[U-Boot] [PATCH] powerpc/85xx: Add P1023RDB board support
P1023RDB Specification: ----------------------- Memory subsystem: 512MB DDR3 (Fixed DDR on board) 64MB NOR flash 128MB NAND flash
Ethernet: eTSEC1: Connected to Atheros AR8035 GETH PHY eTSEC2: Connected to Atheros AR8035 GETH PHY
PCIe: Three mini-PCIe slots
USB: Two USB2.0 Type A ports
I2C: AT24C08 8K Board EEPROM (8 bit address)
Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com --- board/freescale/p1023rdb/Makefile | 32 +++ board/freescale/p1023rdb/law.c | 34 +++ board/freescale/p1023rdb/p1023rdb.c | 194 ++++++++++++++++ board/freescale/p1023rdb/tlb.c | 116 ++++++++++ boards.cfg | 1 + include/configs/P1023RDB.h | 433 +++++++++++++++++++++++++++++++++++ 6 files changed, 810 insertions(+), 0 deletions(-) create mode 100644 board/freescale/p1023rdb/Makefile create mode 100644 board/freescale/p1023rdb/law.c create mode 100644 board/freescale/p1023rdb/p1023rdb.c create mode 100644 board/freescale/p1023rdb/tlb.c create mode 100644 include/configs/P1023RDB.h
diff --git a/board/freescale/p1023rdb/Makefile b/board/freescale/p1023rdb/Makefile new file mode 100644 index 0000000..c8e0866 --- /dev/null +++ b/board/freescale/p1023rdb/Makefile @@ -0,0 +1,32 @@ +# +# Copyright 2013 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms of the GNU General Public License as published by the Free +# Software Foundation; either version 2 of the License, or (at your option) +# any later version. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/p1023rdb/law.c b/board/freescale/p1023rdb/law.c new file mode 100644 index 0000000..b041d1f --- /dev/null +++ b/board/freescale/p1023rdb/law.c @@ -0,0 +1,34 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_4M, + LAW_TRGT_IF_DPAA_SWP_SRAM), + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p1023rdb/p1023rdb.c b/board/freescale/p1023rdb/p1023rdb.c new file mode 100644 index 0000000..16659e9 --- /dev/null +++ b/board/freescale/p1023rdb/p1023rdb.c @@ -0,0 +1,194 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Authors: Roy Zang tie-fei.zang@freescale.com + * Chunhe Lan Chunhe.Lan@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/io.h> +#include <asm/cache.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_portals.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <netdev.h> +#include <malloc.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <asm/fsl_dtsec.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + /* Set ABSWP to implement conversion of addresses in the LBC */ + setbits_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); + + return 0; +} + +int checkboard(void) +{ + printf("Board: P1023 RDB\n"); + + return 0; +} + +/* Fixed sdram init -- doesn't use serial presence detect. */ +phys_size_t fixed_sdram(void) +{ +#ifndef CONFIG_SYS_RAMBOOT + ccsr_ddr_t *ddr = (ccsr_ddr_t *)CONFIG_SYS_MPC8xxx_DDR_ADDR; + + set_next_law(0, LAW_SIZE_512M, LAW_TRGT_IF_DDR_1); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + out_be32(&ddr->cs1_bnds, CONFIG_SYS_DDR_CS1_BNDS); + out_be32(&ddr->cs1_config, CONFIG_SYS_DDR_CS1_CONFIG); + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + out_be32(&ddr->sdram_data_init, CONFIG_SYS_DDR_DATA_INIT); + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->timing_cfg_4, CONFIG_SYS_DDR_TIMING_4); + out_be32(&ddr->timing_cfg_5, CONFIG_SYS_DDR_TIMING_5); + out_be32(&ddr->ddr_zq_cntl, CONFIG_SYS_DDR_ZQ_CNTL); + out_be32(&ddr->ddr_wrlvl_cntl, CONFIG_SYS_DDR_WRLVL_CNTL); + out_be32(&ddr->ddr_cdr1, CONFIG_SYS_DDR_CDR_1); + out_be32(&ddr->ddr_cdr2, CONFIG_SYS_DDR_CDR_2); + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); +#endif + return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024ul; +} + +#ifdef CONFIG_PCI +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} +#endif + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + setup_portals(); + + return 0; +} + +unsigned long get_board_sys_clk(ulong dummy) +{ + return gd->bus_clk; +} + +unsigned long get_board_ddr_clk(ulong dummy) +{ + return gd->mem_clk; +} + +int board_eth_init(bd_t *bis) +{ + ccsr_gur_t *gur = (ccsr_gur_t *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + struct fsl_pq_mdio_info dtsec_mdio_info; + + /* + * Need to set dTSEC 1 pin multiplexing to TSEC. The default setting + * is not correct. + */ + setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_TSEC1_1); + + dtsec_mdio_info.regs = + (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR; + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fsl_pq_mdio_init(bis, &dtsec_mdio_info); + + fm_info_set_phy_address(FM1_DTSEC1, CONFIG_SYS_FM1_DTSEC1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, CONFIG_SYS_FM1_DTSEC2_PHY_ADDR); + + fm_info_set_mdio(FM1_DTSEC1, + miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); + fm_info_set_mdio(FM1_DTSEC2, + miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); + +#ifdef CONFIG_FMAN_ENET + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} + +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_HAS_FSL_DR_USB + fdt_fixup_dr_usb(blob, bd); +#endif + + fdt_fixup_fman_ethernet(blob); +} +#endif diff --git a/board/freescale/p1023rdb/tlb.c b/board/freescale/p1023rdb/tlb.c new file mode 100644 index 0000000..978c279 --- /dev/null +++ b/board/freescale/p1023rdb/tlb.c @@ -0,0 +1,116 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I, + 0, 0, BOOKE_PAGESZ_4K, 1), + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_4M, 1), + + /* W**G* - Flash/promjet, localbus */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x40000000, + CONFIG_SYS_PCIE3_MEM_PHYS + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x50000000, + CONFIG_SYS_PCIE3_MEM_PHYS + 0x50000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_VIRT, CONFIG_SYS_PCIE3_IO_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256K, 1), + + /* Bman/Qman */ + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 7, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x00100000, + CONFIG_SYS_BMAN_MEM_PHYS + 0x00100000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 8, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, + 0, 9, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x00100000, + CONFIG_SYS_QMAN_MEM_PHYS + 0x00100000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 10, BOOKE_PAGESZ_1M, 1), + + /* *I*G - NAND */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 11, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_RAMBOOT + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, + CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 12, BOOKE_PAGESZ_256M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, + CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 13, BOOKE_PAGESZ_256M, 1), +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index f785da8..d0db248 100644 --- a/boards.cfg +++ b/boards.cfg @@ -815,6 +815,7 @@ P1022DS_36BIT_SPIFLASH powerpc mpc85xx p1022ds freesca P1022DS_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:SDCARD P1022DS_36BIT_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SDCARD P1022DS_36BIT powerpc mpc85xx p1022ds freescale - P1022DS:36BIT +P1023RDB powerpc mpc85xx p1023rdb freescale - P1023RDB P1023RDS powerpc mpc85xx p1023rds freescale - P1023RDS P1023RDS_NAND powerpc mpc85xx p1023rds freescale - P1023RDS:NAND P1024RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h new file mode 100644 index 0000000..0827e51 --- /dev/null +++ b/include/configs/P1023RDB.h @@ -0,0 +1,433 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Authors: Roy Zang tie-fei.zang@freescale.com + * Chunhe Lan Chunhe.Lan@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE /* BOOKE */ +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx +#define CONFIG_P1023 +#define CONFIG_P1023RDB +#define CONFIG_MP /* support multiple processors */ + +#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controler 1 (slot 1) */ +#define CONFIG_PCIE2 /* PCIE controler 2 (slot 2) */ +#define CONFIG_PCIE3 /* PCIE controler 3 (slot 3) */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif + +#define CONFIG_SYS_CLK_FREQ 66666666 +#define CONFIG_DDR_CLK_FREQ CONFIG_SYS_CLK_FREQ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_HWCONFIG + +#define CONFIG_ENABLE_36BIT_PHYS + +#define CONFIG_SYS_MEMTEST_START 0x01000000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x02000000 + +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +/* Implement conversion of addresses in the LBC */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 +#define CONFIG_SYS_LBC_LCRR LCRR_CLKDIV_8 + +/* DDR Setup */ +#define CONFIG_VERY_BIG_RAM + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef + +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 2 + +/* These are used when DDR doesn't use SPD. */ +#define CONFIG_SYS_SDRAM_SIZE 512u /* DDR is 512M */ + +/* Default settings for "stable" mode */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014202 +#define CONFIG_SYS_DDR_CS1_BNDS 0x00000000 +#define CONFIG_SYS_DDR_CS1_CONFIG 0x00000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00330104 +#define CONFIG_SYS_DDR_TIMING_1 0x6f6b4644 +#define CONFIG_SYS_DDR_TIMING_2 0x03a8910c +#define CONFIG_SYS_DDR_TIMING_3 0x00020000 +#define CONFIG_SYS_DDR_TIMING_4 0x00000001 +#define CONFIG_SYS_DDR_TIMING_5 0x02401400 +#define CONFIG_SYS_DDR_MODE_1 0x00041420 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x0a28030c +#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef +#define CONFIG_SYS_DDR_CLK_CTRL 0x03000000 +#define CONFIG_SYS_DDR_ZQ_CNTL 0x89080600 +#define CONFIG_SYS_DDR_WRLVL_CNTL 0x8655f608 +#define CONFIG_SYS_DDR_CONTROL 0xc70c0000/* + *Type = DDR3: No Interleaving + */ +#define CONFIG_SYS_DDR_CONTROL2 0x24401010 +#define CONFIG_SYS_DDR_CDR_1 0x80040000 +#define CONFIG_SYS_DDR_CDR_2 0x00000001 + +/* + * Memory map + * + * 0x0000_0000 0x1fff_ffff DDR 500M Cacheable + * 0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable + * 0xc000_0000 0xdfff_ffff PCI 512M non-cacheable + * 0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable + * + * Localbus non-cacheable + * + * 0xec00_0000 0xefff_ffff NOR flash 64M NOR flash + * 0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M + * 0xff60_0000 0xff7f_ffff CCSR 2M non-cacheable + * 0xffa0_0000 0xffaf_ffff NAND 1M non-cacheable + * 0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 + */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_FLASH_BASE 0xec000000 /* start of FLASH 64M */ +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE + +#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_16 | BR_V) +#define CONFIG_FLASH_OR_PRELIM 0xfc000ff7 + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f function */ +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ + +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (6 * 1024 * 1024) /* Reserved for malloc */ + +#define CONFIG_SYS_NAND_BASE 0xffa00000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_BASE_LIST {CONFIG_SYS_NAND_BASE} +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND +#define CONFIG_NAND_FSL_ELBC +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* NAND flash config */ +#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_256KB /* length 256K */ \ + | OR_FCM_PGS \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) + +#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ +#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ +#define CONFIG_SYS_BR1_PRELIM CONFIG_SYS_NAND_BR_PRELIM +#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER + +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* + * I2C2 EEPROM + */ +#define CONFIG_ID_EEPROM +#ifdef CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#endif +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_BUS_NUM 0 + +#define CONFIG_CMD_I2C + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +/* controller 3, Slot 1, tgtid 3, Base address b000 */ +#define CONFIG_SYS_PCIE3_NAME "Slot 3" +#define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xffc00000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_PHYS 0xffc00000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ + +/* controller 2, direct to uli, tgtid 2, Base address 9000 */ +#define CONFIG_SYS_PCIE2_NAME "Slot 2" +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 1, Slot 2, tgtid 1, Base address a000 */ +#define CONFIG_SYS_PCIE1_NAME "Slot 1" +#define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc20000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc20000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +#if defined(CONFIG_PCI) +#define CONFIG_E1000 /* Defind e1000 pci Ethernet card */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#endif /* CONFIG_PCI */ + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_IS_IN_FLASH +#if CONFIG_SYS_MONITOR_BASE > 0xfff80000 +#define CONFIG_ENV_ADDR 0xfff80000 +#else +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#endif +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_PING +#define CONFIG_CMD_MII +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_REGINFO + +#if defined(CONFIG_PCI) +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* + * USB + */ +#define CONFIG_HAS_FSL_DR_USB +#ifdef CONFIG_HAS_FSL_DR_USB +#define CONFIG_USB_EHCI + +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_USB_EHCI_FSL +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH (u-boot.bin) /* U-Boot image on TFTP server */ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define CONFIG_BAUDRATE 115200 + +/* Qman/Bman */ +#define CONFIG_SYS_DPAA_QBMAN /* support Q/Bman */ +#define CONFIG_SYS_QMAN_MEM_BASE 0xff000000 +#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 +#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 + +/* For FM */ +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHY_ATHEROS +#endif + +/* Default address of microcode for the Linux Fman driver */ +/* QE microcode/firmware address */ +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xeff40000 +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x1 +#define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x2 + +#define CONFIG_SYS_TBIPA_VALUE 8 +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=usb1:dr_mode=host,phy_type=ulpi\0" + +#endif /* __CONFIG_H */
It's amazing that Freescale is still producing board files that are missing 57,600 baud.
When they could just use the default table?
Chunhe, what is the orderable part number of this board, I don't see anything on the FSL web page with the description above.
Now, Freescale is developing it, and does not normally release it.
Thanks, -Chunhe
Regards
Sinan Akman
- /* TLB 0 - for temp stack in cache */
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR,
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024,
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024,
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024,
- /* TLB 1 */
- /* *I*** - Covers boot page */
- SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000,
- /* *I*G* - CCSRBAR */
- SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS,
- /* W**G* - Flash/promjet, localbus */
- /* This will be changed to *I*G* after relocation to RAM. */
- SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE,
- /* *I*G* - PCI */
- SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT,
- /* *I*G* - PCI */
- SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x40000000,
- SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x50000000,
Do not use MAS3_SX on I/O mappings. The G bit does not prevent speculative instruction fetches.
- /* *I*G - NAND */
- SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE,
Why do you need 1M for NAND? There's only 8K of stuff there.
- Memory map
- 0x0000_0000 0x1fff_ffff DDR 500M
Cacheable
- 0x8000_0000 0xbfff_ffff PCI Express Mem 1G
non-cacheable
- 0xc000_0000 0xdfff_ffff PCI 512M
non-cacheable
- 0xe100_0000 0xe3ff_ffff PCI IO range 4M
non-cacheable
- Localbus non-cacheable
- 0xec00_0000 0xefff_ffff NOR flash 64M NOR
flash
- 0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M
- 0xff60_0000 0xff7f_ffff CCSR 2M
non-cacheable
- 0xffa0_0000 0xffaf_ffff NAND 1M
non-cacheable
- 0xffd0_0000 0xffd0_3fff L1 for stack 16K
Cacheable TLB0
L1 for stack is neither "localbus" nor "non-cacheable". If you don't want to distinguish that category, remove the comment.
[snip hundreds of lines of board config file]
Can we please refactor these board config headers to focus only on what's different from board to board? These patches are very hard to effectively review as is.
-Scott
participants (6)
Chunhe Lan
Chunhe Lan
Scott Wood
Sinan Akman
Timur Tabi
