[PATCH] misc: atsha204a: Don't check for error when waking up the device
The device ignores any levels or transitions on the SCL pin when the device is idle, asleep or during waking up.
Linux kernel driver for atsha204a (atmel-sha204a.ko) also ignores return value from i2c wakeup send command, see: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
And also userspace Turris libatsha204 library ignores return value from wakeup send command, see: https://gitlab.nic.cz/turris/libatsha204/-/blob/v29.2/src/libatsha204/layer_...
U-Boot driver should do same thing.
Fixes waking up ATSHA204 on Turris 1.x boards.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/misc/atsha204a-i2c.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/misc/atsha204a-i2c.c b/drivers/misc/atsha204a-i2c.c index 81ecb5b6177b..fa2d5948f128 100644 --- a/drivers/misc/atsha204a-i2c.c +++ b/drivers/misc/atsha204a-i2c.c @@ -103,12 +103,13 @@ int atsha204a_wakeup(struct udevice *dev) for (try = 1; try <= 10; ++try) { debug("Try %i... ", try);
+ /* + * The device ignores any levels or transitions on the SCL pin + * when the device is idle, asleep or during waking up. + * Don't check for error when waking up the device. + */ memset(req, 0, 4); - res = atsha204a_send(dev, req, 4); - if (res) { - debug("failed on I2C send, trying again\n"); - continue; - } + atsha204a_send(dev, req, 4);
udelay(ATSHA204A_TWLO_US + ATSHA204A_TWHI_US);
Thanks, Stefan
memset(req, 0, 4);*/
if (res) {
continue;
Viele Grüße, Stefan Roese
Paweł, could you please test this change if it works on your board? I was that you were fixing another wakeup issue in patch "misc: atsha204a: Increase wake delay by tWHI".
if (res) {
continue;
-- 2.20.1
Hi Pali,
I applied the patch and it works fine on my board. Log from atsha204a_wakeup(): Waking up ATSHA204A Try 1... success
Tested-by: Paweł Anikiel pan@semihalf.com
Regards, Paweł
if (res) {
continue;
atsha204a_send(dev, req, 4); udelay(ATSHA204A_TWLO_US + ATSHA204A_TWHI_US);
-- 2.20.1
Reviewed-by: Marek Behún kabel@kernel.org
Stefan, will you apply this via marvell?
I can do this, let me check. I plan to send a pull request soon anyways.
Thanks, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
if (res) {
continue;
Marek Behún
Pali Rohár
Paweł Anikiel
Stefan Roese
