[U-Boot] [PATCH 1/3] m28evk: Remove CONFIG_NET_MULTI option
CONFIG_NET_MULTI is not used anymore, so remove it from board file.
Cc: Marek Vasut marek.vasut@gmail.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/m28evk.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 39c841f..51eb1c1 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -179,7 +179,6 @@ * Ethernet on SOC (FEC) */ #ifdef CONFIG_CMD_NET -#define CONFIG_NET_MULTI #define CONFIG_ETHPRIME "FEC0" #define CONFIG_FEC_MXC #define CONFIG_FEC_MXC_MULTI
Cc: Marek Vasut marek.vasut@gmail.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/efikamx.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/include/configs/efikamx.h b/include/configs/efikamx.h index 522487b..e2f0f74 100644 --- a/include/configs/efikamx.h +++ b/include/configs/efikamx.h @@ -206,7 +206,6 @@ /* USB NET */ #ifdef CONFIG_CMD_NET #define CONFIG_USB_ETHER_ASIX -#define CONFIG_NET_MULTI #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP #endif
Cc: Marek Vasut marek.vasut@gmail.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Fix typo in board name include/configs/efikamx.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
Changes since v1:
Acked-by: Marek Vasut marek.vasut@gmail.com
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/flea3.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index aac3930..649e272 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -113,7 +113,6 @@ /* * Ethernet on SOC (FEC) */ -#define CONFIG_NET_MULTI #define CONFIG_FEC_MXC #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_PHYLIB
- Ethernet on SOC (FEC)
Though you should drop it from all other board files (hint: git grep CONFIG_NET_MULTI)
Ok, will submit a patch for removing it from other board files.
Regards,
Fabio Estevam
Maybe it is worth to have a single patch dropping CONFIG_NET_MULTI from all boards instead of single patches - I assume that the patchs's length remains under the ML limit.
Stefano Babic
Fabio Estevam
Stefano Babic
