[PATCH 06/11] mtd: nand: Move Samsung specific init/detection logic in nand_samsung.c
Upstream commit c51d0ac59f24200dfdccc897ff7c3c9446c7599a
Move Samsung specific initialization and detection logic into nand_samsung.c. This is part of the "separate vendor specific code from core" cleanup process.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Richard Weinberger richard@nod.at Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/Makefile | 3 +- drivers/mtd/nand/raw/nand_base.c | 50 +--------------- drivers/mtd/nand/raw/nand_ids.c | 4 +- drivers/mtd/nand/raw/nand_samsung.c | 90 +++++++++++++++++++++++++++++ include/linux/mtd/rawnand.h | 2 + 5 files changed, 99 insertions(+), 50 deletions(-) create mode 100644 drivers/mtd/nand/raw/nand_samsung.c
diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index e3f6b903f7..0e3f017bf6 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_SPL_NAND_DENALI) += denali_spl.o obj-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o obj-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o obj-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o -obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o +obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o nand_samsung.o obj-$(CONFIG_SPL_NAND_IDENT) += nand_ids.o nand_timings.o obj-$(CONFIG_TPL_NAND_INIT) += nand.o ifeq ($(CONFIG_SPL_ENV_SUPPORT),y) @@ -31,6 +31,7 @@ obj-y += nand_ids.o obj-y += nand_util.o obj-y += nand_ecc.o obj-y += nand_base.o +obj-y += nand_samsung.o obj-y += nand_timings.o
endif # not spl diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 4cb38378f4..7f41395afe 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -4173,47 +4173,12 @@ void nand_decode_ext_id(struct nand_chip *chip) /* * Field definitions are in the following datasheets: * Old style (4,5 byte ID): Samsung K9GAG08U0M (p.32) - * New Samsung (6 byte ID): Samsung K9GAG08U0F (p.44) * Hynix MLC (6 byte ID): Hynix H27UBG8T2B (p.22) * * Check for ID length, non-zero 6th byte, cell type, and Hynix/Samsung * ID to decide what to do. */ - if (id_len == 6 && chip->id.data[0] == NAND_MFR_SAMSUNG && - !nand_is_slc(chip) && chip->id.data[5] != 0x00) { - /* Calc pagesize */ - mtd->writesize = 2048 << (extid & 0x03); - extid >>= 2; - /* Calc oobsize */ - switch (((extid >> 2) & 0x04) | (extid & 0x03)) { - case 1: - mtd->oobsize = 128; - break; - case 2: - mtd->oobsize = 218; - break; - case 3: - mtd->oobsize = 400; - break; - case 4: - mtd->oobsize = 436; - break; - case 5: - mtd->oobsize = 512; - break; - case 6: - mtd->oobsize = 640; - break; - case 7: - default: /* Other cases are "reserved" (unknown) */ - mtd->oobsize = 1024; - break; - } - extid >>= 2; - /* Calc blocksize */ - mtd->erasesize = (128 * 1024) << - (((extid >> 1) & 0x04) | (extid & 0x03)); - } else if (id_len == 6 && chip->id.data[0] == NAND_MFR_HYNIX && + if (id_len == 6 && chip->id.data[0] == NAND_MFR_HYNIX && !nand_is_slc(chip)) { unsigned int tmp;
@@ -4375,13 +4340,10 @@ static void nand_decode_bbm_options(struct mtd_info *mtd, * Micron devices with 2KiB pages and on SLC Samsung, Hynix, Toshiba, * AMD/Spansion, and Macronix. All others scan only the first page. */ - if (!nand_is_slc(chip) && - (maf_id == NAND_MFR_SAMSUNG || - maf_id == NAND_MFR_HYNIX)) + if (!nand_is_slc(chip) && maf_id == NAND_MFR_HYNIX) chip->bbt_options |= NAND_BBT_SCANLASTPAGE; else if ((nand_is_slc(chip) && - (maf_id == NAND_MFR_SAMSUNG || - maf_id == NAND_MFR_HYNIX || + (maf_id == NAND_MFR_HYNIX || maf_id == NAND_MFR_TOSHIBA || maf_id == NAND_MFR_AMD || maf_id == NAND_MFR_MACRONIX)) || @@ -4550,12 +4512,6 @@ struct nand_flash_dev *nand_get_flash_type(struct nand_chip *chip, /* Get chip options */ chip->options |= type->options;
- /* - * Check if chip is not a Samsung device. Do not clear the - * options for chips which do not have an extended id. - */ - if (*maf_id != NAND_MFR_SAMSUNG && !type->pagesize) - chip->options &= ~NAND_SAMSUNG_LP_OPTIONS; ident_done:
if (chip->options & NAND_BUSWIDTH_AUTO) { diff --git a/drivers/mtd/nand/raw/nand_ids.c b/drivers/mtd/nand/raw/nand_ids.c index 2a50f0b214..f4126c3a5a 100644 --- a/drivers/mtd/nand/raw/nand_ids.c +++ b/drivers/mtd/nand/raw/nand_ids.c @@ -10,7 +10,7 @@ #include <linux/mtd/rawnand.h> #include <linux/sizes.h>
-#define LP_OPTIONS NAND_SAMSUNG_LP_OPTIONS +#define LP_OPTIONS 0 #define LP_OPTIONS16 (LP_OPTIONS | NAND_BUSWIDTH_16)
#define SP_OPTIONS NAND_NEED_READRDY @@ -189,7 +189,7 @@ struct nand_flash_dev nand_flash_ids[] = { /* Manufacturer IDs */ struct nand_manufacturers nand_manuf_ids[] = { {NAND_MFR_TOSHIBA, "Toshiba"}, - {NAND_MFR_SAMSUNG, "Samsung"}, + {NAND_MFR_SAMSUNG, "Samsung", &samsung_nand_manuf_ops}, {NAND_MFR_FUJITSU, "Fujitsu"}, {NAND_MFR_NATIONAL, "National"}, {NAND_MFR_RENESAS, "Renesas"}, diff --git a/drivers/mtd/nand/raw/nand_samsung.c b/drivers/mtd/nand/raw/nand_samsung.c new file mode 100644 index 0000000000..3dfbbec382 --- /dev/null +++ b/drivers/mtd/nand/raw/nand_samsung.c @@ -0,0 +1,90 @@ +/* + * Copyright (C) 2017 Free Electrons + * Copyright (C) 2017 NextThing Co + * + * Author: Boris Brezillon boris.brezillon@free-electrons.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <linux/bug.h> +#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> + +static void samsung_nand_decode_id(struct nand_chip *chip) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + /* New Samsung (6 byte ID): Samsung K9GAG08U0F (p.44) */ + if (chip->id.len == 6 && !nand_is_slc(chip) && + chip->id.data[5] != 0x00) { + u8 extid = chip->id.data[3]; + + /* Get pagesize */ + mtd->writesize = 2048 << (extid & 0x03); + + extid >>= 2; + + /* Get oobsize */ + switch (((extid >> 2) & 0x4) | (extid & 0x3)) { + case 1: + mtd->oobsize = 128; + break; + case 2: + mtd->oobsize = 218; + break; + case 3: + mtd->oobsize = 400; + break; + case 4: + mtd->oobsize = 436; + break; + case 5: + mtd->oobsize = 512; + break; + case 6: + mtd->oobsize = 640; + break; + case 7: + default: /* Other cases are "reserved" (unknown) */ + WARN(1, "Invalid OOB size value"); + mtd->oobsize = 1024; + break; + } + + /* Get blocksize */ + extid >>= 2; + mtd->erasesize = (128 * 1024) << + (((extid >> 1) & 0x04) | (extid & 0x03)); + } else { + nand_decode_ext_id(chip); + } +} + +static int samsung_nand_init(struct nand_chip *chip) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (mtd->writesize > 512) + chip->options |= NAND_SAMSUNG_LP_OPTIONS; + + if (!nand_is_slc(chip)) + chip->bbt_options |= NAND_BBT_SCANLASTPAGE; + else + chip->bbt_options |= NAND_BBT_SCAN2NDPAGE; + + return 0; +} + +const struct nand_manufacturer_ops samsung_nand_manuf_ops = { + .detect = samsung_nand_decode_id, + .init = samsung_nand_init, +}; diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 8fb2a43296..d0312e924b 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -1158,6 +1158,8 @@ struct nand_manufacturers { extern struct nand_flash_dev nand_flash_ids[]; extern struct nand_manufacturers nand_manuf_ids[];
+extern const struct nand_manufacturer_ops samsung_nand_manuf_ops; + int nand_default_bbt(struct mtd_info *mtd); int nand_markbad_bbt(struct mtd_info *mtd, loff_t offs); int nand_isreserved_bbt(struct mtd_info *mtd, loff_t offs);
Michael Trimarchi
