[PATCH v2 1/2] lmb: Fix LMB_MEMORY_REGIONS flag usage
Remove test on CONFIG_LMB_MEMORY_REGIONS introduced by commit 7c1860fce4e3 ("lmb: Fix lmb property's defination under struct lmb").
This code in lmb_init() is strange, because if CONFIG_LMB_USE_MAX_REGIONS and CONFIG_LMB_MEMORY_REGIONS are not defined, the implicit #else is empty and the required initialization is not done: lmb->memory.max = ? lmb->reserved.max = ?
But this setting is not possible: - CONFIG_LMB_USE_MAX_REGIONS not defined - CONFIG_LMB_MEMORY_REGIONS not defined because CONFIG_LMB_MEMORY_REGIONS and CONFIG_LMB_RESERVED_REGIONS are defined as soon as the CONFIG_LMB_USE_MAX_REGIONS is not defined.
This patch removes this impossible case #elif and I add some explanation in lmb.h to explain why in the struct lmb {} the lmb property is defined if CONFIG_LMB_MEMORY_REGIONS is NOT defined.
This patch also removes CONFIG_LMB_XXX dependency on CONFIG_LMB as these defines are used in API file lmb.h and not only in library file.
Fixes: 5e2548c1d6e03 ("lmb: Fix LMB_MEMORY_REGIONS flag usage") Reported-by: Mark Millard marklmi@yahoo.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
Changes in v2: - Remove CONFIG_LMB_XXX dependency on CONFIG_LMB as these defines are used in lmb.h file, include by default to export the LMB API and not only in LMB libary code. This modification is required to avoid issue in API definition when CONFIG_LMB is not set. - Fix some typo in commit message and in comment
include/lmb.h | 20 +++++++++++++++++++- lib/Kconfig | 7 +++---- lib/lmb.c | 2 +- 3 files changed, 23 insertions(+), 6 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 7298c2ccc403..07bf22144eac 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -35,6 +35,24 @@ struct lmb_property { enum lmb_flags flags; };
+/* + * For regions size management, see LMB configuration in KConfig + * all the #if test are done with CONFIG_LMB_USE_MAX_REGIONS (boolean) + * + * case 1. CONFIG_LMB_USE_MAX_REGIONS is defined (legacy mode) + * => CONFIG_LMB_MAX_REGIONS is used to configure the region size, + * directly in the array lmb_region.region[], with the same + * configuration for memory and reserved regions. + * + * case 2. CONFIG_LMB_USE_MAX_REGIONS is not defined, the size of each + * region is configurated *independently* with + * => CONFIG_LMB_MEMORY_REGIONS: struct lmb.memory_regions + * => CONFIG_LMB_RESERVED_REGIONS: struct lmb.reserved_regions + * lmb_region.region is only a pointer to the correct buffer, + * initialized in lmb_init(). This configuration is useful to manage + * more reserved memory regions with CONFIG_LMB_RESERVED_REGIONS. + */ + /** * struct lmb_region - Description of a set of region. * @@ -68,7 +86,7 @@ struct lmb_region { struct lmb { struct lmb_region memory; struct lmb_region reserved; -#ifdef CONFIG_LMB_MEMORY_REGIONS +#if !IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) struct lmb_property memory_regions[CONFIG_LMB_MEMORY_REGIONS]; struct lmb_property reserved_regions[CONFIG_LMB_RESERVED_REGIONS]; #endif diff --git a/lib/Kconfig b/lib/Kconfig index 83e5edd73b0e..da6c7cd5f628 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -1027,7 +1027,6 @@ config LMB
config LMB_USE_MAX_REGIONS bool "Use a common number of memory and reserved regions in lmb lib" - depends on LMB default y help Define the number of supported memory regions in the library logical @@ -1037,7 +1036,7 @@ config LMB_USE_MAX_REGIONS
config LMB_MAX_REGIONS int "Number of memory and reserved regions in lmb lib" - depends on LMB && LMB_USE_MAX_REGIONS + depends on LMB_USE_MAX_REGIONS default 16 help Define the number of supported regions, memory and reserved, in the @@ -1045,7 +1044,7 @@ config LMB_MAX_REGIONS
config LMB_MEMORY_REGIONS int "Number of memory regions in lmb lib" - depends on LMB && !LMB_USE_MAX_REGIONS + depends on !LMB_USE_MAX_REGIONS default 8 help Define the number of supported memory regions in the library logical @@ -1054,7 +1053,7 @@ config LMB_MEMORY_REGIONS
config LMB_RESERVED_REGIONS int "Number of reserved regions in lmb lib" - depends on LMB && !LMB_USE_MAX_REGIONS + depends on !LMB_USE_MAX_REGIONS default 8 help Define the number of supported reserved regions in the library logical diff --git a/lib/lmb.c b/lib/lmb.c index 2444b2a62121..8fbe453dfa9d 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -110,7 +110,7 @@ void lmb_init(struct lmb *lmb) #if IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) lmb->memory.max = CONFIG_LMB_MAX_REGIONS; lmb->reserved.max = CONFIG_LMB_MAX_REGIONS; -#elif defined(CONFIG_LMB_MEMORY_REGIONS) +#else lmb->memory.max = CONFIG_LMB_MEMORY_REGIONS; lmb->reserved.max = CONFIG_LMB_RESERVED_REGIONS; lmb->memory.region = lmb->memory_regions;
Add the max number of region in lmb dump; this patch allows to check the limit for usage of the LMB regions, memory or reserved.
Result on STM32MP157C-DK2:
STM32MP> bdinfo ..... lmb_dump_all: memory.cnt = 0x1 / max = 0x2 memory[0] [0xc0000000-0xdfffffff], 0x20000000 bytes flags: 0 reserved.cnt = 0x6 / max = 0x10 reserved[0] [0x10000000-0x10045fff], 0x00046000 bytes flags: 4 reserved[1] [0x30000000-0x3003ffff], 0x00040000 bytes flags: 4 reserved[2] [0x38000000-0x3800ffff], 0x00010000 bytes flags: 4 reserved[3] [0xd4000000-0xd7ffffff], 0x04000000 bytes flags: 4 reserved[4] [0xdcae5000-0xdfffffff], 0x0351b000 bytes flags: 0 reserved[5] [0xddafb5b8-0xdfffffff], 0x02504a48 bytes flags: 0 ....
(no changes since v1)
lib/lmb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 8fbe453dfa9d..b2c233edb64e 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -27,7 +27,7 @@ static void lmb_dump_region(struct lmb_region *rgn, char *name) enum lmb_flags flags; int i;
- printf(" %s.cnt = 0x%lx\n", name, rgn->cnt); + printf(" %s.cnt = 0x%lx / max = 0x%lx\n", name, rgn->cnt, rgn->max);
for (i = 0; i < rgn->cnt; i++) { base = rgn->region[i].base;
Changes in v2:
- For regions size management, see LMB configuration in KConfig
- all the #if test are done with CONFIG_LMB_USE_MAX_REGIONS (boolean)
- case 1. CONFIG_LMB_USE_MAX_REGIONS is defined (legacy mode)
- case 2. CONFIG_LMB_USE_MAX_REGIONS is not defined, the size of each
- struct lmb_region - Description of a set of region.
- depends on LMB_USE_MAX_REGIONS default 16 help Define the number of supported regions, memory and reserved, in the
- depends on !LMB_USE_MAX_REGIONS default 8 help Define the number of supported memory regions in the library logical
- depends on !LMB_USE_MAX_REGIONS default 8 help Define the number of supported reserved regions in the library logical
Acked-by: Michal Simek michal.simek@amd.com
Thanks, Michal
Fixes: 5e2548c1d6e03 ("lmb: Fix LMB_MEMORY_REGIONS flag usage") Reported-by: Mark Millard marklmi@yahoo.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Acked-by: Michal Simek michal.simek@amd.com
Michal Simek
Patrick Delaunay
