[U-Boot] [PATCH v2 1/3] board_f: Add mach specific DMA address check function.
From: Christoph Müllner christoph.muellner@theobroma-systems.com
Some machines have limited DMA engines, which cannot deal with arbitrary addresses. This patch introduces a function to model these restrictions on a machine level.
Signed-off-by: Christoph Müllner christoph.muellner@theobroma-systems.com Signed-off-by: Christoph Muellner christoph.muellner@theobroma-systems.com ---
Changes in v2: None
common/board_f.c | 5 +++++ include/init.h | 2 ++ 2 files changed, 7 insertions(+)
diff --git a/common/board_f.c b/common/board_f.c index 7ef20f2042..92dc34d2d8 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -1053,3 +1053,8 @@ void board_init_f_r(void) hang(); } #endif /* CONFIG_X86 */ + +__weak int mach_addr_is_dmaable(void __iomem *ptr) +{ + return 1; +} diff --git a/include/init.h b/include/init.h index afc953d51e..1653d5086f 100644 --- a/include/init.h +++ b/include/init.h @@ -125,6 +125,8 @@ int misc_init_f(void); int embedded_dtb_select(void); #endif
+int mach_addr_is_dmaable(void __iomem *ptr); + /* common/init/board_init.c */ extern ulong monitor_flash_len;
Currently addr_aligned() performs an alignment and a length check to validate the DMA address. However, some machines have stricter restrictions of DMA-able addresses.
This patch adds a call to mach_addr_is_dmaable() to honor this machine specific restrictions.
Changes in v2: None
common/bouncebuf.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/common/bouncebuf.c b/common/bouncebuf.c index a7098e2caf..1b82243b06 100644 --- a/common/bouncebuf.c +++ b/common/bouncebuf.c @@ -26,6 +26,12 @@ static int addr_aligned(struct bounce_buffer *state) return 0; }
+ /* Check if valid DMA address. */ + if (!mach_addr_is_dmaable(state->user_buffer)) { + debug("Buffer address is not DMA-able\n"); + return 0; + } + /* Aligned */ return 1; }
Patches on the U-Boot mailing list from Rockchip engineers indicate, that the RK3399's DMA engines are not able to use addresses in high-memory (above 0xf8000000).
This patch models this restriction in an RK3399 specific mach_addr_is_dmaable() function.
Changes in v2: - Convert argument type from unsigned long to void pointer.
arch/arm/mach-rockchip/rk3399/rk3399.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index a7ccd4f3ed..8895417bda 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -109,3 +109,16 @@ void board_debug_uart_init(void) #endif } #endif + +int mach_addr_is_dmaable(void __iomem *ptr) +{ + uintptr_t addr = (uintptr_t)ptr; + + /* + * The RK3399 cannot cope with high-memory DMA targets/sources. + */ + if (addr < 0xf8000000UL) + return 1; + + return 0; +}
Hi Christoph,
On Tue, 7 May 2019 at 09:59, Christoph Muellner christoph.muellner@theobroma-systems.com wrote:
Changes in v2: None
Can we handle this with driver model somehow? How does the kernel handle it? Is there a device-tree binding for the DMA node that could provide this information.
Also, where is this function called from?
Hi Simon,
Am Samstag, 18. Mai 2019, 18:08:58 CEST schrieb Simon Glass:
Changes in v2: None
The problem Christoph is trying to solve here is doing a mmc transfer from mmc to the sram (not main memory), which cannot use dma. So this exact problem doesn't happen in the kernel itself.
But back in veyron times we had a similar dma issue with anything accessing that area as dma hung the system, but the solution was just reserving the memblock: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
As the commit describes, other options would've been soc-settings also going around the kernel's driver model or limiting the dma-able memory even more (to 2GB), so we opted to just reserve the upper 16MB completely.
I don't think so. At least in the kernel affecting the dma-mask is a setting for the using component (mmc, gmac, whatever), so would mean adapting every device doing dma ... and even then there wasn't a dt-binding for something like that, which in turn would've required to adapt every driver to set a specific per-soc dma-mask for Rockchip compatibles - hence the "simple" reserve above was the least intrusive option.
In the theobroma u-boot it gets called from the bouncebuffer right now https://git.theobroma-systems.com/puma-u-boot.git/commit/?id=d68222d45b4e7f5... to check if the mmc drivers can dma directly or needs to use the bouncebuffer for reaching something like the sram.
Heiko
Hi Heiko,
On Wed, 22 May 2019 at 05:29, Heiko Stuebner heiko@sntech.de wrote:
Hi Simon,
Changes in v2: None
OK I see.
That's odd. Are you saying that some devices can DMA from SRAM and some cannot?
If the DMA is not allowed, could the DMA driver return -EPERM or similar when the attempt is made, and then the bounce buffer can be used if needed?
OK ta.
Heiko
On 23.05.19 00:57, Simon Glass wrote:
Hi Heiko,
Hi Simon,
Changes in v2: None
OK I see.
Yes, that is also confirmed by Kever (see commit message of [1]). My patch series assumes, that only the CPU can see the non-DDR memory areas (including SRAM). I would really like to get feedback here from Kever.
Kever has posted a first patch to address this end of March [2]. After waiting a few weeks, I've prepared a reworked version (because I needed it for mainline ATF testing on our RK3399-Q7). A few hours after I sent them to the list Kever also pushed another patch for this [1].
From my perspective mainline ATF cannot be used with mainline U-Boot
on RK3399 when booting from SD card or eMMC at the moment.
[1] https://patchwork.ozlabs.org/patch/1096366/ [2] https://patchwork.ozlabs.org/patch/1069730/
OK ta.
Heiko
Christoph Muellner
Christoph Müllner
Heiko Stuebner
