[U-Boot] [PATCH] thermal: Fix comments
It seems that many comments were copied from the I2C uclass, so adjust the comments for the thermal class.
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/thermal.h | 16 ++++------------ 1 file changed, 4 insertions(+), 12 deletions(-)
diff --git a/include/thermal.h b/include/thermal.h index 5d6101b..b197c0a 100644 --- a/include/thermal.h +++ b/include/thermal.h @@ -13,7 +13,7 @@ int thermal_get_temp(struct udevice *dev, int *temp);
/** - * struct struct dm_thermal_ops - Driver model Thermal operations + * struct dm_thermal_ops - Driver model Thermal operations * * The uclass interface is implemented by all Thermal devices which use * driver model. @@ -22,19 +22,11 @@ struct dm_thermal_ops { /** * Get the current temperature * - * The device provided is the slave device. It's parent controller - * will be used to provide the communication. - * - * This must be called before doing any transfers with a Thermal slave. - * It will enable and initialize any Thermal hardware as necessary, - * and make sure that the SCK line is in the correct idle state. It is - * not allowed to claim the same bus for several slaves without - * releasing the bus in between. + * This must be called before doing any transfers with a Thermal device. + * It will enable and initialize any Thermal hardware as necessary. * * @dev: The Thermal device - * - * Returns: 0 if the bus was claimed successfully, or a negative value - * if it wasn't. + * @temp: pointer that returns the measured temperature */ int (*get_temp)(struct udevice *dev, int *temp); };
Acked-by: Otavio Salvador otavio@ossystems.com.br
Tom, this would be a good patch to go in 2015.07 release, simple and trivial.
On 14 July 2015 at 05:56, Otavio Salvador otavio.salvador@ossystems.com.br wrote:
-- Otavio Salvador O.S. Systems http://www.ossystems.com.br http://code.ossystems.com.br Mobile: +55 (53) 9981-7854 Mobile: +1 (347) 903-9750 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Fabio Estevam
Otavio Salvador
