[U-Boot-Users] [PATCH8] microblaze - emaclite support
DESC: Add support for Xilinx emaclite
Signed-off-by: Michal Simek monstr@monstr.eu
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index e69de29..5d8eaa5 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -0,0 +1,376 @@ +/* + * (C) Copyright 2007 Michal Simek + * + * Michal SIMEK monstr@monstr.eu + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <net.h> +#include <config.h> +#include <asm/io.h> + +#ifdef XILINX_EMACLITE_BASEADDR + +#undef DEBUG + +#define ENET_MAX_MTU PKTSIZE +#define ENET_MAX_MTU_ALIGNED PKTSIZE_ALIGN +#define ENET_ADDR_LENGTH 6 + +/* EmacLite constants */ +#define XEL_BUFFER_OFFSET 0x0800 /* Next buffer's offset */ +#define XEL_TPLR_OFFSET 0x07F4 /* Tx packet length */ +#define XEL_TSR_OFFSET 0x07FC /* Tx status */ +#define XEL_RSR_OFFSET 0x17FC /* Rx status */ +#define XEL_RXBUFF_OFFSET 0x1000 /* Receive Buffer */ + +/* Xmit complete */ +#define XEL_TSR_XMIT_BUSY_MASK 0x00000001UL +/* Xmit interrupt enable bit */ +#define XEL_TSR_XMIT_IE_MASK 0x00000008UL +/* Buffer is active, SW bit only */ +#define XEL_TSR_XMIT_ACTIVE_MASK 0x80000000UL +/* Program the MAC address */ +#define XEL_TSR_PROGRAM_MASK 0x00000002UL +/* define for programming the MAC address into the EMAC Lite */ +#define XEL_TSR_PROG_MAC_ADDR (XEL_TSR_XMIT_BUSY_MASK | XEL_TSR_PROGRAM_MASK) + +/* Transmit packet length upper byte */ +#define XEL_TPLR_LENGTH_MASK_HI 0x0000FF00UL +/* Transmit packet length lower byte */ +#define XEL_TPLR_LENGTH_MASK_LO 0x000000FFUL + +/* Recv complete */ +#define XEL_RSR_RECV_DONE_MASK 0x00000001UL +/* Recv interrupt enable bit */ +#define XEL_RSR_RECV_IE_MASK 0x00000008UL + +typedef struct { + unsigned int baseaddress; /* Base address for device (IPIF) */ + unsigned int nexttxbuffertouse; /* Next TX buffer to write to */ + unsigned int nextrxbuffertouse; /* Next RX buffer to read from */ + unsigned char deviceid; /* Unique ID of device - for future */ +} xemaclite; + +static xemaclite emaclite; + +static char etherrxbuff[PKTSIZE_ALIGN/4]; /* Receive buffer */ + +/* hardcoded MAC address for the Xilinx EMAC Core when env is nowhere*/ +#ifdef CFG_ENV_IS_NOWHERE +static u8 emacaddr[ENET_ADDR_LENGTH] = { 0x00, 0x0a, 0x35, 0x00, 0x22, 0x01 }; +#endif + +void xemaclite_alignedread (u32 * srcptr, void *destptr, unsigned bytecount) +{ + unsigned int i; + u32 alignbuffer; + u32 *to32ptr; + u32 *from32ptr; + u8 *to8ptr; + u8 *from8ptr; + + from32ptr = (u32 *) srcptr; + + /* Word aligned buffer, no correction needed. */ + to32ptr = (u32 *) destptr; + while (bytecount > 3) { + *to32ptr++ = *from32ptr++; + bytecount -= 4; + } + to8ptr = (u8 *) to32ptr; + + alignbuffer = *from32ptr++; + from8ptr = (u8 *) & alignbuffer; + + for (i = 0; i < bytecount; i++) { + *to8ptr++ = *from8ptr++; + } +} + +void xemaclite_alignedwrite (void *srcptr, u32 destptr, unsigned bytecount) +{ + unsigned i; + u32 alignbuffer; + u32 *to32ptr = (u32 *) destptr; + u32 *from32ptr; + u8 *to8ptr; + u8 *from8ptr; + + from32ptr = (u32 *) srcptr; + while (bytecount > 3) { + + *to32ptr++ = *from32ptr++; + bytecount -= 4; + } + + alignbuffer = 0; + to8ptr = (u8 *) & alignbuffer; + from8ptr = (u8 *) from32ptr; + + for (i = 0; i < bytecount; i++) { + *to8ptr++ = *from8ptr++; + } + + *to32ptr++ = alignbuffer; +} + +void eth_halt (void) +{ +#ifdef DEBUG + puts ("eth_halt\n"); +#endif +} + +int eth_init (bd_t * bis) +{ +#ifdef DEBUG + puts ("EmacLite Initialization Started\n"); +#endif + memset (&emaclite, 0, sizeof (xemaclite)); + emaclite.baseaddress = XILINX_EMACLITE_BASEADDR; + + if (!getenv("ethaddr")) { + memcpy(bis->bi_enetaddr, emacaddr, ENET_ADDR_LENGTH); + } + +/* + * TX - TX_PING & TX_PONG initialization + */ + /* Restart PING TX */ + out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET, 0); + /* Copy MAC address */ + xemaclite_alignedwrite (bis->bi_enetaddr, + emaclite.baseaddress, ENET_ADDR_LENGTH); + /* Set the length */ + out_be32 (emaclite.baseaddress + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); + /* Update the MAC address in the EMAC Lite */ + out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET, XEL_TSR_PROG_MAC_ADDR);+ /* Wait for EMAC Lite to finish with the MAC address update */ + while ((in_be32 (emaclite.baseaddress + XEL_TSR_OFFSET) & + XEL_TSR_PROG_MAC_ADDR) != 0) ; + +#ifdef XILINX_EMACLITE_TX_PING_PONG + /* The same operation with PONG TX */ + out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, 0);+ xemaclite_alignedwrite (bis->bi_enetaddr, emaclite.baseaddress + + XEL_BUFFER_OFFSET, ENET_ADDR_LENGTH); + out_be32 (emaclite.baseaddress + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); + out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, + XEL_TSR_PROG_MAC_ADDR); + while ((in_be32 (emaclite.baseaddress + XEL_TSR_OFFSET + + XEL_BUFFER_OFFSET) & XEL_TSR_PROG_MAC_ADDR) != 0) ; +#endif + +/* + * RX - RX_PING & RX_PONG initialization + */ + /* Write out the value to flush the RX buffer */ + out_be32 (emaclite.baseaddress + XEL_RSR_OFFSET, XEL_RSR_RECV_IE_MASK); +#ifdef XILINX_EMACLITE_RX_PING_PONG + out_be32 (emaclite.baseaddress + XEL_RSR_OFFSET + XEL_BUFFER_OFFSET, + XEL_RSR_RECV_IE_MASK); +#endif + +#ifdef DEBUG + puts ("EmacLite Initialization complete\n"); +#endif + return 0; +} + +int xemaclite_txbufferavailable (xemaclite * instanceptr) +{ + u32 reg; + u32 txpingbusy; + u32 txpongbusy; + /* + * Read the other buffer register + * and determine if the other buffer is available + */ + reg = in_be32 (instanceptr->baseaddress + + instanceptr->nexttxbuffertouse + 0); + txpingbusy = ((reg & XEL_TSR_XMIT_BUSY_MASK) == + XEL_TSR_XMIT_BUSY_MASK); + + reg = in_be32 (instanceptr->baseaddress + + (instanceptr->nexttxbuffertouse ^ XEL_TSR_OFFSET) + 0); + txpongbusy = ((reg & XEL_TSR_XMIT_BUSY_MASK) == + XEL_TSR_XMIT_BUSY_MASK); + + return (!(txpingbusy && txpongbusy)); +} + +int eth_send (volatile void *ptr, int len) { + + unsigned int reg; + unsigned int baseaddress; + + unsigned maxtry = 1000; + + if (len > ENET_MAX_MTU) + len = ENET_MAX_MTU; + + while (!xemaclite_txbufferavailable (&emaclite) && maxtry) { + udelay (10); + maxtry--; + } + + if (!maxtry) { + printf ("Error: Timeout waiting for ethernet TX buffer\n"); + /* Restart PING TX */ + out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET, 0); +#ifdef XILINX_EMACLITE_TX_PING_PONG + out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET + + XEL_BUFFER_OFFSET, 0); +#endif + return 0; + } + + /* Determine the expected TX buffer address */ + baseaddress = (emaclite.baseaddress + emaclite.nexttxbuffertouse); + + /* Determine if the expected buffer address is empty */ + reg = in_be32 (baseaddress + XEL_TSR_OFFSET); + if (((reg & XEL_TSR_XMIT_BUSY_MASK) == 0) + && ((in_be32 ((baseaddress) + XEL_TSR_OFFSET) + & XEL_TSR_XMIT_ACTIVE_MASK) == 0)) { + +#ifdef XILINX_EMACLITE_TX_PING_PONG + emaclite.nexttxbuffertouse ^= XEL_BUFFER_OFFSET; +#endif +#ifdef DEBUG + printf ("Send packet from 0x%x\n", baseaddress); +#endif + /* Write the frame to the buffer */ + xemaclite_alignedwrite ((void *) ptr, baseaddress, len); + out_be32 (baseaddress + XEL_TPLR_OFFSET,(len & + (XEL_TPLR_LENGTH_MASK_HI | XEL_TPLR_LENGTH_MASK_LO))); + reg = in_be32 (baseaddress + XEL_TSR_OFFSET); + reg |= XEL_TSR_XMIT_BUSY_MASK; + if ((reg & XEL_TSR_XMIT_IE_MASK) != 0) { + reg |= XEL_TSR_XMIT_ACTIVE_MASK; + } + out_be32 (baseaddress + XEL_TSR_OFFSET, reg); + return 1; + } +#ifdef XILINX_EMACLITE_TX_PING_PONG + /* Switch to second buffer */ + baseaddress ^= XEL_BUFFER_OFFSET; + /* Determine if the expected buffer address is empty */ + reg = in_be32 (baseaddress + XEL_TSR_OFFSET); + if (((reg & XEL_TSR_XMIT_BUSY_MASK) == 0) + && ((in_be32 ((baseaddress) + XEL_TSR_OFFSET) + & XEL_TSR_XMIT_ACTIVE_MASK) == 0)) { +#ifdef DEBUG + printf ("Send packet from 0x%x\n", baseaddress); +#endif + /* Write the frame to the buffer */ + xemaclite_alignedwrite ((void *) ptr, baseaddress, len); + out_be32 (baseaddress + XEL_TPLR_OFFSET,(len & + (XEL_TPLR_LENGTH_MASK_HI | XEL_TPLR_LENGTH_MASK_LO))); + reg = in_be32 (baseaddress + XEL_TSR_OFFSET); + reg |= XEL_TSR_XMIT_BUSY_MASK; + if ((reg & XEL_TSR_XMIT_IE_MASK) != 0) { + reg |= XEL_TSR_XMIT_ACTIVE_MASK; + } + out_be32 (baseaddress + XEL_TSR_OFFSET, reg); + return 1; + } +#endif + puts ("Error while sending frame\n"); + return 0; +} + +int eth_rx (void) +{ + unsigned int length; + unsigned int reg; + unsigned int baseaddress; + + baseaddress = emaclite.baseaddress + emaclite.nextrxbuffertouse; + reg = in_be32 (baseaddress + XEL_RSR_OFFSET); +#ifdef DEBUG + printf ("Testing data at address 0x%x\n", baseaddress); +#endif + if ((reg & XEL_RSR_RECV_DONE_MASK) == XEL_RSR_RECV_DONE_MASK) { +#ifdef XILINX_EMACLITE_RX_PING_PONG + emaclite.nextrxbuffertouse ^= XEL_BUFFER_OFFSET; +#endif + } else { +#ifndef XILINX_EMACLITE_RX_PING_PONG +#ifdef DEBUG + printf ("No data was available - address 0x%x\n", baseaddress); +#endif + return 0; +#else + baseaddress ^= XEL_BUFFER_OFFSET; + reg = in_be32 (baseaddress + XEL_RSR_OFFSET); + if ((reg & XEL_RSR_RECV_DONE_MASK) != + XEL_RSR_RECV_DONE_MASK) { +#ifdef DEBUG + printf ("No data was available - address 0x%x\n", + baseaddress); +#endif + return 0; + } +#endif + } + /* Get the length of the frame that arrived */ + switch(((in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC)) & + 0xFFFF0000 ) >> 16) { + case 0x806: + length = 42 + 20; /* FIXME size of ARP */ +#ifdef DEBUG + puts ("ARP Packet\n"); +#endif + break; + case 0x800: + length = 14 + 14 + + (((in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0x10)) & + 0xFFFF0000) >> 16); /* FIXME size of IP packet */ +#ifdef DEBUG + puts("IP Packet\n"); +#endif + break; + default: +#ifdef DEBUG + puts("Other Packet\n"); +#endif + length = ENET_MAX_MTU; + break; + } + + xemaclite_alignedread ((u32 *) (baseaddress + XEL_RXBUFF_OFFSET), + etherrxbuff, length); + + /* Acknowledge the frame */ + reg = in_be32 (baseaddress + XEL_RSR_OFFSET); + reg &= ~XEL_RSR_RECV_DONE_MASK; + out_be32 (baseaddress + XEL_RSR_OFFSET, reg); + +#ifdef DEBUG + printf ("Packet receive from 0x%x, length %dB\n", baseaddress, length); +#endif + NetReceive ((uchar *) etherrxbuff, length); + return 1; + +} +#endif
Good looking driver. See comments below.
Cheers, g.
Need a CONFIG_ prefix.
+#undef DEBUG
+typedef struct {
+} xemaclite;
unsigned int i;
u32 alignbuffer;
u32 *to32ptr;
u32 *from32ptr;
u8 *to8ptr;
u8 *from8ptr;
bytecount -= 4;
unsigned i;
u32 alignbuffer;
u32 *from32ptr;
u8 *to8ptr;
u8 *from8ptr;
bytecount -= 4;
alignbuffer = 0;
I'm curious: why alignedread/write? Is this to IO space? Why not simply memcpy()?
You should use the debug() macro here (defined in common.h) Just move your '#undef DEBUG' so that it is above the '#include <common.h>' line.
Ditto
- TX - TX_PING & TX_PONG initialization
CONFIG_ prefix
- RX - RX_PING & RX_PONG initialization
CONFIG_
+#ifdef DEBUG
u32 reg;
u32 txpingbusy;
u32 txpongbusy;
unsigned int reg;
len = ENET_MAX_MTU;
udelay (10);
Is the delay needed? Is there any reason not to poll at full speed?
maxtry--;
if (!maxtry) {
CONFIG_
+#ifdef DEBUG
debug()
return 1;
+#ifdef DEBUG
return 1;
unsigned int reg;
+#ifdef DEBUG
} else {
+#else
+#ifdef DEBUG
baseaddress);
case 0x806:
+#ifdef DEBUG
break;
case 0x800:
length = 14 + 14 +
+#ifdef DEBUG
break;
default:
+#ifdef DEBUG
break;
+#ifdef DEBUG
return 1;
+} +#endif
This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
thanks
OK
+#undef DEBUG
+typedef struct {
+} xemaclite;
unsigned int i;
u32 alignbuffer;
u32 *to32ptr;
u32 *from32ptr;
u8 *to8ptr;
u8 *from8ptr;
bytecount -= 4;
unsigned i;
u32 alignbuffer;
u32 *from32ptr;
u8 *to8ptr;
u8 *from8ptr;
bytecount -= 4;
alignbuffer = 0;
I made this driver from xilinx source code. I try to replace these fuction with memcpy but without any success. :-( I would like to remove this part of code but I don't have stable driver with it.
OK
Ditto
CONFIG_ prefix
OK
CONFIG_
+#ifdef DEBUG
u32 reg;
u32 txpingbusy;
u32 txpongbusy;
0);
unsigned int reg;
len = ENET_MAX_MTU;
udelay (10);
I don't know. In xilinx driver has delay. I can test it without delay next week.
maxtry--;
if (!maxtry) {
CONFIG_
+#ifdef DEBUG
debug()
return 1;
+#ifdef DEBUG
return 1;
unsigned int reg;
+#ifdef DEBUG
} else {
baseaddress);
+#else
+#ifdef DEBUG
baseaddress);
case 0x806:
+#ifdef DEBUG
break;
case 0x800:
length = 14 + 14 +
+#ifdef DEBUG
break;
default:
+#ifdef DEBUG
break;
+#ifdef DEBUG
length);
return 1;
+} +#endif
M
Grant Likely
Michal Simek
