[U-Boot] Severals questions How to submit new u-boot features
I am actually working to add a new driver to u-boot related to Trusted Platform Module (TPM) for embedded system. (On a u-boot version 2009.11) I would be interested to know:
- what is the process to do the submission ?
- Because the available i2c interfaces looks to be only for i2c memory (such as eeprom memory), I had to rework some i2c interfaces to be able to send directly my TPM command/data through the i2c bus. This mean write or read some data directly on the i2c bus without sending any offset byte.
Will it be acceptable for the community to add those two new interfaces (i2c_write_direct/i2c_read_direct) for each i2c driver ?
- Is there any coding style specification ?
Thanks for your help Best Regards Christophe RICARD STMicroelectronics.
Read up http://www.denx.de/wiki/U-Boot/Patches
You can do that with the current i2c drivers by making sure that adrlen=0.
I would think they are unneeded, see the adrlen=0 trick. (If I were to suggest an I2C overhaul [hi Heiko :)], I'd rather suggest adding a generic i2c transaction API which would allow mixing elementary writes and reads with optional STARTs and STOPs inbetween).
Look up <>http://www.denx.de/wiki/U-Boot/CodingStyle%3E (actually many topics are covered, see left column).
np :)
Amicalement,
Albert ARIBAUD
