[U-Boot] PATCH: Fix MPC8260 with ethernet on SCC
This fixes MPC8260 compilation with ethernet on SCC. Probably was a typo or something...
Signed-off-by: Sergey Kubushyn ksi@koi8.net --- diff -purN u-boot.orig/cpu/mpc8260/cpu.c u-boot/cpu/mpc8260/cpu.c --- u-boot.orig/cpu/mpc8260/cpu.c 2009-02-02 13:39:05.000000000 -0800 +++ u-boot/cpu/mpc8260/cpu.c 2009-02-06 15:29:28.000000000 -0800 @@ -327,7 +327,7 @@ int cpu_eth_init(bd_t *bis) fec_initialize(bis); #endif #if defined(CONFIG_ETHER_ON_SCC) - mpc82xx_scc_enet_initialize(bd); + mpc82xx_scc_enet_initialize(bis); #endif return 0; }
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
- mpc82xx_scc_enet_initialize(bis);
#endif return 0; }
Nice catch. I'll apply it tonight.
regards, Ben
Hello Ben,
#endif return 0; }
This is introduced from:
[hs@pollux u-boot]$ git log cpu/mpc8260/ether_scc.c commit ba705b5b1a97b47388ed48858bef6bf7b6bfcd56 Author: Gary Jennejohn garyj@denx.de Date: Thu Nov 20 12:28:38 2008 +0100
mgcoge make ether_scc.c work with CONFIG_NET_MULTI
This change is needed for mgcoge because it uses two ethernet drivers.
Add a check for the presence of the PIGGY board on mgcoge. Without this board networking cannot work and the initialization must be aborted.
Only allocate rtx once to prevent DPRAM exhaustion.
Initialize ether_scc.c and the keymile-specific HDLC driver (to be added soon) in eth.c.
Signed-off-by: Gary Jennejohn garyj@denx.de Signed-off-by: Ben Warren biggerbadderben@gmail.com
This patch also breaks compiling the mgcoge :-(
[hs@pollux u-boot]$ ./MAKEALL mgcoge Configuring for mgcoge board... ether_scc.c:47:2: error: #error "CONFIG_NET_MULTI must be defined." cpu.c: In function 'cpu_eth_init': cpu.c:330: error: 'bd' undeclared (first use in this function) cpu.c:330: error: (Each undeclared identifier is reported only once cpu.c:330: error: for each function it appears in.) make[1]: *** [cpu.o] Fehler 1 make: *** [cpu/mpc8260/libmpc8260.a] Fehler 2 make: *** Warte auf noch nicht beendete Prozesse... ppc_82xx-size: './u-boot': No such file
Second error fixed from ksi's patch.
Seems to me the mgcoge port is the only actual existing 8260 port who uses CONFIG_ETHER_ON_SCC ... so adding a CONFIG_NET_MULTI only in this config File will help ;-)
So, please when adding ksi's patch, add the following to:
Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/mgcoge.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index e4f4ff9..22e50ab 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -67,6 +67,7 @@ #define CONFIG_ETHER_ON_SCC /* Ethernet is on SCC */ #undef CONFIG_ETHER_ON_FCC /* Ethernet is not on FCC */ #undef CONFIG_ETHER_NONE /* No external Ethernet */ +#define CONFIG_NET_MULTI 1
#define CONFIG_ETHER_INDEX 4 #define CONFIG_SYS_SCC_TOUT_LOOP 10000000
Dear Heiko,
Sorry, doesn't apply: error: patch failed: include/configs/mgcoge.h:67 error: include/configs/mgcoge.h: patch does not apply fatal: sha1 information is lacking or useless (include/configs/mgcoge.h). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001.
[And please provide a usable Subject / commit message. Thanks.]
Ben Warren
Heiko Schocher
ksi@koi8.net
