[U-Boot] [PATCH] ARM: socfpga: Enable DM I2C framework on A10
13 Aug
2018
13 Aug
'18
8:54 p.m.
Enable the DM I2C framework on Arria10, so that the DM capable Designware I2C driver can handle the reset via DM reset framework.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 368f217fc6..63ce32ff66 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -11,6 +11,7 @@ config TARGET_SOCFPGA_ARRIA10 bool select ALTERA_SDRAM select SPL_BOARD_INIT if SPL + select DM_I2C select DM_RESET select SPL_DM_RESET if SPL
2.16.2
2465
