[U-Boot-Users] Stuck relocating command table
I have been trying unsuccessfully to bring up u-boot on my PowerPC 440GP evaluation board. I am using the predefined configuration file for this board (EBONY.h). I have tried both the 1.1.2 release and the head CVS files, both with the same result.
It displays the expected initial messages and then hangs after displaying the DRAM amount. I traced the code to find out where it is hanging. It makes it to board_init_r in board.c, and enters the loop in which u-boot is relocating the command table. It never gets out of this loop.
One peculiar thing is that when I printed out the value of __u_boot_cmd_start and __u_boot_cmd_end just before the loop, they did not match what the u-boot.map file says they should be.
The printed versions were
__u_boot_cmd_start = 0x07faeed8 __u_boot_cmd_end = 0x07ff57f4
(difference 0x4691C)
The u-boot.map versions are
__u_boot_cmd_start = 0xfffa57f4 __u_boot_cmd_end = 0xfffa8ffc
(difference 0x3808)
The loop seems to be reading from the wrong flash locations because it is reading garbage.
Can someone help me figure this out? Could it be the build tools? I am using gcc 3.3.6 and binutils 2.16.1. Are these okay for building u-boot?
Thanks.
Gregg
Hello greg.
I've got the same problem with others build tools. ( http://article.gmane.org/gmane.comp.boot-loaders.u-boot/17370 and http://search.gmane.org/search.php?query=compile+with+recent+toolchain&e... )
Can you try this please (and reply me if it works or no) :
In "u-boot.lds" replace : __u_boot_cmd_start = .; with __u_boot_cmd_start = ADDR(.u_boot_cmd);
I hope it can help you.
Regards, Cedric VINCENT.
Cedric VINCENT <cedric.vincent <at> gmail.com> writes:
Yes, that fixed it. Thanks. I still have other problems, but at least I get all the way to a u-boot prompt now. I have to #undef CONFIG_SPD_EEPROM to get it to complete the boot. Otherwise it hangs after doing I2C probe.
Gregg
Cedric VINCENT
Gregg Nemas
