[PULL u-boot] Please pull u-boot-amlogic-20200428
Hi Tom,
This PR enables access to SPI NOR flash on the Khadas VIM2 & VIM3, adds the GXBB USB PHY driver, fixes MMC driver init freeze on G12A/G12B/SM1 SoCs and finally fixes USB PHY power-up on Khadas VIM3/VIM3L boards.
The CI job is at https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/2972
Thanks, Neil
The following changes since commit d16d37bcd4087b8ea0f66cb76a73edad182d151a:
Merge tag 'video-for-v2020.07-rc1' of https://gitlab.denx.de/u-boot/custodians/u-boot-video (2020-04-27 09:41:51 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20200428
for you to fetch changes up to 3dc4f8397015dac7c343f86a93bfb962ff4e8d6f:
usb: dwc3-meson-g12a: add power-on/off of the PHYs (2020-04-28 10:23:10 +0200)
---------------------------------------------------------------- - fix sd-emmc controller A init on G12A/G12B/SM1 SoCs - add GXBB USB PHY driver - enable access to SPI NOR Flash on VIM2 and VIM3/VIM3L boards - fix USB PHYs Power-Up on on VIM3/VIM3L boards
---------------------------------------------------------------- Beniamino Galvani (1): phy: meson: add GXBB PHY driver
Neil Armstrong (7): clk: meson: g12a: add missing SD_EMMC_A controller gates arm64: dts: meson: sync dt and bindings from v5.7-rc1 arm: dts: meson-gxm-khadas-vim2-u-boot: enable SPI NOR flash configs: khadas-vim2: enable support for SPI NOR flash arm: dts: meson-khadas-vim3: enable SPI NOR flash configs: khadas-vim3: enable support for SPI NOR flash usb: dwc3-meson-g12a: add power-on/off of the PHYs
arch/arm/dts/meson-axg-s400.dts | 6 +- arch/arm/dts/meson-g12-common.dtsi | 136 +++++++++++- arch/arm/dts/meson-g12.dtsi | 1 + arch/arm/dts/meson-g12a-sei510.dts | 4 +- arch/arm/dts/meson-g12a-u200.dts | 2 +- .../dts/meson-g12b-a311d-khadas-vim3-u-boot.dtsi | 7 + arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 4 +- arch/arm/dts/meson-g12b-odroid-n2.dts | 25 ++- arch/arm/dts/meson-gx.dtsi | 52 +++++ arch/arm/dts/meson-gxbb-odroidc2.dts | 1 + arch/arm/dts/meson-gxl-s905x-p212.dtsi | 9 +- arch/arm/dts/meson-gxm-khadas-vim2-u-boot.dtsi | 15 ++ arch/arm/dts/meson-gxm-khadas-vim2.dts | 89 ++------ arch/arm/dts/meson-gxm.dtsi | 28 +++ arch/arm/dts/meson-khadas-vim3-u-boot.dtsi | 21 ++ arch/arm/dts/meson-khadas-vim3.dtsi | 24 ++- arch/arm/dts/meson-sm1-khadas-vim3l-u-boot.dtsi | 7 + arch/arm/dts/meson-sm1-khadas-vim3l.dts | 8 +- arch/arm/dts/meson-sm1-sei610.dts | 3 +- arch/arm/dts/meson-sm1.dtsi | 1 + configs/khadas-vim2_defconfig | 8 + configs/khadas-vim3_defconfig | 9 + configs/khadas-vim3l_defconfig | 9 + drivers/clk/meson/g12a.c | 2 + drivers/phy/Kconfig | 8 + drivers/phy/Makefile | 1 + drivers/phy/meson-gxbb-usb2.c | 235 +++++++++++++++++++++ drivers/usb/dwc3/dwc3-meson-g12a.c | 16 ++ include/dt-bindings/clock/g12a-clkc.h | 2 + include/dt-bindings/clock/gxbb-clkc.h | 1 + 30 files changed, 633 insertions(+), 101 deletions(-) create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3-u-boot.dtsi create mode 100644 arch/arm/dts/meson-khadas-vim3-u-boot.dtsi create mode 100644 arch/arm/dts/meson-sm1-khadas-vim3l-u-boot.dtsi create mode 100644 drivers/phy/meson-gxbb-usb2.c
On Tue, Apr 28, 2020 at 03:14:17PM +0200, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
