[U-Boot] [PATCH v3 1/2] power: pmic: Kconfig: Add SPL_PMIC configs for palmas/lp873x/lp87565
Add SPL_PMIC configs for palmas/lp873x/lp87565. These were missing and the Makefile already assumes them to be defined. Add the corresponding SPL config options. This enables the pmics in SPL.
Signed-off-by: Keerthy j-keerthy@ti.com ---
Changes in v3:
* As per Tom's comments added the SPL_* configs instead of removing SPL in Makefile
drivers/power/pmic/Kconfig | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index b0cd260354..064b383880 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -238,3 +238,24 @@ config PMIC_STPMIC1 The STPMIC1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2 power switches. It is accessed via an I2C interface. The device is used with STM32MP1 SoCs. This driver implements register read/write operations. + +config SPL_PMIC_PALMAS + bool "Enable driver for Texas Instruments PALMAS PMIC" + depends on DM_PMIC + help + The PALMAS is a PMIC containing several LDOs, SMPS. + This driver binds the pmic children in SPL. + +config SPL_PMIC_LP873X + bool "Enable driver for Texas Instruments LP873X PMIC" + depends on DM_PMIC + help + The LP873X is a PMIC containing couple of LDOs and couple of SMPS. + This driver binds the pmic children in SPL. + +config SPL_PMIC_LP87565 + bool "Enable driver for Texas Instruments LP87565 PMIC" + depends on DM_PMIC + help + The LP87565 is a PMIC containing a bunch of SMPS. + This driver binds the pmic children in SPL.
Add SPL_DM_REGULATOR configs for palmas/lp873x/lp87565. These were missing and the Makefile already assumes them to be defined. Add the corresponding SPL config options. This enables the regulator support in SPL.
Changes in v3:
drivers/power/regulator/Kconfig | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 72dfc48981..4e6c440d13 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -258,3 +258,29 @@ config SPL_DM_REGULATOR_STPMIC1 depends on SPL_DM_REGULATOR && PMIC_STPMIC1 help Enable support for the regulator functions of the STPMIC1 PMIC in SPL. + +config SPL_DM_REGULATOR_PALMAS + bool "Enable driver for PALMAS PMIC regulators" + depends on SPL_PMIC_PALMAS + help + This enables implementation of driver-model regulator uclass + features for REGULATOR PALMAS and the family of PALMAS PMICs. + The driver implements get/set api for: value and enable in SPL. + +config SPL_DM_REGULATOR_LP87565 + bool "Enable driver for LP87565 PMIC regulators" + depends on SPL_PMIC_LP87565 + help + This enables implementation of driver-model regulator uclass + features for REGULATOR LP87565 and the family of LP87565 PMICs. + LP87565 series of PMICs have 4 single phase BUCKs that can also + be configured in multi phase modes. The driver implements + get/set api for value and enable in SPL. + +config SPL_DM_REGULATOR_LP873X + bool "Enable driver for LP873X PMIC regulators" + depends on SPL_PMIC_LP873X + help + This enables implementation of driver-model regulator uclass + features for REGULATOR LP873X and the family of LP873X PMICs. + The driver implements get/set api for: value and enable in SPL.
Keerthy
