[U-Boot] [PATCH 2/4] sandbox: Add "host size" hostfs command for fs test
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- cmd/host.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/cmd/host.c b/cmd/host.c index 8d84415..b427e54 100644 --- a/cmd/host.c +++ b/cmd/host.c @@ -25,6 +25,12 @@ static int do_host_ls(cmd_tbl_t *cmdtp, int flag, int argc, return do_ls(cmdtp, flag, argc, argv, FS_TYPE_SANDBOX); }
+static int do_host_size(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return do_size(cmdtp, flag, argc, argv, FS_TYPE_SANDBOX); +} + static int do_host_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -138,6 +144,7 @@ static cmd_tbl_t cmd_host_sub[] = { U_BOOT_CMD_MKENT(load, 7, 0, do_host_load, "", ""), U_BOOT_CMD_MKENT(ls, 3, 0, do_host_ls, "", ""), U_BOOT_CMD_MKENT(save, 6, 0, do_host_save, "", ""), + U_BOOT_CMD_MKENT(size, 3, 0, do_host_size, "", ""), U_BOOT_CMD_MKENT(bind, 3, 0, do_host_bind, "", ""), U_BOOT_CMD_MKENT(info, 3, 0, do_host_info, "", ""), U_BOOT_CMD_MKENT(dev, 0, 1, do_host_dev, "", ""), @@ -174,6 +181,7 @@ U_BOOT_CMD( "host ls hostfs - <filename> - list files on host\n" "host save hostfs - <addr> <filename> <bytes> [<offset>] - " "save a file to host\n" + "host size hostfs - <filename> - determine size of file on host" "host bind <dev> [<filename>] - bind "host" device to file\n" "host info [<dev>] - show device binding & info\n" "host dev [<dev>] - Set or retrieve the current host device\n"
Please can you add a short commit message?
"host size hostfs - <filename> - determine size of file on host" "host bind <dev> [<filename>] - bind \"host\" device to file\n" "host info [<dev>] - show device binding & info\n" "host dev [<dev>] - Set or retrieve the current host device\n"
-- 2.9.2
Stefan Brüns
