[U-Boot] [PATCH] drivers/serial/ns16550: move ifdef into Makefile COBJS-$(...)
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/serial/Makefile | 4 ++-- drivers/serial/ns16550.c | 5 ----- drivers/serial/serial.c | 4 ---- 3 files changed, 2 insertions(+), 11 deletions(-)
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 17235ff..abe2c02 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -28,10 +28,10 @@ LIB := $(obj)libserial.a COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o COBJS-$(CONFIG_MCFUART) += mcfuart.o COBJS-$(CONFIG_NS9750_UART) += ns9750_serial.o -COBJS-y += ns16550.o +COBJS-$(CONFIG_SYS_NS16550) += ns16550.o COBJS-$(CONFIG_DRIVER_S3C4510_UART) += s3c4510b_uart.o COBJS-$(CONFIG_S3C64XX) += s3c64xx.o -COBJS-y += serial.o +COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 93c2243..a9391c7 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -5,9 +5,6 @@ */
#include <config.h> - -#ifdef CONFIG_SYS_NS16550 - #include <ns16550.h>
#define LCRVAL LCR_8N1 /* 8 data, 1 stop, no parity */ @@ -75,5 +72,3 @@ int NS16550_tstc (NS16550_t com_port) { return ((com_port->lsr & LSR_DR) != 0); } - -#endif diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index bce7548..966df9a 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -23,8 +23,6 @@
#include <common.h>
-#ifdef CONFIG_SYS_NS16550_SERIAL - #include <ns16550.h> #ifdef CONFIG_NS87308 #include <ns87308.h> @@ -328,5 +326,3 @@ DECLARE_ESERIAL_FUNCTIONS(4); struct serial_device eserial4_device = INIT_ESERIAL_STRUCTURE(4,"eserial3","EUART4"); #endif /* CONFIG_SERIAL_MULTI */ - -#endif
Dear Mike Frysinger,
Fails:
Applying: drivers/serial/ns16550: move ifdef into Makefile COBJS-$(...) error: patch failed: drivers/serial/Makefile:28 error: drivers/serial/Makefile: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged drivers/serial/Makefile CONFLICT (content): Merge conflict in drivers/serial/Makefile Failed to merge in the changes. Patch failed at 0001.
Please rebase and resubmit. Thanks.
Fails:
your last commit (861a0000) messed up the drivers/serial/Makefile ... you committed the conflict info ... -mike
Yes, stupid me. Sorry, should go to bed earlier.
I ditched that commit.
Mike Frysinger
