arm/dts/cn9130-db-A.dts | 55 ++++ arch/arm/dts/cn9130-db-B.dts | 51 ++++ arch/arm/dts/cn9130-db-dev-info.dtsi | 44 +++ arch/arm/dts/cn9130-db.dtsi | 316 ++++++++++++++++++++++ arch/arm/dts/cn9131-db-A.dts | 54 ++++ arch/arm/dts/cn9131-db-B.dts | 69 +++++ arch/arm/dts/cn9131-db.dtsi | 166 ++++++++++++ arch/arm/dts/cn9132-db-A.dts | 13 + arch/arm/dts/cn9132-db-B.dts | 13 + arch/arm/dts/cn9132-db.dtsi | 217 +++++++++++++++ arch/arm/mach-mvebu/armada8k/cpu.c | 70 ++--- arch/arm/mach-mvebu/include/mach/fw_info.h | 18 ++ board/Marvell/octeontx2_cn913x/MAINTAINERS | 1 + board/Marvell/octeontx2_cn913x/README | 24 ++ cmd/mvebu/Kconfig | 9 +- cmd/mvebu/Makefile | 2 +- cmd/mvebu/{rx_training.c => comphy_rx_training.c} | 10 +- configs/mvebu_db_cn9130_defconfig | 89 ++++++ configs/x530_defconfig | 2 +- drivers/pci/pcie_dw_mvebu.c | 37 ++- drivers/spi/kirkwood_spi.c | 67 ++++- 22 files changed, 1250 insertions(+), 83 deletions(-) create mode 100644 arch/arm/dts/cn9130-db-A.dts create mode 100644 arch/arm/dts/cn9130-db-B.dts create mode 100644 arch/arm/dts/cn9130-db-dev-info.dtsi create mode 100644 arch/arm/dts/cn9130-db.dtsi create mode 100644 arch/arm/dts/cn9131-db-A.dts create mode 100644 arch/arm/dts/cn9131-db-B.dts create mode 100644 arch/arm/dts/cn9131-db.dtsi create mode 100644 arch/arm/dts/cn9132-db-A.dts create mode 100644 arch/arm/dts/cn9132-db-B.dts create mode 100644 arch/arm/dts/cn9132-db.dtsi create mode 100644 arch/arm/mach-mvebu/include/mach/fw_info.h create mode 100644 board/Marvell/octeontx2_cn913x/README rename cmd/mvebu/{rx_training.c => comphy_rx_training.c} (74%) create mode 100644 configs/mvebu_db_cn9130_defconfig
Stefan Roese
