Pull request: u-boot-spi/master
Hi Tom,
Please pull this PR.
thanks, Jagan.
The following changes since commit 8d5d3bcf3c53d798bd7f3fe7092e994593bcc41c:
Merge branch '2020-04-16-master-imports' (2020-04-17 11:17:29 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-spi master
for you to fetch changes up to 48465bbc84d2f3824641b7627f417e36f515c896:
mtd: spi-nor-ids: Add Spansion s25fs512s flash entry (2020-04-20 23:55:06 +0530)
---------------------------------------------------------------- Bacem Daassi (1): mtd: spi-nor: Enable dual and quad read for s25fl256s0
Jagan Teki (7): environment: distro: Add SF distro command rk3399: Add boot flash script offset, size rockchip: Enable SF distro bootcmd spi: sifive: Tidy up dm_spi_slave_platdata variable mtd: spi-nor: Enable QE bit for ISSI flash mtd: spi-nor-ids: Enable 4B_OPCODES for is25wp256 watchdog: kconfig: Enable designware for rk3399
Kuldeep Singh (3): spi: Transform the FSL QuadSPI driver to use the SPI MEM API mtd: spi-nor-ids: Enable SPI_NOR_OCTAL_READ flag for mt35xu* mtd: spi-nor-ids: Add Spansion s25fs512s flash entry
Pratyush Yadav (1): spi: cadence-qspi: Move ref clock calculation to probe
Rasmus Villemoes (1): spi: use is_power_of_2 instead of hweight32 in spi_nor_write()
Robert Marko (2): mtd: spi-nand: Import Toshiba SPI-NAND support mtd: nand: spi: add support for Toshiba TC58CVG2S0HRAIJ
Tudor Ambarus (1): spi: spi-mem: Add SPI_MEM_NO_DATA to the spi_mem_data_dir enum
drivers/mtd/nand/spi/Makefile | 2 +- drivers/mtd/nand/spi/core.c | 1 + drivers/mtd/nand/spi/toshiba.c | 201 +++++ drivers/mtd/spi/spi-nor-core.c | 6 +- drivers/mtd/spi/spi-nor-ids.c | 12 +- drivers/spi/cadence_qspi.c | 33 +- drivers/spi/fsl_qspi.c | 1577 ++++++++++++++----------------------- drivers/spi/fsl_qspi.h | 145 ---- drivers/spi/spi-mem.c | 2 +- drivers/spi/spi-sifive.c | 30 +- drivers/watchdog/Kconfig | 1 + include/configs/rk3399_common.h | 3 + include/configs/rockchip-common.h | 9 +- include/environment/distro/sf.h | 41 + include/linux/mtd/spi-nor.h | 1 + include/linux/mtd/spinand.h | 1 + include/spi-mem.h | 2 + 17 files changed, 910 insertions(+), 1157 deletions(-) create mode 100644 drivers/mtd/nand/spi/toshiba.c delete mode 100644 drivers/spi/fsl_qspi.h create mode 100644 include/environment/distro/sf.h
On Tue, Apr 21, 2020 at 01:54:04PM +0530, Jagan Teki wrote:
Hi Tom,
thanks, Jagan.
NAK, a handful of boards fail like this: +(firefly-px30) In file included from include/configs/px30_common.h:52, +(firefly-px30) from include/configs/evb_px30.h:9, +(firefly-px30) from include/config.h:5, +(firefly-px30) from include/common.h:16, +(firefly-px30) from env/common.c:10: +(firefly-px30) include/config_distro_bootcmd.h:402:2: error: expected '}' before 'BOOTENV_DEV_NAME_SF' +(firefly-px30) 402 | BOOTENV_DEV_NAME_##devtypeu(devtypeu, devtypel, instance) +(firefly-px30) | ^~~~~~~~~~~~~~~~~ +(firefly-px30) include/configs/rockchip-common.h:45:31: note: in expansion of macro 'BOOTENV_DEV_NAME' +(firefly-px30) 45 | #define BOOT_TARGET_SF(func) func(SF, sf, 0) +(firefly-px30) | ^~~~ +(firefly-px30) include/configs/rockchip-common.h:55:2: note: in expansion of macro 'BOOT_TARGET_SF' +(firefly-px30) 55 | BOOT_TARGET_SF(func) +(firefly-px30) | ^~~~~~~~~~~~~~ +(firefly-px30) include/config_distro_bootcmd.h:404:18: note: in expansion of macro 'BOOT_TARGET_DEVICES' +(firefly-px30) 404 | "boot_targets=" BOOT_TARGET_DEVICES(BOOTENV_DEV_NAME) "\0" +(firefly-px30) | ^~~~~~~~~~~~~~~~~~~ +(firefly-px30) include/config_distro_bootcmd.h:423:2: note: in expansion of macro 'BOOTENV_BOOT_TARGETS' +(firefly-px30) 423 | BOOTENV_BOOT_TARGETS \ +(firefly-px30) | ^~~~~~~~~~~~~~~~~~~~ +(firefly-px30) include/configs/px30_common.h:58:2: note: in expansion of macro 'BOOTENV' +(firefly-px30) 58 | BOOTENV +(firefly-px30) | ^~~~~~~ +(firefly-px30) include/env_default.h:111:2: note: in expansion of macro 'CONFIG_EXTRA_ENV_SETTINGS' +(firefly-px30) 111 | CONFIG_EXTRA_ENV_SETTINGS +(firefly-px30) | ^~~~~~~~~~~~~~~~~~~~~~~~~ +(firefly-px30) In file included from env/common.c:26: +(firefly-px30) include/env_default.h:22:37: note: to match this '{' +(firefly-px30) 22 | const uchar default_environment[] = { +(firefly-px30) | ^ +(firefly-px30) make[2]: *** [env/common.o] Error 1 +(firefly-px30) make[1]: *** [env] Error 2 +(firefly-px30) make: *** [sub-make] Error 2
See https://gitlab.denx.de/u-boot/u-boot/-/jobs/80958 and https://gitlab.denx.de/u-boot/u-boot/-/jobs/80910
Jagan Teki
