[U-Boot] [PATCH] cs8900 assign dev->priv before using it
cs8900_get_enetaddr() call get_reg_init_bus(), which will use dev->priv in CONFIG_CS8900_BUS16 config, so we should assign dev->priv before using it.
--- drivers/net/cs8900.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/net/cs8900.c b/drivers/net/cs8900.c index 587f7f6..962b74c 100644 --- a/drivers/net/cs8900.c +++ b/drivers/net/cs8900.c @@ -320,12 +320,12 @@ int cs8900_initialize(u8 dev_num, int base_addr) } memset(priv, 0, sizeof(*priv)); priv->regs = (struct cs8900_regs *)base_addr; + dev->priv = priv;
/* Load MAC address from EEPROM */ cs8900_get_enetaddr(dev);
dev->iobase = base_addr; - dev->priv = priv; dev->init = cs8900_init; dev->halt = cs8900_halt; dev->send = cs8900_send;
Hello Hui,
dev->priv = priv;
Thanks for catching this. I'd prefer to move the 'cs8900_get_enetaddr() call to below all the function pointer assignments. In the interest of getting this bug fix in the current release, I'll just modify your patch and apply it.
Next time please remember your signed-off-by line.
regards, Ben
Ben Warren
Hui Tang
Hui.Tang
