Re: [U-Boot-Users] u-boot compilation
Robert Schwebel robert@schwebel.de schrieb am 05.11.02 21:22:47:
i have used the toolchain 2.95.3 from www.arm.linux.org.uk. I have installed in in /usr/local/arm like discribed in the README file..
My impression when I looked at this toolchain for the last time was that it is only a stage 1 toolchain - at least this is what the build script generates.
What do you mean here - what else than stage 1 can a cross compiler be?!
Regards, Marius.
________________________________________________________________ Keine verlorenen Lotto-Quittungen, keine vergessenen Gewinne mehr! Beim WEB.DE Lottoservice: http://tippen2.web.de/?x=13
Normally when you build a toolchain you first have to build a compiler which is able to work without glibc headers (needs only to have C support). Then you use it to build glibc and afterwards you recompile your compiler with glibc support and whatever languages you need.
At least that was the only way I could manage to build a working toolchain. If you just build a toolchain with faked glibc headers you will not be able to compile more than the kernel with it.
Robert
Marius Gröger
Robert Schwebel
