[U-Boot] [PATCH] MIPS: remove local_irq_[save|restore] from CP0 macros
With moving write_on_tlb() to arch/mips/include/asm/mipsregs.h there are now compiler warnings when some generic code includes asm/io.h. This happens for example when enabling OF live tree.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
arch/mips/include/asm/mipsregs.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/arch/mips/include/asm/mipsregs.h b/arch/mips/include/asm/mipsregs.h index 930562ebb2..f80311e64e 100644 --- a/arch/mips/include/asm/mipsregs.h +++ b/arch/mips/include/asm/mipsregs.h @@ -1013,9 +1013,7 @@ do { \ #define __read_64bit_c0_split(source, sel) \ ({ \ unsigned long long __val; \ - unsigned long __flags; \ \ - local_irq_save(__flags); \ if (sel == 0) \ __asm__ __volatile__( \ ".set\tmips64\n\t" \ @@ -1034,16 +1032,12 @@ do { \ "dsra\t%L0, %L0, 32\n\t" \ ".set\tmips0" \ : "=r" (__val)); \ - local_irq_restore(__flags); \ \ __val; \ })
#define __write_64bit_c0_split(source, sel, val) \ do { \ - unsigned long __flags; \ - \ - local_irq_save(__flags); \ if (sel == 0) \ __asm__ __volatile__( \ ".set\tmips64\n\t" \ @@ -1064,7 +1058,6 @@ do { \ "dmtc0\t%L0, " #source ", " #sel "\n\t" \ ".set\tmips0" \ : : "r" (val)); \ - local_irq_restore(__flags); \ } while (0)
#define __readx_32bit_c0_register(source) \
Am 19.12.18 um 15:18 schrieb Daniel Schwierzeck:
applied to u-boot-mips
Daniel Schwierzeck
