[U-Boot] [PATCH] sunxi: A64/H5 devices: enable usb keyboard support
Now the A64/H5 SoCs support video output it's useful to enable usb keyboard support so console can be used via standard keyboard/video interface.
Tested on Pine64.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- configs/a64-olinuxino_defconfig | 2 ++ configs/bananapi_m64_defconfig | 2 ++ configs/nanopi_a64_defconfig | 2 ++ configs/orangepi_pc2_defconfig | 2 ++ configs/orangepi_win_defconfig | 2 ++ configs/orangepi_zero_plus2_defconfig | 2 ++ configs/pine64_plus_defconfig | 2 ++ configs/sopine_baseboard_defconfig | 2 ++ 8 files changed, 16 insertions(+)
diff --git a/configs/a64-olinuxino_defconfig b/configs/a64-olinuxino_defconfig index b32df990a0..b0e23fc630 100644 --- a/configs/a64-olinuxino_defconfig +++ b/configs/a64-olinuxino_defconfig @@ -12,3 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-olinuxino" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/bananapi_m64_defconfig b/configs/bananapi_m64_defconfig index 47f31c6d9d..c2997223ab 100644 --- a/configs/bananapi_m64_defconfig +++ b/configs/bananapi_m64_defconfig @@ -13,3 +13,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-bananapi-m64" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/nanopi_a64_defconfig b/configs/nanopi_a64_defconfig index 0a04911c81..458fcc6f8e 100644 --- a/configs/nanopi_a64_defconfig +++ b/configs/nanopi_a64_defconfig @@ -11,3 +11,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-nanopi-a64" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index dd5f2c78ab..f89b67894d 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -14,3 +14,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-pc2" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig index d7211b5823..de014a2766 100644 --- a/configs/orangepi_win_defconfig +++ b/configs/orangepi_win_defconfig @@ -12,3 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-orangepi-win" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/orangepi_zero_plus2_defconfig b/configs/orangepi_zero_plus2_defconfig index fdb6bb4ed9..fb5f1b2388 100644 --- a/configs/orangepi_zero_plus2_defconfig +++ b/configs/orangepi_zero_plus2_defconfig @@ -14,3 +14,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus2" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 21ce06f370..b4dbc7d03e 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -14,3 +14,5 @@ CONFIG_RTL8211E_PINE64_GIGABIT_FIX=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/sopine_baseboard_defconfig b/configs/sopine_baseboard_defconfig index 05436a1b43..a7db99d1e2 100644 --- a/configs/sopine_baseboard_defconfig +++ b/configs/sopine_baseboard_defconfig @@ -18,3 +18,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_KEYBOARD=y +CONFIG_USB_KEYBOARD=y
Tested on Pine64.
Mmmh, as Maxime mentioned before: That should be already enabled?
$ git describe HEAD v2018.03 $ make -s pine64_plus_defconfig $ grep KEYBOARD .config CONFIG_DM_KEYBOARD=y CONFIG_USB_KEYBOARD=y
Plus I use this for ages with *_defconfig on various Allwinner boards.
So what am I missing here?
Cheers, Andre.
On Wed, Apr 18, 2018 at 4:29 PM, Andre Przywara andre.przywara@arm.com wrote:
Tested on Pine64.
I couldn't see where it came from in the config and it wasn't working for me when I tested it on 2018.03
Cheers, Andre.
Tested on Pine64.
As Maxime mentioned the other day [1]: arch/arm/Kconfig: config ARCH_SUNXI .... select DM_KEYBOARD .... select USB_KEYBOARD if DISTRO_DEFAULTS Kconfig: config DISTRO_DEFAULTS default y if ARCH_SUNXI || TEGRA
That is weird. Are you sure the USB port you connected the keyboard to actually works? I found this to be a problem on some boards, due to missing regulator support. I think I used the lower port on the Pine64 and that worked fine.
Cheers, Andre.
[1]: https://lists.denx.de/pipermail/u-boot/2018-April/324976.html
Andre Przywara
Peter Robinson
