[U-Boot] [PATCH] ARM: OMAP4: Fix bug in omap4470_volts struct
The struct incorrectly referenced SMPS1 for all three power domains. Fixed this by using SMPS2 and SMPS5 as appropriate.
Add some comments and choose voltage values that correspond to voltage selection codes.
Signed-off-by: Lubomir Popov l-popov@ti.com --- arch/arm/cpu/armv7/omap4/hw_data.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c index 6a225c8..1b2f439 100644 --- a/arch/arm/cpu/armv7/omap4/hw_data.c +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -288,17 +288,21 @@ struct vcores_data omap4460_volts = { .mm.pmic = &twl6030, };
+/* + * Take closest integer part of the mV value corresponding to a TWL6032 SMPS + * voltage selection code. Aligned with OMAP4470 ES1.0 OCA V.0.7. + */ struct vcores_data omap4470_volts = { - .mpu.value = 1200, + .mpu.value = 1202, .mpu.addr = SMPS_REG_ADDR_SMPS1, .mpu.pmic = &twl6030,
.core.value = 1126, - .core.addr = SMPS_REG_ADDR_SMPS1, + .core.addr = SMPS_REG_ADDR_SMPS2, .core.pmic = &twl6030,
- .mm.value = 1137, - .mm.addr = SMPS_REG_ADDR_SMPS1, + .mm.value = 1139, + .mm.addr = SMPS_REG_ADDR_SMPS5, .mm.pmic = &twl6030, };
Applied to u-boot-ti/master, thanks!
But I have a follow-up question, should we be using the TWL6032 support I also just pushed in this case?
Hi Tom,
Sorry, but I'm currently unsubscripted from the ML. Could you please providea link to Oleg's patches so that I can take a look?
Thanks, Lubo
P.S. Regarding Nikita's fix for OMAP3 I2C, don't you think it should be applied as well? Or it is up to Heiko? (http://patchwork.ozlabs.org/patch/294957/)
Lubomir Popov
