[PATCH 1/1] test: build dependency for event unit tests
The test_event_base and test_event_probe unit tests use function event_register() which depends on CONFIG_EVENT_DYNAMIC=y.
Fixes: 7d02645fe4c0 ("event: Add a simple test") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- test/common/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/common/Makefile b/test/common/Makefile index a5ab10f6f6..12c65f8c95 100644 --- a/test/common/Makefile +++ b/test/common/Makefile @@ -2,5 +2,5 @@ obj-y += cmd_ut_common.o obj-$(CONFIG_AUTOBOOT) += test_autoboot.o obj-$(CONFIG_CYCLIC) += cyclic.o -obj-$(CONFIG_EVENT) += event.o +obj-$(CONFIG_EVENT_DYNAMIC) += event.o obj-y += cread.o
On Thu, 7 Sept 2023 at 10:45, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Fixes: 7d02645fe4c0 ("event: Add a simple test") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org
