[U-Boot] [PATCH v2 1/3] Enable FEC driver to retrieve PHY address from device tree
Currently if we have more than one phy on the MDIO bus, we do not have a good mechanism for determining which should be used at runtime. Enable the FEC driver to determine the address for the PHY from the device tree.
Signed-off-by: Martyn Welch martyn.welch@collabora.com
Changes in v2: - New in v2
drivers/net/fec_mxc.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 99c5c649a0..425f6197cb 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1264,11 +1264,32 @@ static const struct eth_ops fecmxc_ops = { .read_rom_hwaddr = fecmxc_read_rom_hwaddr, };
+static int device_get_phy_addr(struct udevice *dev) +{ + struct ofnode_phandle_args phandle_args; + int reg; + + if (dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, + &phandle_args)) { + debug("Failed to find phy-handle"); + return -ENODEV; + } + + reg = ofnode_read_u32_default(phandle_args.node, "reg", 0); + + return reg; +} + static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) { struct phy_device *phydev; + int addr; int mask = 0xffffffff;
+ addr = device_get_phy_addr(dev); + if (addr >= 0) + mask = 1 << addr; + #ifdef CONFIG_FEC_MXC_PHYADDR mask = 1 << CONFIG_FEC_MXC_PHYADDR; #endif
Current define usage causes tooling to attempt to build for USB driver model when building non-DM SPL. Update logic to avoid this.
drivers/usb/gadget/ci_udc.c | 2 +- drivers/usb/host/Makefile | 14 ++++++++++++++ drivers/usb/host/ehci-hcd.c | 12 ++++++------ drivers/usb/host/ehci-mx6.c | 2 +- include/usb.h | 12 ++++++------ 5 files changed, 28 insertions(+), 14 deletions(-)
diff --git a/drivers/usb/gadget/ci_udc.c b/drivers/usb/gadget/ci_udc.c index 0a84f6850d..bd596ce977 100644 --- a/drivers/usb/gadget/ci_udc.c +++ b/drivers/usb/gadget/ci_udc.c @@ -1015,7 +1015,7 @@ int usb_gadget_register_driver(struct usb_gadget_driver *driver) if (driver->speed != USB_SPEED_FULL && driver->speed != USB_SPEED_HIGH) return -EINVAL;
-#ifdef CONFIG_DM_USB +#if CONFIG_IS_ENABLED(DM_USB) ret = usb_setup_ehci_gadget(&controller.ctrl); #else ret = usb_lowlevel_init(0, USB_INIT_DEVICE, (void **)&controller.ctrl); diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index cb8c315a15..2fc44e381c 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -3,10 +3,24 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
+ifdef CONFIG_SPL_BUILD +BUILDME = y +else +BUILDME = n +endif + +ifdef CONFIG_SPL_DM +BUILDME := $(BUILDME)y +else +BUILDME := $(BUILDME)n +endif + ifdef CONFIG_DM_USB +ifneq ($(BUILDME),yn) obj-$(CONFIG_CMD_USB) += usb-uclass.o obj-$(CONFIG_SANDBOX) += usb-sandbox.o endif +endif
# ohci obj-$(CONFIG_USB_OHCI_NEW) += ohci-hcd.o diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index d1d8f08d98..4b28db70a5 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -30,7 +30,7 @@ */ #define HCHALT_TIMEOUT (8 * 1000)
-#ifndef CONFIG_DM_USB +#if !CONFIG_IS_ENABLED(DM_USB) static struct ehci_ctrl ehcic[CONFIG_USB_MAX_CONTROLLER_COUNT]; #endif
@@ -111,7 +111,7 @@ static struct descriptor {
static struct ehci_ctrl *ehci_get_ctrl(struct usb_device *udev) { -#ifdef CONFIG_DM_USB +#if CONFIG_IS_ENABLED(DM_USB) return dev_get_priv(usb_get_bus(udev->dev)); #else return udev->controller; @@ -973,7 +973,7 @@ static void ehci_setup_ops(struct ehci_ctrl *ctrl, const struct ehci_ops *ops) } }
-#ifndef CONFIG_DM_USB +#if !CONFIG_IS_ENABLED(DM_USB) void ehci_set_controller_priv(int index, void *priv, const struct ehci_ops *ops) { struct ehci_ctrl *ctrl = &ehcic[index]; @@ -1097,7 +1097,7 @@ static int ehci_common_init(struct ehci_ctrl *ctrl, uint tweaks) return 0; }
-#ifndef CONFIG_DM_USB +#if !CONFIG_IS_ENABLED(DM_USB) int usb_lowlevel_stop(int index) { ehci_shutdown(&ehcic[index]); @@ -1518,7 +1518,7 @@ static int _ehci_submit_int_msg(struct usb_device *dev, unsigned long pipe, return result; }
-#ifndef CONFIG_DM_USB +#if !CONFIG_IS_ENABLED(DM_USB) int submit_bulk_msg(struct usb_device *dev, unsigned long pipe, void *buffer, int length) { @@ -1556,7 +1556,7 @@ int destroy_int_queue(struct usb_device *dev, struct int_queue *queue) } #endif
-#ifdef CONFIG_DM_USB +#if CONFIG_IS_ENABLED(DM_USB) static int ehci_submit_control_msg(struct udevice *dev, struct usb_device *udev, unsigned long pipe, void *buffer, int length, struct devrequest *setup) diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index be010b1adb..1acf08dfb7 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -335,7 +335,7 @@ int ehci_mx6_common_init(struct usb_ehci *ehci, int index) return 0; }
-#ifndef CONFIG_DM_USB +#if !CONFIG_IS_ENABLED(DM_USB) int ehci_hcd_init(int index, enum usb_init_type init, struct ehci_hccr **hccr, struct ehci_hcor **hcor) { diff --git a/include/usb.h b/include/usb.h index b6b48a8c60..ef5cd5400f 100644 --- a/include/usb.h +++ b/include/usb.h @@ -140,7 +140,7 @@ struct usb_device { int act_len; /* transferred bytes */ int maxchild; /* Number of ports if hub */ int portnr; /* Port number, 1=first */ -#ifndef CONFIG_DM_USB +#if !CONFIG_IS_ENABLED(DM_USB) /* parent hub, or NULL if this is the root hub */ struct usb_device *parent; struct usb_device *children[USB_MAXCHILDREN]; @@ -148,7 +148,7 @@ struct usb_device { #endif /* slot_id - for xHCI enabled devices */ unsigned int slot_id; -#ifdef CONFIG_DM_USB +#if CONFIG_IS_ENABLED(DM_USB) struct udevice *dev; /* Pointer to associated device */ struct udevice *controller_dev; /* Pointer to associated controller */ #endif @@ -173,7 +173,7 @@ enum usb_init_type { int usb_lowlevel_init(int index, enum usb_init_type init, void **controller); int usb_lowlevel_stop(int index);
-#if defined(CONFIG_USB_MUSB_HOST) || defined(CONFIG_DM_USB) +#if defined(CONFIG_USB_MUSB_HOST) || CONFIG_IS_ENABLED(DM_USB) int usb_reset_root_port(struct usb_device *dev); #else #define usb_reset_root_port(dev) @@ -186,8 +186,8 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, int submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, int transfer_len, int interval);
-#if defined CONFIG_USB_EHCI_HCD || defined CONFIG_USB_MUSB_HOST \ - || defined(CONFIG_DM_USB) +#if defined CONFIG_USB_EHCI_HCD || defined CONFIG_USB_MUSB_HOST || \ + CONFIG_IS_ENABLED(DM_USB) struct int_queue *create_int_queue(struct usb_device *dev, unsigned long pipe, int queuesize, int elementsize, void *buffer, int interval); int destroy_int_queue(struct usb_device *dev, struct int_queue *queue); @@ -588,7 +588,7 @@ struct usb_hub_device { struct usb_tt tt; /* Transaction Translator */ };
-#ifdef CONFIG_DM_USB +#if CONFIG_IS_ENABLED(DM_USB) /** * struct usb_platdata - Platform data about a USB controller *
Isn't this exact problem fixed in u-boot-usb/master ?
Any changes I've missed in master didn't clash with this when I rebase to master. I also get build errors when attempting to build from master with this patch removed.
Martyn
By master you mean u-boot/master or u-boot-usb/master ? Trimming CC and CCing Simon.
Ehrm, did you really mean me or rather Simon Glass? Because I don't really have anything to do with USB in U-Boot...
I meant Sven, sorry.
Ah, sorry, misread, I meant u-boot/master.
Martyn
Check u-boot-usb/master and sync with Sven please.
Port for the PHYTEC phyBOARD-i.MX6UL-Segin single board computer. Based on the PHYTEC phyCORE-i.MX6UL SOM (PCL063). This port provides both SPL and DCD based boot options (hence the two defconfigs).
CPU: Freescale i.MX6UL rev1.2 528 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 44C Reset cause: POR Board: PHYTEC phyCORE-i.MX6UL I2C: ready DRAM: 256 MiB NAND: 512 MiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC0
Working: - Eth0 - i2C - MMC/SD - NAND - UART (1 & 5) - USB (host & otg)
Changes in v2: - Switch to driver model
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx6ul-pcl063.dtsi | 180 ++++++++++++++++++++++ arch/arm/dts/imx6ul-phycore-segin.dts | 76 ++++++++++ arch/arm/mach-imx/mx6/Kconfig | 13 ++ board/phytec/pcl063/Kconfig | 12 ++ board/phytec/pcl063/MAINTAINERS | 9 ++ board/phytec/pcl063/Makefile | 7 + board/phytec/pcl063/README | 43 ++++++ board/phytec/pcl063/imximage.cfg | 177 ++++++++++++++++++++++ board/phytec/pcl063/pcl063.c | 206 ++++++++++++++++++++++++++ board/phytec/pcl063/spl.c | 118 +++++++++++++++ configs/phycore_pcl063_defconfig | 66 +++++++++ configs/phycore_pcl063_spl_defconfig | 71 +++++++++ include/configs/pcl063.h | 100 +++++++++++++ 14 files changed, 1080 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6ul-pcl063.dtsi create mode 100644 arch/arm/dts/imx6ul-phycore-segin.dts create mode 100644 board/phytec/pcl063/Kconfig create mode 100644 board/phytec/pcl063/MAINTAINERS create mode 100644 board/phytec/pcl063/Makefile create mode 100644 board/phytec/pcl063/README create mode 100644 board/phytec/pcl063/imximage.cfg create mode 100644 board/phytec/pcl063/pcl063.c create mode 100644 board/phytec/pcl063/spl.c create mode 100644 configs/phycore_pcl063_defconfig create mode 100644 configs/phycore_pcl063_spl_defconfig create mode 100644 include/configs/pcl063.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d36447d18d..ffda97a291 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -444,7 +444,8 @@ dtb-$(CONFIG_MX6UL) += \ imx6ul-isiot-nand.dtb \ imx6ul-opos6uldev.dtb \ imx6ul-14x14-evk.dtb \ - imx6ul-9x9-evk.dtb + imx6ul-9x9-evk.dtb \ + imx6ul-phycore-segin.dtb
dtb-$(CONFIG_MX6ULL) += imx6ull-14x14-evk.dtb
diff --git a/arch/arm/dts/imx6ul-pcl063.dtsi b/arch/arm/dts/imx6ul-pcl063.dtsi new file mode 100644 index 0000000000..fa63911480 --- /dev/null +++ b/arch/arm/dts/imx6ul-pcl063.dtsi @@ -0,0 +1,180 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Collabora Ltd. + * + * Based on dts[i] from Phytech barebox port: + * Copyright (C) 2016 PHYTEC Messtechnik GmbH + * Author: Christian Hemp c.hemp@phytec.de + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +/dts-v1/; + +#include "imx6ul.dtsi" + +/ { + model = "Phytec phyCORE-i.MX6 Ultra Lite SOM"; + compatible = "phytec,imx6ul-pcl063", "fsl,imx6ul"; + + memory { + reg = <0x80000000 0x20000000>; + }; + + chosen { + stdout-path = &uart1; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + phy-mode = "rmii"; + phy-handle = <ðphy0>; + status = "okay"; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@1 { + reg = <1>; + micrel,led-mode = <1>; + }; + }; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + nand-on-flash-bbt; + fsl,no-blockmark-swap; + status = "okay"; + + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "uboot"; + reg = <0x0 0x400000>; + }; + + partition@400000 { + label = "uboot-env"; + reg = <0x400000 0x100000>; + }; + + partition@500000 { + label = "root"; + reg = <0x500000 0x0>; + }; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c1>; + pinctrl-1 = <&pinctrl_i2c1_gpio>; + scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>; + status = "okay"; + + eeprom@52 { + compatible = "cat,24c32"; + reg = <0x52>; + }; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; + bus-width = <0x4>; + pinctrl-0 = <&pinctrl_usdhc1>; + no-1-8-v; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + + pinctrl_enet1: enet1grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO06__ENET1_MDIO 0x1b0b0 + MX6UL_PAD_GPIO1_IO07__ENET1_MDC 0X1b0b0 + MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 + MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 + >; + }; + + pinctrl_gpmi_nand: gpminandgrp { + fsl,pins = < + MX6UL_PAD_NAND_CLE__RAWNAND_CLE 0x0b0b1 + MX6UL_PAD_NAND_ALE__RAWNAND_ALE 0x0b0b1 + MX6UL_PAD_NAND_WP_B__RAWNAND_WP_B 0x0b0b1 + MX6UL_PAD_NAND_READY_B__RAWNAND_READY_B 0x0b000 + MX6UL_PAD_NAND_CE0_B__RAWNAND_CE0_B 0x0b0b1 + MX6UL_PAD_NAND_RE_B__RAWNAND_RE_B 0x0b0b1 + MX6UL_PAD_NAND_WE_B__RAWNAND_WE_B 0x0b0b1 + MX6UL_PAD_NAND_DATA00__RAWNAND_DATA00 0x0b0b1 + MX6UL_PAD_NAND_DATA01__RAWNAND_DATA01 0x0b0b1 + MX6UL_PAD_NAND_DATA02__RAWNAND_DATA02 0x0b0b1 + MX6UL_PAD_NAND_DATA03__RAWNAND_DATA03 0x0b0b1 + MX6UL_PAD_NAND_DATA04__RAWNAND_DATA04 0x0b0b1 + MX6UL_PAD_NAND_DATA05__RAWNAND_DATA05 0x0b0b1 + MX6UL_PAD_NAND_DATA06__RAWNAND_DATA06 0x0b0b1 + MX6UL_PAD_NAND_DATA07__RAWNAND_DATA07 0x0b0b1 + >; + }; + + pinctrl_i2c1: i2cgrp { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 + MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 + >; + }; + + pinctrl_i2c1_gpio: i2c1grp_gpio { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x1b8b0 + MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x1b8b0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 + MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10059 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 + MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 + + >; + }; +}; diff --git a/arch/arm/dts/imx6ul-phycore-segin.dts b/arch/arm/dts/imx6ul-phycore-segin.dts new file mode 100644 index 0000000000..d34836e0d7 --- /dev/null +++ b/arch/arm/dts/imx6ul-phycore-segin.dts @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Collabora Ltd. + * + * Based on dts[i] from Phytech barebox port: + * Copyright (C) 2016 PHYTEC Messtechnik GmbH + * Author: Christian Hemp c.hemp@phytec.de + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +/dts-v1/; + +#include "imx6ul-pcl063.dtsi" + +/ { + model = "Phytec phyBOARD-i.MX6UL-Segin SBC"; + compatible = "phytec,phyboard-imx6ul-segin", "phytec,imx6ul-pcl063", + "fsl,imx6ul"; +}; + +&i2c1 { + i2c_rtc: rtc@68 { + compatible = "microcrystal,rv4162"; + reg = <0x68>; + status = "okay"; + }; +}; + +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart5>; + uart-has-rtscts; + status = "okay"; +}; + +&usbotg1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg1_id>; + dr_mode = "otg"; + srp-disable; + hnp-disable; + adp-disable; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + disable-over-current; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + + pinctrl_uart5: uart5grp { + fsl,pins = < + MX6UL_PAD_UART5_TX_DATA__UART5_DCE_TX 0x1b0b1 + MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX 0x1b0b1 + MX6UL_PAD_GPIO1_IO08__UART5_DCE_RTS 0x1b0b1 + MX6UL_PAD_GPIO1_IO09__UART5_DCE_CTS 0x1b0b1 + >; + }; + + pinctrl_usb_otg1_id: usbotg1idgrp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO00__ANATOP_OTG1_ID 0x17059 + >; + }; + +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 06c25bae36..e253f495c5 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -428,6 +428,18 @@ config TARGET_PFLA02 select MX6QDL select SUPPORT_SPL
+config TARGET_PCL063 + bool "PHYTEC PCL063 (phyCORE-i.MX6UL)" + select MX6UL + select DM + select DM_ETH + select DM_GPIO + select DM_I2C + select DM_MMC + select DM_SERIAL + select DM_THERMAL + select SUPPORT_SPL + config TARGET_SECOMX6 bool "secomx6 boards"
@@ -550,6 +562,7 @@ source "board/freescale/mx6ullevk/Kconfig" source "board/grinn/liteboard/Kconfig" source "board/phytec/pcm058/Kconfig" source "board/phytec/pfla02/Kconfig" +source "board/phytec/pcl063/Kconfig" source "board/gateworks/gw_ventana/Kconfig" source "board/kosagi/novena/Kconfig" source "board/samtec/vining_2000/Kconfig" diff --git a/board/phytec/pcl063/Kconfig b/board/phytec/pcl063/Kconfig new file mode 100644 index 0000000000..977db70f64 --- /dev/null +++ b/board/phytec/pcl063/Kconfig @@ -0,0 +1,12 @@ +if TARGET_PCL063 + +config SYS_BOARD + default "pcl063" + +config SYS_VENDOR + default "phytec" + +config SYS_CONFIG_NAME + default "pcl063" + +endif diff --git a/board/phytec/pcl063/MAINTAINERS b/board/phytec/pcl063/MAINTAINERS new file mode 100644 index 0000000000..6fbf50c565 --- /dev/null +++ b/board/phytec/pcl063/MAINTAINERS @@ -0,0 +1,9 @@ +PCL063 BOARD +M: Martyn Welch martyn.welch@collabora.com +S: Maintained +F: arch/arm/dts/imx6ul-pcl063.dtsi +F: arch/arm/dts/imx6ul-phycore-segin.dts +F: board/phytec/pcl063/ +F: configs/phycore_pcl063_defconfig +F: configs/phycore_pcl063_spl_defconfig +F: include/configs/pcl063.h diff --git a/board/phytec/pcl063/Makefile b/board/phytec/pcl063/Makefile new file mode 100644 index 0000000000..53c73c9b08 --- /dev/null +++ b/board/phytec/pcl063/Makefile @@ -0,0 +1,7 @@ +# Copyright (C) 2018 Collabora Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := pcl063.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/phytec/pcl063/README b/board/phytec/pcl063/README new file mode 100644 index 0000000000..d73e90e83d --- /dev/null +++ b/board/phytec/pcl063/README @@ -0,0 +1,43 @@ +How to use U-Boot on PHYTEC phyBOARD-i.MX6UL-Segin +-------------------------------------------------- + +- Clean U-Boot tree: + + $ make mrproper + +- Configure U-Boot for phyCORE-i.MX6UL (using DCD): + + $ make phycore_pcl063_defconfig + + Or for build with SPL: + + $ make phycore_pcl063_spl_defconfig + +- Build U-Boot + + $ make + + This will either generate an u-boot.imx image or SPL and u-boot-dtb.img + images depending on the config chosen. + +- When an u-boot.imx image has been built, flash this into a micro SD card as + follows: + + $ sudo dd if=u-boot.imx of=/dev/mmcblk0 bs=1k seek=1; sync + +- If the SPL and u-boot-dtb.img image have been built both need to be flashed + into the micro SD card: + + $ sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync + $ sudo dd if=u-boot-dtb.img of=/dev/mmcblk0 bs=1k seek=69; sync + +- Jumper settings: + + JP1: Open: Boot from NAND + Closed: Boot from SD/MMC1 + +- Connect the Serial cable to UART0 and the PC for the console. + +- Insert the micro SD card in the board and power it up. + +- U-Boot messages should come up. diff --git a/board/phytec/pcl063/imximage.cfg b/board/phytec/pcl063/imximage.cfg new file mode 100644 index 0000000000..a50aaa4711 --- /dev/null +++ b/board/phytec/pcl063/imximage.cfg @@ -0,0 +1,177 @@ +/* + * Copyright (C) 2018 Collabora Ltd. + * + * Values taken from: Barebox: + * - arch/arm/boards/phytec-som-imx6/flash-header-phytec-pcl063.h + * - arch/arm/boards/phytec-som-imx6/flash-header-phytec-pcl063-256mb.imxcfg + * + * Based on board/ccv/xpress/imximage.cfg: + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define __ASSEMBLY__ +#include <config.h> + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * sd, nand + */ +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* Enable all clocks */ +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff + +/* ddr io type */ +DATA 4 0x020e04b4 0x000C0000 /* IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE */ +DATA 4 0x020e04ac 0x00000000 /* IOMUXC_SW_PAD_CTL_GRP_DDRPKE */ + +/* clock */ +DATA 4 0x020e027c 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK0_P */ + +/* control and address */ +DATA 4 0x020E024C 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS */ +DATA 4 0x020E0250 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS */ +DATA 4 0x020E0490 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_ADDDS */ +DATA 4 0x020E0288 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET */ +DATA 4 0x020E0270 0x00000000 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be + configured using Group Control Register: + IOMUXC_SW_PAD_CTL_GRP_CTLDS */ +DATA 4 0x020E0260 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_ODT0 */ +DATA 4 0x020E0264 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_ODT1 */ +DATA 4 0x020E04A0 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_CTLDS */ + +/* data strobes */ +DATA 4 0x020e0494 0x00020000 /* IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL */ +DATA 4 0x020e0280 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0_P */ +DATA 4 0x020e0284 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1_P */ + +/* data */ +DATA 4 0x020E04B0 0x00020000 /* IOMUXC_SW_PAD_CTL_GRP_DDRMODE */ +DATA 4 0x020E0498 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_B0DS */ +DATA 4 0x020E04A4 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_B1DS */ +DATA 4 0x020E0244 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0 */ +DATA 4 0x020E0248 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1 */ + +/* + * DDR Controller Registers + * + * Manufacturer: Micron + * Device Part Number: MT41K256M16TW-107 IT:P + * Clock Freq.: 933MHz + * Density per CS in Gb: 1 + * Chip Selects used: 1 + * Number of Banks: 8 + * Row address: 15 + * Column address: 10 + * Data bus width 16 + */ +DATA 4 0x021b001c 0x00008000 /* MMDC0_MDSCR, set the Configuration request bit + during MMDC set up */ + +/* + * Calibration setup + */ +DATA 4 0x021b0800 0xA1390003 /* DDR_PHY_P0_MPZQHWCTRL, enable both one-time & + periodic HW ZQ calibration. */ + +/* + * For target board, may need to run write leveling calibration to fine tune + * these settings. + */ +DATA 4 0x021b080c 0x00000000 + +/* Read DQS Gating calibration */ +DATA 4 0x021b083c 0x41480148 /* MPDGCTRL0 PHY0 */ + +/* Read calibration */ +DATA 4 0x021b0848 0x40403E42 /* MPRDDLCTL PHY0 */ + +/* Write calibration */ +DATA 4 0x021b0850 0x40405852 /* MPWRDLCTL PHY0 */ + +/* + * read data bit delay: (3 is the reccommended default value, although out of + * reset value is 0) + */ +DATA 4 0x021b081c 0x33333333 /* DDR_PHY_P0_MPREDQBY0DL3 */ +DATA 4 0x021b0820 0x33333333 /* DDR_PHY_P0_MPREDQBY1DL3 */ +DATA 4 0x021b082c 0xF3333333 +DATA 4 0x021b0830 0xF3333333 + +DATA 4 0x021b08c0 0x00922012 + +/* Clock Fine Tuning */ +DATA 4 0x021B0858 0x00000F00 /* [MMDC_MPSDCTRL] MMDC PHY CK Control Register */ + +/* Complete calibration by forced measurement: */ +DATA 4 0x021b08b8 0x00000800 /* DDR_PHY_P0_MPMUR0, frc_msr */ +/* + * Calibration setup end + */ + +/* MMDC init: */ +DATA 4 0x021b0004 0x0002002D /* MMDC0_MDPDC */ +DATA 4 0x021b0008 0x1B333030 /* MMDC0_MDOTC */ +DATA 4 0x021b000c 0x676B52F3 /* MMDC0_MDCFG0 */ +DATA 4 0x021b0010 0xB66D0B63 /* MMDC0_MDCFG1 */ +DATA 4 0x021b0014 0x01FF00DB /* MMDC0_MDCFG2 */ + +/* + * MDMISC: RALAT kept to the high level of 5. + * MDMISC: consider reducing RALAT if your 528MHz board design allow that. + * Lower RALAT benefits: + * a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT + * to 3 + * b. Small performence improvment + */ +DATA 4 0x021b0018 0x00211740 /* MMDC0_MDMISC */ + +DATA 4 0x021b001c 0x00008000 /* MMDC0_MDSCR, set the Configuration request bit + during MMDC set up */ + +DATA 4 0x021b002c 0x000026D2 /* MMDC0_MDRWD */ +DATA 4 0x021b0030 0x006B1023 /* MMDC0_MDOR */ +DATA 4 0x021b0040 0x00000047 /* Chan0 CS0_END */ +DATA 4 0x021b0000 0x83180000 /* MMDC0_MDCTL */ + +/* Mode register writes */ +DATA 4 0x021b001c 0x02008032 /* MMDC0_MDSCR, MR2 write, CS0 */ +DATA 4 0x021b001c 0x00008033 /* MMDC0_MDSCR, MR3 write, CS0 */ +DATA 4 0x021b001c 0x00048031 /* MMDC0_MDSCR, MR1 write, CS0 */ +DATA 4 0x021b001c 0x15208030 /* MMDC0_MDSCR, MR0 write, CS0 */ +DATA 4 0x021b001c 0x04008040 /* MMDC0_MDSCR, ZQ calibration command sent to + device on CS0 */ + +DATA 4 0x021b0020 0x00007800 /* MMDC0_MDREF */ +DATA 4 0x021b0818 0x00000227 /* DDR_PHY_P0_MPODTCTRL */ +DATA 4 0x021b0004 0x0002556D /* MMDC0_MDPDC now SDCTL power down enabled */ +DATA 4 0x021b0404 0x00011006 /* MMDC0_MAPSR ADOPT power down enabled, MMDC will + enter automatically to self-refresh while the + number of idle cycle reached. */ +DATA 4 0x021b001c 0x00000000 /* MMDC0_MDSCR, clear this register (especially + the configuration bit as initialization is + complete) */ + +DATA 4 0x021b0890 0x00400A38 diff --git a/board/phytec/pcl063/pcl063.c b/board/phytec/pcl063/pcl063.c new file mode 100644 index 0000000000..200e50990b --- /dev/null +++ b/board/phytec/pcl063/pcl063.c @@ -0,0 +1,206 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Collabora Ltd. + * + * Based on board/ccv/xpress/xpress.c: + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + */ + +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc.h> +#include <linux/bitops.h> +#include <miiphy.h> +#include <netdev.h> +#include <usb.h> +#include <usb/ehci-ci.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | \ + PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart5_pads[] = { + MX6_PAD_UART5_TX_DATA__UART5_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART5_RX_DATA__UART5_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_GPIO1_IO09__UART5_DCE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_GPIO1_IO08__UART5_DCE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads)); +} + +#ifdef CONFIG_NAND_MXS + +#define NAND_PAD_CTRL (PAD_CTL_DSE_48ohm | PAD_CTL_SRE_SLOW | PAD_CTL_HYS) + +#define NAND_PAD_READY0_CTRL (PAD_CTL_DSE_48ohm | PAD_CTL_PUS_22K_UP) + +#define NANDREADYPC MUX_PAD_CTRL(NAND_PAD_READY0_CTRL) + +static iomux_v3_cfg_t const gpmi_pads[] = { + MX6_PAD_NAND_DATA00__RAWNAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA01__RAWNAND_DATA01 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA02__RAWNAND_DATA02 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA03__RAWNAND_DATA03 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA04__RAWNAND_DATA04 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA05__RAWNAND_DATA05 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA06__RAWNAND_DATA06 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA07__RAWNAND_DATA07 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_CLE__RAWNAND_CLE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_ALE__RAWNAND_ALE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_RE_B__RAWNAND_RE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_WE_B__RAWNAND_WE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_READY_B__RAWNAND_READY_B | NANDREADYPC, +}; + +static void setup_gpmi_nand(void) +{ + imx_iomux_v3_setup_multiple_pads(gpmi_pads, ARRAY_SIZE(gpmi_pads)); + + setup_gpmi_io_clk((3 << MXC_CCM_CSCDR1_BCH_PODF_OFFSET) | + (3 << MXC_CCM_CSCDR1_GPMI_PODF_OFFSET)); +} + +#endif /* CONFIG_NAND_MXS */ + +#ifdef CONFIG_FEC_MXC + +#define ENET_CLK_PAD_CTRL (PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | PAD_CTL_DSE_48ohm | \ + PAD_CTL_SRE_FAST) + +#define MDIO_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST | \ + PAD_CTL_ODE) + +static iomux_v3_cfg_t const fec1_pads[] = { + MX6_PAD_GPIO1_IO06__ENET1_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL), + MX6_PAD_GPIO1_IO07__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static iomux_v3_cfg_t const fec2_pads[] = { + MX6_PAD_ENET2_TX_DATA0__ENET2_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_DATA1__ENET2_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_EN__ENET2_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), + MX6_PAD_ENET2_RX_DATA0__ENET2_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_RX_DATA1__ENET2_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_RX_ER__ENET2_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_RX_EN__ENET2_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); + imx_iomux_v3_setup_multiple_pads(fec2_pads, ARRAY_SIZE(fec2_pads)); +} + +static int setup_fec(void) +{ + struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + int ret; + + /* + * Use 50M anatop loopback REF_CLK1 for ENET1, + * clear gpr1[13], set gpr1[17]. + */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, + IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK); + + ret = enable_fec_anatop_clock(0, ENET_50MHZ); + if (ret) + return ret; + + /* + * Use 50M anatop loopback REF_CLK2 for ENET2, + * clear gpr1[14], set gpr1[18]. + */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC2_MASK, + IOMUX_GPR1_FEC2_CLOCK_MUX1_SEL_MASK); + + ret = enable_fec_anatop_clock(1, ENET_50MHZ); + if (ret) + return ret; + + enable_enet_clk(1); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* + * Defaults + Enable status LEDs (LED1: Activity, LED0: Link) & select + * 50 MHz RMII clock mode. + */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif /* CONFIG_FEC_MXC */ + +int board_early_init_f(void) +{ + setup_iomux_uart(); + setup_iomux_fec(); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_NAND_MXS + setup_gpmi_nand(); +#endif + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + return 0; +} + +int checkboard(void) +{ + puts("Board: PHYTEC phyCORE-i.MX6UL\n"); + + return 0; +} diff --git a/board/phytec/pcl063/spl.c b/board/phytec/pcl063/spl.c new file mode 100644 index 0000000000..e2a13efe91 --- /dev/null +++ b/board/phytec/pcl063/spl.c @@ -0,0 +1,118 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Collabora Ltd. + * + * Based on board/ccv/xpress/spl.c: + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/crm_regs.h> + +/* Configuration for Micron MT41K256M16TW-107 IT:P, 32M x 16 x 8 -> 256MiB */ + +static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { + .grp_addds = 0x00000030, + .grp_ddrmode_ctl = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ddr_type = 0x000c0000, +}; + +static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_dqm0 = 0x00000030, + .dram_dqm1 = 0x00000030, + .dram_ras = 0x00000030, + .dram_cas = 0x00000030, + .dram_odt0 = 0x00000030, + .dram_odt1 = 0x00000030, + .dram_sdba2 = 0x00000000, + .dram_sdclk_0 = 0x00000030, + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_reset = 0x00000030, +}; + +static struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x00000000, + .p0_mpdgctrl0 = 0x41480148, + .p0_mprddlctl = 0x40403E42, + .p0_mpwrdlctl = 0x40405852, +}; + +struct mx6_ddr_sysinfo ddr_sysinfo = { + .dsize = 0, /* Bus size = 16bit */ + .cs_density = 18, + .ncs = 1, + .cs1_mirror = 0, + .rtt_wr = 1, + .rtt_nom = 1, + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .pd_fast_exit = 1, + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .ddr_type = DDR_TYPE_DDR3, + .refsel = 1, /* Refresh cycles at 32KHz */ + .refr = 7, /* 8 refresh commands per refresh cycle */ +}; + +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 933, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 1, + .trcd = 1391, + .trcmin = 4791, + .trasmin = 3400, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0xFFFFFFFF, &ccm->CCGR0); + writel(0xFFFFFFFF, &ccm->CCGR1); + writel(0xFFFFFFFF, &ccm->CCGR2); + writel(0xFFFFFFFF, &ccm->CCGR3); + writel(0xFFFFFFFF, &ccm->CCGR4); + writel(0xFFFFFFFF, &ccm->CCGR5); + writel(0xFFFFFFFF, &ccm->CCGR6); +} + +static void spl_dram_init(void) +{ + mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); +} + +void board_init_f(ulong dummy) +{ + ccgr_init(); + + /* Setup AIPS and disable watchdog */ + arch_cpu_init(); + + /* Setup iomux and i2c */ + board_early_init_f(); + + /* Setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); +} diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig new file mode 100644 index 0000000000..aa60e38774 --- /dev/null +++ b/configs/phycore_pcl063_defconfig @@ -0,0 +1,66 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PCL063=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=8 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcl063/imximage.cfg" +CONFIG_BOOTDELAY=3 +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="gpmi-nand:4m(uboot),1m(env),-(root)" +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_MXC_UART=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y +CONFIG_DM_ETH=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Phytec" +CONFIG_USB_GADGET_VENDOR_NUM=0x01b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4fff +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/phycore_pcl063_spl_defconfig b/configs/phycore_pcl063_spl_defconfig new file mode 100644 index 0000000000..d82aeb3bd2 --- /dev/null +++ b/configs/phycore_pcl063_spl_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PCL063=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=8 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET_SUPPORT=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="gpmi-nand:4m(uboot),1m(env),-(root)" +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_MXC_UART=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_ETH=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Phytec" +CONFIG_USB_GADGET_VENDOR_NUM=0x01b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4fff +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h new file mode 100644 index 0000000000..d8856b3e5d --- /dev/null +++ b/include/configs/pcl063.h @@ -0,0 +1,100 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Collabora Ltd. + * + * Based on include/configs/xpress.h: + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + */ +#ifndef __PCL063_H +#define __PCL063_H + +#include <linux/sizes.h> +#include "mx6_common.h" + +/* SPL options */ +#include "imx6_spl.h" + +/* + * There is a bug in some i.MX6UL processors that results in the initial + * portion of OCRAM being unavailable when booting from (at least) an SD + * card. + * + * Tweak the SPL text base address to avoid this. + */ +#undef CONFIG_SPL_TEXT_BASE +#define CONFIG_SPL_TEXT_BASE 0x00909000 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) + +/* Console configs */ +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* MMC Configs */ +#define CONFIG_FSL_USDHC + +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR + +/* I2C configs */ +#ifdef CONFIG_CMD_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x10000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +/* Physical Memory Map */ +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE SZ_256M + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_SIZE (16 << 10) +#define CONFIG_ENV_OFFSET (512 << 10) + +/* NAND */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 + +/* USB Configs */ +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define CONFIG_IMX_THERMAL + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttymxc0,115200n8\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "fdt_addr_r=0x82000000\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "kernel_addr_r=0x81000000\0" \ + "pxefile_addr_r=0x87100000\0" \ + "ramdisk_addr_r=0x82100000\0" \ + "scriptaddr=0x87000000\0" \ + BOOTENV + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(UBIFS, ubifs, 0) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#endif /* __PCL063_H */
Hi Martyn,
thanks for upstreaming this board. For the three patches & with u-boot.imx image type, Tested-by: Wadim Egorov w.egorov@phytec.de
But it seems, phycore_pcl063_spl_defconfig is not working:
U-Boot spl 2018.11-00307-g74b1be3 (Nov 27 2018 - 15:05:14 +0100) Trying to boot from MMC1 MMC Device 0 not found spl: could not find mmc device 0. error: -19 spl: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
Also, some nits below.
Am 23.11.18 um 17:47 schrieb Martyn Welch:
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART (1 & 5)
- USB (host & otg)
Changes in v2:
- imx6ul-9x9-evk.dtb \
- imx6ul-phycore-segin.dtb
- Copyright (C) 2018 Collabora Ltd.
- Based on dts[i] from Phytech barebox port:
it's Phytec
- Copyright (C) 2016 PHYTEC Messtechnik GmbH
- Author: Christian Hemp c.hemp@phytec.de
- The code contained herein is licensed under the GNU General Public
- License. You may obtain a copy of the GNU General Public License
- Version 2 or later at the following locations:
+/dts-v1/;
- model = "Phytec phyCORE-i.MX6 Ultra Lite SOM";
- compatible = "phytec,imx6ul-pcl063", "fsl,imx6ul";
- memory {
- chosen {
+&fec1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_enet1>;
- phy-mode = "rmii";
- phy-handle = <ðphy0>;
- status = "okay";
- mdio: mdio {
#size-cells = <0>;
reg = <1>;
+&gpmi {
- pinctrl-0 = <&pinctrl_gpmi_nand>;
- nand-on-flash-bbt;
- fsl,no-blockmark-swap;
- status = "okay";
- #address-cells = <1>;
- #size-cells = <1>;
- partition@0 {
label = "uboot";
- partition@400000 {
- partition@500000 {
label = "root";
+&i2c1 {
- clock-frequency = <100000>;
- pinctrl-names = "default", "gpio";
- pinctrl-0 = <&pinctrl_i2c1>;
- pinctrl-1 = <&pinctrl_i2c1_gpio>;
- scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>;
- sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>;
- status = "okay";
- eeprom@52 {
reg = <0x52>;
+&uart1 {
- pinctrl-0 = <&pinctrl_uart1>;
- status = "okay";
+&usdhc1 {
- pinctrl-0 = <&pinctrl_usdhc1>;
- cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>;
- bus-width = <0x4>;
- no-1-8-v;
- status = "okay";
+&iomuxc {
- pinctrl_enet1: enet1grp {
fsl,pins = <
- pinctrl_gpmi_nand: gpminandgrp {
fsl,pins = <
- pinctrl_i2c1: i2cgrp {
fsl,pins = <
- pinctrl_i2c1_gpio: i2c1grp_gpio {
fsl,pins = <
- pinctrl_uart1: uart1grp {
fsl,pins = <
- pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
same here, Phytec
+/dts-v1/;
- model = "Phytec phyBOARD-i.MX6UL-Segin SBC";
- compatible = "phytec,phyboard-imx6ul-segin", "phytec,imx6ul-pcl063",
"fsl,imx6ul";
+&i2c1 {
- i2c_rtc: rtc@68 {
reg = <0x68>;
status = "okay";
+&uart5 {
- pinctrl-0 = <&pinctrl_uart5>;
- uart-has-rtscts;
- status = "okay";
+&usbotg1 {
- pinctrl-0 = <&pinctrl_usb_otg1_id>;
- dr_mode = "otg";
- srp-disable;
- hnp-disable;
- adp-disable;
- status = "okay";
+&usbotg2 {
- dr_mode = "host";
- disable-over-current;
- status = "okay";
+&iomuxc {
- pinctrl_uart5: uart5grp {
fsl,pins = <
- pinctrl_usb_otg1_id: usbotg1idgrp {
fsl,pins = <
- bool "PHYTEC PCL063 (phyCORE-i.MX6UL)"
- select MX6UL
- select DM
- select DM_ETH
- select DM_GPIO
- select DM_I2C
- select DM_MMC
- select DM_SERIAL
- select DM_THERMAL
- select SUPPORT_SPL
+config SYS_BOARD
- default "pcl063"
+config SYS_VENDOR
- default "phytec"
- default "pcl063"
- $ make mrproper
- $ make phycore_pcl063_defconfig
- Or for build with SPL:
- $ make phycore_pcl063_spl_defconfig
+- Build U-Boot
- $ make
- This will either generate an u-boot.imx image or SPL and u-boot-dtb.img
- images depending on the config chosen.
- follows:
- $ sudo dd if=u-boot.imx of=/dev/mmcblk0 bs=1k seek=1; sync
the output file is u-boot-dtb.imx
Wadim
- into the micro SD card:
- $ sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync
- $ sudo dd if=u-boot-dtb.img of=/dev/mmcblk0 bs=1k seek=69; sync
+- Jumper settings:
- JP1: Open: Boot from NAND
- Values taken from: Barebox:
- Based on board/ccv/xpress/imximage.cfg:
- Copyright (C) 2015-2016 Stefan Roese sr@denx.de
+IMAGE_VERSION 2
- Boot Device : one of
- sd, nand
+BOOT_FROM sd
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- DDR Controller Registers
- Manufacturer: Micron
- Device Part Number: MT41K256M16TW-107 IT:P
- Clock Freq.: 933MHz
- Density per CS in Gb: 1
- Chip Selects used: 1
- Number of Banks: 8
- Row address: 15
- Column address: 10
- Data bus width 16
- Calibration setup
- For target board, may need to run write leveling calibration to fine tune
- these settings.
- read data bit delay: (3 is the reccommended default value, although out of
- reset value is 0)
- Calibration setup end
- MDMISC: RALAT kept to the high level of 5.
- MDMISC: consider reducing RALAT if your 528MHz board design allow that.
- Lower RALAT benefits:
- a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT
- to 3
- b. Small performence improvment
device on CS0 */
complete) */
- Based on board/ccv/xpress/xpress.c:
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
PAD_CTL_HYS)
- MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART5_TX_DATA__UART5_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART5_RX_DATA__UART5_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_GPIO1_IO09__UART5_DCE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_GPIO1_IO08__UART5_DCE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
- imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads));
- MX6_PAD_NAND_DATA00__RAWNAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA01__RAWNAND_DATA01 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA02__RAWNAND_DATA02 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA03__RAWNAND_DATA03 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA04__RAWNAND_DATA04 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA05__RAWNAND_DATA05 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA06__RAWNAND_DATA06 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_DATA07__RAWNAND_DATA07 | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_CLE__RAWNAND_CLE | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_ALE__RAWNAND_ALE | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_RE_B__RAWNAND_RE_B | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_WE_B__RAWNAND_WE_B | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B | MUX_PAD_CTRL(NAND_PAD_CTRL),
- MX6_PAD_NAND_READY_B__RAWNAND_READY_B | NANDREADYPC,
- imx_iomux_v3_setup_multiple_pads(gpmi_pads, ARRAY_SIZE(gpmi_pads));
- setup_gpmi_io_clk((3 << MXC_CCM_CSCDR1_BCH_PODF_OFFSET) |
PAD_CTL_SRE_FAST)
PAD_CTL_ODE)
- MX6_PAD_GPIO1_IO06__ENET1_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL),
- MX6_PAD_GPIO1_IO07__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL),
- MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_TX_DATA0__ENET2_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_TX_DATA1__ENET2_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_TX_EN__ENET2_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL),
- MX6_PAD_ENET2_RX_DATA0__ENET2_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_RX_DATA1__ENET2_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_RX_ER__ENET2_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET2_RX_EN__ENET2_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads));
- imx_iomux_v3_setup_multiple_pads(fec2_pads, ARRAY_SIZE(fec2_pads));
- struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR;
- int ret;
- clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK,
- ret = enable_fec_anatop_clock(0, ENET_50MHZ);
- if (ret)
return ret;
- clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC2_MASK,
- ret = enable_fec_anatop_clock(1, ENET_50MHZ);
- if (ret)
return ret;
- enable_enet_clk(1);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190);
- if (phydev->drv->config)
- setup_iomux_uart();
- setup_iomux_fec();
- /* Address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_gpmi_nand();
- setup_fec();
- puts("Board: PHYTEC phyCORE-i.MX6UL\n");
- Based on board/ccv/xpress/spl.c:
- .grp_addds = 0x00000030,
- .grp_ddrmode_ctl = 0x00020000,
- .grp_b0ds = 0x00000030,
- .grp_ctlds = 0x00000030,
- .grp_b1ds = 0x00000030,
- .grp_ddrpke = 0x00000000,
- .grp_ddrmode = 0x00020000,
- .grp_ddr_type = 0x000c0000,
- .dram_dqm0 = 0x00000030,
- .dram_dqm1 = 0x00000030,
- .dram_ras = 0x00000030,
- .dram_cas = 0x00000030,
- .dram_odt0 = 0x00000030,
- .dram_odt1 = 0x00000030,
- .dram_sdba2 = 0x00000000,
- .dram_sdclk_0 = 0x00000030,
- .dram_sdqs0 = 0x00000030,
- .dram_sdqs1 = 0x00000030,
- .dram_reset = 0x00000030,
- .p0_mpwldectrl0 = 0x00000000,
- .p0_mpdgctrl0 = 0x41480148,
- .p0_mprddlctl = 0x40403E42,
- .p0_mpwrdlctl = 0x40405852,
- .dsize = 0, /* Bus size = 16bit */
- .cs_density = 18,
- .ncs = 1,
- .cs1_mirror = 0,
- .rtt_wr = 1,
- .rtt_nom = 1,
- .walat = 1, /* Write additional latency */
- .ralat = 5, /* Read additional latency */
- .mif3_mode = 3, /* Command prediction working mode */
- .bi_on = 1, /* Bank interleaving enabled */
- .pd_fast_exit = 1,
- .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */
- .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */
- .ddr_type = DDR_TYPE_DDR3,
- .refsel = 1, /* Refresh cycles at 32KHz */
- .refr = 7, /* 8 refresh commands per refresh cycle */
- .mem_speed = 933,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .pagesz = 1,
- .trcd = 1391,
- .trcmin = 4791,
- .trasmin = 3400,
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- writel(0xFFFFFFFF, &ccm->CCGR0);
- writel(0xFFFFFFFF, &ccm->CCGR1);
- writel(0xFFFFFFFF, &ccm->CCGR2);
- writel(0xFFFFFFFF, &ccm->CCGR3);
- writel(0xFFFFFFFF, &ccm->CCGR4);
- writel(0xFFFFFFFF, &ccm->CCGR5);
- writel(0xFFFFFFFF, &ccm->CCGR6);
- mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs);
- mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr);
- ccgr_init();
- /* Setup AIPS and disable watchdog */
- arch_cpu_init();
- /* Setup iomux and i2c */
- board_early_init_f();
- /* Setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- /* DDR initialization */
- spl_dram_init();
- Based on include/configs/xpress.h:
- There is a bug in some i.MX6UL processors that results in the initial
- portion of OCRAM being unavailable when booting from (at least) an SD
- card.
- Tweak the SPL text base address to avoid this.
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
- "console=ttymxc0,115200n8\0" \
- "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \
- "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \
- "fdt_addr_r=0x82000000\0" \
- "fdt_high=0xffffffff\0" \
- "initrd_high=0xffffffff\0" \
- "kernel_addr_r=0x81000000\0" \
- "pxefile_addr_r=0x87100000\0" \
- "ramdisk_addr_r=0x82100000\0" \
- "scriptaddr=0x87000000\0" \
- BOOTENV
- func(MMC, mmc, 0) \
- func(UBIFS, ubifs, 0) \
- func(DHCP, dhcp, na)
On Tue, 2018-11-27 at 15:15 +0100, Wadim Egorov wrote:
Hi Martyn,
Whoops - was testing via USB upload...
Fixed in next revision.
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART (1 & 5)
- USB (host & otg)
Changes in v2:
diff --git a/arch/arm/dts/imx6ul-pcl063.dtsi b/arch/arm/dts/imx6ul- pcl063.dtsi new file mode 100644 index 0000000000..fa63911480 --- /dev/null +++ b/arch/arm/dts/imx6ul-pcl063.dtsi @@ -0,0 +1,180 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
it's Phytec
Public
License
+/dts-v1/;
- memory {
- chosen {
+&fec1 {
- status = "okay";
- mdio: mdio {
#size-cells = <0>;
reg = <1>;
+&gpmi {
- status = "okay";
- partition@0 {
label = "uboot";
label = "root";
+&i2c1 {
- status = "okay";
- eeprom@52 {
reg = <0x52>;
+&uart1 {
- status = "okay";
+&usdhc1 {
- no-1-8-v;
- status = "okay";
+&iomuxc {
fsl,pins = <
b0b0
b0b0
b0b0
b0b0
b0b0
001b031
fsl,pins = <
b0b1
b0b1
b000
b0b1
b0b1
b0b1
b0b1
b0b1
b0b1
b0b1
b0b1
fsl,pins = <
8b0
8b0
fsl,pins = <
fsl,pins = <
fsl,pins = <
7059
0059
same here, Phytec
Public
License
+/dts-v1/;
pcl063",
"fsl,imx6ul";
+&i2c1 {
- i2c_rtc: rtc@68 {
reg = <0x68>;
status = "okay";
+&uart5 {
- uart-has-rtscts;
- status = "okay";
+&usbotg1 {
- dr_mode = "otg";
- srp-disable;
- hnp-disable;
- adp-disable;
- status = "okay";
+&usbotg2 {
- dr_mode = "host";
- status = "okay";
+&iomuxc {
fsl,pins = <
b0b1
b0b1
fsl,pins = <
+}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach- imx/mx6/Kconfig index 06c25bae36..e253f495c5 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -428,6 +428,18 @@ config TARGET_PFLA02 select MX6QDL select SUPPORT_SPL
- select MX6UL
- select DM
- select DM_ETH
- select DM_GPIO
- select DM_I2C
- select DM_MMC
- select DM_SERIAL
- select DM_THERMAL
+config SYS_BOARD
- default "pcl063"
+config SYS_VENDOR
- default "phytec"
- default "pcl063"
- $ make mrproper
+- Build U-Boot
- $ make
dtb.img
- follows:
Wadim
sync
+- Jumper settings:
pcl063.h
256mb.imxcfg
+IMAGE_VERSION 2
- sd, nand
+BOOT_FROM sd
- where:
Register:
- Row address: 15
- Data bus width 16
- Calibration setup
fine tune
- these settings.
although out of
- reset value is 0)
allow that.
change RALAT
- to 3
device on CS0 */
while the
is
complete) */
PHYS_SDRAM_SIZE);
PAD_CTL_HYS)
PAD_CTL_SRE_FAST)
PAD_CTL_ODE)
*)IOMUXC_BASE_ADDR;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
select
- setup_fec();
- .cs_density = 18,
- .ncs = 1,
- .cs1_mirror = 0,
- .rtt_wr = 1,
- .rtt_nom = 1,
- .mem_speed = 933,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .pagesz = 1,
- .trcd = 1391,
- .trcmin = 4791,
- .trasmin = 3400,
&mx6_grp_ioregs);
- ccgr_init();
- arch_cpu_init();
- timer_init();
- spl_dram_init();
+} diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig new file mode 100644 index 0000000000..aa60e38774 --- /dev/null +++ b/configs/phycore_pcl063_defconfig @@ -0,0 +1,66 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PCL063=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=8 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcl063/imximage. cfg" +CONFIG_BOOTDELAY=3 +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="gpmi-nand:4m(uboot),1m(env),-(root)" +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_MXC_UART=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y +CONFIG_DM_ETH=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Phytec" +CONFIG_USB_GADGET_VENDOR_NUM=0x01b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4fff +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/phycore_pcl063_spl_defconfig b/configs/phycore_pcl063_spl_defconfig new file mode 100644 index 0000000000..d82aeb3bd2 --- /dev/null +++ b/configs/phycore_pcl063_spl_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PCL063=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=8 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET_SUPPORT=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="gpmi-nand:4m(uboot),1m(env),-(root)" +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_MXC_UART=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_ETH=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Phytec" +CONFIG_USB_GADGET_VENDOR_NUM=0x01b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4fff +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h new file mode 100644 index 0000000000..d8856b3e5d --- /dev/null +++ b/include/configs/pcl063.h @@ -0,0 +1,100 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
initial
an SD
- card.
+/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_STA RT + 0x10000000)
- BOOTENV
Nice ! A few nits below.
Is the DCD option really needed or can it be dropped ? The SPL is far more flexible.
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART (1 & 5)
- USB (host & otg)
Signed-off-by: Martyn Welch martyn.welch@collabora.com
Changes in v2:
"Phytec", fix globally. But maybe you can pull the DT from upstream Linux instead ?
This is in the SPDX tag above, drop it. [...]
ifdef[SPACE] instead of TAB, keep it consistent.
- setup_fec();
Dropped in the next revision.
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART (1 & 5)
- USB (host & otg)
Changes in v2:
Public
License
- setup_fec();
On Fri, 23 Nov 2018 16:47:30 +0000 Martyn Welch martyn@welchs.me.uk wrote:
Currently if we have more than one phy on the MDIO bus, we do not have a good mechanism for determining which should be used at runtime. Enable the FEC driver to determine the address for the PHY from the device tree.
Changes in v2:
- New in v2
drivers/net/fec_mxc.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 99c5c649a0..425f6197cb 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1264,11 +1264,32 @@ static const struct eth_ops fecmxc_ops = { .read_rom_hwaddr = fecmxc_read_rom_hwaddr, };
+static int device_get_phy_addr(struct udevice *dev) +{
- struct ofnode_phandle_args phandle_args;
- int reg;
- if (dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0,
&phandle_args)) {
debug("Failed to find phy-handle");
return -ENODEV;
- reg = ofnode_read_u32_default(phandle_args.node, "reg", 0);
- return reg;
static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) { struct phy_device *phydev;
int addr; int mask = 0xffffffff;
addr = device_get_phy_addr(dev);
if (addr >= 0)
mask = 1 << addr;
#ifdef CONFIG_FEC_MXC_PHYADDR mask = 1 << CONFIG_FEC_MXC_PHYADDR; #endif
I suppose that the above code is to move the CONFIG_FEC_MXC_PHYADDR to DTS.
I do agree for this,
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
participants (7)
Lukasz Majewski
Martyn Welch
Martyn Welch
Simon Goldschmidt
Wadim Egorov
