[U-Boot] [PATCH] use "boot selecr" jumper on NGW100 to select USART
Without the "boot select" jumper U-Boot will use the USART selected using the CONFIG_USART1, CONFIG_USART2, directive.
If CONFIG_ALT_USART1 (or ..2, ..3, ..0) is defined then, with the jumper in place, that USART is used instead.
Signed-off-by: Thomas Sprinkmeier thomas.sprinkmeier@gmail.com --- board/atmel/atngw100/atngw100.c | 40 ++++++++++++++++++++++++++++ drivers/serial/atmel_usart.c | 54 ++++++++++++++++++++++++++++++++++++++- drivers/serial/atmel_usart.h | 9 +++--- include/configs/atngw100.h | 1 + 4 files changed, 98 insertions(+), 6 deletions(-)
diff --git a/board/atmel/atngw100/atngw100.c b/board/atmel/atngw100/atngw100.c index 004d8da..a2ffdb4 100644 --- a/board/atmel/atngw100/atngw100.c +++ b/board/atmel/atngw100/atngw100.c @@ -53,7 +53,47 @@ int board_early_init_f(void) hmatrix_slave_write(EBI, SFR, HMATRIX_BIT(EBI_SDRAM_ENABLE));
portmux_enable_ebi(16, 23, 0, PORTMUX_DRIVE_HIGH); + +#if defined(CONFIG_ALT_USART0) || defined(CONFIG_ALT_USART1) || \ + defined(CONFIG_ALT_USART2) || defined(CONFIG_ALT_USART3) +#define USART_USE_ALT (!gpio_get_value(GPIO_PIN_PB(30))) + + /* PB30, the 'boot' jumper with external pull-up resistor */ + /* PORTMUX_DIR_INPUT == 0 as high-impedance input is the default state. + In other words, I don't think this actually does anything... */ + portmux_select_gpio(PORTMUX_PORT_B, + (1 << 30), + PORTMUX_DIR_INPUT); + /* Now to read the state of the pin and use it to determine which + USART to initialise. Should I sleep first to make sure the + pin settles down (just in case the above call did actually + do something)? */ + if (USART_USE_ALT) { +#if defined(CONFIG_ALT_USART0) + portmux_enable_usart0(PORTMUX_DRIVE_MIN); +#elif defined(CONFIG_ALT_USART1) + portmux_enable_usart1(PORTMUX_DRIVE_MIN); +#elif defined(CONFIG_ALT_USART2) + portmux_enable_usart2(PORTMUX_DRIVE_MIN); +#elif defined(CONFIG_ALT_USART3) + portmux_enable_usart3(PORTMUX_DRIVE_MIN); +#endif + } else { +#endif +#if defined(CONFIG_USART0) + portmux_enable_usart0(PORTMUX_DRIVE_MIN); +#elif defined(CONFIG_USART1) portmux_enable_usart1(PORTMUX_DRIVE_MIN); +#elif defined(CONFIG_USART2) + portmux_enable_usart2(PORTMUX_DRIVE_MIN); +#elif defined(CONFIG_USART3) + portmux_enable_usart3(PORTMUX_DRIVE_MIN); +#else + #error "Define CONFIG_USART0..3" +#endif +#ifdef USART_USE_ALT + } +#endif
#if defined(CONFIG_MACB) portmux_enable_macb0(PORTMUX_MACB_MII, PORTMUX_DRIVE_HIGH); diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index f50552a..ffafe9e 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -34,6 +34,33 @@ #elif defined(CONFIG_USART3) # define USART_ID 3 # define USART_BASE USART3_BASE +#else +#warning "You need to define CONFIG_USART[0..3]" +#endif + +#if defined(CONFIG_ALT_USART0) +# define USART_ALT_ID 0 +# define USART_ALT_BASE USART0_BASE +#elif defined(CONFIG_ALT_USART1) +# define USART_ALT_ID 1 +# define USART_ALT_BASE USART1_BASE +#elif defined(CONFIG_ALT_USART2) +# define USART_ALT_ID 2 +# define USART_ALT_BASE USART2_BASE +#elif defined(CONFIG_ALT_USART3) +# define USART_ALT_ID 3 +# define USART_ALT_BASE USART3_BASE +#endif + +#ifdef USART_ALT_ID +#if USART_ID == USART_ALT_ID +#warning "Alternate USART should be different from primary" +#warning " change CONFIG_USARTn and/or CONFIG_ALT_USARTn" +#endif + +/* true iff jumper in place */ +#define USART_USE_ALT (!gpio_get_value(GPIO_PIN_PB(30))) + #endif
#include "atmel_usart.h" @@ -50,7 +77,13 @@ void serial_setbrg(void) * Baud Rate = -------------- * 16 * CD */ - usart_hz = get_usart_clk_rate(USART_ID); +#ifdef USART_ALT_ID + if (USART_USE_ALT) + usart_hz = get_usart_clk_rate(USART_ALT_ID); + else +#endif + usart_hz = get_usart_clk_rate(USART_ID); + divisor = (usart_hz / 16 + gd->baudrate / 2) / gd->baudrate; usart3_writel(BRGR, USART3_BF(CD, divisor)); } @@ -97,3 +130,22 @@ int serial_tstc(void) { return (usart3_readl(CSR) & USART3_BIT(RXRDY)) != 0; } + +int atmel_serial_read(int reg) +{ +#ifdef USART_ALT_ID + if (USART_USE_ALT) + return readl(USART_ALT_BASE + reg); +#endif + return readl(USART_BASE + reg); +} + +void atmel_serial_write(int reg, int value) +{ +#ifdef USART_ALT_ID + if (USART_USE_ALT) + writel(value, (void *)USART_ALT_BASE + reg); + else +#endif + writel(value, (void *)USART_BASE + reg); +} diff --git a/drivers/serial/atmel_usart.h b/drivers/serial/atmel_usart.h index af3773a..4fc5f50 100644 --- a/drivers/serial/atmel_usart.h +++ b/drivers/serial/atmel_usart.h @@ -305,10 +305,9 @@ << USART3_##name##_OFFSET)) \ | USART3_BF(name,value))
-/* Register access macros */ -#define usart3_readl(reg) \ - readl((void *)USART_BASE + USART3_##reg) -#define usart3_writel(reg,value) \ - writel((value), (void *)USART_BASE + USART3_##reg) +int atmel_serial_read(int reg); +void atmel_serial_write(int reg, int value); +#define usart3_readl(reg) atmel_serial_read(USART3_##reg) +#define usart3_writel(reg, value) atmel_serial_write(USART3_##reg, value)
#endif /* __DRIVERS_ATMEL_USART_H__ */ diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 4ed5514..d5a6e83 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -59,6 +59,7 @@ #define CONFIG_SYS_PLL0_OPT 0x04
#define CONFIG_USART1 1 +#define CONFIG_ALT_USART1 3
/* User serviceable stuff */ #define CONFIG_DOS_PARTITION 1
Dear Thomas Sprinkmeier,
In message e355f1140911041955q1adf2c1fp75375e4b98cfdc00@mail.gmail.com you wrote:
Please fix the typo in the Subject:
- defined(CONFIG_ALT_USART2) || defined(CONFIG_ALT_USART3)
Your patch is white space corrupted. All "original" indentation was by TABs, but in your patch it's all spaces.
Incorrect multiline comment style. Please fix globally.
Incorrect indentation. Please fix globally.
} else {
+#else
If only one CONFIG_USARTx is allowed, you should think opf a way to get rid of these long, repeated #if...#elif...#elif constructs.
Instead of making code more AT91 specific, we should try the opposite: make it _less_ so.
Thomas Sprinkmeier
