[U-Boot] [PATCH] fsl: add support for NXID v1 EEPROM format
Freescale application note AN3638 describes an update to the NXID format, which stores MAC addresses and related data on an on-board EEPROM. The new version adds support for up to 23 MAC addresses, instead of just 8. Since the initial implementation of NXID had a "0" in the 'version' field, this new version is called "v1".
Boards that are shipped with EEPROMs in the NXID v1 format should define CONFIG_SYS_I2C_EEPROM_NXID_1 instead of CONFIG_SYS_I2C_EEPROM_NXID.
Signed-off-by: Timur Tabi timur@freescale.com --- board/freescale/common/sys_eeprom.c | 26 +++++++++++++++++--------- 1 files changed, 17 insertions(+), 9 deletions(-)
diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 3929ad0..7621b91 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -28,13 +28,21 @@ #include <i2c.h> #include <linux/ctype.h>
+#ifdef CONFIG_SYS_I2C_EEPROM_CCID #include "../common/eeprom.h" +#define MAX_NUM_PORTS 8 +#endif
-#if !defined(CONFIG_SYS_I2C_EEPROM_CCID) && !defined(CONFIG_SYS_I2C_EEPROM_NXID) -#error "Please define either CONFIG_SYS_I2C_EEPROM_CCID or CONFIG_SYS_I2C_EEPROM_NXID" +#ifdef CONFIG_SYS_I2C_EEPROM_NXID +#define MAX_NUM_PORTS 8 +#define NXID_VERSION 0 #endif
-#define MAX_NUM_PORTS 8 /* This value must be 8 as defined in doc */ +#ifdef CONFIG_SYS_I2C_EEPROM_NXID_1 +#define CONFIG_SYS_I2C_EEPROM_NXID +#define MAX_NUM_PORTS 23 +#define NXID_VERSION 1 +#endif
/** * static eeprom: EEPROM layout for CCID or NXID formats @@ -68,8 +76,8 @@ static struct __attribute__ ((__packed__)) eeprom { u8 res_1[21]; /* 0x2b - 0x3f Reserved */ u8 mac_count; /* 0x40 Number of MAC addresses */ u8 mac_flag; /* 0x41 MAC table flags */ - u8 mac[MAX_NUM_PORTS][6]; /* 0x42 - 0x71 MAC addresses */ - u32 crc; /* 0x72 CRC32 checksum */ + u8 mac[MAX_NUM_PORTS][6]; /* 0x42 - x MAC addresses */ + u32 crc; /* x+1 CRC32 checksum */ #endif } e;
@@ -300,7 +308,7 @@ static void set_mac_address(unsigned int index, const char *string) char *p = (char *) string; unsigned int i;
- if (!string) { + if ((index >= MAX_NUM_PORTS) || !string) { printf("Usage: mac <n> XX:XX:XX:XX:XX:XX\n"); return; } @@ -333,7 +341,7 @@ int do_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (cmd == 'i') { #ifdef CONFIG_SYS_I2C_EEPROM_NXID memcpy(e.id, "NXID", sizeof(e.id)); - e.version = 0; + e.version = NXID_VERSION; #else memcpy(e.id, "CCID", sizeof(e.id)); #endif @@ -382,8 +390,8 @@ int do_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) e.mac_count = simple_strtoul(argv[2], NULL, 16); update_crc(); break; - case '0' ... '7': /* "mac 0" through "mac 7" */ - set_mac_address(cmd - '0', argv[2]); + case '0' ... '9': /* "mac 0" through "mac 22" */ + set_mac_address(simple_strtoul(argv[1], NULL, 10), argv[2]); break; case 'h': /* help */ default:
applied to 85xx
- k
Kumar Gala
Timur Tabi
