[U-Boot-Users] [PATCH] mpc86xx: Convert to using new law setup code
This patch converts 86xx to the new law setup in C that Kumar posted recently.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- board/freescale/mpc8641hpcn/Makefile | 2 +- board/freescale/mpc8641hpcn/law.c | 64 ++++++++++++++++++++++++++++++++++ cpu/mpc86xx/cpu_init.c | 7 ++++ cpu/mpc86xx/spd_sdram.c | 16 ++++++++- cpu/mpc86xx/start.S | 2 + include/configs/MPC8641HPCN.h | 1 + 6 files changed, 90 insertions(+), 2 deletions(-) create mode 100644 board/freescale/mpc8641hpcn/law.c
diff --git a/board/freescale/mpc8641hpcn/Makefile b/board/freescale/mpc8641hpcn/Makefile index 201da3e..e73e7ba 100644 --- a/board/freescale/mpc8641hpcn/Makefile +++ b/board/freescale/mpc8641hpcn/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o +COBJS := $(BOARD).o law.o
SOBJS := init.o
diff --git a/board/freescale/mpc8641hpcn/law.c b/board/freescale/mpc8641hpcn/law.c new file mode 100644 index 0000000..245f420 --- /dev/null +++ b/board/freescale/mpc8641hpcn/law.c @@ -0,0 +1,64 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x7fff_ffff DDR 2G + * 0x8000_0000 0x9fff_ffff PCI1 MEM 512M + * 0xa000_0000 0xbfff_ffff PCI2 MEM 512M + * 0xc000_0000 0xdfff_ffff RapidIO 512M + * 0xe200_0000 0xe2ff_ffff PCI1 IO 16M + * 0xe300_0000 0xe3ff_ffff PCI2 IO 16M + * 0xf800_0000 0xf80f_ffff CCSRBAR 1M + * 0xf810_0000 0xf81f_ffff PIXIS 1M + * 0xfe00_0000 0xffff_ffff FLASH (boot bank) 32M + * + * Notes: + * CCSRBAR don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + */ + +struct law_entry law_table[] = { +#if !defined(CONFIG_SPD_EEPROM) + SET_LAW_ENTRY(1, CFG_DDR_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_DDR_1), +#endif + SET_LAW_ENTRY(2, CFG_PCI1_MEM_BASE, LAW_SIZE_512M, LAW_TRGT_IF_PCI_1), + SET_LAW_ENTRY(3, CFG_PCI2_MEM_BASE, LAW_SIZE_512M, LAW_TRGT_IF_PCI_2), + SET_LAW_ENTRY(4, PIXIS_BASE, LAW_SIZE_2M, LAW_TRGT_IF_LBC), + SET_LAW_ENTRY(5, CFG_PCI1_IO_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_PCI_1), + SET_LAW_ENTRY(6, CFG_PCI2_IO_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_PCI_2), + SET_LAW_ENTRY(7, (CFG_FLASH_BASE & 0xfe000000), LAW_SIZE_32M, LAW_TRGT_IF_LBC), +#if !defined(CONFIG_SPD_EEPROM) + SET_LAW_ENTRY(8, CFG_DDR_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_DDR_2), +#endif + SET_LAW_ENTRY(9, CFG_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/cpu/mpc86xx/cpu_init.c b/cpu/mpc86xx/cpu_init.c index 4f8956e..ab5906d 100644 --- a/cpu/mpc86xx/cpu_init.c +++ b/cpu/mpc86xx/cpu_init.c @@ -49,6 +49,10 @@ void cpu_init_f(void) /* Clear initial global data */ memset ((void *) gd, 0, sizeof (gd_t));
+#ifdef CONFIG_FSL_LAW + init_laws(); +#endif + /* Map banks 0 and 1 to the FLASH banks 0 and 1 at preliminary * addresses - these have to be modified later when FLASH size * has been determined @@ -114,5 +118,8 @@ void cpu_init_f(void) */ int cpu_init_r(void) { +#ifdef CONFIG_FSL_LAW + disable_law(0); +#endif return 0; } diff --git a/cpu/mpc86xx/spd_sdram.c b/cpu/mpc86xx/spd_sdram.c index 54e40f1..bfea4b3 100644 --- a/cpu/mpc86xx/spd_sdram.c +++ b/cpu/mpc86xx/spd_sdram.c @@ -27,7 +27,7 @@ #include <i2c.h> #include <spd.h> #include <asm/mmu.h> - +#include <asm/fsl_law.h>
#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) extern void dma_init(void); @@ -1179,12 +1179,16 @@ spd_sdram(void) /* * Set up LAWBAR for DDR 1 space. */ +#ifdef CONFIG_FSL_LAW + set_law(1, CFG_DDR_SDRAM_BASE, law_size_interleaved, LAW_TRGT_IF_DDR_INTRLV); +#else mcm->lawbar1 = ((CFG_DDR_SDRAM_BASE >> 12) & 0xfffff); mcm->lawar1 = (LAWAR_EN | LAWAR_TRGT_IF_DDR_INTERLEAVED | (LAWAR_SIZE & law_size_interleaved)); debug("DDR: LAWBAR1=0x%08x\n", mcm->lawbar1); debug("DDR: LAWAR1=0x%08x\n", mcm->lawar1); +#endif debug("Interleaved memory size is 0x%08lx\n", memsize_total);
#ifdef CONFIG_DDR_INTERLEAVE @@ -1239,12 +1243,16 @@ spd_sdram(void) /* * Set up LAWBAR for DDR 1 space. */ +#ifdef CONFIG_FSL_LAW + set_law(1, CFG_DDR_SDRAM_BASE, law_size_ddr1, LAW_TRGT_IF_DDR_1); +#else mcm->lawbar1 = ((CFG_DDR_SDRAM_BASE >> 12) & 0xfffff); mcm->lawar1 = (LAWAR_EN | LAWAR_TRGT_IF_DDR1 | (LAWAR_SIZE & law_size_ddr1)); debug("DDR: LAWBAR1=0x%08x\n", mcm->lawbar1); debug("DDR: LAWAR1=0x%08x\n", mcm->lawar1); +#endif }
#if (CONFIG_NUM_DDR_CONTROLLERS > 1) @@ -1269,6 +1277,11 @@ spd_sdram(void) /* * Set up LAWBAR for DDR 2 space. */ +#ifdef CONFIG_FSL_LAW + set_law(8, + (ddr1_enabled ? (memsize_ddr1 * 1024 * 1024) : CFG_DDR_SDRAM_BASE), + law_size_ddr2, LAW_TRGT_IF_DDR_2); +#else if (ddr1_enabled) mcm->lawbar8 = (((memsize_ddr1 * 1024 * 1024) >> 12) & 0xfffff); @@ -1280,6 +1293,7 @@ spd_sdram(void) | (LAWAR_SIZE & law_size_ddr2)); debug("\nDDR: LAWBAR8=0x%08x\n", mcm->lawbar8); debug("DDR: LAWAR8=0x%08x\n", mcm->lawar8); +#endif }
debug("\nMemory size of DDR2 = 0x%08lx\n", memsize_ddr2); diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index 6cf145f..99f96f8 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -283,8 +283,10 @@ in_flash: bl setup_ccsrbar #endif
+#ifndef CONFIG_FSL_LAW bl law_entry sync +#endif
/* run low-level CPU init code (from Flash) */ bl cpu_init_f diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index ab875f0..be96696 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -49,6 +49,7 @@ #define CONFIG_PCI1 1 /* PCIE controler 1 (ULI bridge) */ #define CONFIG_PCI2 1 /* PCIE controler 2 (slot) */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ +#define CONFIG_FSL_LAW 1 /* Use common FSL law init code */
#define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
Becky Bruce
