[PATCH 1/3] lib: sha1: Add support for hardware specific sha1_process
Mark sha1_process as weak to allow hardware specific implementation. Add parameter to support for multiple blocks processing.
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- lib/sha1.c | 26 +++++++++++++++++++------- 1 file changed, 19 insertions(+), 7 deletions(-)
diff --git a/lib/sha1.c b/lib/sha1.c index 8154e1e..e5e42bc 100644 --- a/lib/sha1.c +++ b/lib/sha1.c @@ -25,6 +25,8 @@ #include <watchdog.h> #include <u-boot/sha1.h>
+#include <linux/compiler_attributes.h> + const uint8_t sha1_der_prefix[SHA1_DER_LEN] = { 0x30, 0x21, 0x30, 0x09, 0x06, 0x05, 0x2b, 0x0e, 0x03, 0x02, 0x1a, 0x05, 0x00, 0x04, 0x14 @@ -65,7 +67,7 @@ void sha1_starts (sha1_context * ctx) ctx->state[4] = 0xC3D2E1F0; }
-static void sha1_process(sha1_context *ctx, const unsigned char data[64]) +static void __maybe_unused sha1_process_one(sha1_context *ctx, const unsigned char data[64]) { unsigned long temp, W[16], A, B, C, D, E;
@@ -219,6 +221,18 @@ static void sha1_process(sha1_context *ctx, const unsigned char data[64]) ctx->state[4] += E; }
+__weak void sha1_process(sha1_context *ctx, const unsigned char *data, + unsigned int blocks) +{ + if (!blocks) + return; + + while (blocks--) { + sha1_process_one(ctx, data); + data += 64; + } +} + /* * SHA-1 process buffer */ @@ -242,17 +256,15 @@ void sha1_update(sha1_context *ctx, const unsigned char *input,
if (left && ilen >= fill) { memcpy ((void *) (ctx->buffer + left), (void *) input, fill); - sha1_process (ctx, ctx->buffer); + sha1_process(ctx, ctx->buffer, 1); input += fill; ilen -= fill; left = 0; }
- while (ilen >= 64) { - sha1_process (ctx, input); - input += 64; - ilen -= 64; - } + sha1_process(ctx, input, ilen / 64); + input += ilen / 64 * 64; + ilen = ilen % 64;
if (ilen > 0) { memcpy ((void *) (ctx->buffer + left), (void *) input, ilen);
sha1 digest size is 5*32-bit => 160-bit. Using 64-bit unsigned long does not cause issue with the current sha1 implementation, but could be problematic for vectorized access.
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- include/u-boot/sha1.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/u-boot/sha1.h b/include/u-boot/sha1.h index 283f103..09fee59 100644 --- a/include/u-boot/sha1.h +++ b/include/u-boot/sha1.h @@ -30,7 +30,7 @@ extern const uint8_t sha1_der_prefix[]; typedef struct { unsigned long total[2]; /*!< number of bytes processed */ - unsigned long state[5]; /*!< intermediate digest state */ + uint32_t state[5]; /*!< intermediate digest state */ unsigned char buffer[64]; /*!< data block being processed */ } sha1_context;
This patch adds support for the SHA-1 Secure Hash Algorithm for CPUs that have support for the SHA-1 part of the ARM v8 Crypto Extensions.
It greatly improves sha-1 based operations, about 10x faster on iMX8M evk board. ~12ms vs ~165ms for a 20MiB kernel sha-1 verification.
asm implementation is a simplified version of the Linux version (from Ard Biesheuvel).
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- arch/arm/cpu/armv8/Kconfig | 10 +++ arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/sha1_ce_core.S | 132 ++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv8/sha1_ce_glue.c | 21 ++++++ 4 files changed, 164 insertions(+) create mode 100644 arch/arm/cpu/armv8/sha1_ce_core.S create mode 100644 arch/arm/cpu/armv8/sha1_ce_glue.c
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 9967376..675cbb8 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -171,4 +171,14 @@ config ARMV8_SECURE_BASE
endif
+menuconfig ARMV8_CRYPTO + bool "ARM64 Accelerated Cryptographic Algorithms" + +if ARMV8_CRYPTO + +config ARMV8_CE_SHA1 + bool "SHA-1 digest algorithm (ARMv8 Crypto Extensions)" + default y +endif + endif diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index 85fe047..ff2495c 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -44,3 +44,4 @@ obj-$(CONFIG_TARGET_HIKEY) += hisilicon/ obj-$(CONFIG_ARMV8_PSCI) += psci.o obj-$(CONFIG_TARGET_BCMNS3) += bcmns3/ obj-$(CONFIG_XEN) += xen/ +obj-$(CONFIG_ARMV8_CE_SHA1) += sha1_ce_glue.o sha1_ce_core.o diff --git a/arch/arm/cpu/armv8/sha1_ce_core.S b/arch/arm/cpu/armv8/sha1_ce_core.S new file mode 100644 index 0000000..f826da3 --- /dev/null +++ b/arch/arm/cpu/armv8/sha1_ce_core.S @@ -0,0 +1,132 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * sha1_ce_core.S - SHA-1 secure hash using ARMv8 Crypto Extensions + * + * Copyright (C) 2014 Linaro Ltd ard.biesheuvel@linaro.org + * Copyright (C) 2022 Linaro Ltd loic.poulain@linaro.org + */ + + #include <config.h> + #include <linux/linkage.h> + #include <asm/system.h> + #include <asm/macro.h> + + .text + .arch armv8-a+crypto + + k0 .req v0 + k1 .req v1 + k2 .req v2 + k3 .req v3 + + t0 .req v4 + t1 .req v5 + + dga .req q6 + dgav .req v6 + dgb .req s7 + dgbv .req v7 + + dg0q .req q12 + dg0s .req s12 + dg0v .req v12 + dg1s .req s13 + dg1v .req v13 + dg2s .req s14 + + .macro add_only, op, ev, rc, s0, dg1 + .ifc \ev, ev + add t1.4s, v\s0().4s, \rc().4s + sha1h dg2s, dg0s + .ifnb \dg1 + sha1\op dg0q, \dg1, t0.4s + .else + sha1\op dg0q, dg1s, t0.4s + .endif + .else + .ifnb \s0 + add t0.4s, v\s0().4s, \rc().4s + .endif + sha1h dg1s, dg0s + sha1\op dg0q, dg2s, t1.4s + .endif + .endm + + .macro add_update, op, ev, rc, s0, s1, s2, s3, dg1 + sha1su0 v\s0().4s, v\s1().4s, v\s2().4s + add_only \op, \ev, \rc, \s1, \dg1 + sha1su1 v\s0().4s, v\s3().4s + .endm + + .macro loadrc, k, val, tmp + movz \tmp, :abs_g0_nc:\val + movk \tmp, :abs_g1:\val + dup \k, \tmp + .endm + + /* + * void sha1_armv8_ce_process(uint32_t state[5], uint8_t const *src, + * uint32_t blocks) + */ +ENTRY(sha1_armv8_ce_process) + /* load round constants */ + loadrc k0.4s, 0x5a827999, w6 + loadrc k1.4s, 0x6ed9eba1, w6 + loadrc k2.4s, 0x8f1bbcdc, w6 + loadrc k3.4s, 0xca62c1d6, w6 + + /* load state (4+1 digest states) */ + ld1 {dgav.4s}, [x0] + ldr dgb, [x0, #16] + + /* load input (64 bytes into v8->v11 16B vectors) */ +0: ld1 {v8.4s-v11.4s}, [x1], #64 + sub w2, w2, #1 +#if __BYTE_ORDER == __LITTLE_ENDIAN + rev32 v8.16b, v8.16b + rev32 v9.16b, v9.16b + rev32 v10.16b, v10.16b + rev32 v11.16b, v11.16b +#endif + +1: add t0.4s, v8.4s, k0.4s + mov dg0v.16b, dgav.16b + + add_update c, ev, k0, 8, 9, 10, 11, dgb + add_update c, od, k0, 9, 10, 11, 8 + add_update c, ev, k0, 10, 11, 8, 9 + add_update c, od, k0, 11, 8, 9, 10 + add_update c, ev, k1, 8, 9, 10, 11 + + add_update p, od, k1, 9, 10, 11, 8 + add_update p, ev, k1, 10, 11, 8, 9 + add_update p, od, k1, 11, 8, 9, 10 + add_update p, ev, k1, 8, 9, 10, 11 + add_update p, od, k2, 9, 10, 11, 8 + + add_update m, ev, k2, 10, 11, 8, 9 + add_update m, od, k2, 11, 8, 9, 10 + add_update m, ev, k2, 8, 9, 10, 11 + add_update m, od, k2, 9, 10, 11, 8 + add_update m, ev, k3, 10, 11, 8, 9 + + add_update p, od, k3, 11, 8, 9, 10 + add_only p, ev, k3, 9 + add_only p, od, k3, 10 + add_only p, ev, k3, 11 + add_only p, od + + /* update state */ + add dgbv.2s, dgbv.2s, dg1v.2s + add dgav.4s, dgav.4s, dg0v.4s + + /* loop on next block? */ + cbz w2, 2f + b 0b + + /* store new state */ +2: st1 {dgav.4s}, [x0] + str dgb, [x0, #16] + mov w0, w2 + ret +ENDPROC(sha1_armv8_ce_process) diff --git a/arch/arm/cpu/armv8/sha1_ce_glue.c b/arch/arm/cpu/armv8/sha1_ce_glue.c new file mode 100644 index 0000000..97a6733 --- /dev/null +++ b/arch/arm/cpu/armv8/sha1_ce_glue.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * sha1_ce_glue.S - SHA-1 secure hash using ARMv8 Crypto Extensions + * + * Copyright (C) 2022 Linaro Ltd loic.poulain@linaro.org + */ + +#include <common.h> +#include <u-boot/sha1.h> + +extern void sha1_armv8_ce_process(uint32_t state[5], uint8_t const *src, + uint32_t blocks); + +void sha1_process(sha1_context *ctx, const unsigned char *data, + unsigned int blocks) +{ + if (!blocks) + return; + + sha1_armv8_ce_process(ctx->state, data, blocks); +}
Loic Poulain
