[U-Boot] [PATCH V5] mpc85xx: inhibit qman and bman portals by default
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is required when supporting power management.
Signed-off-by: Jeffrey Ladouceur Jeffrey.Ladouceur@freescale.com --- The following dependent patches should be applied first: http://patchwork.ozlabs.org/patch/403532 http://patchwork.ozlabs.org/patch/403533 http://patchwork.ozlabs.org/patch/403540 http://patchwork.ozlabs.org/patch/403534 http://patchwork.ozlabs.org/patch/403535 http://patchwork.ozlabs.org/patch/403538 http://patchwork.ozlabs.org/patch/403536 http://patchwork.ozlabs.org/patch/403539
Changes in v5: - Qman portals also require their isdr register to be set in order to support power management (sleep, deepsleep). Otherwise QMan will appear to not be idle if all portals are not managed by the OS.
Changes in v4: - The assertion that reading from portal reserved memory would return zero is incorrect. Therefore modify code to depend on specified number of portals in board config file
Changes in v3: - Update subject title to be consistent Changes in v2: - Removed P1023RDS as it is no longer supported.
arch/powerpc/cpu/mpc85xx/portals.c | 43 +++++++++++++++++++++++++++++++++++ include/configs/B4860QDS.h | 16 +++++++++++++ include/configs/P1023RDB.h | 16 +++++++++++++ include/configs/P2041RDB.h | 16 +++++++++++++ include/configs/T102xQDS.h | 16 +++++++++++++ include/configs/T102xRDB.h | 16 +++++++++++++ include/configs/T1040QDS.h | 16 +++++++++++++ include/configs/T104xRDB.h | 16 +++++++++++++ include/configs/T208xQDS.h | 16 +++++++++++++ include/configs/T208xRDB.h | 16 +++++++++++++ include/configs/T4240EMU.h | 16 +++++++++++++ include/configs/T4240QDS.h | 16 +++++++++++++ include/configs/T4240RDB.h | 16 +++++++++++++ include/configs/corenet_ds.h | 16 +++++++++++++ include/configs/km/kmp204x-common.h | 16 +++++++++++++ 15 files changed, 267 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index 98815f8..ec3b292 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -14,9 +14,46 @@ #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h>
+#define MAX_BPORTALS (CONFIG_SYS_BMAN_CINH_SIZE / CONFIG_SYS_BMAN_SP_CINH_SIZE) +#define MAX_QPORTALS (CONFIG_SYS_QMAN_CINH_SIZE / CONFIG_SYS_QMAN_SP_CINH_SIZE) +static void inhibit_portals(void __iomem *addr, int max_portals, + int arch_max_portals, int portal_cinh_size) +{ + uint32_t val; + int i; + + /* arch_max_portals is the maximum based on memory size. This includes + * the reserved memory in the SoC. max_portals the number of physical + * portals in the SoC */ + if (max_portals > arch_max_portals) { + printf("ERROR: portal config error\n"); + max_portals = arch_max_portals; + } + + for (i = 0; i < max_portals; i++) { + out_be32(addr, -1); + val = in_be32(addr); + if (!val) { + printf("ERROR: Stopped after %d portals\n", i); + goto done; + } + addr += portal_cinh_size; + } +#ifdef DEBUG + printf("Cleared %d portals\n", i); +#endif +done: + + return; +} + void setup_portals(void) { ccsr_qman_t *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; + void __iomem *bpaddr = (void *)CONFIG_SYS_BMAN_CINH_BASE + + CONFIG_SYS_BMAN_SWP_ISDR_REG; + void __iomem *qpaddr = (void *)CONFIG_SYS_QMAN_CINH_BASE + + CONFIG_SYS_QMAN_SWP_ISDR_REG; #ifdef CONFIG_FSL_CORENET int i;
@@ -38,6 +75,12 @@ void setup_portals(void) out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); #endif out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); + + /* Change default state of BMan ISDR portals to all 1s */ + inhibit_portals(bpaddr, CONFIG_SYS_BMAN_NUM_PORTALS, MAX_BPORTALS, + CONFIG_SYS_BMAN_SP_CINH_SIZE); + inhibit_portals(qpaddr, CONFIG_SYS_QMAN_NUM_PORTALS, MAX_QPORTALS, + CONFIG_SYS_QMAN_SP_CINH_SIZE); }
/* Update portal containter to match LAW setup of portal in phy map */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index dc1a9bc..4256488 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -641,6 +641,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT @@ -649,6 +657,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #endif #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN
diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 6b29add..bc51d82 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -344,9 +344,25 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_QMAN_MEM_BASE 0xff000000 #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08
/* For FM */ #define CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 2e11aaa..d3701d0 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -489,6 +489,14 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #ifdef CONFIG_PHYS_64BIT @@ -497,6 +505,14 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #endif #define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 5f8f749..27624f7 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -724,6 +724,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT @@ -732,6 +740,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #endif #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 2960bd1..6c36f86 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -685,6 +685,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT @@ -693,6 +701,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #endif #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 2178f9d..8eca546 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -607,10 +607,26 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 216f34f..b023e9a 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -630,10 +630,26 @@ #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 2f381e7..9876b3e 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -617,10 +617,26 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 18 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 47b3bd5..db6b42e 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -567,10 +567,26 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 18 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h index 53c69b0..e8ba5d6 100644 --- a/include/configs/T4240EMU.h +++ b/include/configs/T4240EMU.h @@ -85,10 +85,26 @@ #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 1e0f5ec..dd7d52f 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -417,10 +417,26 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 48b8dc7..dbe1682 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -577,10 +577,26 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 72b7efa..225ffdd 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -495,6 +495,14 @@ #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #ifdef CONFIG_PHYS_64BIT @@ -503,6 +511,14 @@ #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #endif #define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
#define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 864e5f1..949b3da 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -339,10 +339,26 @@ int get_scl(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff4200000ull #define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Applied to u-boot-mpc85xx master, awaiting upstream.
York
Jeffrey Ladouceur
York Sun
