[U-Boot] [PATCH 1/2] NET: NE2000: Cleanup IO accessors
Introduce ne2k_register_io(in, out), which allows user to supply two functions. One for reading data from the card, the other for writing data to the card. Then introduce drivers' private data, which carry pointers to these functions and are passed throughout the driver.
The private data will carry more entries later.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- drivers/net/ne2000_base.c | 318 +++++++++++++++++++++++++++------------------ include/netdev.h | 2 + 2 files changed, 191 insertions(+), 129 deletions(-)
NOTE: Formating not cleaned up, only relevant change made!
diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c index 88f2b37..35a8581 100644 --- a/drivers/net/ne2000_base.c +++ b/drivers/net/ne2000_base.c @@ -76,10 +76,7 @@ Add SNMP #include <command.h> #include <net.h> #include <malloc.h> - -/* forward definition of function used for the uboot interface */ -void uboot_push_packet_len(int len); -void uboot_push_tx_done(int key, int val); +#include <errno.h>
/* NE2000 base header file */ #include "ne2000_base.h" @@ -94,12 +91,37 @@ void uboot_push_tx_done(int key, int val);
static dp83902a_priv_data_t nic; /* just one instance of the card supported */
+uint32_t ne2k_default_in(uint8_t *addr, uint32_t offset) +{ + uint32_t ret; + DP_IN(addr, offset, ret); + return ret; +} + +void ne2k_default_out(uint8_t *addr, uint32_t offset, uint32_t val) +{ + DP_OUT(addr, offset, val); +} + +struct ne2k_io_accessors { + uint32_t (*in)(uint8_t *addr, uint32_t offset); + void (*out)(uint8_t *addr, uint32_t offset, uint32_t val); +}; + +struct ne2k_private_data { + struct ne2k_io_accessors io; +}; + +/* forward definition of function used for the uboot interface */ +void uboot_push_packet_len(struct ne2k_private_data *pdata, int len); +void uboot_push_tx_done(int key, int val); + /** * This function reads the MAC address from the serial EEPROM, * used if PROM read fails. Does nothing for ax88796 chips (sh boards) */ static bool -dp83902a_init(unsigned char *enetaddr) +dp83902a_init(struct eth_device *dev) { dp83902a_priv_data_t *dp = &nic; u8* base; @@ -116,13 +138,17 @@ dp83902a_init(unsigned char *enetaddr) DEBUG_LINE();
#if defined(NE2000_BASIC_INIT) + unsigned char *enetaddr = dev->enetaddr; + struct ne2k_private_data *pdata = dev->priv; + const struct ne2k_io_accessors *io = &pdata->io; + /* AX88796L doesn't need */ /* Prepare ESA */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ + io->out(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ /* Use the address from the serial EEPROM */ for (i = 0; i < 6; i++) - DP_IN(base, DP_P1_PAR0+i, dp->esa[i]); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */ + dp->esa[i] = io->in(base, DP_P1_PAR0+i); + io->out(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */
printf("NE2000 - %s ESA: %02x:%02x:%02x:%02x:%02x:%02x\n", "eeprom", @@ -139,16 +165,18 @@ dp83902a_init(unsigned char *enetaddr) }
static void -dp83902a_stop(void) +dp83902a_stop(struct eth_device *dev) { dp83902a_priv_data_t *dp = &nic; + struct ne2k_private_data *pdata = dev->priv; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base;
DEBUG_FUNCTION();
- DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ - DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ - DP_OUT(base, DP_IMR, 0x00); /* Disable all interrupts */ + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ + io->out(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ + io->out(base, DP_IMR, 0x00); /* Disable all interrupts */
dp->running = false; } @@ -160,9 +188,12 @@ dp83902a_stop(void) * the hardware ready to send/receive packets. */ static void -dp83902a_start(u8 * enaddr) +dp83902a_start(struct eth_device *dev) { dp83902a_priv_data_t *dp = &nic; + unsigned char *enaddr = dev->enetaddr; + struct ne2k_private_data *pdata = dev->priv; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; int i;
@@ -170,37 +201,37 @@ dp83902a_start(u8 * enaddr)
DEBUG_FUNCTION();
- DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ - DP_OUT(base, DP_DCR, DP_DCR_INIT); - DP_OUT(base, DP_RBCH, 0); /* Remote byte count */ - DP_OUT(base, DP_RBCL, 0); - DP_OUT(base, DP_RCR, DP_RCR_MON); /* Accept no packets */ - DP_OUT(base, DP_TCR, DP_TCR_LOCAL); /* Transmitter [virtually] off */ - DP_OUT(base, DP_TPSR, dp->tx_buf1); /* Transmitter start page */ + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ + io->out(base, DP_DCR, DP_DCR_INIT); + io->out(base, DP_RBCH, 0); /* Remote byte count */ + io->out(base, DP_RBCL, 0); + io->out(base, DP_RCR, DP_RCR_MON); /* Accept no packets */ + io->out(base, DP_TCR, DP_TCR_LOCAL); /* Transmitter [virtually] off */ + io->out(base, DP_TPSR, dp->tx_buf1); /* Transmitter start page */ dp->tx1 = dp->tx2 = 0; dp->tx_next = dp->tx_buf1; dp->tx_started = false; dp->running = true; - DP_OUT(base, DP_PSTART, dp->rx_buf_start); /* Receive ring start page */ - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); /* Receive ring boundary */ - DP_OUT(base, DP_PSTOP, dp->rx_buf_end); /* Receive ring end page */ + io->out(base, DP_PSTART, dp->rx_buf_start); /* Receive ring start page */ + io->out(base, DP_BNDRY, dp->rx_buf_end - 1); /* Receive ring boundary */ + io->out(base, DP_PSTOP, dp->rx_buf_end); /* Receive ring end page */ dp->rx_next = dp->rx_buf_start - 1; dp->running = true; - DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ - DP_OUT(base, DP_IMR, DP_IMR_All); /* Enable all interrupts */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ - DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ + io->out(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ + io->out(base, DP_IMR, DP_IMR_All); /* Enable all interrupts */ + io->out(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ + io->out(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ dp->running = true; for (i = 0; i < ETHER_ADDR_LEN; i++) { /* FIXME */ /*((vu_short*)( base + ((DP_P1_PAR0 + i) * 2) + * 0x1400)) = enaddr[i];*/ - DP_OUT(base, DP_P1_PAR0+i, enaddr[i]); + io->out(base, DP_P1_PAR0+i, enaddr[i]); } /* Enable and start device */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_TCR, DP_TCR_NORMAL); /* Normal transmit operations */ - DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); + io->out(base, DP_TCR, DP_TCR_NORMAL); /* Normal transmit operations */ + io->out(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ dp->running = true; }
@@ -211,9 +242,10 @@ dp83902a_start(u8 * enaddr) */
static void -dp83902a_start_xmit(int start_page, int len) +dp83902a_start_xmit(struct ne2k_private_data *pdata, int start_page, int len) { dp83902a_priv_data_t *dp = (dp83902a_priv_data_t *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base;
DEBUG_FUNCTION(); @@ -224,12 +256,12 @@ dp83902a_start_xmit(int start_page, int len) printf("TX already started?!?\n"); #endif
- DP_OUT(base, DP_ISR, (DP_ISR_TxP | DP_ISR_TxE)); - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_TBCL, len & 0xFF); - DP_OUT(base, DP_TBCH, len >> 8); - DP_OUT(base, DP_TPSR, start_page); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); + io->out(base, DP_ISR, (DP_ISR_TxP | DP_ISR_TxE)); + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); + io->out(base, DP_TBCL, len & 0xFF); + io->out(base, DP_TBCH, len >> 8); + io->out(base, DP_TPSR, start_page); + io->out(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START);
dp->tx_started = true; } @@ -239,9 +271,10 @@ dp83902a_start_xmit(int start_page, int len) * that there is free buffer space (dp->tx_next). */ static void -dp83902a_send(u8 *data, int total_len, u32 key) +dp83902a_send(struct ne2k_private_data *pdata, u8 *data, int total_len, u32 key) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; int len, start_page, pkt_len, i, isr; #if DEBUG & 4 @@ -271,7 +304,7 @@ dp83902a_send(u8 *data, int total_len, u32 key) printf("TX prep page %d len %d\n", start_page, pkt_len); #endif
- DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ + io->out(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ { /* * Dummy read. The manual sez something slightly different, @@ -279,15 +312,14 @@ dp83902a_send(u8 *data, int total_len, u32 key) * does (i.e., also read data). */
- u16 tmp; int len = 1;
- DP_OUT(base, DP_RSAL, 0x100 - len); - DP_OUT(base, DP_RSAH, (start_page - 1) & 0xff); - DP_OUT(base, DP_RBCL, len); - DP_OUT(base, DP_RBCH, 0); - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_RDMA | DP_CR_START); - DP_IN_DATA(dp->data, tmp); + io->out(base, DP_RSAL, 0x100 - len); + io->out(base, DP_RSAH, (start_page - 1) & 0xff); + io->out(base, DP_RBCL, len); + io->out(base, DP_RBCH, 0); + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_RDMA | DP_CR_START); + io->in(dp->data, 0); }
#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA @@ -299,11 +331,11 @@ dp83902a_send(u8 *data, int total_len, u32 key) #endif
/* Send data to device buffer(s) */ - DP_OUT(base, DP_RSAL, 0); - DP_OUT(base, DP_RSAH, start_page); - DP_OUT(base, DP_RBCL, pkt_len & 0xFF); - DP_OUT(base, DP_RBCH, pkt_len >> 8); - DP_OUT(base, DP_CR, DP_CR_WDMA | DP_CR_START); + io->out(base, DP_RSAL, 0); + io->out(base, DP_RSAH, start_page); + io->out(base, DP_RBCL, pkt_len & 0xFF); + io->out(base, DP_RBCH, pkt_len >> 8); + io->out(base, DP_CR, DP_CR_WDMA | DP_CR_START);
/* Put data into buffer */ #if DEBUG & 4 @@ -316,7 +348,7 @@ dp83902a_send(u8 *data, int total_len, u32 key) if (0 == (++dx % 16)) printf("\n "); #endif
- DP_OUT_DATA(dp->data, *data++); + io->out(dp->data, 0, *data++); len--; } #if DEBUG & 4 @@ -329,7 +361,7 @@ dp83902a_send(u8 *data, int total_len, u32 key) /* Padding to 802.3 length was required */ for (i = total_len; i < pkt_len;) { i++; - DP_OUT_DATA(dp->data, 0); + io->out(dp->data, 0, 0); } }
@@ -344,11 +376,11 @@ dp83902a_send(u8 *data, int total_len, u32 key)
/* Wait for DMA to complete */ do { - DP_IN(base, DP_ISR, isr); + isr = io->in(base, DP_ISR); } while ((isr & DP_ISR_RDC) == 0);
/* Then disable DMA */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START);
/* Start transmit if not already going */ if (!dp->tx_started) { @@ -357,7 +389,7 @@ dp83902a_send(u8 *data, int total_len, u32 key) } else { dp->tx_int = 2; /* Expecting interrupt from BUF2 */ } - dp83902a_start_xmit(start_page, pkt_len); + dp83902a_start_xmit(pdata, start_page, pkt_len); } }
@@ -369,23 +401,23 @@ dp83902a_send(u8 *data, int total_len, u32 key) * 'dp83902a_recv' will be called to actually fetch it from the hardware. */ static void -dp83902a_RxEvent(void) +dp83902a_RxEvent(struct ne2k_private_data *pdata) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; - u8 rsr; u8 rcv_hdr[4]; int i, len, pkt, cur;
DEBUG_FUNCTION();
- DP_IN(base, DP_RSR, rsr); + io->in(base, DP_RSR); while (true) { /* Read incoming packet header */ - DP_OUT(base, DP_CR, DP_CR_PAGE1 | DP_CR_NODMA | DP_CR_START); - DP_IN(base, DP_P1_CURP, cur); - DP_OUT(base, DP_P1_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_IN(base, DP_BNDRY, pkt); + io->out(base, DP_CR, DP_CR_PAGE1 | DP_CR_NODMA | DP_CR_START); + cur = io->in(base, DP_P1_CURP); + io->out(base, DP_P1_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); + pkt = io->in(base, DP_BNDRY);
pkt += 1; if (pkt == dp->rx_buf_end) @@ -394,27 +426,27 @@ dp83902a_RxEvent(void) if (pkt == cur) { break; } - DP_OUT(base, DP_RBCL, sizeof(rcv_hdr)); - DP_OUT(base, DP_RBCH, 0); - DP_OUT(base, DP_RSAL, 0); - DP_OUT(base, DP_RSAH, pkt); + io->out(base, DP_RBCL, sizeof(rcv_hdr)); + io->out(base, DP_RBCH, 0); + io->out(base, DP_RSAL, 0); + io->out(base, DP_RSAH, pkt); if (dp->rx_next == pkt) { if (cur == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); + io->out(base, DP_BNDRY, dp->rx_buf_end - 1); else - DP_OUT(base, DP_BNDRY, cur - 1); /* Update pointer */ + io->out(base, DP_BNDRY, cur - 1); /* Update pointer */ return; } dp->rx_next = pkt; - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - DP_OUT(base, DP_CR, DP_CR_RDMA | DP_CR_START); + io->out(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ + io->out(base, DP_CR, DP_CR_RDMA | DP_CR_START); #ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_RX_DMA CYGACC_CALL_IF_DELAY_US(10); #endif
/* read header (get data size)*/ for (i = 0; i < sizeof(rcv_hdr);) { - DP_IN_DATA(dp->data, rcv_hdr[i++]); + rcv_hdr[i++] = io->in(dp->data, 0); }
#if DEBUG & 5 @@ -424,12 +456,12 @@ dp83902a_RxEvent(void) len = ((rcv_hdr[3] << 8) | rcv_hdr[2]) - sizeof(rcv_hdr);
/* data read */ - uboot_push_packet_len(len); + uboot_push_packet_len(pdata, len);
if (rcv_hdr[1] == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); + io->out(base, DP_BNDRY, dp->rx_buf_end - 1); else - DP_OUT(base, DP_BNDRY, rcv_hdr[1] - 1); /* Update pointer */ + io->out(base, DP_BNDRY, rcv_hdr[1] - 1); /* Update pointer */ } }
@@ -441,9 +473,10 @@ dp83902a_RxEvent(void) * efficient processing in the upper layers of the stack. */ static void -dp83902a_recv(u8 *data, int len) +dp83902a_recv(struct ne2k_private_data *pdata, u8 *data, int len) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; int i, mlen; u8 saved_char = 0; @@ -459,13 +492,13 @@ dp83902a_recv(u8 *data, int len) #endif
/* Read incoming packet data */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_RBCL, len & 0xFF); - DP_OUT(base, DP_RBCH, len >> 8); - DP_OUT(base, DP_RSAL, 4); /* Past header */ - DP_OUT(base, DP_RSAH, dp->rx_next); - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - DP_OUT(base, DP_CR, DP_CR_RDMA | DP_CR_START); + io->out(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); + io->out(base, DP_RBCL, len & 0xFF); + io->out(base, DP_RBCH, len >> 8); + io->out(base, DP_RSAL, 4); /* Past header */ + io->out(base, DP_RSAH, dp->rx_next); + io->out(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ + io->out(base, DP_CR, DP_CR_RDMA | DP_CR_START); #ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_RX_DMA CYGACC_CALL_IF_DELAY_US(10); #endif @@ -489,7 +522,7 @@ dp83902a_recv(u8 *data, int len)
{ u8 tmp; - DP_IN_DATA(dp->data, tmp); + tmp = io->in(dp->data, 0); #if DEBUG & 4 printf(" %02x", tmp); if (0 == (++dx % 16)) printf("\n "); @@ -506,16 +539,16 @@ dp83902a_recv(u8 *data, int len) }
static void -dp83902a_TxEvent(void) +dp83902a_TxEvent(struct ne2k_private_data *pdata) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; - u8 tsr; u32 key;
DEBUG_FUNCTION();
- DP_IN(base, DP_TSR, tsr); + io->in(base, DP_TSR); if (dp->tx_int == 1) { key = dp->tx1_key; dp->tx1 = 0; @@ -526,10 +559,10 @@ dp83902a_TxEvent(void) /* Start next packet if one is ready */ dp->tx_started = false; if (dp->tx1) { - dp83902a_start_xmit(dp->tx1, dp->tx1_len); + dp83902a_start_xmit(pdata, dp->tx1, dp->tx1_len); dp->tx_int = 1; } else if (dp->tx2) { - dp83902a_start_xmit(dp->tx2, dp->tx2_len); + dp83902a_start_xmit(pdata, dp->tx2, dp->tx2_len); dp->tx_int = 2; } else { dp->tx_int = 0; @@ -543,16 +576,16 @@ dp83902a_TxEvent(void) * interrupt. */ static void -dp83902a_ClearCounters(void) +dp83902a_ClearCounters(struct ne2k_private_data *pdata) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; - u8 cnt1, cnt2, cnt3;
- DP_IN(base, DP_FER, cnt1); - DP_IN(base, DP_CER, cnt2); - DP_IN(base, DP_MISSED, cnt3); - DP_OUT(base, DP_ISR, DP_ISR_CNT); + io->in(base, DP_FER); + io->in(base, DP_CER); + io->in(base, DP_MISSED); + io->out(base, DP_ISR, DP_ISR_CNT); }
/* @@ -560,55 +593,57 @@ dp83902a_ClearCounters(void) * out in section 7.0 of the datasheet. */ static void -dp83902a_Overflow(void) +dp83902a_Overflow(struct ne2k_private_data *pdata) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *)&nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; u8 isr;
/* Issue a stop command and wait 1.6ms for it to complete. */ - DP_OUT(base, DP_CR, DP_CR_STOP | DP_CR_NODMA); + io->out(base, DP_CR, DP_CR_STOP | DP_CR_NODMA); CYGACC_CALL_IF_DELAY_US(1600);
/* Clear the remote byte counter registers. */ - DP_OUT(base, DP_RBCL, 0); - DP_OUT(base, DP_RBCH, 0); + io->out(base, DP_RBCL, 0); + io->out(base, DP_RBCH, 0);
/* Enter loopback mode while we clear the buffer. */ - DP_OUT(base, DP_TCR, DP_TCR_LOCAL); - DP_OUT(base, DP_CR, DP_CR_START | DP_CR_NODMA); + io->out(base, DP_TCR, DP_TCR_LOCAL); + io->out(base, DP_CR, DP_CR_START | DP_CR_NODMA);
/* * Read in as many packets as we can and acknowledge any and receive * interrupts. Since the buffer has overflowed, a receive event of * some kind will have occured. */ - dp83902a_RxEvent(); - DP_OUT(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE); + dp83902a_RxEvent(pdata); + io->out(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE);
/* Clear the overflow condition and leave loopback mode. */ - DP_OUT(base, DP_ISR, DP_ISR_OFLW); - DP_OUT(base, DP_TCR, DP_TCR_NORMAL); + io->out(base, DP_ISR, DP_ISR_OFLW); + io->out(base, DP_TCR, DP_TCR_NORMAL);
/* * If a transmit command was issued, but no transmit event has occured, * restart it here. */ - DP_IN(base, DP_ISR, isr); + isr = io->in(base, DP_ISR); if (dp->tx_started && !(isr & (DP_ISR_TxP|DP_ISR_TxE))) { - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); + io->out(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); } }
static void -dp83902a_poll(void) +dp83902a_poll(struct ne2k_private_data *pdata) { struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; u8 isr;
- DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0 | DP_CR_START); - DP_IN(base, DP_ISR, isr); + io->out(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0 | DP_CR_START); + isr = io->in(base, DP_ISR); while (0 != isr) { /* * The CNT interrupt triggers when the MSB of one of the error @@ -616,7 +651,7 @@ dp83902a_poll(void) * we should read their values to reset them. */ if (isr & DP_ISR_CNT) { - dp83902a_ClearCounters(); + dp83902a_ClearCounters(pdata); } /* * Check for overflow. It's a special case, since there's a @@ -624,27 +659,27 @@ dp83902a_poll(void) * a running state.a */ if (isr & DP_ISR_OFLW) { - dp83902a_Overflow(); + dp83902a_Overflow(pdata); } else { /* * Other kinds of interrupts can be acknowledged simply by * clearing the relevant bits of the ISR. Do that now, then * handle the interrupts we care about. */ - DP_OUT(base, DP_ISR, isr); /* Clear set bits */ + io->out(base, DP_ISR, isr); /* Clear set bits */ if (!dp->running) break; /* Is this necessary? */ /* * Check for tx_started on TX event since these may happen * spuriously it seems. */ if (isr & (DP_ISR_TxP|DP_ISR_TxE) && dp->tx_started) { - dp83902a_TxEvent(); + dp83902a_TxEvent(pdata); } if (isr & (DP_ISR_RxP|DP_ISR_RxE)) { - dp83902a_RxEvent(); + dp83902a_RxEvent(pdata); } } - DP_IN(base, DP_ISR, isr); + isr = io->in(base, DP_ISR); } }
@@ -655,13 +690,13 @@ static u8 *pbuf = NULL; static int pkey = -1; static int initialized = 0;
-void uboot_push_packet_len(int len) { +void uboot_push_packet_len(struct ne2k_private_data *pdata, int len) { PRINTK("pushed len = %d\n", len); if (len >= 2000) { printf("NE2000: packet too big\n"); return; } - dp83902a_recv(&pbuf[0], len); + dp83902a_recv(pdata, &pbuf[0], len);
/*Just pass it to the upper layer*/ NetReceive(&pbuf[0], len); @@ -717,7 +752,7 @@ static int ne2k_setup_driver(struct eth_device *dev) if (!eth_getenv_enetaddr("ethaddr", dev->enetaddr)) { /* If the MAC address is not in the environment, get it: */ if (!get_prom(dev->enetaddr, nic.base)) /* get MAC from prom */ - dp83902a_init(dev->enetaddr); /* fallback: seeprom */ + dp83902a_init(dev); /* fallback: seeprom */ /* And write it into the environment otherwise eth_write_hwaddr * returns -1 due to eth_getenv_enetaddr_by_index() failing, * and this causes "Warning: failed to set MAC address", and @@ -729,7 +764,7 @@ static int ne2k_setup_driver(struct eth_device *dev)
static int ne2k_init(struct eth_device *dev, bd_t *bd) { - dp83902a_start(dev->enetaddr); + dp83902a_start(dev); initialized = 1; return 0; } @@ -738,28 +773,30 @@ static void ne2k_halt(struct eth_device *dev) { debug("### ne2k_halt\n"); if(initialized) - dp83902a_stop(); + dp83902a_stop(dev); initialized = 0; }
static int ne2k_recv(struct eth_device *dev) { - dp83902a_poll(); + struct ne2k_private_data *pdata = dev->priv; + dp83902a_poll(pdata); return 1; }
static int ne2k_send(struct eth_device *dev, volatile void *packet, int length) { int tmo; + struct ne2k_private_data *pdata = dev->priv;
debug("### ne2k_send\n");
pkey = -1;
- dp83902a_send((u8 *) packet, length, 666); + dp83902a_send(pdata, (u8 *) packet, length, 666); tmo = get_timer (0) + TOUT * CONFIG_SYS_HZ; while(1) { - dp83902a_poll(); + dp83902a_poll(pdata); if (pkey != -1) { PRINTK("Packet sucesfully sent\n"); return 0; @@ -775,25 +812,48 @@ static int ne2k_send(struct eth_device *dev, volatile void *packet, int length)
/** * Setup the driver for use and register it with the eth layer - * @return 0 on success, -1 on error (causing caller to print error msg) + * @return 0 on success, < 0 on error (causing caller to print error msg) */ -int ne2k_register(void) +int ne2k_register_io(uint32_t (*in)(uint8_t *addr, uint32_t offset), + void (*out)(uint8_t *addr, uint32_t offset, uint32_t value)) { struct eth_device *dev; + struct ne2k_private_data *pdata;
dev = calloc(sizeof(*dev), 1); if (dev == NULL) - return -1; + return -ENOMEM; + + pdata = calloc(sizeof(struct ne2k_private_data), 1); + if (pdata == NULL) { + free(dev); + return -ENOMEM; + }
if (ne2k_setup_driver(dev)) - return -1; + return -EINVAL; + + if (in == NULL) + in = ne2k_default_in; + + if (out == NULL) + out = ne2k_default_out; + + pdata->io.in = in; + pdata->io.out = out;
dev->init = ne2k_init; dev->halt = ne2k_halt; dev->send = ne2k_send; dev->recv = ne2k_recv; + dev->priv = pdata;
sprintf(dev->name, "NE2000");
return eth_register(dev); } + +int ne2k_register(void) +{ + return ne2k_register_io(NULL, NULL); +} diff --git a/include/netdev.h b/include/netdev.h index 150fa8e..7ea4642 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -81,6 +81,8 @@ int mpc82xx_scc_enet_initialize(bd_t *bis); int mvgbe_initialize(bd_t *bis); int natsemi_initialize(bd_t *bis); int ne2k_register(void); +int ne2k_register_io(uint32_t (*in)(uint8_t *addr, uint32_t offset), + void (*out)(uint8_t *addr, uint32_t offset, uint32_t value)); int npe_initialize(bd_t *bis); int ns8382x_initialize(bd_t *bis); int pcnet_initialize(bd_t *bis);
This patch should complete effort to let multiple ne2k cards be used. All card-specific data shall now be hidden in per-card allocated private_data structure.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- drivers/net/ne2000_base.c | 52 +++++++++++++++++++++++--------------------- 1 files changed, 27 insertions(+), 25 deletions(-)
diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c index 35a8581..381b334 100644 --- a/drivers/net/ne2000_base.c +++ b/drivers/net/ne2000_base.c @@ -89,8 +89,6 @@ Add SNMP #include "ne2000.h" #endif
-static dp83902a_priv_data_t nic; /* just one instance of the card supported */ - uint32_t ne2k_default_in(uint8_t *addr, uint32_t offset) { uint32_t ret; @@ -110,6 +108,7 @@ struct ne2k_io_accessors {
struct ne2k_private_data { struct ne2k_io_accessors io; + struct dp83902a_priv_data nic; };
/* forward definition of function used for the uboot interface */ @@ -123,7 +122,8 @@ void uboot_push_tx_done(int key, int val); static bool dp83902a_init(struct eth_device *dev) { - dp83902a_priv_data_t *dp = &nic; + struct ne2k_private_data *pdata = dev->priv; + struct dp83902a_priv_data *dp = &pdata->nic; u8* base; #if defined(NE2000_BASIC_INIT) int i; @@ -139,7 +139,6 @@ dp83902a_init(struct eth_device *dev)
#if defined(NE2000_BASIC_INIT) unsigned char *enetaddr = dev->enetaddr; - struct ne2k_private_data *pdata = dev->priv; const struct ne2k_io_accessors *io = &pdata->io;
/* AX88796L doesn't need */ @@ -167,8 +166,8 @@ dp83902a_init(struct eth_device *dev) static void dp83902a_stop(struct eth_device *dev) { - dp83902a_priv_data_t *dp = &nic; struct ne2k_private_data *pdata = dev->priv; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base;
@@ -190,9 +189,9 @@ dp83902a_stop(struct eth_device *dev) static void dp83902a_start(struct eth_device *dev) { - dp83902a_priv_data_t *dp = &nic; - unsigned char *enaddr = dev->enetaddr; struct ne2k_private_data *pdata = dev->priv; + struct dp83902a_priv_data *dp = &pdata->nic; + unsigned char *enaddr = dev->enetaddr; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; int i; @@ -244,7 +243,7 @@ dp83902a_start(struct eth_device *dev) static void dp83902a_start_xmit(struct ne2k_private_data *pdata, int start_page, int len) { - dp83902a_priv_data_t *dp = (dp83902a_priv_data_t *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base;
@@ -273,7 +272,7 @@ dp83902a_start_xmit(struct ne2k_private_data *pdata, int start_page, int len) static void dp83902a_send(struct ne2k_private_data *pdata, u8 *data, int total_len, u32 key) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; int len, start_page, pkt_len, i, isr; @@ -403,7 +402,7 @@ dp83902a_send(struct ne2k_private_data *pdata, u8 *data, int total_len, u32 key) static void dp83902a_RxEvent(struct ne2k_private_data *pdata) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; u8 rcv_hdr[4]; @@ -475,7 +474,7 @@ dp83902a_RxEvent(struct ne2k_private_data *pdata) static void dp83902a_recv(struct ne2k_private_data *pdata, u8 *data, int len) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; int i, mlen; @@ -541,7 +540,7 @@ dp83902a_recv(struct ne2k_private_data *pdata, u8 *data, int len) static void dp83902a_TxEvent(struct ne2k_private_data *pdata) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; u32 key; @@ -578,7 +577,7 @@ dp83902a_TxEvent(struct ne2k_private_data *pdata) static void dp83902a_ClearCounters(struct ne2k_private_data *pdata) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base;
@@ -595,7 +594,7 @@ dp83902a_ClearCounters(struct ne2k_private_data *pdata) static void dp83902a_Overflow(struct ne2k_private_data *pdata) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *)&nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; u8 isr; @@ -637,7 +636,7 @@ dp83902a_Overflow(struct ne2k_private_data *pdata) static void dp83902a_poll(struct ne2k_private_data *pdata) { - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; + struct dp83902a_priv_data *dp = &pdata->nic; const struct ne2k_io_accessors *io = &pdata->io; u8 *base = dp->base; u8 isr; @@ -716,6 +715,9 @@ void uboot_push_tx_done(int key, int val) { */ static int ne2k_setup_driver(struct eth_device *dev) { + struct ne2k_private_data *pdata = dev->priv; + struct dp83902a_priv_data *dp = &pdata->nic; + PRINTK("### ne2k_setup_driver\n");
if (!pbuf) { @@ -736,13 +738,13 @@ static int ne2k_setup_driver(struct eth_device *dev) } #endif
- nic.base = (u8 *) CONFIG_DRIVER_NE2000_BASE; + dp->base = (u8 *) CONFIG_DRIVER_NE2000_BASE;
- nic.data = nic.base + DP_DATA; - nic.tx_buf1 = START_PG; - nic.tx_buf2 = START_PG2; - nic.rx_buf_start = RX_START; - nic.rx_buf_end = RX_END; + dp->data = dp->base + DP_DATA; + dp->tx_buf1 = START_PG; + dp->tx_buf2 = START_PG2; + dp->rx_buf_start = RX_START; + dp->rx_buf_end = RX_END;
/* * According to doc/README.enetaddr, drivers shall give priority @@ -751,7 +753,7 @@ static int ne2k_setup_driver(struct eth_device *dev) */ if (!eth_getenv_enetaddr("ethaddr", dev->enetaddr)) { /* If the MAC address is not in the environment, get it: */ - if (!get_prom(dev->enetaddr, nic.base)) /* get MAC from prom */ + if (!get_prom(dev->enetaddr, dp->base)) /* get MAC from prom */ dp83902a_init(dev); /* fallback: seeprom */ /* And write it into the environment otherwise eth_write_hwaddr * returns -1 due to eth_getenv_enetaddr_by_index() failing, @@ -830,9 +832,6 @@ int ne2k_register_io(uint32_t (*in)(uint8_t *addr, uint32_t offset), return -ENOMEM; }
- if (ne2k_setup_driver(dev)) - return -EINVAL; - if (in == NULL) in = ne2k_default_in;
@@ -848,6 +847,9 @@ int ne2k_register_io(uint32_t (*in)(uint8_t *addr, uint32_t offset), dev->recv = ne2k_recv; dev->priv = pdata;
+ if (ne2k_setup_driver(dev)) + return -EINVAL; + sprintf(dev->name, "NE2000");
where are the users of this new API ? as it stands, i just see bloat. every register access is now an indirect function call ? what's the point ? -mike
Go to ... drivers/net/ax88796.h ... and check how it's done now. It's just wrong. Now for .03 release I have pxa3xx support ready which uses just this chip and adding more sh^Htuff to that fill would be even worse bloat.
M
i agree, that code is terrible. however, those code paths can be trivially merged without the proposed bloat yours brings in. further, that code base isn't even used by the ne2000 driver.
so again, the question stands: what exactly do you need to do different ? looks to me like the DP_* macros should get punted in favor of io.h accessors, and the register offsets rewritten into C structs. -mike
So what's your suggested awesome clean solution?
What are you talking about, did you even bother to look?
Sure, but not every hardware accesses the registers the same way. So I'm open for your suggestions on how to do it properly, apparently you have much better idea up your sleeve.
M
there's no need to get snarky
rename ISA_OFFSET to CONFIG_NE2000_IO_OFFSET, then move the "2" to CONFIG_NE2000_IO_STRIDE, and move them both to the board config header. then you get one unified set:
#define DP_IN(_b_, _o_, _d_) \ (_d_) = readw((void *)((_b_) + ((_o_) * CONFIG_NE2000_IO_STRIDE) + \ CONFIG_NE2000_IO_OFFSET)); etc...
if you really wanted to clean up the driver, the DP_XXX funcs would get turned into C code as static inline helpers, and the base + register offset would get turned into a C struct.
might want to cut the attitude. it's really not adding anything.
of course i looked and i saw ne2000.h defining DP_OUT/etc... but i missed the ugly ifdef logic with CONFIG_DRIVER_AX88796L in ne2000_base.c.
which is why we have asm/io.h in the first place.
on a semi-related note, these vu_{short,char,etc...} types need to get culled from the code base. they're volatile markings in disguise ... -mike
Well sometimes it's hard to digest the style of your comments ;-)
Ok, so if you had two different piece of hardware that had different NE2000_IO_OFFSET and STRIDE, running the same u-boot, how'd you handle it ?
Agreed
That needs handling in a separate patch.
Agreed
M
do you actually have this issue ? there are plenty of theoretical situations like this which would break a significant number (majority?) of drivers in the tree. so unless this is a real case, i'd ignore it for now and stick with what optimizes away to no overhead. -mike
etc...
Sadly, I almost do. Not now of course, but eventually, I'll be there :-(
M
Hi Marek,
etc...
Are you planning to improve this patch?
I think at the very least you should have a compile option to enable this "functional interface" presumably behind a macro, but every user of NE2000 should not have to pay the price. However, like Mike suggested, you should only add this complexity if you actually have this problem on a board.
Thanks, -Joe
Dear Joe Hershberger,
Hi Marek,
etc...
No, I'll eventually rework this one alongside the whole DM crap.
Thanks, -Joe
Best regards, Marek Vasut
Joe Hershberger
Mike Frysinger
