[PATCH v2 0/5] arm: dts: stm32mp157c-odyssey-som: sync SDMMC2 with Linux and TF‑A
This patchset updates the properties of the SDMMC2 device tree node so that they match their Linux kernel and Trusted Firmware A counterparts. Two differences will remain: — in the Linux kernel device tree, the VQMMC supply is incorrectly set to v3v3 (buck4) instead of vdd (buck3); — in the TF‑A device tree, only the “default” pinctrl is configured.
Additionally, this patchset enables SDMMC2 in SPL.
Changes for v2: — rebased on current master (no code changes); — added Patrice Chotard’s Reviewed-by (thanks!); — added missing commit message bodies.
Grzegorz Szymaszek (5): arm: dts: stm32mp157c-odyssey-som: fix the basic SDMMC2 properties arm: dts: stm32mp157c-odyssey-som: enable all SDMMC2 data lanes arm: dts: stm32mp157c-odyssey-som: set the SDMMC2 VQMMC supply arm: dts: stm32mp157c-odyssey-som: enable the SDMMC2 eMMC HS DDR mode arm: dts: stm32mp157c-odyssey-som: enable SDMMC2 in SPL
.../dts/stm32mp157c-odyssey-som-u-boot.dtsi | 21 +++++++++++++++++++ arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 15 +++++++------ 2 files changed, 30 insertions(+), 6 deletions(-)
The SDMMC2 interface hosts an eMMC. Replace the interface properties that would only apply to SD cards—“broken-cd” and “disable-wp”—with relevant ones: “non-removable”, “no-sd” and “no-sdio”.
Signed-off-by: Grzegorz Szymaszek gszymaszek@short.pl Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com --- Changes for v2: - rebased on current master (patch not changed) - added Patrice Chotard’s Reviewed-by
arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index e367a311c4..ed399c00d1 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -267,8 +267,9 @@ pinctrl-0 = <&sdmmc2_b4_pins_a>; pinctrl-1 = <&sdmmc2_b4_od_pins_a>; pinctrl-2 = <&sdmmc2_b4_sleep_pins_a>; - broken-cd; - disable-wp; + non-removable; + no-sd; + no-sdio; st,neg-edge; bus-width = <4>; vmmc-supply = <&v3v3>;
Changes for v2:
- broken-cd;
- disable-wp;
- non-removable;
- no-sd;
- no-sdio; st,neg-edge; bus-width = <4>; vmmc-supply = <&v3v3>;
Applied on u-boot-stm32/next
Thanks
Add the “sdmmc2_d47_pins_d” pins to the SDMMC2 pinctrls. Increase the bus width from four to eight.
arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index ed399c00d1..7323325e60 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -264,14 +264,14 @@
&sdmmc2 { pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc2_b4_pins_a>; - pinctrl-1 = <&sdmmc2_b4_od_pins_a>; - pinctrl-2 = <&sdmmc2_b4_sleep_pins_a>; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_d>; + pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_d>; + pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_d>; non-removable; no-sd; no-sdio; st,neg-edge; - bus-width = <4>; + bus-width = <8>; vmmc-supply = <&v3v3>; status = "okay"; };
Changes for v2:
- pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_d>;
- pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_d>;
- pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_d>; non-removable; no-sd; no-sdio; st,neg-edge;
- bus-width = <4>;
- bus-width = <8>; vmmc-supply = <&v3v3>; status = "okay";
Thanks
Changes for v2:
- bus-width = <4>;
Thanks
Thanks
Set the SDMMC2 VQMMC supply to vdd (buck3). Note that in the corresponding Linux kernel device tree, the supply is set to v3v3 (buck4), which is wrong.
arch/arm/dts/stm32mp157c-odyssey-som.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index 7323325e60..583812f137 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -273,6 +273,7 @@ st,neg-edge; bus-width = <8>; vmmc-supply = <&v3v3>; + vqmmc-supply = <&vdd>; status = "okay"; };
Changes for v2:
- vqmmc-supply = <&vdd>; status = "okay";
Thanks
Changes for v2:
Thanks
Thanks
Enable the SDMMC2 eMMC high-speed DDR mode as it is done in the corresponding Linux kernel device tree.
Signed-off-by: Grzegorz Szymaszek gszymaszek@short.pl Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- Changes for v2: - rebased on current master - added a short commit message body
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi index 583812f137..1510a5b364 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som.dtsi @@ -274,6 +274,7 @@ bus-width = <8>; vmmc-supply = <&v3v3>; vqmmc-supply = <&vdd>; + mmc-ddr-3_3v; status = "okay"; };
Hi Grzegorz
Changes for v2:
- mmc-ddr-3_3v; status = "okay";
Thanks Patrice
On 6/3/21 9:35 AM, Patrice CHOTARD wrote:
Hi Grzegorz
Changes for v2:
Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Thanks
Hi Grzegorz
Changes for v2:
Thanks Patrice
Thanks
Enable the SDMMC2 device tree node, as well as the pins it uses, in U-Boot SPL.
.../dts/stm32mp157c-odyssey-som-u-boot.dtsi | 21 +++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi b/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi index 6be728846e..4ff848350d 100644 --- a/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-odyssey-som-u-boot.dtsi @@ -123,3 +123,24 @@ u-boot,dm-pre-reloc; }; }; + +&sdmmc2 { + u-boot,dm-spl; +}; + +&sdmmc2_b4_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&sdmmc2_d47_pins_d { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +};
Hi Grzegorz
Changes for v2:
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
Grzegorz Szymaszek
Patrice CHOTARD
