[U-Boot] [PATCH] api: storage: Add the missing write operation support
API_dev_write(va_list ap) is currently lacking the write support to storage devices because, historically, those devices did not implement block_write()
The solution has been tested by loading and booting a (patched) GRUB instance in a QEMU vexpress-a9 environment. The disk write operations were triggered with GRUB's save_env command.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com ---
api/api.c | 59 ++++++++++++++++++++++++++++++----------------- api/api_private.h | 1 + api/api_storage.c | 24 +++++++++++++++++++ 3 files changed, 63 insertions(+), 21 deletions(-)
diff --git a/api/api.c b/api/api.c index 9f03f1a35b..f7cfcc9ebc 100644 --- a/api/api.c +++ b/api/api.c @@ -294,27 +294,31 @@ static int API_dev_close(va_list ap)
/* - * Notice: this is for sending network packets only, as U-Boot does not - * support writing to storage at the moment (12.2007) - * * pseudo signature: * * int API_dev_write( * struct device_info *di, * void *buf, - * int *len + * int *len, + * unsigned long *start * ) * * buf: ptr to buffer from where to get the data to send * - * len: length of packet to be sent (in bytes) + * len: ptr to length to be read + * - network: len of packet to be sent (in bytes) + * - storage: # of blocks to write (can vary in size depending on define) * + * start: ptr to start block (only used for storage devices, ignored for + * network) */ static int API_dev_write(va_list ap) { struct device_info *di; void *buf; - int *len; + lbasize_t *len_stor, act_len_stor; + lbastart_t *start; + int *len_net; int err = 0;
/* 1. arg is ptr to the device_info struct */ @@ -332,23 +336,36 @@ static int API_dev_write(va_list ap) if (buf == NULL) return API_EINVAL;
- /* 3. arg is length of buffer */ - len = (int *)va_arg(ap, uintptr_t); - if (len == NULL) - return API_EINVAL; - if (*len <= 0) - return API_EINVAL; + if (di->type & DEV_TYP_STOR) { + /* 3. arg - ptr to var with # of blocks to write */ + len_stor = (lbasize_t *)va_arg(ap, uintptr_t); + if (!len_stor) + return API_EINVAL; + if (*len_stor <= 0) + return API_EINVAL;
- if (di->type & DEV_TYP_STOR) - /* - * write to storage is currently not supported by U-Boot: - * no storage device implements block_write() method - */ - return API_ENODEV; + /* 4. arg - ptr to var with start block */ + start = (lbastart_t *)va_arg(ap, uintptr_t);
- else if (di->type & DEV_TYP_NET) - err = dev_write_net(di->cookie, buf, *len); - else + act_len_stor = dev_write_stor(di->cookie, buf, *len_stor, *start); + if (act_len_stor != *len_stor) { + debugf("write @ %llu: done %llu out of %llu blocks", + (uint64_t)blk, (uint64_t)act_len_stor, + (uint64_t)len_stor); + return API_EIO; + } + + } else if (di->type & DEV_TYP_NET) { + /* 3. arg points to the var with length of packet to write */ + len_net = (int *)va_arg(ap, uintptr_t); + if (!len_net) + return API_EINVAL; + if (*len_net <= 0) + return API_EINVAL; + + err = dev_write_net(di->cookie, buf, *len_net); + + } else err = API_ENODEV;
return err; diff --git a/api/api_private.h b/api/api_private.h index 8d97ca95a2..07fd50ad3a 100644 --- a/api/api_private.h +++ b/api/api_private.h @@ -22,6 +22,7 @@ int dev_close_stor(void *); int dev_close_net(void *);
lbasize_t dev_read_stor(void *, void *, lbasize_t, lbastart_t); +lbasize_t dev_write_stor(void *, void *, lbasize_t, lbastart_t); int dev_read_net(void *, void *, int); int dev_write_net(void *, void *, int);
diff --git a/api/api_storage.c b/api/api_storage.c index 2b90c18aae..7ae03ac230 100644 --- a/api/api_storage.c +++ b/api/api_storage.c @@ -349,3 +349,27 @@ lbasize_t dev_read_stor(void *cookie, void *buf, lbasize_t len, lbastart_t start return dd->block_read(dd, start, len, buf); #endif /* defined(CONFIG_BLK) */ } + + +lbasize_t dev_write_stor(void *cookie, void *buf, lbasize_t len, lbastart_t start) +{ + struct blk_desc *dd = (struct blk_desc *)cookie; + int type = dev_stor_type(dd); + + if (type == ENUM_MAX) + return 0; + + if (!dev_stor_is_valid(type, dd)) + return 0; + +#ifdef CONFIG_BLK + return blk_dwrite(dd, start, len, buf); +#else + if (dd->block_write == NULL) { + debugf("no block_write() for device 0x%08x\n", cookie); + return 0; + } + + return dd->block_write(dd, start, len, buf); +#endif /* defined(CONFIG_BLK) */ +}
Cristian Ciocaltea
