[U-Boot-Users] dd to generate image.
Hi, I'm using dd to generate the u-boot+kernel+rootfs image. I executed command like.. dd if=rootfs.jffs2 of=kernel.img bs=1 seek=ROOTFS_OFFSET But dd is quite slow, generating a 64MB image spends about 5 minutes. I have changed bs=1 to bs=1024 or bigger, but the outputted image size is wrong, too big. dd manpage says that bs is the size of read/write one time. Doesn't it make dd faster?
How do make dd faster?
2008/3/14, Tim Chen tim.chen.86@gmail.com:
try dd if=rootfs.jffs2 of=kernel.img bs=ROOTFS_OFFSET seek=1
(bs is the block size and seek is counted in block size)
-- Richard Genoud - Adeneo
In message 9c1eb1b90803140101t79d577ddsa396573307b1ce21@mail.gmail.com you wrote:
Hm... you must be on a very slow machine, then.
Perhaps you forgot that "seek" is counting in units of "bs"; i.e. if you change from "bs=1" to "bs=1024" you also have to change from "seek=ROOTFS_OFFSET" to "seek=$(expr ROOTFS_OFFSET / 1024)"
Yes, it does.
See above.
Thanks, my problem fixed.
Richard Genoud
Tim Chen
